Grass Posted December 24, 2019 Posted December 24, 2019 Hi! OS - Armbian bionic Board - Orange pi one I dont understand where goes 20-25% of 512mb ram. 18MB goes to video and wlan share. OK... root@OrangePiPBX:~# zramctl NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 lzo 98.2M 19.8M 10.2M 11M 4 [SWAP] /dev/zram0 50M 17.7M 2.5M 2.9M 4 /var/log Now we see - 150MB go's to swap and small partition for "logs". root@OrangePiPBX:~# free total used free shared buff/cache available Mem: 502932 242376 26380 20008 234176 232640 Swap: 100584 21504 79080 Here we see ram now in total(used and free) - 250MB 250+150 = 400 And now... can someone answer me - where is my 100MB ram? Here is config for ZRAM: nano /etc/default/armbian-zram-config ENABLED=true ZRAM_PERCENTAGE=20 Here is config for Ram-log: nano /etc/default/armbian-ramlog ENABLED=true SIZE=50M USE_RSYNC=true root@OrangePiPBX:~# df -h Filesystem Size Used Avail Use% Mounted on udev 177M 0 177M 0% /dev tmpfs 50M 5.4M 44M 11% /run /dev/mmcblk0p1 7.1G 3.8G 3.3G 54% / tmpfs 246M 0 246M 0% /dev/shm tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs 246M 0 246M 0% /sys/fs/cgroup tmpfs 246M 380K 246M 1% /tmp /dev/zram0 49M 18M 28M 40% /var/log tmpfs 50M 0 50M 0% /run/user/0 That's all. Maybe i am doing something wrong?
Tido Posted December 25, 2019 Posted December 25, 2019 Providing logs with armbianmonitor -u significantly raises chances that someone is looking at it. // sent from mobile phone //
Igor Posted December 25, 2019 Posted December 25, 2019 14 hours ago, Grass said: Maybe i am doing something wrong? Probably not. Kernel is changing, features are added, something that we might not want gets in by mistake. I suspect 3D driver reservations or just something, which could be seen from the logs. Or not and a deep investigation is needed.
Grass Posted December 25, 2019 Author Posted December 25, 2019 6 hours ago, Tido said: Providing logs with armbianmonitor -u significantly raises chances that someone is looking at it. // sent from mobile phone // Here is output: http://ix.io/25rM 3 hours ago, Igor said: Probably not. Kernel is changing, features are added, something that we might not want gets in by mistake. I suspect 3D driver reservations or just something, which could be seen from the logs. Or not and a deep investigation is needed. I think i have a problem with some default settings of Zram. Like i see in doc's - Zram and swap is "preninstalled". And from first run i have only 50% of RAM
Grass Posted December 25, 2019 Author Posted December 25, 2019 One more interesting thing! nano /etc/default/armbian-zram-config ENABLED=true #ZRAM_PERCENTAGE=20 i comment ZRAM_PERCENTAGE=20 and what we see now: root@OrangePiPBX:~# swapon --show NAME TYPE SIZE USED PRIO /dev/zram1 partition 245.6M 0B 5 root@OrangePiPBX:~# zramctl NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 lzo 245.6M 4K 78B 12K 4 [SWAP] /dev/zram0 50M 21.2M 2.9M 3.4M 4 /var/log root@OrangePiPBX:~# df -h Filesystem Size Used Avail Use% Mounted on udev 177M 0 177M 0% /dev tmpfs 50M 1.7M 48M 4% /run /dev/mmcblk0p1 7.1G 3.8G 3.3G 54% / tmpfs 246M 0 246M 0% /dev/shm tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs 246M 0 246M 0% /sys/fs/cgroup tmpfs 246M 4.0K 246M 1% /tmp /dev/zram0 49M 22M 24M 48% /var/log tmpfs 50M 0 50M 0% /run/user/0
Igor Posted January 8, 2020 Posted January 8, 2020 3 hours ago, Grass said: Up. Down. https://forum.armbian.com/terms Quote Do not bump topics or create duplicate messages for the purpose of bringing attention to your issue. If bumping an old topic to resume conversation or provide new information, update the beginning post if possible. Moderators can re-open.
archetech Posted September 29, 2020 Posted September 29, 2020 Same issue here on Bullseye beta on N2+. If a new thread is wanted just say so. Armbian 20.11.0-trunk.9 Bullseye with Linux 5.8.12-meson64 df -h shows no /dev/zram(x) zramctl shows nothing same for fdisk -l swap.target is active loaded. sudo nano /etc/default/armbian-zram-config ENABLED=TRUE is only param set here. Per Igor request: armbianmonitor -u at http://ix.io/2z9h All I got. Any ideas to get this running ? EDIT: May be this wasn't run at some point sudo systemctl start armbian-zram-config per this thread https://forum.armbian.com/topic/15268-zswap-or-zram I'll call this fixed after a few tweaks to the armbian-zram-config file.
