zmicro Posted May 27, 2016 Posted May 27, 2016 Goodmorning, I've upgraded my Orange Pi-PC to 5.11 Upgrading process OK then rebooted. Now PI continue rebooting (leds turn on as usual but after a while they turn off) and i'm not able to access it. Have you any advice? is there a way to reset it? thanks in advance
Igor Posted May 27, 2016 Posted May 27, 2016 Strange ... Check documentation for "How to unbrick my board"
zmicro Posted May 27, 2016 Author Posted May 27, 2016 After lot of time i succesfully recovered my orange pi. Everything was ok, all my data was ok but i found another problem: wireless dongle was no more recognized. I took another sd, installed 5.10 and everything was ok. After upgrading to 5.11 WiFi was lost. My dongle is 8188eu and with 5.10 worked like a charm. Thanks in advance. R.
gnasch Posted May 28, 2016 Posted May 28, 2016 The upgrade indeed kills wifi and on most boots produces a kernel oops , probably by loading a wrong wifi module. I connected a screen to the opi pc and could just view the oops passing by. After a few reboots, by chance it stabilised and went through to login. so I rmmoded the rtl8192cu and all related modules and tried to load armbians special 8192cu module. The result was "module 8192 not found", but the module exists in /lib/modules/3.4.112-sun8i/kernel/net/wireless/and an insmod /lib/modules/3.4.112-sun8i/kernel/net/wireless/8192cu.ko was successful and produced the wlan0. modprobe will not find the module. What is wrong? best, gnasch
zmicro Posted May 29, 2016 Author Posted May 29, 2016 Solved by manually installing Wi-Fi modules. I'm sure that 5.10 worked without problems.
mariuszb Posted May 29, 2016 Posted May 29, 2016 Missing Wifi driver after sudo apt-get update && upgrade ( https://github.com/igorpecovnik/lib/issues/327 ) It can be avoided in the future ?
gnasch Posted May 29, 2016 Posted May 29, 2016 Sorry I don't get it. How can this be repaired? Manually loading the modules with insmod will only work till the next reboot. How can a working configuration be restored? Thanks, gnasch
Igor Posted May 29, 2016 Posted May 29, 2016 This module is not a part of a kernel. We build it on the way and since it's not packed it fails out when an upgrade is issued. Feature, which we added, is not done on the proper way yet ... but you can make a module on your own too. 1
zador.blood.stained Posted May 29, 2016 Posted May 29, 2016 @gnasch If modprobe doesn't see a module present in kernel tree, you may need to run "depmod" (as root) to update module list that modprobe relies on. 1
gnasch Posted May 29, 2016 Posted May 29, 2016 @zador, thank you very much; depmod -a did it! best, gnasch
