Odroid C1+ images?
MadMax
10 hours ago, MadMax said:
Its to bad the C1 has no support anymore.
With what?
This script https://github.com/armbian/config needs serious long term (co)maintainer. It's not a heavy job, but you need to be around on a daily basis. Once you will create trust that you will carry on, I will restart C1 maintanace. If you don't have time for that, you know the answer.
I tried Armbian_20.05.0-trunk.034_Odroidc1_buster_current_5.4.17_minimal and it does not boot.
Seems like there was a Stretch version? Why are older releases that where working are deleted?
I'm also confused by the naming now.
The last image i downloaded a view month ago was Armbian_5.95
Now it's Armbian_19.11.3
Is that the date now? If yes what was the number meaning before?
Quote
So there will be support again and Armbian for C1 is not dead?
I see no stretch there.
Seems like i wasted my money on that board.
Seems like everything after Jessi has no working HDMI and other problems.
And also DietPI stretch that they call stable does not boot.
But you expect we will waste our time / money for you?
12 minutes ago, MadMax said:
Whats wrong?
Attitude? You care for your money, but you don't care for our time ... which I would rather spent with my family. This project is backed by volunteers.
18 minutes ago, MadMax said:
just ask questions
... support is extreme expense in a project that generate no income. It was told to you where images are. We don't claim they work (I know they don't) which is why they were removed. We don't want to waste your time and it would be nice from you to return the same. Or at least understand. Accept.
I don't expect from you to do our job. There are many things you can do https://www.armbian.com/get-involved to learn things and earn respect in the community. Only that can trigger an interest from doer to do something about this issue. If you just rant and do nothing ... Resources are tiny and support is not a cheap copy / paste / re-brand operation.
2 hours ago, sputnik said:
Is there a reason it got deleted from an archives?
Yes, the reason is that images are broken and a few afternoons are needed by someone that understand things that it gets fixed. Not sure if we will do anything more on this board ... sources are here https://github.com/armbian/build and anyone can pick it up.
Archives? https://dl.armbian.com/_old/odroidc1/ and stock Hardkernel images - even also old like hell ?
