KlausA20 Posted February 7, 2020 Posted February 7, 2020 Hi folks, is there a reason behind the Olimex Micro board being listed as "SUPPORT ENDED (EOS)" on the armbian web site? Cheers, Klaus
Igor Posted February 7, 2020 Posted February 7, 2020 Banal reason. No samples in the lab / no official board maintainer even I am sure most if not all features works ...
martinayotte Posted February 7, 2020 Posted February 7, 2020 4 hours ago, Igor said: No samples in the lab / no official board maintainer even I am sure most if not all features works ... Although I'm not an official maintainer, when working on DEV version switch, I'm always doing some tests with my A20 Micro too ...
martinayotte Posted February 7, 2020 Posted February 7, 2020 5 hours ago, KlausA20 said: "SUPPORT ENDED (EOS)" You can still download some old images there : https://dl.armbian.com/_old/micro/archive/ Or you can build your own using Armbian build scripts ...
Igor Posted February 7, 2020 Posted February 7, 2020 4 hours ago, martinayotte said: You can still download some old images there : https://dl.armbian.com/_old/micro/archive/ Or you can build your own using Armbian build scripts ... Images are actually up to date, just lack of device for testing ... well, it can be enabled back. It's well supported A20 hw.
TRS-80 Posted February 7, 2020 Posted February 7, 2020 4 hours ago, martinayotte said: Although I'm not an official maintainer, when working on DEV version switch, I'm always doing some tests with my A20 Micro too ... TRS-80 gently nudges @martinayotte...
