laurentppol Posted February 16, 2020 Share Posted February 16, 2020 Hi, I have recently installed latest (20) Armbian Desktop for OPi PC(+), have problems installing software from network repo (synaptic). 1). Small version problem with one of Qt5 libraries (dependency for Kadu - Polish communicator GG client), synaptic wants version 1u1, on the net there is version 1u3. Installed using wget + dpkg, now Kadu starts (at least) OK. 2). PostgreSQL problem: there is version 11 of PgSQL provided, OK, it's current production. BUT there is PgAdmin3(!) in repo, which works with at most version 9.6 of PgSQL (from PgAdmin site). Now there is PgAdmin4, but (I) cannot make it work (compile from source OK, but doesn't start)., there is NO PgAdmin4 in repo! 3). systemctl start postgresql.service doest NOT work, returns "Service entered failed state", "su - postgres -c 'pg_ctl_start" WORKS. I have same problem on Fedora 24 i386 on laptop, so it is not platform / system version dependent :( laurent Link to comment Share on other sites More sharing options...
lanefu Posted February 16, 2020 Share Posted February 16, 2020 Armbian doens't manage those packages.. that would be upstream debian or ubuntu, dependin on what you're using. try running a `sudo apt clean` and then try again Link to comment Share on other sites More sharing options...
laurentppol Posted February 25, 2020 Author Share Posted February 25, 2020 On 2/16/2020 at 3:37 AM, lanefu said: Armbian doens't manage those packages.. that would be upstream debian or ubuntu, dependin on what you're using. try running a `sudo apt clean` and then try again After a small problem (manual install of http://security-cdn.debian.org/pool/updates/main/q/qtbase-opensource-src/libqt5opengl5_5.11.3+dfsg1-1+deb10u3_armhf.deb downloaded synaptic, but then search "pgadmin" reveals ONLY pgadmin3, which is NOT compatible with PGSQL11. Please add PgAdmin4 to the repo. Link to comment Share on other sites More sharing options...
lanefu Posted February 25, 2020 Share Posted February 25, 2020 As mentioned previously, this is not an armbian issue. Open an issue with debian. Realistically you'll probably just need to build the package yourself Link to comment Share on other sites More sharing options...
