Werner Posted April 8, 2020 Posted April 8, 2020 OrangePi One Plus confirmed as well. Did not test much though. Boots, HDMI works, DE without Panfrost works. Ethernet works...well, that's pretty much it what I have tested
dolphs Posted April 8, 2020 Posted April 8, 2020 @Wernervery well - currently playing with wireguard on both; cpu temp +/- 46-49 degrees , not stressing both boards ( yet ). Will wait for that till 1,8GHz can be configured (re-enabled) again, it has been "discussed" in 5.4 dev already
Werner Posted April 8, 2020 Posted April 8, 2020 On 4/8/2020 at 6:12 AM, dolphs said: Will wait for that till 1,8GHz can be configured (re-enabled) again, Expand It can. At current at least. Simply chance the max at /etc/default/cpufrequtils to 1810000
dolphs Posted April 8, 2020 Posted April 8, 2020 unfortunately not on my OpiOnePlus, at least with this config @orangepioneplus1:~$ cat /etc/default/cpufrequtils ENABLE=true MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=conservative Board shows after "reboot" : root@orangepioneplus1:~# cpufreq-info |grep cpufreq cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:85.35%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45% (179) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:85.35%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45% (179) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:85.35%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45% (179) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:85.36%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45% (179) As well armbian-config not showing 1,8GHz , did not find an overlay setting ( like H5 ) so I guess this is WIP and will await a permanent solution. for now I am OK as it boots in to the new kernel and therefore I can access and play with both boards
Werner Posted April 8, 2020 Posted April 8, 2020 Put this to userpatches when building dev https://github.com/armbian/build/blob/master/patch/kernel/sunxi-current/xxx-sun50i-h6-enable-higher-clock.patch
dolphs Posted April 8, 2020 Posted April 8, 2020 @Werner would you mind allowing my the QnD way by adding your " sun50i-h6-orangepi-one-plus.dtb " to your post so I should not need to recompile and just replace current file in " /boot/dtb/allwinner " ... [ current state meanwhile after compiling :] CC [M] drivers/staging/rtl8723cs-new/core/rtw_mp.o LD [M] drivers/staging/rtl8723cs-new/8723cs.o Makefile:1685: recipe for target 'drivers' failed [ error ] ERROR in function compile_kernel [ compilation.sh:378 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated [ this is meanwhile resolved with ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no BUILD_EXTERNAL=no WIREGUARD=no EXTRAWIFI=no AUFS=no ]
Werner Posted April 8, 2020 Posted April 8, 2020 I just noticed that for 5.6 it seems like this patch is not longer necessary. Simply edit the cpufrequitls max frequency to 1810000 and reload the service. The max clock is unlocked then. Check with armbianmonitor and put some load to the board. Make sure to put some cooling to the board.
dolphs Posted April 8, 2020 Posted April 8, 2020 @Werner Err check my previous post, NOK I did this previously ( exact steps below ) and even the OPiOnePlus got a nice reboot Just to be certain this is what my build says : " Linux orangepioneplus1 5.6.2-sunxi64 #trunk SMP Tue Apr 7 09:22:09 CEST 2020 aarch64 GNU/Linux " Next attempt when 5.6.3 is incorporated in to dev build cd ~/armbian/userpatches # neither in ~armbian/userpatches/kernel/sunxi-current wget https://github.com/armbian/build/blob/master/patch/kernel/sunxi-current/xxx-sun50i-h6-enable-higher-clock.patch cd.. ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no BUILD_EXTERNAL=no EXTRAWIFI=no
Werner Posted April 10, 2020 Posted April 10, 2020 Fixed. https://github.com/armbian/build/commit/a82dbd3f7bd009a7e00c2da6adea26530bf420f1
guidol Posted April 10, 2020 Posted April 10, 2020 On 4/7/2020 at 7:05 PM, guidol said: kernel 5.6.2-sunxi(64) did here also boot on the following SBCs: - OrangePi One / Zero Many Thanks to @martinayotte Expand Also the OrangePi R1 with NAS-Board-Extension does work fine System diagnosis information has been uploaded to http://ix.io/2hqz
dolphs Posted April 10, 2020 Posted April 10, 2020 On 4/10/2020 at 8:05 AM, Werner said: Fixed. Expand @Wernermoin moin I had to put it in sunx-dev of course, me bad however still NOK " only garbage was found in the patch input " - seems I am overlooking something else now ouput.log --- [ warn ] * [u][c] xxx-sun50i-h6-enable-higher-clock.patch [ failed ] patching.log --- Processing file /home/armbian/userpatches/kernel/sunxi-dev/xxx-sun50i-h6-enable-higher-clock.patch patch: **** Only garbage was found in the patch input.
Werner Posted April 10, 2020 Posted April 10, 2020 Not sure, maybe your setup is corrupted? The patch was applied successful at head run: https://armbian.lane-fu.com/jenkins/job/armbian-test-pr/74/consoleFull
dolphs Posted April 10, 2020 Posted April 10, 2020 ok firing up a new build, wiped armbian completely and looks promising so far - will flash OPiOnePlus shortly: [ o.k. ] * [l][c] xxx-sun50i-h6-enable-higher-clock.patch And indeed looking much better now so no need for Jira story anymore ;-), danke-gracias-thanks-bedankt-multumesc-hvala etc etc @orangepioneplus:~# cpufreq-info |tail -1 cpufreq stats: 480 MHz:83.61%, 720 MHz:0.92%, 816 MHz:0.20%, 888 MHz:0.02%, 1.08 GHz:0.09%, 1.32 GHz:0.11%, 1.49 GHz:8.99%, 1.64 GHz:0.09%, 1.80 GHz:5.98% (153) Now let's see how things will hold as H5's show in "idle mode" ( conservative) a CPU temp of +/- 35°C ( current CPU frequency is 480 MHz ) while H6 shows CPU temp of 49°C already with passive cooling . The 1,8Ghz would be needed only when I synch my NAS with remote site for a couple of minutes. For regular TV streaming CPU stays at mostly at 480Mhz ( cpufreq stats: 408 MHz:85.35% ) so I hope active cooling won't be needed because of the 15 degrees temp difference in idle mode already
dolphs Posted April 17, 2020 Posted April 17, 2020 Kernel 5.6.5 brings fix for " arm64: dts: allwinner: h5/h6: Fix PMU compatible ", so more juice comes in place for these nice boards
Igor Posted April 17, 2020 Posted April 17, 2020 On 4/17/2020 at 4:55 PM, dolphs said: Kernel 5.6.5 brings fix for " arm64: dts: allwinner: h5/h6: Fix PMU compatible ", so more juice comes in place for these nice boards Expand Coming to beta.armbian.com tomorrow morning. Together with u-boot 2020.04
guidol Posted April 18, 2020 Posted April 18, 2020 On 4/17/2020 at 9:47 PM, Igor said: Coming to beta.armbian.com tomorrow morning. Together with u-boot 2020.04 Expand Yes arrived on my Neo2... Welcome to Armbian Buster with Linux 5.6.5-sunxi64 dpkg -l|grep u-boot linux-u-boot-nanopineo2-dev 20.05.0-trunk arm64 Uboot loader 2020.04 1
Werner Posted April 18, 2020 Posted April 18, 2020 Same for me One Plus. Running on 5.6.5 with U-Boot 2020.04 1
guidol Posted April 18, 2020 Posted April 18, 2020 On 4/18/2020 at 4:35 PM, Werner said: Same for me One Plus. Running on 5.6.5 with U-Boot 2020.04 Expand beside sunxi and sunxi64 it does also work on meson64 - here my Odroid C2
dolphs Posted April 19, 2020 Posted April 19, 2020 good news , I can concur ii linux-u-boot-orangepioneplus-dev 20.05.0-trunk arm64 Uboot loader 2020.04 ii u-boot-tools 2019.01+dfsg-7 arm64 companion tools for Das U-Boot bootloader And OrangePiOnePlus is happy so far: root@orangepioneplus's password: ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ _ | | | | |_) | | | | | | '_ \ / _ \_| |_ | |_| | __/| | | |_| | | | | __/_ _| \___/|_| |_| \___/|_| |_|\___| |_| Welcome to Armbian buster with Linux 5.6.5-sunxi64 No end-user support: built from trunk Paste fericit tuturor :-) [ yes for some among us Easter is now ]
Werner Posted May 17, 2020 Posted May 17, 2020 OrangePi Lite2 might be broken on the latest 5.6 kernel version (which is at this moment 5.6.12 at megi's repo) since these two patches fail to apply: npi-a64-only-audio-usb.patch board-h6-orangepi-lite2-fix-missing-all.patch
Werner Posted May 17, 2020 Posted May 17, 2020 On 5/17/2020 at 11:36 AM, Werner said: OrangePi Lite2 might be broken on the latest 5.6 kernel version (which is at this moment 5.6.12 at megi's repo) since these two patches fail to apply: npi-a64-only-audio-usb.patch board-h6-orangepi-lite2-fix-missing-all.patch Expand Fixes pushed. 1
