OrangePi One Plus confirmed as well. Did not test much though. Boots, HDMI works, DE without Panfrost works. Ethernet works...well, that's pretty much it what I have tested :lol:
@Wernervery well - currently playing with wireguard on both; cpu temp +/- 46-49 degrees , not stressing both boards ( yet ).
Will wait for that till 1,8GHz can be configured (re-enabled) again, it has been "discussed" in 5.4 dev already
It can. At current at least.
Simply chance the max at /etc/default/cpufrequtils to 1810000
unfortunately not on my OpiOnePlus, at least with this config
@orangepioneplus1:~$ cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=480000
MAX_SPEED=1810000
GOVERNOR=conservative
Board shows after "reboot" :
root@orangepioneplus1:~# cpufreq-info |grep cpufreq
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
  driver: cpufreq-dt
  available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil
  cpufreq stats: 480 MHz:85.35%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45%  (179)
  driver: cpufreq-dt
  driver: cpufreq-dt
  driver: cpufreq-dt
  cpufreq stats: 480 MHz:85.36%, 720 MHz:4.05%, 816 MHz:0.51%, 888 MHz:0.95%, 1.08 GHz:1.39%, 1.32 GHz:1.31%, 1.49 GHz:6.45%  (179)
As well armbian-config not showing 1,8GHz , did not find an overlay setting ( like H5 ) so I guess this is WIP and will await a permanent solution.
for now I am OK as it boots in to the new kernel and therefore I can access and play with both boards
@Werner would you mind allowing my the QnD way by adding your " sun50i-h6-orangepi-one-plus.dtb " to your post so I should not need to recompile and just replace current file in " /boot/dtb/allwinner " ...:rolleyes:
[ current state meanwhile after compiling :]
  CC [M]  drivers/staging/rtl8723cs-new/core/rtw_mp.o
  LD [M]  drivers/staging/rtl8723cs-new/8723cs.o
Makefile:1685: recipe for target 'drivers' failed
[ error ] ERROR in function compile_kernel [ compilation.sh:378 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
[ this is meanwhile resolved with
./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no BUILD_EXTERNAL=no WIREGUARD=no EXTRAWIFI=no AUFS=no ]
I just noticed that for 5.6 it seems like this patch is not longer necessary. Simply edit the cpufrequitls max frequency to 1810000 and reload the service. The max clock is unlocked then. Check with armbianmonitor and put some load to the board.
Make sure to put some cooling to the board.
@Werner Err check my previous post, NOK
I did this previously ( exact steps below ) and even the OPiOnePlus got a nice reboot
Just to be certain this is what my build says : " Linux orangepioneplus1 5.6.2-sunxi64 #trunk SMP Tue Apr 7 09:22:09 CEST 2020 aarch64 GNU/Linux "
Next attempt when 5.6.3 is incorporated in to dev build
cd ~/armbian/userpatches     # neither in ~armbian/userpatches/kernel/sunxi-current
wget https://github.com/armbian/build/blob/master/patch/kernel/sunxi-current/xxx-sun50i-h6-enable-higher-clock.patch
cd..
./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no BUILD_EXTERNAL=no EXTRAWIFI=no
On 4/7/2020 at 10:05 PM, guidol said:
kernel 5.6.2-sunxi(64) did here also boot on the following SBCs:
- OrangePi One / Zero
Many Thanks to @martinayotte ;)
Also the OrangePi R1 with NAS-Board-Extension does work fine ;)
System diagnosis information has been uploaded to http://ix.io/2hqz
1 hour ago, Werner said:
Fixed.
@Wernermoin moin I had to put it in sunx-dev of course,
me bad however still NOK " only garbage was found in the patch input " - seems I am overlooking something else now
ouput.log
[ warn ] * [u][c] xxx-sun50i-h6-enable-higher-clock.patch [ failed ]
patching.log
Processing file /home/armbian/userpatches/kernel/sunxi-dev/xxx-sun50i-h6-enable-higher-clock.patch
patch: **** Only garbage was found in the patch input.
ok firing up a new build, wiped armbian completely and looks promising so far - will flash OPiOnePlus shortly:
[ o.k. ] * [l][c] xxx-sun50i-h6-enable-higher-clock.patch
And indeed looking much better now so no need for Jira  story anymore ;-), danke-gracias-thanks-bedankt-multumesc-hvala etc etc
@orangepioneplus:~# cpufreq-info |tail -1
  cpufreq stats: 480 MHz:83.61%, 720 MHz:0.92%, 816 MHz:0.20%, 888 MHz:0.02%, 1.08 GHz:0.09%, 1.32 GHz:0.11%, 1.49 GHz:8.99%, 1.64 GHz:0.09%, 1.80 GHz:5.98%  (153)
Now let's see how things will hold as H5's show in "idle mode" ( conservative)  a CPU temp of +/- 35°C ( current CPU frequency is 480 MHz )
while H6 shows CPU temp of 49°C already with passive cooling  . The 1,8Ghz would be needed only when I synch my NAS with remote site for a couple of minutes.
For regular TV streaming CPU stays at mostly at 480Mhz (  cpufreq stats: 408 MHz:85.35% ) so I hope active cooling won't be needed because of the 15 degrees temp difference in idle mode already
Kernel 5.6.5 brings fix for "  arm64: dts: allwinner: h5/h6: Fix PMU compatible ", so more juice comes in place for these nice boards
Coming to beta.armbian.com tomorrow morning. Together with u-boot 2020.04
Yes :) arrived on my Neo2...
Welcome to Armbian Buster with Linux 5.6.5-sunxi64
dpkg -l|grep u-boot
linux-u-boot-nanopineo2-dev      20.05.0-trunk	arm64	Uboot loader 2020.04
3 hours ago, Werner said:
Same for me One Plus. Running on 5.6.5 with U-Boot 2020.04 :thumbup:
beside sunxi and sunxi64 it does also work on meson64 - here my Odroid C2 ;)
good news , I can concur
ii  linux-u-boot-orangepioneplus-dev      20.05.0-trunk                       arm64        Uboot loader 2020.04
ii  u-boot-tools                          2019.01+dfsg-7                      arm64        companion tools for Das U-Boot bootloader
And OrangePiOnePlus is happy so far:
root@orangepioneplus's password:
  ___  ____  _    ___
 / _ \|  _ \(_)  / _ \ _ __   ___   _
| | | | |_) | | | | | | '_ \ / _ \_| |_
| |_| |  __/| | | |_| | | | |  __/_   _|
 \___/|_|   |_|  \___/|_| |_|\___| |_|
Welcome to Armbian buster with Linux 5.6.5-sunxi64
No end-user support: built from trunk
Paste fericit tuturor :-) [ yes for some among us Easter is now ]
OrangePi Lite2 might be broken on the latest 5.6 kernel version (which is at this moment 5.6.12 at megi's repo) since these two patches fail to apply:
npi-a64-only-audio-usb.patch
board-h6-orangepi-lite2-fix-missing-all.patch
Fixes pushed.
