technik007_cz Posted June 3, 2016 Posted June 3, 2016 Hi there, I do no need help how to sort it out. This is only report for Igor. I installed Jessie server image with legacy kernel on my Cubietruck few on April. I decided try upgrade to vanilla kernel about two weeks ago with command see below. And today I decided return back to legacy kernel with same command. (it is not important why but I have answer for it, I am enjoying testing ... ;-) ) ... but before I rebooted my experiencies say check /boot folder and I did not find important files there. I used command: wget -q -O - http://upgrade.armbian.com| bash And here is output of log: cat /boot/upgrade.logNo packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used.No packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used."linux-image-2.6" is a virtual package provided by: linux-image-udoo linux-image-sunxi linux-image-sun8i linux-image-sun7i linux-image-sun4i linux-image-s500 linux-image-odroidxu4 linux-image-odroidxu linux-image-odroidc1 linux-image-next-udoo linux-image-next-sunxi linux-image-next-odroidxu linux-image-next-marvell linux-image-next-cubox linux-image-neo linux-image-marvell linux-image-dev-sunxi linux-image-dev-sun8i linux-image-dev-cubox linux-image-cubox linux-image-bananaYou must choose one to install."linux-image" is a virtual package provided by: linux-image-udoo linux-image-sunxi linux-image-sun8i linux-image-sun7i linux-image-sun4i linux-image-s500 linux-image-odroidxu4 linux-image-odroidxu linux-image-odroidc1 linux-image-next-udoo linux-image-next-sunxi linux-image-next-odroidxu linux-image-next-marvell linux-image-next-cubox linux-image-neo linux-image-marvell linux-image-dev-sunxi linux-image-dev-sun8i linux-image-dev-cubox linux-image-cubox linux-image-bananaYou must choose one to install.No packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used."linux-headers-2.6" is a virtual package provided by: linux-headers-sunxi linux-headers-sun8i linux-headers-sun7i linux-headers-sun4i linux-headers-bananaYou must choose one to install."linux-headers" is a virtual package provided by: linux-headers-udoo linux-headers-sunxi linux-headers-sun8i linux-headers-sun7i linux-headers-sun4i linux-headers-s500 linux-headers-odroidxu4 linux-headers-odroidxu linux-headers-odroidc1 linux-headers-next-udoo linux-headers-next-sunxi linux-headers-next-odroidxu linux-headers-next-marvell linux-headers-next-cubox linux-headers-neo linux-headers-marvell linux-headers-dev-sunxi linux-headers-dev-sun8i linux-headers-dev-cubox linux-headers-cubox linux-headers-bananaYou must choose one to install.No packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used.No packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used.No packages will be installed, upgraded, or removed.0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 0 B will be used.
technik007_cz Posted June 3, 2016 Author Posted June 3, 2016 I tried install kernel, headers, firmware and uboot for legacy kernel. Can be problem for script this message on konsole? WARNING: The following packages cannot be authenticated! ... Install these packages without verification? [y/N] I think it cannot pass it without user interaction or it do not expect it can run into situation when repository key is old, missing or something else.
wildcat_paris Posted June 4, 2016 Posted June 4, 2016 @technick007_cz for the keyring, if you have the id of the key google "apt-key adv" for an example
