vipk31 Posted April 2, 2020 Posted April 2, 2020 I install armabian success on SD card and make guid : https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb but error command not found I used armbian : Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_20200205.img.xz Can current armbian be installed on eMMC? please help me .
Igor Posted April 2, 2020 Posted April 2, 2020 On 4/2/2020 at 3:41 AM, vipk31 said: I used armbian Expand Are you sure? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity Moving to TV boxes. (un-official armbian ports)
SteeMan Posted April 2, 2020 Posted April 2, 2020 On 4/2/2020 at 3:41 AM, vipk31 said: I install armabian success on SD card and make guid : https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb but error command not found I used armbian : Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_20200205.img.xz Can current armbian be installed on eMMC? please help me . Expand The standard armbian documentation only applies to the standard armbian builds. The builds by @balbes150 are a fork of the standard armbian code for Android TV boxes (instead of standard SBC boards) and therefore you can't use the standard documentation as there are a number of differences. To install into emmc look in your /root directory and you will see a set of install scripts. Choose the one appropriate for your CPU and run it for installation into emmc. The current active thread of discussion for the @balbes150 builds is: Please carefully read the first posting in this thread as it goes over many of the specifics that are unique or different for these android tv box builds. 1
RaptorSDS Posted April 9, 2020 Posted April 9, 2020 be carfull it looks like for the new 4.xx(19.xx) and 5.xx(20.xx) Kernel Version from balbes150
