Burschi500 Posted April 11, 2020 Posted April 11, 2020 Armbianmonitor: http://ix.io/2hyL Good morning, after some time using armbian on my OdroidN2 with great success (got Nextcloud with working Talk installed, external USB, Minecraft server, nginx, LetsEncrypt, Netdata...) I encountered some problems I am not able to solve by myself: I bought a RTC battery and a LED power button to "finalize" my Odroid (hardwarewise), and to my surprise both did not work as expected. RTC: It says: chris@OdroidN2:~$ sudo hwclock hwclock: select() to /dev/rtc0 to wait for clock tick timed out cat /proc/interrupts |grep rtc ...gives me also no return (empty string), so i guess there is a module missing in the kernel : chris@OdroidN2:~$ uname -a Linux OdroidN2 5.4.28-meson64 #20.02.8 SMP PREEMPT Mon Mar 30 09:12:52 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux There is a post on RTC here in the forums which looks like my problem, its here. Maybe it is the same problem? Next problem is GPIO: As mentioned above i tried to install a LED power button, and used this to set it up. I got the LED working as expected (Pin 1 and 6), but the power on-off is not working (Pin 9 and 11). The button i purchased is a NO-switch, and after checking the correct wiring i also tested the button for funcion. Everything is fine according to the multimeter. After some reading i tested for working GPIO (installed wiringpi with this instruction), and it looks like this is the problem: chris@OdroidN2:~$ sudo gpio readall No "Hardware" linechris@OdroidN2:~$ It looks to me as there is also some module missing or am i wrong? I also have no i2c bus, in /dev/ there is only i2c-0. Now - what is wrong and what can i do about it? Is there information missing i should provide to solve my problem?
martinayotte Posted April 11, 2020 Posted April 11, 2020 11 hours ago, Burschi500 said: I also have no i2c bus, in /dev/ there is only i2c-0. Odroid-N2 external RTC is attached on I2C3 which isn't enabled by default. To enable it, use this overlay source and compile it and load it. /dts-v1/; /plugin/; / { compatible = "amlogic,meson-g12b"; fragment@0 { target-path = "/aliases"; __overlay__ { i2c3a = "/soc/bus@ffd00000/i2c@1c000"; }; }; fragment@1 { target-path = "/soc/bus@ffd00000/i2c@1c000"; __overlay__ { status = "okay"; pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; pinctrl-names = "default"; pcf8563: rtc@51 { /*I2C-bus slave address: read A3h and write A2h*/ compatible = "nxp,pcf8563"; reg = <0x51>; }; }; }; }; Then, the i2c will appear as well as module for PCF8563 will be loaded, it will be hookup as /dev/rtc1, you can then set the clock and re-read it using : hwclock -w -f /dev/rtc1 hwclock -f /dev/rtc1
Burschi500 Posted April 12, 2020 Author Posted April 12, 2020 Thank you very much, I used your instructions from over there, and it works (i got warnings but i guess these are ok)! Do I have to issue these commands at every boot, or is it "done" now? I read here that you have to put something in config.txt which might translate to boot.ini? Any chance that i can get the GPIO working in a similar manner?
martinayotte Posted April 12, 2020 Posted April 12, 2020 8 hours ago, Burschi500 said: Do I have to issue these commands at every boot To load the overlay ? Yes, it requires to be loaded at every boot, for example thru calls from /etc/rc.local, or using useroverlays variable in /boot/armbianEnv.txt. 8 hours ago, Burschi500 said: Any chance that i can get the GPIO working in a similar manner? I don't know, I've not used the WiringPi mentioned above, but you can try using sysfs gpio. EDIT: Something looks a bit fishy : I've not been able to make gpio sysfs working ...
Burschi500 Posted April 13, 2020 Author Posted April 13, 2020 Actually i don't want to program with WiringPi, i just want to use the hardwarepins for a hardwarebutton. WiringPi and gpio readall was just a test if basic functionality is present (which is not). But as your EDIT says there might be a different problem than in WiringPi. It does not break Armbian on OdroidN2 for me, but ... i just want to have this shiny button working and not just shining :).
martinayotte Posted April 14, 2020 Posted April 14, 2020 On 4/13/2020 at 4:24 AM, Burschi500 said: But as your EDIT says there might be a different problem than in WiringPi I've decided to take a look at the WiringPi issue, and I figured out that "cat /proc/cpuinfo" doesn't give same output under Armbian that WiringPi is expecting with HardKernel version. But I figured out to comment out all the Hardware/Revision parsing of /proc/cpuinfo, and hard coded the the result as a OdroidN2 board, and the rest of the library is working fine. I didn't the same with WiringPi python wrapper too ... This is the recipe : Comment out those lines : https://github.com/hardkernel/wiringPi/blob/master/wiringPi/wiringPi.c#L328-L449 and hardcode the following, just after the commenting : libwiring.model = MODEL_ODROID_N2; libwiring.maker = MAKER_AMLOGIC; libwiring.mem = 4; libwiring.rev = 1; EDIT: Now, I will go back to gpio sysfs issue, but there is less hurry ...
Burschi500 Posted April 15, 2020 Author Posted April 15, 2020 Thanks for your effort. I fear that i need more detailed instructions. Can you give me the command set i must use or a direction where to look?
martinayotte Posted April 15, 2020 Posted April 15, 2020 7 hours ago, Burschi500 said: I fear that i need more detailed instructions. Can you give me the command set i must use or a direction where to look? As I said, after doing "git clone", simply commenting the whole detection code from line 328 to 449, and then hardcode the OdroidN2 definition mentioned above, then compile the library ...
Burschi500 Posted April 18, 2020 Author Posted April 18, 2020 Just noticed that an update for wiringpi was available - thank you - gpio readall is now working as expected as i get the table the link was referring to. Unfortunately the powerbutton is still not working when using the lines given above in boot.ini. I tested the same with a kernel from hardkernel (which i tried because my trial to move the system to ssd failed miserably) and there the button worked as expected. I guess it is still an issue of the kernel?
onkel_enno Posted March 15, 2021 Posted March 15, 2021 Any success to enable the GPIO? The Power Button was working on my old "Ubuntu Bionic with Armbian Linux 4.9.190" out of the box. I create a new system using "Armbian 21.02.3 Focal with Linux 5.10.21-meson64" and it is not working anymore.
Igor Posted March 15, 2021 Posted March 15, 2021 9 minutes ago, onkel_enno said: and it is not working anymore In general - kernel 5.y is not simple functional upgrade from private(!) 4.9.y. Functions needs to be developed and/or ported to support this and that functionality. Very expensive problem in term of development resources. For specific functions - if things are working, they are working this way: https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/tree/README https://github.com/sgjava/java-periphery
onkel_enno Posted March 16, 2021 Posted March 16, 2021 Am 15.3.2021 um 09:09 schrieb Igor: In general - kernel 5.y is not simple functional upgrade from private(!) 4.9.y. Very good hint, thank you. I switched to the latest legacy kernel 4.9 with armbian-config and ... it works.
