Jean-Marc Posted April 20, 2020 Posted April 20, 2020 Hi, I am trying to boot image Armbian_20.02.1_Nanopi-r1_buster_current_5.4.20.img, without success ... First, i am using following line to create SD ... ansible@solo:/mnt/backup$ sudo dd if=./Armbian_20.02.1_Nanopi-r1_buster_current_5.4.20.img of=/dev/mmcblk0 bs=1M status=progress ;sudo sync After connected my tty on internal pins on PCB, it is possible to connect to this tty and look at the first u-boot log ... Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on May 6 2018, 08:02:47. Port /dev/tty-target-srv-nanopir1-170-position-1.2.4.1, 20:34:41 Press CTRL-A Z for help on special keys U-Boot SPL 2019.10-armbian (Feb 17 2020 - 06:18:08 +0100) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2019.10-armbian (Feb 17 2020 - 06:18:08 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi R1 DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c11000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: phy interface7 Error: ethernet@1c30000 address not set. eth-1: ethernet@1c30000 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 3 ms (1.2 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 236 bytes read in 3 ms (76.2 KiB/s) 7342788 bytes read in 557 ms (12.6 MiB/s) 7744344 bytes read in 587 ms (12.6 MiB/s) Found mainline kernel configuration 29509 bytes read in 10 ms (2.8 MiB/s) 504 bytes read in 7 ms (70.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo 504 bytes read in 7 ms (70.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost1.dtbo 502 bytes read in 7 ms (69.3 KiB/s) Applying kernel provided DT overlay sun8i-h3-uart1.dtbo 4155 bytes read in 7 ms (579.1 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 7342724 Bytes = 7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 498ff000, end 49fffa84 ... OK Loading Device Tree to 4988f000, end 498fefff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. But not possible to have the login (!). As a result, after umounting SD and modifying code in in /boot/armbianEnv.txt (verbosity=7), then following booting is always the same... Regards
Jean-Marc Posted April 20, 2020 Author Posted April 20, 2020 Hi, Please find log file on nanopir1 and Armbian. Not possible for me to boot the target with a tty connected on internal chip. U-Boot SPL 2019.10-armbian (Jan 05 2020 - 01:28:29 +0100) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2019.10-armbian (Jan 05 2020 - 01:28:29 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi R1 DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c11000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: phy interface7 Error: ethernet@1c30000 address not set. eth-1: ethernet@1c30000 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 4 ms (924.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 236 bytes read in 3 ms (76.2 KiB/s) 7341915 bytes read in 552 ms (12.7 MiB/s) 7741936 bytes read in 582 ms (12.7 MiB/s) Found mainline kernel configuration 29509 bytes read in 11 ms (2.6 MiB/s) 504 bytes read in 9 ms (54.7 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo 504 bytes read in 9 ms (54.7 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost1.dtbo 502 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun8i-h3-uart1.dtbo 4155 bytes read in 10 ms (405.3 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 7341851 Bytes = 7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 498ff000, end 49fff71b ... OK Loading Device Tree to 4988f000, end 498fefff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Thanks in advance for your help .... Best regards
Igor Posted April 20, 2020 Posted April 20, 2020 15 minutes ago, Jean-Marc said: Not possible for me to boot the target with a tty connected on internal chip. How long do you wait? There is also more recent image on the download. Did you try that too?
Igor Posted April 20, 2020 Posted April 20, 2020 1 hour ago, Jean-Marc said: First, i am using following line to create SD .. If you DD, you don't know if your SD was written properly. https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card
Jean-Marc Posted April 21, 2020 Author Posted April 21, 2020 Igor, Thanks for your reply. I have tested many releases from Armbian, always with the same CLASS 10 from SANDISK ultra. It seems there is no issue for this point of view. Regards
Jean-Marc Posted April 21, 2020 Author Posted April 21, 2020 Quote How long do you wait? There is also more recent image on the download. Did you try that too? About 10 minutes (!)
