mboehmer Posted June 4, 2020 Share Posted June 4, 2020 I have my C4 now, with eMMC card, and tried first the standard download image. Works nicely! I started compiling my own system, so I can assist in debugging - anything which I should start with? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 4, 2020 Author Share Posted June 4, 2020 43 minutes ago, mboehmer said: I started compiling my own system, so I can assist in debugging - anything which I should start with? With the nastiest problem we have Board stuck at u-boot (modern 2020.04 & kernel 5.6.y only) on reboot ... we don't know why or where to look at this point. Perhaps observing commit log from the stock u-boot might reveal something? Perhaps this is already solved in a u-boot trunk? Any information surrounding this bug would be helpful. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 4, 2020 Share Posted June 4, 2020 OK, I asked for it, so I got it. Is reboot affected by uSD or eMMC? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 4, 2020 Author Share Posted June 4, 2020 1 hour ago, mboehmer said: Is reboot affected by uSD or eMMC? Both. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 4, 2020 Share Posted June 4, 2020 Which image should I test? downloadable one or self compiled? 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 4, 2020 Share Posted June 4, 2020 (edited) Hm. I just did a loop of reboots on the download image (Armbian Focal with Linux 5.6.15-meson64), and had no stuck. I use an Hardkernel 16GB eMMC and a 2A 12V power supply. EDIT: I can't get a reboot problem reproduced with eMMC card. With uSD card, it happens very frequently (same image used). The reboot command either is the last message I get in the console, or we end up like that: [ 262.787662] reboot: Restarting system bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id:øSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:400;USB:8;LOOP:1;EMMC:800;NAND:81;SD?:0;SD:400;USB:8; It seems to me that the reboot problem only affects uSD operation. Edited June 4, 2020 by mboehmer New information added 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 5, 2020 Author Share Posted June 5, 2020 2 hours ago, mboehmer said: and had no stuck Can you perhaps repeat this like 10 times? I hope to get some input from others. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 5, 2020 Share Posted June 5, 2020 Hi Igor, eMMC reboot was 20x so far with no lockup. It seems a uSD card problem - I have not managed to get a "reboot" with uSD card done properly. I use a SanDisk Extreme 16GB Class 3 HC I card. The power supply should be sufficient (12V 2A). With uSD card, the following errors occur when I log in after booting and do a "reboot" as root: root@odroidc4:~# reboot [ 59.522866] reboot: Restarting system bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id:øSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:400;USB:8;LOOP:1;EMMC:800;NAND:81;SD?:0;SD:400;USB:8; After that, the system is stuck and needs a power cycle (didn't find a reset yet). The same image on an eMMC card does the following on a "reboot": root@odroidc4:~# reboot [ 50.423833] reboot: Restarting system bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0000 - pwm id 0x01 bl2_stage_init 0xc1 bl2_stage_init 0x02 L0:00000000 L1:00000703 L2:00008067 L3:15000020 S1:00000000 B2:20282000 B1:a0f83180 TE: 67922 BL2 Built : 20:29:41, Jun 18 2019. g12a ga659aac - luan.yuan@droid15-sz Board ID = 1 Set cpu clk to 24M Set clk81 to 24M Use GP1_pll as DSU clk. DSU clk: 1200 Mhz CPU clk: 1200 MHz Set clk81 to 166.6M eMMC boot @ 0 sw8 s So there are differences in the output, I have no clue yet where this output comes from. Hope this helps. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 5, 2020 Share Posted June 5, 2020 I compiled a Buster system with new kernel (5.6.16) now with the build system, and tested on eMMC card. Same results, reboot works fine on eMMC card. 0 Quote Link to comment Share on other sites More sharing options...
Arpel Posted June 8, 2020 Share Posted June 8, 2020 Hi, My 2 cents here : I'm using Armbian on C4 since 14 days now and I only had reboot issue (on eMMC) with the early versions (5.4 kernel) : 5.6 never got stuck. 1 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 8, 2020 Share Posted June 8, 2020 1 hour ago, Arpel said: Hi, My 2 cents here : I'm using Armbian on C4 since 14 days now and I only had reboot issue (on eMMC) with the early versions (5.4 kernel) : 5.6 never got stuck. Could you try with uSD cardf (while we both know that uSD is always second choice My system stucks very often with uSD while eMMC seems to work fine. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 11, 2020 Share Posted June 11, 2020 Made some tests now with Armbian 20.05.2 and 4.9.224-odroidc4 - reboot works with uSD cards. For me it looks like a timing problem in Uboot... I will have to make some measurements on uSC pins to see if the problem can be seen there. Removing the uSD card after the first boot attempt and reinserting it doesn't help, power cycle is needed. 0 Quote Link to comment Share on other sites More sharing options...
vkozlov Posted June 11, 2020 Share Posted June 11, 2020 7 minutes ago, mboehmer said: Made some tests now with Armbian 20.05.2 and 4.9.224-odroidc4 - reboot works with uSD cards. Same for me, Focal-based 4.9 works just fine, but 5.6.15 almost always stucks. Could it be an issue with module unloading? Maybe it sounds stupid; but I had the very similar issue with Atomic PI and Ubuntu 20.04 - it wasn't able to reboot properly and dw_dmac module was the root cause, I have blacklisted it and problem disappeared. I wonder if we have something like it on Odroid-C4. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 11, 2020 Author Share Posted June 11, 2020 3 hours ago, vkozlov said: Could it be an issue with module unloading? Maybe it sounds stupid; but I had the very similar issue with Atomic PI and Ubuntu 20.04 - it wasn't able to reboot properly and dw_dmac module was the root cause, I have blacklisted it and problem disappeared. I wonder if we have something like it on Odroid-C4. No, AFAIK it always hangs at boot loader, below Linux and Ubuntu user land. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 11, 2020 Share Posted June 11, 2020 If you take a look on my previous post, it looks like the bootloader starting, and then being broken by a reset, immediately following a new boot attempt. The "normal" boot messages are like that (cold starting a 5.x kernel from uSD card): SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0000 - pwm id 0x01 bl2_stage_init 0xc1 bl2_stage_init 0x02 Doing a "reboot" or "shutdown -r now" as root leads to the following messages, compare the "hw id" line: [ 95.523748] reboot: Restarting system bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0;CHK:0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id:øSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:400;USB:8; The first "SM1" line is the same, no clue about the meanings of the status message, but "SD:0" seems to say "SDcard is fine", and booting starts. The next "bl2_stage_init" lines are identical, but while the "hw id" line is fine in the cold start, it is interrupted in the warm start (reset) by a SM1 line again, this time mit "SD:400" - which obviously is bad. I could figure out something so far: SD:20000 -> no SDcard inserted SD:0 -> SD card fine (?) SD:400 -> our problem As this message occurs without any boot media, it must originate directly from the SoC. It doesn't originate from the power on reset (VDDIO_AO), this line is accessible on the UART header, no dip visible. I will dig deeper... Edit: my best guess so far is a forgotten watchdog timer which resets the system while it tries to reboot. For reasons unknown to me this seems not to hit when eMMC is booting. According to the data sheet the eMMC card is probed earlier then uSD, and this may already make a difference? 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 16, 2020 Share Posted June 16, 2020 Some news: it is not the TEST_N pin. There is no pulse or noise visible which could reset the CPUs. I will check the VDDIO_AO next, which could cause a reset also. Only glitch so far I have seen: Amlogic recommends a 1nF cap on RESET_N line, which is missing in the C4. Can anyone explain at what point of the boot sequence the "SM1:" message is being generated? Any clues for a reset source hitting here? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 17, 2020 Author Share Posted June 17, 2020 https://github.com/armbian/build/pull/2024#issuecomment-644629168 0 Quote Link to comment Share on other sites More sharing options...
Sean Mathews Posted June 17, 2020 Share Posted June 17, 2020 On 6/8/2020 at 7:04 AM, Igor said: Currently we have only one(1) board and no official maintainer(s). I already blow several days solo for this board and I think / hope the biggest problems were fixed but I have no intention to add more long term work on my shoulders. We need two persons to be around to deal with this board or support stays on the at least same level as on other Linux distros. I am currently working a project and want to use this board. @igor Would it be possible to see the diff on github of what was done to bring up the ODROID-C4 board. I looked over the commits on github but was not able to find much on this board. I think I saw one commit that was bringing over settings from another similar board? Best SM 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 17, 2020 Author Share Posted June 17, 2020 2 hours ago, Sean Mathews said: and want to use this board. And you are willing to cover yearly support costs? 3 hours ago, Sean Mathews said: Would it be possible to see the diff All code and all transactions are public. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 20, 2020 Share Posted June 20, 2020 As we know now where the uSD card problem resides, is there anyone working on that already? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 21, 2020 Author Share Posted June 21, 2020 21 hours ago, mboehmer said: As we know now where the uSD card problem resides, is there anyone working on that already? I have no info. 0 Quote Link to comment Share on other sites More sharing options...
Sean Mathews Posted June 21, 2020 Share Posted June 21, 2020 I can help contribute a little to the development. Send me info on how and how much 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 21, 2020 Author Share Posted June 21, 2020 1 hour ago, Sean Mathews said: I can help You are helping yourself while we don't know yet if we can afford to support this hw / your attempt - for dealing with a board that makes some noise and have some users we easily lost 20.000 - 30.000 EUR per year. Some initial work was already done, but it's not too late to unplug and go slow as everyone else. 1 hour ago, Sean Mathews said: Send me info on how and how much Here is a test you have to pass: https://github.com/armbian/build#support 0 Quote Link to comment Share on other sites More sharing options...
Technicavolous Posted June 23, 2020 Share Posted June 23, 2020 @Sean Mathews if you make any progress please give a share! As for "how and how much," consider a monthly subscription. Some of us do that ;] Or Buy Igor a Beer or tank of gas. Or watch the wish list for something you'd like to contribute. ( @Igor is there still an Amazon wish list page somewhere??) @mboehmer I've rebooted my C4 over and over with several downloaded images, I've not had a single stick. Finally compiled my own image. Sticks every time on shutdown -r now. I have the Hardkernel eMMC 16GB, but also tried Sandisk 32GB U3. I am using lab power supplies ... 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 24, 2020 Share Posted June 24, 2020 On 6/23/2020 at 3:02 AM, Technicavolous said: @mboehmer I've rebooted my C4 over and over with several downloaded images, I've not had a single stick. Finally compiled my own image. Sticks every time on shutdown -r now. I have the Hardkernel eMMC 16GB, but also tried Sandisk 32GB U3. I am using lab power supplies ... Which kernel / Uboot did you use for compiling? I assume you compiled a complete image? WIth eMMC reboot works like a charm (tried Hardkernel eMMC 16GB, as well as Radxa ones), with uSD cards it fails every time. I assume we need to make sure that Uboot switches the card to 3.3V mode during startup. Putting this into the kernel is dangerous, as the reboot may or may not happen by software. 0 Quote Link to comment Share on other sites More sharing options...
Technicavolous Posted June 24, 2020 Share Posted June 24, 2020 Last night I noticed a slight difference in shutdowns. sudo shutdown -h now appears to shut down the board properly, the red light goes out. sudo halt leaves the red light on indefinitely. I have only recently got my build system working, and frankly this is the first time I've ever done that ... I just left everything default, selected the board, current kernel, no kernel config, os with desktop. I've not even opened any config files yet. My coding days were back in the MS C++ 7 era, predating VC ;] so it will take me a bit to get acclimated to the build system. 0 Quote Link to comment Share on other sites More sharing options...
jjjbenderjjj Posted June 24, 2020 Share Posted June 24, 2020 Can somebody write the output of the commands for 5.4 kernel. It would be very helpful for me (I try to figure out is there SVE or not in this CPU) uname -a cat /proc/cpuinfo lshw Thx you all in advance. 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 25, 2020 Share Posted June 25, 2020 17 hours ago, jjjbenderjjj said: Can somebody write the output of the commands for 5.4 kernel. It would be very helpful for me (I try to figure out is there SVE or not in this CPU) uname -a cat /proc/cpuinfo lshw Thx you all in advance. For 5.6 kernel attached. I have no 5.4 system running,. Hope it helps nevertheless. 5.6.txt 0 Quote Link to comment Share on other sites More sharing options...
jjjbenderjjj Posted June 25, 2020 Share Posted June 25, 2020 1 hour ago, mboehmer said: For 5.6 kernel attached. I have no 5.4 system running,. Hope it helps nevertheless. 5.6.txt 4.29 kB · 4 downloads God bless YOU!!! According to this portion of a code [arch/arm64/kernel/cpuinfo.c: 384] (and other one): if (IS_ENABLED(CONFIG_ARM64_SVE) && id_aa64pfr0_sve(info->reg_id_aa64pfr0)) info->reg_zcr = read_zcr_features(); Of course, I double-check this [if] statement and {IS_ENABLED(CONFIG_ARM64_SVE)} part gives [1] but other one not (this is obvious to us because the already present in our defconfig) ;( And if WE all try to read this feature register [res_from_aa64pfr0_el1 (64-bit width)] WE will get (if I am right) some unpleasantness results ;( : register uint64_t res_from_aa64pfr0_el1; __asm__ __volatile__("mrs %[res_from_aa64pfr0_el1], id_aa64pfr0_el1 \n\t" ::[res_from_aa64pfr0_el1]"r"(res_from_aa64pfr0_el1) :"memory", "cc"); printf("ID_AA64PFR0_EL1[0] 0x%" PRIX64 "\n", res_from_aa64pfr0_el1); printf("ID_AA64PFR0_EL1[1] 0x%" PRIX64 "\n", res_from_aa64pfr0_el1 >> 32); printf("ID_AA64PFR0_EL1.SVE 0x%" PRIX64 "\n", (res_from_aa64pfr0_el1 >> 32) & 0xF); Our [CPU] doesn't have [SVE]. Please somebody proves me wrong! 0 Quote Link to comment Share on other sites More sharing options...
mboehmer Posted June 26, 2020 Share Posted June 26, 2020 12 hours ago, jjjbenderjjj said: Our [CPU] doesn't have [SVE]. Please somebody proves me wrong! Hm. How about starting with the existing problems (like the 1.8V/3.3V switching for the uSD card), before you try to find out something about the CPU instruction set? A system not being able to properly reboot with uSD card will not be of use forf anyone. Seems like you know what you are doing, so you help us here. 0 Quote Link to comment Share on other sites More sharing options...
