hexdump Posted March 26, 2021 Posted March 26, 2021 the situation for the 32bit amlogic socs (like the odroid c1) is that there is essentially just one single person working on them whenever time permits it ... so the only two options are to be patient or to help (which is not an easy option) or of course to forget about the board ... 0 Quote
BarTender Posted May 18, 2021 Posted May 18, 2021 Also have a C1+ and happy to assist with testing, just tried to connect up an I2C RTC and aml_i2c is missing from the current released version of buster. modprobe aml_i2c modprobe: FATAL: Module aml_i2c not found in directory /lib/modules/5.10.21-meson Armbian 21.02.3 Buster with Linux 5.10.21-meson Any way I can compile the library standalone or will I need to rebuild the kernel? 0 Quote
Werner Posted May 19, 2021 Posted May 19, 2021 On 5/18/2021 at 8:58 AM, BarTender said: will I need to rebuild the kernel? Expand I guess that. 0 Quote
pwrozycki Posted August 16, 2021 Posted August 16, 2021 (edited) I would like to add my two cents. I have read this thread after installing Armbian 21.02.3 Focal with Linux 5.10.21-meson and running into some USB related issues - USB hard drive was not detected. But contrary to what image description states - eMMC works. My odroid-c1 device contains root filesystem on eMMC. I have not noticed any issues related to eMMC support. About USB issue - it turns out there is a workaround I found it on some kernel dev mailing linst - adding usbcore.autosuspend=-1 to kernel boot arguments makes USB fully functional. At least I have not yet run into any issues. Edited August 16, 2021 by pwrozycki 0 Quote
Markus_ Posted April 3, 2022 Posted April 3, 2022 Building images with https://github.com/armbian/build for Odroid C1 is broken since several months (u-boot compilation breaks). According to https://wiki.odroid.com/odroid-c1/software/building_u-boot "arm-none-eabi-gcc" must be used, but I had additional problems building with 20.04. Finally I was lucky to build bullseye_5.16.18. Perhaps anybody is interested in actual image/kernel. USB is still not working good. Hint from post above with "usbcore.autosuspend=-1" may help. Power cut is still required for reboot HDMI and eMMC not tested image/kernel debs with bullseye_5.16.18 https://mega.nz/folder/xwd23LgD#gawWyLs7o_UxImVOBUil9w 0 Quote
itsmaxdd Posted July 15, 2022 Posted July 15, 2022 Hi @Markus_ Do you mind explaining how to dd or flash your images on an odroid c1+? I have one that i would like to put back at work. Regards, 0 Quote
Markus_ Posted July 17, 2022 Posted July 17, 2022 usbimager is preferred to flash image to microsd. Please keep in mind Odroid C1 don't work with every microsd card (Sandisk Ultra is ok) https://docs.armbian.com/User-Guide_Getting-Started/ https://gitlab.com/bztsrc/usbimager 1 Quote
Markus_ Posted August 22, 2022 Posted August 22, 2022 I built images for Odroid C1 with kernel 5.18.19 for Debian Bullseye and Ubuntu Jammy. Perhaps it's useful for anybody. - headless only (no HDMI output) - power cut is required for reboot - usb hotplug works with hint from post above "usbcore.autosuspend=-1" as boot arguments in /boot/boot.ini end of line "setenv bootargs" image/kernel debs: https://mega.nz/folder/xwd23LgD#gawWyLs7o_UxImVOBUil9w 0 Quote
sgjava Posted December 21, 2022 Posted December 21, 2022 @Markus_ Can you provide the steps to build? It would be interesting to try 6.1.0 kernel since that's LTS like 5.1.0. 0 Quote
Markus_ Posted December 23, 2022 Posted December 23, 2022 Building Image for Odroid C1 is broken again since some weeks (old u-boot compiler?). I created above images with this help https://docs.armbian.com/Developer-Guide_Build-Preparation/ on Xubuntu 22.04.1 direct (no Virtualbox/Docker), just ./compile.sh and choose EOS odroidc1 but as it's broken, no need to download all dependencies. Kernel can be upgraded with armbian-config (System, Other). 5.15.80 and 6.0.10 are latest, but you can install 6.1.0 from https://github.com/hzyitc/armbian-onecloud/releases , just download (eg. with wget to /tmp) linux-dtb-edge-meson_23.02.0-trunk_armhf.deb linux-headers-edge-meson_23.02.0-trunk_armhf.deb linux-image-edge-meson_23.02.0-trunk_armhf.deb and install all 3 packages with "dpkg -i linux*.deb" (takes some minutes) and reboot. armbian-onecloud has S805 like Odroid C1. 0 Quote
