First, thanks to everyone here who made this great os.
I am trying to read a DS18B20 temperature sensor on my orange pi pc, but I can't get it to work. I hooked up ground and 3.3v to the sensor, the data line I placed it on gpio 20/ physical pin 37 as other posts suggest but it is not reading it.
You can post now and register later.
If you have an account, sign in now to post with your account.
Question
sgarcia05
I edited /etc/modules-load.d/modules.conf
and modified it to:
it loads up in dmesg
but it is not visible in /sys/bus/w1/devices/
I tried other gpio sensors, currently I can read from an i2c sensor bmp180 and turn on/off lights with a 315/433mhz transmit module.
in the /boot/bin/orangepipc.bin (using bin2fex) I can see the 1wire sensor is set correctly to pin 20, the sensor has its own pull-up resistor
I am running armbian Linux orange 3.4.112-sun8i #8 SMP PREEMPT Tue May 31 19:00:17 CEST 2016 armv7l GNU/Linux
I also plan on adding an RTC.
Thanks for any help.
Link to comment
Share on other sites
82 answers to this question
