I want install ISPConfig of the last OS Buster of a Cubietruck 3.
The install stop before the end. I've test on 4 different 64Go SD and it's the same problem.
Thanks
1 hour ago, Club AC-News said:
If this helps - I can confirms that it works on Bionic variant. I am using it, but for Buster ... someone would need to debug.
I tried with several "bionic" images now for Cubietruck installing ISCP. During each installation, the procedure stops on this screen and nothing more happens.
Thanks
If they have a bash install script try running it with bash -x and | tee the output to a file so you know exactly what happens in the background.
I will repeat my "when maintaining stops, things starts to fall apart" :huh: And this script didn't get love for months ... nor we have any CI on it to be aware of that right on the spot.
Probably some package name has been changed. Manual install section by section might also help to find the cause of this problem.
