Igor Posted June 1, 2020 Posted June 1, 2020 Send a merge request to this file https://github.com/armbian/build/blob/master/config/kernel/linux-sunxi64-current.config There will be a bug fix update - soon after we find a solution for this fatal problem.
Werner Posted June 2, 2020 Posted June 2, 2020 Got missing here:https://github.com/armbian/build/commit/fea2ecb9f957101848bcf2af6b6b08ec44a5a526#diff-9d0bcdf961153323f063525ccdbca36d
dolphs Posted June 4, 2020 Posted June 4, 2020 Hi, seems upgrading to 30 May release 20.05.01 I lost "bbr" as congestion control setting. Can this be put back in please? - TiA! - root@wgvpn01:/etc/sysctl.d# uname -a Linux wgvpn01 5.4.43-rockchip64 #20.05.1 SMP PREEMPT Sat May 30 13:30:37 CEST 2020 aarch64 GNU/Linux root@wgvpn01:/etc/sysctl.d# sysctl net.ipv4.tcp_available_congestion_control net.ipv4.tcp_available_congestion_control = reno cubic root@wgvpn01:/etc/sysctl.d# sysctl -p wg.conf net.core.default_qdisc = fq net.core.rmem_max = 16777216 net.core.wmem_max = 16777216 net.ipv4.tcp_rmem = 4096 87380 16777216 net.ipv4.tcp_wmem = 4096 65535 16777216 sysctl: setting key "net.ipv4.tcp_congestion_control": No such file or directory net.ipv4.tcp_congestion_control = bbr net.ipv4.tcp_fastopen = 3 net.ipv4.tcp_no_metrics_save = 1 net.ipv4.tcp_slow_start_after_idle = 0 net.ipv4.tcp_mtu_probing = 1
dolphs Posted June 4, 2020 Posted June 4, 2020 meanwhile read here things have been reported earlier this week, sorry for the additional request
Ximodel Posted June 4, 2020 Author Posted June 4, 2020 the problem still exists after upgrading to armbian 20.05.1 but bbr does work in my another nanopineo2, which has 20.02.1 installed
dolphs Posted June 4, 2020 Posted June 4, 2020 was hoping 20.05.2 solved things but alas, we have to wait a little more: # sysctl -p ovpn.conf sysctl: setting key "net.ipv4.tcp_congestion_control": No such file or directory net.ipv4.tcp_congestion_control = bbr # uname -a Linux wgvpn01 5.4.43-sunxi64 #20.05.2 SMP Tue Jun 2 17:20:17 CEST 2020 aarch64 GNU/Linux
Igor Posted June 4, 2020 Posted June 4, 2020 1 hour ago, Ximodel said: the problem still exists after upgrading to armbian 20.05.1 Did you notice any information telling that this was included in the upgrade? Or that was it fixed in sources? Support terms:https://github.com/armbian/build#support Also when the problem will be fixed in sources, its not fully automatically yet to push it to the images. You are welcome to help out and improve the upgrading process.
dolphs Posted June 4, 2020 Posted June 4, 2020 allritie then, proposed file change - hope did it proper way -
Werner Posted June 4, 2020 Posted June 4, 2020 Looking good so far. Please test your adjustments before submitting them.
Igor Posted June 4, 2020 Posted June 4, 2020 I would propose that this is fixed in all configs under this pull requests.
Ximodel Posted June 5, 2020 Author Posted June 5, 2020 On 6/4/2020 at 1:48 PM, Igor said: Did you notice any information telling that this was included in the upgrade? Or that was it fixed in sources? Support terms:https://github.com/armbian/build#support Also when the problem will be fixed in sources, its not fully automatically yet to push it to the images. You are welcome to help out and improve the upgrading process. As regards bbr, it is not fixed after the upgrade. I would like to provide any help if I can, but ironically, when i ran the following command right after upgrade sudo armbianmonitor -u System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for. "the URL" is disappearing and I don't even know what is going wrong... And would you like to help me with the reply restriction? 1 reply a day is so harsh that I cannot give immediate information 1
Werner Posted June 5, 2020 Posted June 5, 2020 3 minutes ago, Ximodel said: As regards bbr, it is not fixed after the upgrade. I would like to provide any help if I can, but ironically, when i ran the following command right after upgrade sudo armbianmonitor -u System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for. "the URL" is disappearing and I don't even know what is going wrong... And would you like to help me with the reply restriction? 1 reply a day is so harsh that I cannot give immediate information You received a 'like', restriction should be gone now. Try armbianmonitor -U (take note the U is large), This will output the stuff directly to console/file. 1
Igor Posted June 5, 2020 Posted June 5, 2020 46 minutes ago, Ximodel said: As regards bbr, it is not fixed after the upgrade. Nobody claimed that. Such service is too expensive which is why we don't provide it yet. If you need this module faster than its our release update cycle, you are on your own. You can also ask someone to provide this update for you ... there are more ways. 46 minutes ago, Ximodel said: when i ran the following command right after upgrade Certain condition has to met: - network connection - 3rd party paste/bin service availability ... bugs are always possible and it takes time before they are addressed. 46 minutes ago, Ximodel said: And would you like to help me with the reply restriction? 1 reply a day is so harsh that I cannot give immediate information We will help you only under our terms and when possible. There are around 1000x too much - users are generating a lot of stress expecting even far better than paid support - of you asking (some dare to demand) for help (100% paid from our own pocket). Limit has its purpose and ofc some colateral damage ... since most of people seek for a free support its better that you wait, then us. Anyway, lots of cases are not resolved since its simply not possible. You are not restricted anymore after 7 days or if you get one like. Which you got.
Ximodel Posted June 10, 2020 Author Posted June 10, 2020 just did apt update && apt upgrade, dignosis below fyi armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/2oQ0 Please post the URL in the forum where you've been asked for. regarding bbr, it is no. Not fixed yet. root@nanopineo2:~# find /lib -name "*tcp*" /lib/modules/5.4.43-sunxi64/kernel/drivers/scsi/libiscsi_tcp.ko /lib/modules/5.4.43-sunxi64/kernel/drivers/scsi/iscsi_tcp.ko /lib/modules/5.4.43-sunxi64/kernel/drivers/usb/typec/tcpm /lib/modules/5.4.43-sunxi64/kernel/drivers/usb/typec/tcpm/tcpci.ko /lib/modules/5.4.43-sunxi64/kernel/drivers/usb/typec/tcpm/tcpm.ko /lib/modules/5.4.43-sunxi64/kernel/drivers/usb/typec/tcpm/tcpci_rt1711h.ko /lib/modules/5.4.43-sunxi64/kernel/drivers/atm/atmtcp.ko /lib/modules/5.4.43-sunxi64/kernel/net/netfilter/xt_tcpudp.ko /lib/modules/5.4.43-sunxi64/kernel/net/netfilter/xt_tcpmss.ko /lib/modules/5.4.43-sunxi64/kernel/net/rds/rds_tcp.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_cdg.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_dctcp.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_yeah.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_highspeed.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_vegas.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_scalable.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_veno.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_htcp.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_illinois.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_lp.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_hybla.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_diag.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_nv.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_westwood.ko /lib/modules/5.4.43-sunxi64/kernel/net/ipv4/tcp_bic.ko In my another device /lib/modules/5.4.20-sunxi64/kernel/drivers/scsi/iscsi_tcp.ko /lib/modules/5.4.20-sunxi64/kernel/drivers/scsi/libiscsi_tcp.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_diag.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_bic.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_scalable.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_dctcp.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_nv.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_hybla.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_highspeed.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_westwood.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_cdg.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_illinois.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_htcp.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_bbr.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_veno.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_lp.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_yeah.ko /lib/modules/5.4.20-sunxi64/kernel/net/ipv4/tcp_vegas.ko /lib/modules/5.4.20-sunxi64/kernel/net/netfilter/xt_tcpmss.ko root@nanopineo2:~# ^C
Werner Posted June 10, 2020 Posted June 10, 2020 4 minutes ago, Ximodel said: regarding bbr, it is no. Not fixed yet. 1
