Jack953 Posted July 8, 2020 Posted July 8, 2020 By defaul armbian should be light so I think it should use LXDE , runit and no pulseaudio
Werner Posted July 10, 2020 Posted July 10, 2020 I think these wishes, besides the DE are out of range for Armbian. Armbian provides a usable kernel for many different boards and puts a OS over it with minimal adjustments to provide a mostly untouched experience with that OS. It is up to you to customize your OS as it is in any other distribution. By the way you can customize it even at image level while building. Check https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-image-customization-script
ning Posted July 10, 2020 Posted July 10, 2020 your question is Armbian should start from scratch, not based on debian?
