What i know orange pi has two microphone option.
1- on board microphone
2 - from audio in out
When i check with arecord -l
i see only one card which is realtek5651
ı have tried voice record with arecord. ı couldnt get any voice.
with usb sound card i can record.
i can listen with on board auido out.
Why i can not get any voice from on board microphone or audio in.?
you can see my alsa values
http://alsa-project.org/db/?f=351ef8f0285ef89eaa267f2b7ff9866f06ef3413
you can see all informations
http://ix.io/2rH8
Edited by asendem
extra information added
Hi, I made a similar topic. Same here. I can't tell if the audio drivers are not finished yet or we just dont know how to...
I hope well get some more info...
Myself.  i am not so professional these things.
If you can show hot to add dts file. May be would be good. or if somebody add this to armbian so we can update.
BY the way when i do cat /proc/asound/modules i got these results below
 0 snd_soc_simple_card
 1 snd_soc_simple_card
  On 7/16/2020 at 11:19 PM, Jack953 said:
With original OS the onboard mic works (not too stable).
Expand
What do you mean with original OS? Where to download?
About microphone . which type microphone need to use to make it work through the jack?
Expand
The one from www.orangepi.org, made in china, and not mainline kernel.
Expand
u have to use earphones+mic that uses a OMTP 3 way jack (today are more common ctia jack). However it didn't worked for me, only onboard.
Hi, I experience issue with built-in microphone on OrangePi4 LTS / Armbian.
I see input devices, but arecord/parec doesn't record anything. I hear nothing when do `aplay output.wav`, but I still hear
paplay /usr/share/sounds/alsa/Front_Right.wav
paplay /usr/share/sounds/alsa/Front_Left.wav
More info
arecord -f cd -D hw:0,0 -d 5 -r 44100 output.wav
aplay output.wav
orangepi4-lts:~:# arecord -l
#**** List of CAPTURE Hardware Devices ****
#card 0: rockchipes8316c [rockchip-es8316c], device 0: ff880000.i2s-ES8316 HiFi ES8316 HiFi-0 [ff880000.i2s-ES8316 HiFi ES8316 HiFi-0]
#  Subdevices: 1/1
# Subdevice #0: subdevice #0
# card 1: hdmisound [hdmi-sound], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 [ff8a0000.i2s-i2s-hifi i2s-hifi-0]
#  Subdevices: 1/1
orangepi4-lts:~:# uname -a
# Linux orangepi4-lts 6.1.30-rockchip64 #3 SMP PREEMPT Wed May 24 16:32:53 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
orangepi4-lts:~:# cat /etc/issue
# Armbian 23.5.1 Jammy \l
pactl list sources | grep "Name:"
# Name: alsa_output.platform-es8316c-card.stereo-fallback.monitor
# Name: alsa_input.platform-es8316c-card.stereo-fallback
# Name: alsa_output.platform-hdmi-sound.stereo-fallback.monitor
device=alsa_input.platform-es8316c-card.stereo-fallback
parec --device ${device} --format=s16le --channels=2 --rate=44100 --file-format=wav output.wav
paplay output.wav
Any suggestions?
Edited by Mr. Fennec
