I am running Armbian Bionic with Linux Linux 5.4.45-sunxi on an OrangePi PC Plus board. It is running HomeAssistant and a small NodeJS service. Everything is working great, however recently some random shutdowns started. I started investigating and here are my findings:
I was unable to SSH or ping the device (it is connected via WIFI) so I connected to the serial pins, but that didn't work either until manual reboot.
/var/log/syslog file starts with
Aug 12 13:17:04 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0
so it looks like the log from before the shutdown disappeared.
last -x command only returns:
ogrevanj ttyS0                         Thu Aug 13 07:52 - down   (00:19)
runlevel (to lvl 5)   5.4.45-sunxi     Wed Aug 12 13:17 - 08:12  (18:55)
reboot   system boot  5.4.45-sunxi     Thu Jan  1 00:00 - 08:12 (18487+08:11)
wtmp begins Thu Jan  1 00:00:19 1970
Checking the HomeAssistant, it looks like the program was running until 13:44 as all charts end at that time. There is no stopping or starting record in the log. There is a spike in CPU utilization chart from 30% to 88% at 13:17, then the CPU utilization returns to 30% and stays there until 13:44. The chart of free memory also spikes at 13:17 from around 800 MB to 867 MB and then returns. The CPU temperature chart shows values between 73 °C and 76 °C, so overheating shouldn't be a problem.
The unattended upgrades package was removed from the system.
Here is the entire /var/log/syslog: https://pastebin.pl/view/b3a82f64
What may be the cause of the shutdown? Is there some other place I can check to find out? Why is neither WIFI nor serial working? Can I add some service or something to catch the bug, next time it happens?
Expand
- unstable power supply
- bad / too long cable causing too big voltage drop
- reaching critical temperature (try different kernel to rule that out)
- something else.
