Hayk Arzumanyan Posted August 28, 2020 Share Posted August 28, 2020 Hello. I have own developed custom boards with H3 processor. One of it works nice, second one doesn't boot. Here is the serial output. U-Boot 2020.04-armbian (Jun 01 2020 - 18:57:23 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: mmc@1c0f000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28000 Out: serial@1c28000 Err: serial@1c28000 Net: phy interface0 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 3 ms (1.2 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 201 bytes read in 2 ms (97.7 KiB/s) 10307086 bytes read in 492 ms (20 MiB/s) 7236216 bytes read in 347 ms (19.9 MiB/s) Found mainline kernel configuration 29463 bytes read in 8 ms (3.5 MiB/s) 4185 bytes read in 9 ms (454.1 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 10307022 Bytes = 9.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 4962b000, end 49fff5ce ... OK Loading Device Tree to 495bb000, end 4962afff ... OK fdt_find_or_add_subnode: memory: FDT_ERR_BADSTRUCTURE ERROR: arch-specific fdt fixup failed - must RESET the board to recover. FDT creation failed! hanging...### ERROR ### Please RESET the board ### Have any suggestions? What is fdt_find_or_add_subnode: memory: FDT_ERR_BADSTRUCTURE ERROR: arch-specific fdt fixup failed?? Link to comment Share on other sites More sharing options...
Igor Posted August 31, 2020 Share Posted August 31, 2020 On 8/28/2020 at 5:24 PM, Hayk Arzumanyan said: I have own developed custom boards with H3 processor Allwinner H3 sub-forum is dedicated to board we know and we decide to support. Moving to general areas. Link to comment Share on other sites More sharing options...
Hayk Arzumanyan Posted August 31, 2020 Author Share Posted August 31, 2020 My boards are 1:1 copy of Orange Pi One. It's not unknown board. And Armbian is Buster server stable version from https://www.armbian.com/orange-pi-one/ Link to comment Share on other sites More sharing options...
Werner Posted August 31, 2020 Share Posted August 31, 2020 42 minutes ago, Hayk Arzumanyan said: 1:1 copy If that would be true it would boot just fine and I have several OrangePi One SBCs laying around at my space Link to comment Share on other sites More sharing options...
Hayk Arzumanyan Posted August 31, 2020 Author Share Posted August 31, 2020 Werner it's true. I'm not here to lie ))) I'm not asking what do you have. I'm asking do you know FDT creation failed problem what does it mean??? I haven't only these two boards. I have a lot of 1:1 copy Orange Pi One boards they boot fine. Only in one board it happens. And I don't understand FDT creation failed it's RAM or H3 processor problem. Link to comment Share on other sites More sharing options...
Werner Posted August 31, 2020 Share Posted August 31, 2020 I serioulsy don't wanted to imply you are lying. Heaven forbid! For the issue itself I unfortunately cannot answer your question since I don't know how and why this happens. However Igor is right anyways. it is a board that is not supported since it is custom made so it is correct to move the topic to general discussion / p2p help. Link to comment Share on other sites More sharing options...
Igor Posted August 31, 2020 Share Posted August 31, 2020 59 minutes ago, Hayk Arzumanyan said: 1:1 copy of Orange Pi One. It's not unknown board Scheme is the same - is PCB also 100% identical? Link to comment Share on other sites More sharing options...
Hayk Arzumanyan Posted August 31, 2020 Author Share Posted August 31, 2020 Yes, it's identical. 10 times checked. Link to comment Share on other sites More sharing options...
