micho Posted September 15, 2020 Share Posted September 15, 2020 Hello, I have used NanoPi M4v2 with "NVMe SSD adapter" (Officially sold by the FriendlyElec). NVMe SSD is detected when I installed ubuntu based kernel 4.4. (FriendlyCore 18.04 or Armbian Bionic desktop based kernal 4.4.y) But When I installed armbian based kernel 5.x, NVMe SSD is not detected. Anyone can advise? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 15, 2020 Share Posted September 15, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. RK3399 is known to have best support with kernel 4.4.x atm. 0 Quote Link to comment Share on other sites More sharing options...
micho Posted September 15, 2020 Author Share Posted September 15, 2020 Thank you for your attention. I installed the latest armbian (focal, kernel 5.8.6) to upload logs. And nvme ssd was detected!! I tested the other images (kernel 5.7.15 and 5.4.46). All versions worked fine. I can't explain why this happened. I'm just guessing it might be a compatibility problem with nvme ssd. I'm sorry for the confusion to you. 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted October 16, 2020 Share Posted October 16, 2020 I’m on 5.8.14 and my nvme is not detected.... It was working fine till I updated to that kernel version The logs are uploaded to http://ix.io/2ATb Many thanks.... 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted October 16, 2020 Share Posted October 16, 2020 Could be a power supply issue? jsalas@nanoserver:~$ dmesg | grep -i pci [ 0.008528] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 1.483641] PCI: CLS 0 bytes, default 64 [ 2.709362] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 2.771099] ehci-pci: EHCI PCI platform driver [ 2.804225] ohci-pci: OHCI PCI platform driver [ 3.208966] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 3.734680] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 3.735230] rockchip-pcie: probe of f8000000.pcie failed with error -110 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted October 16, 2020 Share Posted October 16, 2020 Well clearly is not a power issue. I've installed 4.4 kernel and worked root@nanopct4:~# dmesg | grep -i pcie [ 1.958739] phy phy-pcie-phy.5: Looking up phy-supply from device tree [ 1.958752] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie-phy failed [ 1.961110] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [ 1.961124] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [ 1.961156] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0) [ 1.961403] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [ 1.961416] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed [ 1.961433] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 1.961443] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [ 1.961531] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [ 1.961546] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 1.961556] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [ 1.961567] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [ 1.961581] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 1.961591] rockchip-pcie f8000000.pcie: no bus-scan-delay-ms in device tree, default 0 ms [ 1.961601] rockchip-pcie f8000000.pcie: missing "memory-region" property [ 1.961617] PCI host bridge /pcie@f8000000 ranges: [ 2.106173] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.113740] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 2.114038] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 2.114051] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 2.114067] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded [ 2.114204] aer 0000:00:00.0:pcie02: service driver aer loaded root@nanopct4:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.4G 0 part mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk mmcblk1rpmb 179:96 0 4M 0 disk mmcblk0 179:128 0 7.5G 0 disk └─mmcblk0p1 179:129 0 7.3G 0 part / zram0 252:0 0 50M 0 disk /var/log zram1 252:1 0 1G 0 disk [SWAP] zram2 252:2 0 1G 0 disk /tmp nvme0n1 259:0 0 931.5G 0 disk ├─nvme0n1p1 259:1 0 450G 0 part ├─nvme0n1p2 259:2 0 400G 0 part └─nvme0n1p3 259:3 0 81.5G 0 part 0 Quote Link to comment Share on other sites More sharing options...
aprayoga Posted November 12, 2020 Share Posted November 12, 2020 @i5Js maybe similar issue with the one we encounter on Helios64. The PCIe SATA controller failed in PCIe Gen1 training if Linux kernel do a reset through ep-gpio. you can try to remove ep-gpios on nano pi device tree like in this commit: https://github.com/armbian/build/pull/2213/files#diff-f8fb8dd7f6933c824a8b57561c4ed874d35aae33928cc1b5c797ae5d035a3cddR19 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted January 21, 2021 Share Posted January 21, 2021 Sorry to bump this topic again, I'm trying to use kernel 5 in my nanopc-t4, but is still not detecting the nvme. How can I apply that patch? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted January 21, 2021 Share Posted January 21, 2021 I’ve tried with the kernel 5.10.0-RC7, and It’s detected again.... I would like to know which are the differences with the stable kernel :) 0 Quote Link to comment Share on other sites More sharing options...
Viper Posted February 18, 2021 Share Posted February 18, 2021 I have experienced exactly the same issue on a NanoPC T4. Switching back to an older kernel solved the problem, so it is clearly something recently introduced. I hope that we will get it fixed. 0 Quote Link to comment Share on other sites More sharing options...
i5Js Posted February 24, 2021 Share Posted February 24, 2021 Now it's working with kernel 5.10.12 i5Js@noldork3sN2:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk2 179:0 0 14.6G 0 disk └─mmcblk2p1 179:1 0 14.4G 0 part / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk zram0 252:0 0 1.9G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log nvme0n1 259:0 0 465.8G 0 disk 0 Quote Link to comment Share on other sites More sharing options...
molodye Posted November 3, 2023 Share Posted November 3, 2023 On 10/16/2020 at 3:34 PM, i5Js said: I’m on 5.8.14 and my nvme is not detected.... It was working fine till I updated to that kernel version The logs are uploaded to http://ix.io/2ATb Many thanks.... I have encounter the same problem on my nanopc 4 with bookworm 6.1.30. 0 Quote Link to comment Share on other sites More sharing options...
molodye Posted November 4, 2023 Share Posted November 4, 2023 On 2/25/2021 at 1:00 AM, i5Js said: Now it's working with kernel 5.10.12 hi,friend. i wonder to know have you tested the armbian 23.81 bookworm 6.1.50 wether the m2 nvme ssd works well? 0 Quote Link to comment Share on other sites More sharing options...
barbaar Posted January 2 Share Posted January 2 Hi all, best wishes and a better new year 2024. I gave it a try with 6+ Kernels. Unfortunately none worked. With latest version even USB Keyboard didn't work. As I have not enough skills to experiment with kernel-building I would appreciate some help. I could make free one Nanopi M4 V2 for testing. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted January 3 Share Posted January 3 I think @NicoD has or had an M4V2. Maybe they can help testing. 0 Quote Link to comment Share on other sites More sharing options...
barbaar Posted January 16 Share Posted January 16 Meanwhile I tested latest 5.15 and 5.10 Kernel with the result that NVME didn't show up in lsblk. Hopin NicoD will help. 0 Quote Link to comment Share on other sites More sharing options...
