Daniele Posted September 18, 2020 Posted September 18, 2020 Hi, I have and Orange Pi PC board on which I'm trying to use Armbian from yestarday, "trying" because I have several different problems on which I investigated also on this forum, but I'm unable to solve at the moment (the reason because I'm writing here). Let's start from the beginning. I downloaded the armbian image from armbian website (https://www.armbian.com/orange-pi-pc/), version I'm using now is Armbian 20.08.1 Buster with Linux 5.8.5-sunxi, but I have tried also other versions with exact same behaviour. The first problem is time synchronization root@orangepipc:~# timedatectl Local time: Thu 2020-09-03 16:34:17 CEST Universal time: Thu 2020-09-03 14:34:17 UTC RTC time: Thu 1970-01-01 07:54:18 Time zone: Europe/Rome (CEST, +0200) System clock synchronized: no NTP service: inactive RTC in local TZ: no In this forum I found that a possible solution could be uninstall/install chrony, but if I'm able to remove this I'm not able to reinstall root@orangepipc:~# apt install chrony Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: chrony 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 216 kB of archives. After this operation, 397 kB of additional disk space will be used. Err:1 http://deb.debian.org/debian buster/main armhf chrony armhf 3.4-4 Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to deb.debian.org:80 (151.101.114.133). - connect (111: Connection refused) E: Failed to fetch http://deb.debian.org/debian/pool/main/c/chrony/chrony_3.4-4_armhf.deb Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to deb.debian.org:80 (151.101.114.133). - connect (111: Connection refused) E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? In general I'm not able to use apt at all... root@orangepipc:~# apt update Err:1 http://apt.armbian.com buster InRelease Could not connect to apt.armbian.com:80 (173.45.128.12). - connect (111: Connection refused) Err:2 http://security.debian.org buster/updates InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.192.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.0.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.64.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.128.204). - connect (111: Connection refused) Err:3 http://deb.debian.org/debian buster InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to deb.debian.org:80 (151.101.114.133). - connect (111: Connection refused) Err:4 http://deb.debian.org/debian buster-updates InRelease Unable to connect to deb.debian.org:http: Err:5 http://deb.debian.org/debian buster-backports InRelease Unable to connect to deb.debian.org:http: Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. W: Failed to fetch http://deb.debian.org/debian/dists/buster/InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to deb.debian.org:80 (151.101.114.133). - connect (111: Connection refused) W: Failed to fetch http://deb.debian.org/debian/dists/buster-updates/InRelease Unable to connect to deb.debian.org:http: W: Failed to fetch http://deb.debian.org/debian/dists/buster-backports/InRelease Unable to connect to deb.debian.org:http: W: Failed to fetch http://security.debian.org/dists/buster/updates/InRelease Could not connect to prod.debian.map.fastly.net:80 (151.101.112.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.192.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.0.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.64.204). - connect (111: Connection refused) Could not connect to security.debian.org:80 (151.101.128.204). - connect (111: Connection refused) W: Failed to fetch http://apt.armbian.com/dists/buster/InRelease Could not connect to apt.armbian.com:80 (173.45.128.12). - connect (111: Connection refused) W: Some index files failed to download. They have been ignored, or old ones used instead. root@orangepipc:~# DNS resolution and ping of the server to which apt is unable to connect are working fine root@orangepipc:~# ping deb.debian.org PING debian.map.fastly.net (151.101.114.133) 56(84) bytes of data. 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=1 ttl=52 time=36.8 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=2 ttl=52 time=37.4 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=3 ttl=52 time=37.2 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=4 ttl=52 time=38.0 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=5 ttl=52 time=37.6 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=6 ttl=52 time=36.8 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=7 ttl=52 time=38.7 ms ^X64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=8 ttl=52 time=37.3 ms 64 bytes from 151.101.114.133 (151.101.114.133): icmp_seq=9 ttl=52 time=36.5 ms ^C --- debian.map.fastly.net ping statistics --- 9 packets transmitted, 9 received, 0% packet loss, time 20ms rtt min/avg/max/mdev = 36.540/37.377/38.687/0.623 ms If i put url http://deb.debian.org/debian/dists/buster/InRelease in web browser it's working, so the problem is not server unavailability. I don't have trouble with my LAN root@orangepipc:~# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 172.20.0.195 netmask 255.255.255.0 broadcast 172.20.0.255 ether 02:81:ab:f8:f0:eb txqueuelen 1000 (Ethernet) RX packets 279682 bytes 22254870 (21.2 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 2114 bytes 213315 (208.3 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 38 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 loop txqueuelen 1000 (Local Loopback) RX packets 1 bytes 29 (29.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1 bytes 29 (29.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 I have also problem using GPIO but it's a secondary trouble for the moment. I do not know what to do, I need help because in this way Armbian is useless on my board. Thanks in advance, Daniele.
Daniele Posted September 18, 2020 Author Posted September 18, 2020 (edited) Obviously also armbianmonitor is not able to connect to external host root@orangepipc:~# armbianmonitor -u System diagnosis information will now be uploaded to curl: (7) Failed to connect to ix.io port 80: Connection refused Please post the URL in the forum where you've been asked for. This is response of armbianmonitor -U command Reveal hidden contents 1 2 ### Activated 1 lzo-rle zram swap devices with 499 MB each 3 4 ### Activated Armbian ramlog partition with zstd compression 5 6 ### Activated lzo-rle compressed /tmp 7 8 Thu 03 Sep 2020 06:41:05 AM UTC | Orange Pi PC | 20.08.1 | armhf | armv7l | 5.8.5-sunxi 9 10 ### dmesg: 11 12 [ 0.000000] Booting Linux on physical CPU 0x0 13 [ 0.000000] Linux version 5.8.5-sunxi (root@desktop) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) XXX.XXX.1.20191209) #20.08.1 SMP Wed Sep 2 08:03:45 CEST 2020 14 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d 15 [ 0.000000] CPU: div instructions available: patching division code 16 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 17 [ 0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC 18 [ 0.000000] Memory policy: Data cache writealloc 19 [ 0.000000] cma: Reserved 128 MiB at 0x77c00000 20 [ 0.000000] Zone ranges: 21 [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] 22 [ 0.000000] HighMem [mem 0x0000000070000000-0x000000007fffffff] 23 [ 0.000000] Movable zone start for each node 24 [ 0.000000] Early memory node ranges 25 [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff] 26 [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] 27 [ 0.000000] On node 0 totalpages: 262144 28 [ 0.000000] Normal zone: 1728 pages used for memmap 29 [ 0.000000] Normal zone: 0 pages reserved 30 [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 31 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 32 [ 0.000000] psci: probing for conduit method from DT. 33 [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT 34 [ 0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920 35 [ 0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096 36 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 37 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 38 [ 0.000000] Kernel command line: root=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=5d748697-01 ubootsource=mmc usb-storage.quirks= sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 39 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) 40 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) 41 [ 0.000000] allocated 1048576 bytes of page_ext 42 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 43 [ 0.000000] Memory: 880656K/1048576K available (9216K kernel code, 1002K rwdata, 3268K rodata, 1024K init, 327K bss, 36848K reserved, 131072K cma-reserved, 131060K highmem) 44 [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 with crng_init=0 45 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 46 [ 0.000000] ftrace: allocating 39954 entries in 79 pages 47 [ 0.000000] ftrace: allocated 79 pages with 5 groups 48 [ 0.000000] rcu: Hierarchical RCU implementation. 49 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. 50 [ 0.000000] Rude variant of Tasks RCU enabled. 51 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 52 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 53 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 54 [ 0.000000] GIC: Using split EOI/Deactivate mode 55 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns 56 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 57 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 58 [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 59 [ 0.000014] Switching to timer-based delay loop, resolution 41ns 60 [ 0.000236] Console: colour dummy device 80x30 61 [ 0.000250] printk: console [tty1] enabled 62 [ 0.000301] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 63 [ 0.000311] pid_max: default: 32768 minimum: 301 64 [ 0.000518] LSM: Security Framework initializing 65 [ 0.000574] Yama: becoming mindful. 66 [ 0.000717] AppArmor: AppArmor initialized 67 [ 0.000781] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 68 [ 0.000793] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 69 [ 0.001834] CPU: Testing write buffer coherency: ok 70 [ 0.002191] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 71 [ 0.002731] Setting up static identity map for 0x40100000 - 0x40100054 72 [ 0.002850] rcu: Hierarchical SRCU implementation. 73 [ 0.006021] smp: Bringing up secondary CPUs ... 74 [ 0.016778] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 75 [ 0.027632] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 76 [ 0.038418] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 77 [ 0.038520] smp: Brought up 1 node, 4 CPUs 78 [ 0.038529] SMP: Total of 4 processors activated (192.00 BogoMIPS). 79 [ 0.038532] CPU: All CPU(s) started in HYP mode. 80 [ 0.038534] CPU: Virtualization extensions available. 81 [ 0.039465] devtmpfs: initialized 82 [ 0.046574] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 83 [ 0.046912] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 84 [ 0.046951] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) 85 [ 0.051507] xor: measuring software checksum speed 86 [ 0.090397] arm4regs : 1255.000 MB/sec 87 [ 0.130458] 8regs : 874.000 MB/sec 88 [ 0.170525] 32regs : 826.000 MB/sec 89 [ 0.210589] neon : 1271.000 MB/sec 90 [ 0.210594] xor: using function: neon (1271.000 MB/sec) 91 [ 0.210658] pinctrl core: initialized pinctrl subsystem 92 [ 0.211140] thermal_sys: Registered thermal governor 'fair_share' 93 [ 0.211144] thermal_sys: Registered thermal governor 'bang_bang' 94 [ 0.211149] thermal_sys: Registered thermal governor 'step_wise' 95 [ 0.212174] NET: Registered protocol family 16 96 [ 0.213716] DMA: preallocated 256 KiB pool for atomic coherent allocations 97 [ 0.214180] audit: initializing netlink subsys (disabled) 98 [ 0.214391] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1 99 [ 0.215021] cpuidle: using governor ladder 100 [ 0.215147] cpuidle: using governor menu 101 [ 0.215656] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 102 [ 0.215661] hw-breakpoint: maximum watchpoint size is 8 bytes. 103 [ 0.237563] cryptd: max_cpu_qlen set to 1000 104 [ 0.306813] raid6: neonx8 gen() 775 MB/s 105 [ 0.374885] raid6: neonx8 xor() 580 MB/s 106 [ 0.442977] raid6: neonx4 gen() 830 MB/s 107 [ 0.511064] raid6: neonx4 xor() 629 MB/s 108 [ 0.579144] raid6: neonx2 gen() 915 MB/s 109 [ 0.647220] raid6: neonx2 xor() 652 MB/s 110 [ 0.715330] raid6: neonx1 gen() 816 MB/s 111 [ 0.783398] raid6: neonx1 xor() 565 MB/s 112 [ 0.851539] raid6: int32x8 gen() 303 MB/s 113 [ 0.919604] raid6: int32x8 xor() 176 MB/s 114 [ 0.987691] raid6: int32x4 gen() 357 MB/s 115 [ 1.055779] raid6: int32x4 xor() 205 MB/s 116 [ 1.123864] raid6: int32x2 gen() 399 MB/s 117 [ 1.191974] raid6: int32x2 xor() 213 MB/s 118 [ 1.260059] raid6: int32x1 gen() 390 MB/s 119 [ 1.328120] raid6: int32x1 xor() 192 MB/s 120 [ 1.328124] raid6: using algorithm neonx2 gen() 915 MB/s 121 [ 1.328127] raid6: .... xor() 652 MB/s, rmw enabled 122 [ 1.328131] raid6: using neon recovery algorithm 123 [ 1.329422] iommu: Default domain type: Translated 124 [ 1.329780] SCSI subsystem initialized 125 [ 1.330002] libata version 3.00 loaded. 126 [ 1.330231] usbcore: registered new interface driver usbfs 127 [ 1.330279] usbcore: registered new interface driver hub 128 [ 1.330342] usbcore: registered new device driver usb 129 [ 1.330430] mc: Linux media interface: v0.10 130 [ 1.330468] videodev: Linux video capture interface: v2.00 131 [ 1.330590] pps_core: LinuxPPS API ver. 1 registered 132 [ 1.330594] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 133 [ 1.330610] PTP clock support registered 134 [ 1.330964] Advanced Linux Sound Architecture Driver Initialized. 135 [ 1.331631] NetLabel: Initializing 136 [ 1.331637] NetLabel: domain hash size = 128 137 [ 1.331639] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 138 [ 1.331714] NetLabel: unlabeled traffic allowed by default 139 [ 1.332398] clocksource: Switched to clocksource arch_sys_counter 140 [ 1.426278] VFS: Disk quotas dquot_6.6.0 141 [ 1.426367] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 142 [ 1.426953] AppArmor: AppArmor Filesystem Enabled 143 [ 1.434982] NET: Registered protocol family 2 144 [ 1.435696] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) 145 [ 1.435738] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) 146 [ 1.435831] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) 147 [ 1.435943] TCP: Hash tables configured (established 8192 bind 8192) 148 [ 1.436078] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) 149 [ 1.436130] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) 150 [ 1.436411] NET: Registered protocol family 1 151 [ 1.436829] Trying to unpack rootfs image as initramfs... 152 [ 2.092345] Freeing initrd memory: 9672K 153 [ 2.093706] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 154 [ 2.094835] Initialise system trusted keyrings 155 [ 2.094887] Key type blacklist registered 156 [ 2.095113] workingset: timestamp_bits=14 max_order=18 bucket_order=4 157 [ 2.100667] zbud: loaded 158 [ 2.102086] squashfs: version 4.0 (2009/01/31) Phillip Lougher 159 [ 2.103043] fuse: init (API version 7.31) 160 [ 2.105621] integrity: Platform Keyring initialized 161 [ 2.214191] Key type asymmetric registered 162 [ 2.214198] Asymmetric key parser 'x509' registered 163 [ 2.214364] bounce: pool size: 64 pages 164 [ 2.214434] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 165 [ 2.214630] io scheduler mq-deadline registered 166 [ 2.214636] io scheduler kyber registered 167 [ 2.214797] io scheduler bfq registered 168 [ 2.220547] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver 169 [ 2.222237] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver 170 [ 2.229020] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 171 [ 2.231302] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator 172 [ 2.231717] printk: console [ttyS0] disabled 173 [ 2.231800] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a 16550A 174 [ 2.231866] printk: console [ttyS0] enabled 175 [ 2.247537] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a9f100) 176 [ 2.247833] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9c000) 177 [ 2.247898] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator 178 [ 2.248822] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) 179 [ 2.249253] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver 180 [ 2.249519] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a9e6fc) 181 [ 2.249528] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 182 [ 2.249960] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 183 [ 2.355272] random: fast init done 184 [ 2.606030] Console: switching to colour frame buffer device 160x45 185 [ 2.678679] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device 186 [ 2.682273] brd: module loaded 187 [ 2.689159] loop: module loaded 188 [ 2.691218] libphy: Fixed MDIO Bus: probed 189 [ 2.691725] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found 190 [ 2.691733] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found 191 [ 2.691858] dwmac-sun8i 1c30000.ethernet: PTP uses main clock 192 [ 2.691905] dwmac-sun8i 1c30000.ethernet: supply phy not found, using dummy regulator 193 [ 2.691985] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator 194 [ 2.692347] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) 195 [ 2.692366] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported 196 [ 2.692423] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported 197 [ 2.692430] dwmac-sun8i 1c30000.ethernet: COE Type 2 198 [ 2.692436] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported 199 [ 2.692442] dwmac-sun8i 1c30000.ethernet: Normal descriptors 200 [ 2.692448] dwmac-sun8i 1c30000.ethernet: Chain mode enabled 201 [ 2.692948] libphy: stmmac: probed 202 [ 2.693502] dwmac-sun8i 1c30000.ethernet: Found internal PHY node 203 [ 2.693926] libphy: mdio_mux: probed 204 [ 2.693949] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY 205 [ 2.693958] dwmac-sun8i 1c30000.ethernet: Powering internal PHY 206 [ 2.707056] libphy: mdio_mux: probed 207 [ 2.708171] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 208 [ 2.708232] ehci-platform: EHCI generic platform driver 209 [ 2.708501] ehci-platform 1c1a000.usb: EHCI Host Controller 210 [ 2.708541] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 211 [ 2.708961] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 212 [ 2.724396] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 213 [ 2.724665] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 214 [ 2.724673] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 215 [ 2.724680] usb usb1: Product: EHCI Host Controller 216 [ 2.724686] usb usb1: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 217 [ 2.724692] usb usb1: SerialNumber: 1c1a000.usb 218 [ 2.725280] hub 1-0:1.0: USB hub found 219 [ 2.725321] hub 1-0:1.0: 1 port detected 220 [ 2.726213] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 221 [ 2.726237] ohci-platform: OHCI generic platform driver 222 [ 2.726412] ohci-platform 1c1a400.usb: Generic Platform OHCI controller 223 [ 2.726435] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 224 [ 2.726618] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 225 [ 2.788589] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 226 [ 2.788597] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 227 [ 2.788604] usb usb2: Product: Generic Platform OHCI controller 228 [ 2.788611] usb usb2: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 229 [ 2.788616] usb usb2: SerialNumber: 1c1a400.usb 230 [ 2.789146] hub 2-0:1.0: USB hub found 231 [ 2.789184] hub 2-0:1.0: 1 port detected 232 [ 2.790553] usbcore: registered new interface driver usb-storage 233 [ 2.791594] sun6i-rtc 1f00000.rtc: registered as rtc0 234 [ 2.791635] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:11 UTC (11) 235 [ 2.791641] sun6i-rtc 1f00000.rtc: RTC enabled 236 [ 2.791951] i2c /dev entries driver 237 [ 2.792300] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator 238 [ 2.794516] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) 239 [ 2.794945] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator 240 [ 2.795705] sunxi-mmc 1c0f000.mmc: Got CD GPIO 241 [ 2.821010] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB 242 [ 2.822197] ledtrig-cpu: registered to indicate activity on CPUs 243 [ 2.822265] hid: raw HID events driver (C) Jiri Kosina 244 [ 2.822389] usbcore: registered new interface driver usbhid 245 [ 2.822391] usbhid: USB HID core driver 246 [ 2.826432] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present! 247 [ 2.827763] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok 248 [ 2.830528] Initializing XFRM netlink socket 249 [ 2.831052] NET: Registered protocol family 10 250 [ 2.859768] mmc0: host does not support reading read-only switch, assuming write-enable 251 [ 2.861758] mmc0: new high speed SDHC card at address 0001 252 [ 2.863323] mmcblk0: mmc0:0001 SD16G 29.2 GiB 253 [ 2.867026] mmcblk0: p1 254 [ 2.878833] Segment Routing with IPv6 255 [ 2.878950] NET: Registered protocol family 17 256 [ 2.878982] NET: Registered protocol family 15 257 [ 2.879069] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 258 [ 2.879200] 8021q: 802.1Q VLAN Support v1.8 259 [ 2.879262] Key type dns_resolver registered 260 [ 2.879710] Registering SWP/SWPB emulation handler 261 [ 2.880013] registered taskstats version 1 262 [ 2.880021] Loading compiled-in X.509 certificates 263 [ 2.886721] Loaded X.509 cert 'Build time autogenerated kernel key: 346848ecd67c995d675bab6785bece621761b48f' 264 [ 2.886905] zswap: loaded using pool lzo/zbud 265 [ 2.887570] Key type ._fscrypt registered 266 [ 2.887575] Key type .fscrypt registered 267 [ 2.887579] Key type fscrypt-provisioning registered 268 [ 2.892804] Btrfs loaded, crc32c=crc32c-generic 269 [ 2.915026] Key type encrypted registered 270 [ 2.915046] AppArmor: AppArmor sha1 policy hashing enabled 271 [ 2.926653] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator 272 [ 2.928175] ehci-platform 1c1b000.usb: EHCI Host Controller 273 [ 2.928203] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 274 [ 2.928730] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 275 [ 2.944399] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 276 [ 2.944715] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 277 [ 2.944724] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 278 [ 2.944730] usb usb3: Product: EHCI Host Controller 279 [ 2.944737] usb usb3: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 280 [ 2.944743] usb usb3: SerialNumber: 1c1b000.usb 281 [ 2.945354] hub 3-0:1.0: USB hub found 282 [ 2.945395] hub 3-0:1.0: 1 port detected 283 [ 2.946284] ehci-platform 1c1c000.usb: EHCI Host Controller 284 [ 2.946309] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 285 [ 2.946610] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 286 [ 2.960416] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 287 [ 2.960662] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 288 [ 2.960671] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 289 [ 2.960677] usb usb4: Product: EHCI Host Controller 290 [ 2.960684] usb usb4: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 291 [ 2.960689] usb usb4: SerialNumber: 1c1c000.usb 292 [ 2.961199] hub 4-0:1.0: USB hub found 293 [ 2.961239] hub 4-0:1.0: 1 port detected 294 [ 2.962032] ehci-platform 1c1d000.usb: EHCI Host Controller 295 [ 2.962056] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 296 [ 2.962349] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 297 [ 2.976413] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 298 [ 2.976642] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 299 [ 2.976650] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 300 [ 2.976656] usb usb5: Product: EHCI Host Controller 301 [ 2.976662] usb usb5: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 302 [ 2.976668] usb usb5: SerialNumber: 1c1d000.usb 303 [ 2.977180] hub 5-0:1.0: USB hub found 304 [ 2.977218] hub 5-0:1.0: 1 port detected 305 [ 2.978004] ohci-platform 1c1b400.usb: Generic Platform OHCI controller 306 [ 2.978028] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 307 [ 2.978216] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 308 [ 3.040585] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 309 [ 3.040593] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 310 [ 3.040599] usb usb6: Product: Generic Platform OHCI controller 311 [ 3.040606] usb usb6: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 312 [ 3.040611] usb usb6: SerialNumber: 1c1b400.usb 313 [ 3.041106] hub 6-0:1.0: USB hub found 314 [ 3.041153] hub 6-0:1.0: 1 port detected 315 [ 3.041960] ohci-platform 1c1c400.usb: Generic Platform OHCI controller 316 [ 3.041982] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 317 [ 3.042205] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 318 [ 3.104572] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 319 [ 3.104581] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 320 [ 3.104587] usb usb7: Product: Generic Platform OHCI controller 321 [ 3.104594] usb usb7: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 322 [ 3.104599] usb usb7: SerialNumber: 1c1c400.usb 323 [ 3.105134] hub 7-0:1.0: USB hub found 324 [ 3.105171] hub 7-0:1.0: 1 port detected 325 [ 3.105951] ohci-platform 1c1d400.usb: Generic Platform OHCI controller 326 [ 3.105974] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 327 [ 3.106197] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 328 [ 3.168575] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 329 [ 3.168584] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 330 [ 3.168591] usb usb8: Product: Generic Platform OHCI controller 331 [ 3.168598] usb usb8: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 332 [ 3.168603] usb usb8: SerialNumber: 1c1d400.usb 333 [ 3.169127] hub 8-0:1.0: USB hub found 334 [ 3.169162] hub 8-0:1.0: 1 port detected 335 [ 3.170832] of_cfs_init 336 [ 3.170957] of_cfs_init: OK 337 [ 3.171105] ALSA device list: 338 [ 3.171112] #0: H3 Audio Codec 339 [ 3.175032] Freeing unused kernel memory: 1024K 340 [ 3.184766] Run /init as init process 341 [ 3.184774] with arguments: 342 [ 3.184819] /init 343 [ 3.184822] with environment: 344 [ 3.184826] HOME=/ 345 [ 3.184829] TERM=linux 346 [ 3.184832] ubootpart=5d748697-01 347 [ 3.184835] ubootsource=mmc 348 [ 3.184839] sunxi_ve_mem_reserve=0 349 [ 3.184842] sunxi_g2d_mem_reserve=0 350 [ 3.184845] sunxi_fb_mem_reserve=16 351 [ 3.184848] cgroup_enable=memory 352 [ 3.185280] process '/usr/bin/sh' started with executable stack 353 [ 3.544722] usb 6-1: new low-speed USB device number 2 using ohci-platform 354 [ 3.564442] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 355 [ 3.568843] usb 8-1: new low-speed USB device number 2 using ohci-platform 356 [ 3.626295] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator 357 [ 3.628129] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver 358 [ 3.628161] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9 359 [ 3.628233] phy id_det change to device 360 [ 3.628589] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 361 [ 3.628600] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 362 [ 3.628607] usb usb9: Product: MUSB HDRC host driver 363 [ 3.628613] usb usb9: Manufacturer: Linux 5.8.5-sunxi musb-hcd 364 [ 3.628620] usb usb9: SerialNumber: musb-hdrc.4.auto 365 [ 3.629381] hub 9-0:1.0: USB hub found 366 [ 3.629434] hub 9-0:1.0: 1 port detected 367 [ 3.772527] usb 6-1: New USB device found, idVendor=046d, idProduct=c517, bcdDevice=38.10 368 [ 3.772541] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 369 [ 3.772548] usb 6-1: Product: USB Receiver 370 [ 3.772554] usb 6-1: Manufacturer: Logitech 371 [ 3.781886] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C517.0001/input/input1 372 [ 3.840737] hid-generic 0003:046D:C517.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 373 [ 3.850498] usb 8-1: New USB device found, idVendor=04f3, idProduct=0234, bcdDevice=24.58 374 [ 3.850517] usb 8-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 375 [ 3.850525] usb 8-1: Product: OM 376 [ 3.852234] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input2 377 [ 3.852560] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input3 378 [ 3.859316] input: OM as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:04F3:0234.0003/input/input7 379 [ 3.912668] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input4 380 [ 3.912678] hid-generic 0003:04F3:0234.0003: input,hidraw1: USB HID v1.11 Mouse [OM] on usb-1c1d400.usb-1/input0 381 [ 3.913164] hid-generic 0003:046D:C517.0002: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 382 [ 3.966068] logitech-djreceiver 0003:046D:C517.0001: hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 383 [ 4.067196] logitech-djreceiver 0003:046D:C517.0002: hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 384 [ 4.144497] logitech-djreceiver 0003:046D:C517.0002: device of type 27 Mhz (0x02) connected on slot 3 385 [ 4.147351] input: Logitech Wireless Keyboard PID:0062 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input8 386 [ 4.147593] input: Logitech Wireless Keyboard PID:0062 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input9 387 [ 4.147736] input: Logitech Wireless Keyboard PID:0062 System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input10 388 [ 4.147980] hid-generic 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 389 [ 4.248500] logitech-hidpp-device 0003:046D:0062.0004: HID++ 1.0 device connected. 390 [ 4.298436] input: Logitech Wireless Keyboard PID:0062 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input14 391 [ 4.298701] logitech-hidpp-device 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 392 [ 4.700779] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 393 [ 5.499589] systemd[1]: System time before build time, advancing clock. 394 [ 5.524530] systemd[1]: Inserted module 'autofs4' 395 [ 5.590335] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 396 [ 5.591083] systemd[1]: Detected architecture arm. 397 [ 5.627772] systemd[1]: Set hostname to <orangepipc>. 398 [ 6.219879] systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring 399 [ 6.231609] systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring 400 [ 6.370984] random: systemd: uninitialized urandom read (16 bytes read) 401 [ 6.385458] random: systemd: uninitialized urandom read (16 bytes read) 402 [ 6.386497] systemd[1]: Listening on Journal Socket (/dev/log). 403 [ 6.387784] random: systemd: uninitialized urandom read (16 bytes read) 404 [ 6.388551] systemd[1]: Listening on Journal Socket. 405 [ 6.398926] systemd[1]: Starting Restore / save the current clock... 406 [ 6.409333] systemd[1]: Starting Load Kernel Modules... 407 [ 6.411549] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. 408 [ 6.535153] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 409 [ 7.910848] zram: Added device: zram0 410 [ 7.914686] zram: Added device: zram1 411 [ 7.915379] zram: Added device: zram2 412 [ 8.023956] sun8i-di 1400000.deinterlace: Device registered as /dev/video0 413 [ 8.026596] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 414 [ 8.036874] cedrus 1c0e000.video-codec: Device registered as /dev/video1 415 [ 8.061842] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz) 416 [ 8.071140] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 417 [ 8.076566] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 418 [ 8.081084] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 419 [ 8.098088] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 420 [ 8.098749] sun8i-ce 1c15000.crypto: Register cbc(aes) 421 [ 8.116616] sun8i-ce 1c15000.crypto: Register ecb(aes) 422 [ 8.118581] sun8i-ce 1c15000.crypto: Register cbc(des3_ede) 423 [ 8.118802] sun8i-ce 1c15000.crypto: Register ecb(des3_ede) 424 [ 8.118967] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1 425 [ 8.120921] zram1: detected capacity change from 0 to 523481088 426 [ 8.231759] sun8i-thermal 1c25000.thermal-sensor: Thermal sensor ready! 427 [ 8.364627] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 428 [ 8.364685] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 429 [ 8.364735] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 430 [ 8.364771] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 431 [ 8.371505] Registered IR keymap rc-empty 432 [ 8.371626] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 433 [ 8.371836] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter 434 [ 8.371985] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input15 435 [ 8.372545] sunxi-ir 1f02000.ir: initialized sunXi IR driver 436 [ 8.393012] mousedev: PS/2 mouse device common for all mice 437 [ 8.400748] lima 1c40000.gpu: bus rate = 200000000 438 [ 8.400757] lima 1c40000.gpu: mod rate = 297000000 439 [ 8.400872] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 440 [ 8.401352] lima 1c40000.gpu: Failed to register cooling device 441 [ 8.401787] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1 442 [ 8.725777] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok 443 [ 9.212615] Adding 511208k swap on /dev/zram1. Priority:5 extents:1 across:511208k SSFS 444 [ 9.373958] zram0: detected capacity change from 0 to 52428800 445 [ 11.452072] zram2: detected capacity change from 0 to 523481088 446 [ 13.529637] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard 447 [ 13.529676] ext4 filesystem being mounted at /tmp supports timestamps until 2038 (0x7fffffff) 448 [ 13.563735] systemd[1]: Started Armbian ZRAM config. 449 [ 13.576270] systemd[1]: Starting Armbian memory supported logging... 450 [ 13.668635] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 451 [ 13.668679] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 452 [ 16.910035] systemd[1]: Started Armbian memory supported logging. 453 [ 16.917552] systemd[1]: Starting Journal Service... 454 [ 17.189244] systemd[1]: Started Journal Service. 455 [ 17.252274] systemd-journald[528]: Received request to flush runtime journal from PID 1 456 457 ### armbian-release: 458 459 # PLEASE DO NOT EDIT THIS FILE 460 BOARD=orangepipc 461 BOARD_NAME="Orange Pi PC" 462 BOARDFAMILY=sun8i 463 BUILD_REPOSITORY_URL=https://github.com/armbian/build 464 BUILD_REPOSITORY_COMMIT=e6fa811d-dirty 465 DISTRIBUTION_CODENAME=buster 466 DISTRIBUTION_STATUS=supported 467 VERSION=20.08.1 468 LINUXFAMILY=sunxi 469 BRANCH=current 470 ARCH=arm 471 IMAGE_TYPE=stable 472 BOARD_TYPE=conf 473 INITRD_ARCH=arm 474 KERNEL_IMAGE_TYPE=Image 475 476 ### boot environment: 477 478 verbosity=1 479 bootlogo=false 480 console=both 481 disp_mode=1920x1080p60 482 overlay_prefix=sun8i-h3 483 rootdev=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da 484 rootfstype=ext4 485 486 ### lsusb: 487 488 Bus 008 Device 002: ID 04f3:0234 Elan Microelectronics Corp. Optical Mouse 489 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 490 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 491 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 492 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 493 Bus 006 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser 494 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 495 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 496 Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 497 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 498 Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 499 Thu 03 Sep 2020 06:41:05 AM UTC | Orange Pi PC | 20.08.1 | armhf | armv7l | 5.8.5-sunxi 500 501 ### lscpu: 502 503 Architecture: armv7l 504 Byte Order: Little Endian 505 CPU(s): 4 506 On-line CPU(s) list: 0-3 507 Thread(s) per core: 1 508 Core(s) per socket: 4 509 Socket(s): 1 510 Vendor ID: ARM 511 Model: 5 512 Model name: Cortex-A7 513 Stepping: r0p5 514 CPU max MHz: 1368.0000 515 CPU min MHz: 480.0000 516 BogoMIPS: 65.14 517 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 518 519 ### cpuinfo: 520 521 processor : 0 522 model name : ARMv7 Processor rev 5 (v7l) 523 BogoMIPS : 65.14 524 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 525 CPU implementer : 0x41 526 CPU architecture: 7 527 CPU variant : 0x0 528 CPU part : 0xc07 529 CPU revision : 5 530 531 processor : 1 532 model name : ARMv7 Processor rev 5 (v7l) 533 BogoMIPS : 65.14 534 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 535 CPU implementer : 0x41 536 CPU architecture: 7 537 CPU variant : 0x0 538 CPU part : 0xc07 539 CPU revision : 5 540 541 processor : 2 542 model name : ARMv7 Processor rev 5 (v7l) 543 BogoMIPS : 65.14 544 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 545 CPU implementer : 0x41 546 CPU architecture: 7 547 CPU variant : 0x0 548 CPU part : 0xc07 549 CPU revision : 5 550 551 processor : 3 552 model name : ARMv7 Processor rev 5 (v7l) 553 BogoMIPS : 65.14 554 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 555 CPU implementer : 0x41 556 CPU architecture: 7 557 CPU variant : 0x0 558 CPU part : 0xc07 559 CPU revision : 5 560 561 Hardware : Allwinner sun8i Family 562 Revision : 0000 563 Serial : 02c00081abf8f0eb 564 565 ### meminfo: 566 567 MemTotal: 1022424 kB 568 MemFree: 906824 kB 569 MemAvailable: 931472 kB 570 Buffers: 8348 kB 571 Cached: 31856 kB 572 SwapCached: 0 kB 573 Active: 33332 kB 574 Inactive: 14004 kB 575 Active(anon): 7416 kB 576 Inactive(anon): 1472 kB 577 Active(file): 25916 kB 578 Inactive(file): 12532 kB 579 Unevictable: 0 kB 580 Mlocked: 0 kB 581 HighTotal: 262132 kB 582 HighFree: 194944 kB 583 LowTotal: 760292 kB 584 LowFree: 711880 kB 585 SwapTotal: 511208 kB 586 SwapFree: 511208 kB 587 Dirty: 12 kB 588 Writeback: 200 kB 589 AnonPages: 7136 kB 590 Mapped: 8148 kB 591 Shmem: 1656 kB 592 KReclaimable: 10436 kB 593 Slab: 30900 kB 594 SReclaimable: 10436 kB 595 SUnreclaim: 20464 kB 596 KernelStack: 872 kB 597 PageTables: 308 kB 598 NFS_Unstable: 0 kB 599 Bounce: 0 kB 600 WritebackTmp: 0 kB 601 CommitLimit: 1022420 kB 602 Committed_AS: 15300 kB 603 VmallocTotal: 245760 kB 604 VmallocUsed: 10416 kB 605 VmallocChunk: 0 kB 606 Percpu: 608 kB 607 CmaTotal: 131072 kB 608 CmaFree: 97532 kB 609 610 ### virtual memory: 611 612 vm.admin_reserve_kbytes = 8192 613 vm.block_dump = 0 614 vm.compact_unevictable_allowed = 1 615 vm.dirty_background_bytes = 0 616 vm.dirty_background_ratio = 10 617 vm.dirty_bytes = 0 618 vm.dirty_expire_centisecs = 3000 619 vm.dirty_ratio = 20 620 vm.dirtytime_expire_seconds = 43200 621 vm.dirty_writeback_centisecs = 500 622 vm.extfrag_threshold = 500 623 vm.highmem_is_dirtyable = 0 624 vm.laptop_mode = 0 625 626 ### [resize2fs] Leaving 1% spare area. Start resizing partition /dev/mmcblk0p1 now: 627 628 major minor #blocks name 629 630 1 0 4096 ram0 631 1 1 4096 ram1 632 1 2 4096 ram2 633 1 3 4096 ram3 634 179 0 30578688 mmcblk0 635 179 1 2719744 mmcblk0p1 636 254 0 51200 zram0 637 254 1 511212 zram1 638 254 2 511212 zram2 639 640 Executing fdisk, fsck and partprobe: 641 vm.legacy_va_layout = 0 642 vm.lowmem_reserve_ratio = 32 0 0 643 vm.max_map_count = 65530 644 645 Welcome to fdisk (util-linux 2.33.1). 646 Changes will remain in memory only, until you decide to write them. 647 Be careful before using the write command. 648 649 650 Command (m for help): Selected partition 1 651 Partition 1 has been deleted. 652 653 Command (m for help): Partition type 654 p primary (0 primary, 0 extended, 4 free) 655 e extended (container for logical partitions) 656 Select (default p): Partition number (1-4, default 1): First sector (2048-61157375, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-61157375, default 61157375): vm.min_free_kbytes = 3463 657 vm.mmap_min_addr = 4096 658 vm.mmap_rnd_bits = 8 659 vm.oom_dump_tasks = 1 660 661 Created a new partition 1 of type 'Linux' and of size 28.9 GiB. 662 Partition #1 contains a ext4 signature. 663 664 Command (m for help): vm.oom_kill_allocating_task = 0 665 666 The partition table has been altered. 667 Syncing disks. 668 669 vm.overcommit_kbytes = 0 670 vm.overcommit_memory = 0 671 vm.overcommit_ratio = 50 672 vm.page-cluster = 0 673 vm.panic_on_oom = 0 674 vm.percpu_pagelist_fraction = 0 675 New partition table: 676 677 major minor #blocks name 678 679 1 0 4096 ram0 680 1 1 4096 ram1 681 1 2 4096 ram2 682 1 3 4096 ram3 683 179 0 30578688 mmcblk0 684 179 1 30268800 mmcblk0p1 685 254 0 51200 zram0 686 254 1 511212 zram1 687 254 2 511212 zram2 688 689 Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits: 690 691 vm.stat_interval = 1 692 resize2fs 1.44.5 (15-Dec-2018) 693 vm.swappiness = 100 694 vm.user_reserve_kbytes = 31484 695 vm.vfs_cache_pressure = 100 696 vm.watermark_boost_factor = 15000 697 vm.watermark_scale_factor = 10 698 699 ### ip addr: 700 701 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 702 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 703 inet XXX.XXX.0.1/8 scope host lo 704 valid_lft forever preferred_lft forever 705 inet6 ::1/128 scope host 706 valid_lft forever preferred_lft forever 707 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 708 link/ether 02:81:ab:f8:f0:eb brd ff:ff:ff:ff:ff:ff 709 710 ### partitions: 711 712 major minor #blocks name 713 714 179 0 30578688 mmcblk0 715 179 1 30268800 mmcblk0p1 716 254 0 51200 zram0 717 254 1 511212 zram1 718 254 2 511212 zram2 719 720 ### df: 721 722 udev 431M 0 431M 0% /dev 723 tmpfs 100M 1.7M 99M 2% /run 724 /dev/mmcblk0p1 2.6G 2.1G 351M 86% / 725 tmpfs 500M 0 500M 0% /dev/shm 726 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 727 tmpfs 500M 0 500M 0% /sys/fs/cgroup 728 /dev/zram2 484M 784K 448M 1% /tmp 729 /dev/zram0 49M 1.1M 44M 3% /var/log 730 731 ### lsblk: 732 733 NAME FSTYPE SIZE MOUNTPOINT UUID 734 mmcblk0 29.2G 735 └─mmcblk0p1 ext4 28.9G / 4b9e57b7-4690-4e61-8e27-b7f542b413da 736 zram0 50M /var/log 737 zram2 499.2M /tmp 738 739 ### zramctl: 740 741 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 742 /dev/zram2 lzo-rle 499.2M 460K 5.7K 84K 4 /tmp 743 /dev/zram1 lzo-rle 499.2M 4K 73B 4K 4 [SWAP] 744 /dev/zram0 zstd 50M 1.1M 170.6K 512K 4 /var/log 745 746 ### mtab: 747 748 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 749 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 750 /dev/zram0 /var/log ext4 rw,relatime,discard 0 0 751 /dev/zram2 /tmp ext4 rw,nosuid,relatime,discard 0 0 752 753 ### mmc0:0001 info: 754 755 manfid: 0x000000 756 cid: 003432534431364720000003bd013773 757 fwrev: 0x0 758 rca: 0x0001 759 csd: 400e00325b590000e94b7f800a40001b 760 ocr: 0x00200000 761 type: SD 762 date: 07/2019 763 hwrev: 0x2 764 dsr: 0x404 765 serial: 0x000003bd 766 erase_size: 512 767 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block 768 ssr: 000000000500000004049000080a190a000800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 769 scr: 0285804200000000 770 oemid: 0x3432 771 preferred_erase_size: 4194304 772 name: SD16G 773 774 ### Boot system health: 775 776 Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required 777 old_desc_blocks = 1, new_desc_blocks = 4 778 The filesystem on /dev/mmcblk0p1 is now 7567200 (4k) blocks long. 779 780 781 ### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now 782 783 resize2fs 1.44.5 (15-Dec-2018) 784 The filesystem is already 7567200 (4k) blocks long. Nothing to do! 785 786 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 787 06:41:07: 1368MHz 0.15 33% 18% 12% 0% 2% 0% 59.6°C 0/8 788 06:41:07: 1368MHz 0.30 28% 5% 0% 1% 20% 0% 56.5°C 0/8 789 06:41:08: 1368MHz 0.30 47% 21% 18% 1% 6% 0% 56.4°C 0/8 790 06:41:08: 1368MHz 0.30 30% 9% 18% 1% 1% 0% 60.1°C 0/8 791 06:41:09: 1368MHz 0.30 71% 42% 24% 1% 3% 0% 61.1°C 0/8 792 793 ### quick iozone test: 4 594 2968 6344 5966 5943 2263 794 795 ### [firstrun] Recreated SSH keys (entropy: 3413 3415) 796 797 ### Activated 1 lzo-rle zram swap devices with 499 MB each 798 799 ### Activated Armbian ramlog partition with zstd compression 800 801 Thu 03 Sep 2020 06:58:51 AM UTC | Orange Pi PC | 20.08.1 | armhf | armv7l | 5.8.5-sunxi 802 803 ### dmesg: 804 805 [ 0.000000] Booting Linux on physical CPU 0x0 806 [ 0.000000] Linux version 5.8.5-sunxi (root@desktop) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) XXX.XXX.1.20191209) #20.08.1 SMP Wed Sep 2 08:03:45 CEST 2020 807 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d 808 [ 0.000000] CPU: div instructions available: patching division code 809 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 810 [ 0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC 811 [ 0.000000] Memory policy: Data cache writealloc 812 [ 0.000000] cma: Reserved 128 MiB at 0x77c00000 813 [ 0.000000] Zone ranges: 814 [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] 815 [ 0.000000] HighMem [mem 0x0000000070000000-0x000000007fffffff] 816 [ 0.000000] Movable zone start for each node 817 [ 0.000000] Early memory node ranges 818 [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff] 819 [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] 820 [ 0.000000] On node 0 totalpages: 262144 821 [ 0.000000] Normal zone: 1728 pages used for memmap 822 [ 0.000000] Normal zone: 0 pages reserved 823 [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 824 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 825 [ 0.000000] psci: probing for conduit method from DT. 826 [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT 827 [ 0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920 828 [ 0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096 829 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 830 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 831 [ 0.000000] Kernel command line: root=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=5d748697-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 832 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) 833 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) 834 [ 0.000000] allocated 1048576 bytes of page_ext 835 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 836 [ 0.000000] Memory: 880656K/1048576K available (9216K kernel code, 1002K rwdata, 3268K rodata, 1024K init, 327K bss, 36848K reserved, 131072K cma-reserved, 131060K highmem) 837 [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 with crng_init=0 838 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 839 [ 0.000000] ftrace: allocating 39954 entries in 79 pages 840 [ 0.000000] ftrace: allocated 79 pages with 5 groups 841 [ 0.000000] rcu: Hierarchical RCU implementation. 842 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. 843 [ 0.000000] Rude variant of Tasks RCU enabled. 844 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 845 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 846 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 847 [ 0.000000] GIC: Using split EOI/Deactivate mode 848 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns 849 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 850 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 851 [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 852 [ 0.000015] Switching to timer-based delay loop, resolution 41ns 853 [ 0.000237] Console: colour dummy device 80x30 854 [ 0.000251] printk: console [tty1] enabled 855 [ 0.000303] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 856 [ 0.000312] pid_max: default: 32768 minimum: 301 857 [ 0.000522] LSM: Security Framework initializing 858 [ 0.000578] Yama: becoming mindful. 859 [ 0.000720] AppArmor: AppArmor initialized 860 [ 0.000783] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 861 [ 0.000796] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 862 [ 0.001836] CPU: Testing write buffer coherency: ok 863 [ 0.002199] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 864 [ 0.002746] Setting up static identity map for 0x40100000 - 0x40100054 865 [ 0.002862] rcu: Hierarchical SRCU implementation. 866 [ 0.006031] smp: Bringing up secondary CPUs ... 867 [ 0.016788] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 868 [ 0.027635] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 869 [ 0.038412] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 870 [ 0.038518] smp: Brought up 1 node, 4 CPUs 871 [ 0.038526] SMP: Total of 4 processors activated (192.00 BogoMIPS). 872 [ 0.038530] CPU: All CPU(s) started in HYP mode. 873 [ 0.038532] CPU: Virtualization extensions available. 874 [ 0.039457] devtmpfs: initialized 875 [ 0.046585] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 876 [ 0.046924] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 877 [ 0.046966] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) 878 [ 0.051519] xor: measuring software checksum speed 879 [ 0.090393] arm4regs : 1255.000 MB/sec 880 [ 0.130453] 8regs : 874.000 MB/sec 881 [ 0.170519] 32regs : 826.000 MB/sec 882 [ 0.210583] neon : 1271.000 MB/sec 883 [ 0.210588] xor: using function: neon (1271.000 MB/sec) 884 [ 0.210654] pinctrl core: initialized pinctrl subsystem 885 [ 0.211137] thermal_sys: Registered thermal governor 'fair_share' 886 [ 0.211141] thermal_sys: Registered thermal governor 'bang_bang' 887 [ 0.211146] thermal_sys: Registered thermal governor 'step_wise' 888 [ 0.212171] NET: Registered protocol family 16 889 [ 0.213719] DMA: preallocated 256 KiB pool for atomic coherent allocations 890 [ 0.214180] audit: initializing netlink subsys (disabled) 891 [ 0.214395] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1 892 [ 0.215031] cpuidle: using governor ladder 893 [ 0.215158] cpuidle: using governor menu 894 [ 0.215665] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 895 [ 0.215669] hw-breakpoint: maximum watchpoint size is 8 bytes. 896 [ 0.237618] cryptd: max_cpu_qlen set to 1000 897 [ 0.306808] raid6: neonx8 gen() 774 MB/s 898 [ 0.374871] raid6: neonx8 xor() 580 MB/s 899 [ 0.442979] raid6: neonx4 gen() 831 MB/s 900 [ 0.511048] raid6: neonx4 xor() 631 MB/s 901 [ 0.579140] raid6: neonx2 gen() 915 MB/s 902 [ 0.647222] raid6: neonx2 xor() 653 MB/s 903 [ 0.715310] raid6: neonx1 gen() 816 MB/s 904 [ 0.783383] raid6: neonx1 xor() 565 MB/s 905 [ 0.851536] raid6: int32x8 gen() 303 MB/s 906 [ 0.919599] raid6: int32x8 xor() 176 MB/s 907 [ 0.987688] raid6: int32x4 gen() 357 MB/s 908 [ 1.055769] raid6: int32x4 xor() 205 MB/s 909 [ 1.123849] raid6: int32x2 gen() 399 MB/s 910 [ 1.191964] raid6: int32x2 xor() 213 MB/s 911 [ 1.260048] raid6: int32x1 gen() 390 MB/s 912 [ 1.328110] raid6: int32x1 xor() 192 MB/s 913 [ 1.328114] raid6: using algorithm neonx2 gen() 915 MB/s 914 [ 1.328117] raid6: .... xor() 653 MB/s, rmw enabled 915 [ 1.328121] raid6: using neon recovery algorithm 916 [ 1.329412] iommu: Default domain type: Translated 917 [ 1.329764] SCSI subsystem initialized 918 [ 1.329989] libata version 3.00 loaded. 919 [ 1.330220] usbcore: registered new interface driver usbfs 920 [ 1.330269] usbcore: registered new interface driver hub 921 [ 1.330333] usbcore: registered new device driver usb 922 [ 1.330423] mc: Linux media interface: v0.10 923 [ 1.330459] videodev: Linux video capture interface: v2.00 924 [ 1.330582] pps_core: LinuxPPS API ver. 1 registered 925 [ 1.330587] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 926 [ 1.330602] PTP clock support registered 927 [ 1.330957] Advanced Linux Sound Architecture Driver Initialized. 928 [ 1.331630] NetLabel: Initializing 929 [ 1.331636] NetLabel: domain hash size = 128 930 [ 1.331639] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 931 [ 1.331715] NetLabel: unlabeled traffic allowed by default 932 [ 1.332394] clocksource: Switched to clocksource arch_sys_counter 933 [ 1.425396] VFS: Disk quotas dquot_6.6.0 934 [ 1.425488] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 935 [ 1.426078] AppArmor: AppArmor Filesystem Enabled 936 [ 1.434174] NET: Registered protocol family 2 937 [ 1.434897] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) 938 [ 1.434938] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) 939 [ 1.435032] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) 940 [ 1.435143] TCP: Hash tables configured (established 8192 bind 8192) 941 [ 1.435276] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) 942 [ 1.435326] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) 943 [ 1.435565] NET: Registered protocol family 1 944 [ 1.436004] Trying to unpack rootfs image as initramfs... 945 [ 2.089439] Freeing initrd memory: 9672K 946 [ 2.090808] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 947 [ 2.091955] Initialise system trusted keyrings 948 [ 2.092000] Key type blacklist registered 949 [ 2.092224] workingset: timestamp_bits=14 max_order=18 bucket_order=4 950 [ 2.097753] zbud: loaded 951 [ 2.099198] squashfs: version 4.0 (2009/01/31) Phillip Lougher 952 [ 2.100136] fuse: init (API version 7.31) 953 [ 2.102709] integrity: Platform Keyring initialized 954 [ 2.211369] Key type asymmetric registered 955 [ 2.211376] Asymmetric key parser 'x509' registered 956 [ 2.211545] bounce: pool size: 64 pages 957 [ 2.211632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 958 [ 2.211817] io scheduler mq-deadline registered 959 [ 2.211822] io scheduler kyber registered 960 [ 2.211994] io scheduler bfq registered 961 [ 2.217711] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver 962 [ 2.219383] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver 963 [ 2.226199] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 964 [ 2.228477] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator 965 [ 2.228915] printk: console [ttyS0] disabled 966 [ 2.228998] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a 16550A 967 [ 2.229064] printk: console [ttyS0] enabled 968 [ 2.244780] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a9f100) 969 [ 2.245082] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9c000) 970 [ 2.245148] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator 971 [ 2.246038] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) 972 [ 2.246447] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver 973 [ 2.246692] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a9e6fc) 974 [ 2.246701] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 975 [ 2.247104] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 976 [ 2.352477] random: fast init done 977 [ 2.604052] Console: switching to colour frame buffer device 160x45 978 [ 2.676747] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device 979 [ 2.680439] brd: module loaded 980 [ 2.687085] loop: module loaded 981 [ 2.689211] libphy: Fixed MDIO Bus: probed 982 [ 2.689727] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found 983 [ 2.689735] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found 984 [ 2.689849] dwmac-sun8i 1c30000.ethernet: PTP uses main clock 985 [ 2.689907] dwmac-sun8i 1c30000.ethernet: supply phy not found, using dummy regulator 986 [ 2.689985] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator 987 [ 2.690311] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) 988 [ 2.690330] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported 989 [ 2.690336] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported 990 [ 2.690342] dwmac-sun8i 1c30000.ethernet: COE Type 2 991 [ 2.690348] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported 992 [ 2.690354] dwmac-sun8i 1c30000.ethernet: Normal descriptors 993 [ 2.690359] dwmac-sun8i 1c30000.ethernet: Chain mode enabled 994 [ 2.690872] libphy: stmmac: probed 995 [ 2.691419] dwmac-sun8i 1c30000.ethernet: Found internal PHY node 996 [ 2.691866] libphy: mdio_mux: probed 997 [ 2.691888] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY 998 [ 2.691897] dwmac-sun8i 1c30000.ethernet: Powering internal PHY 999 [ 2.705011] libphy: mdio_mux: probed 1000 [ 2.706144] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 1001 [ 2.706202] ehci-platform: EHCI generic platform driver 1002 [ 2.706430] ehci-platform 1c1a000.usb: EHCI Host Controller 1003 [ 2.706458] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 1004 [ 2.706878] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 1005 [ 2.720414] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 1006 [ 2.720685] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1007 [ 2.720693] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1008 [ 2.720700] usb usb1: Product: EHCI Host Controller 1009 [ 2.720706] usb usb1: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1010 [ 2.720712] usb usb1: SerialNumber: 1c1a000.usb 1011 [ 2.721303] hub 1-0:1.0: USB hub found 1012 [ 2.721344] hub 1-0:1.0: 1 port detected 1013 [ 2.722249] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 1014 [ 2.722270] ohci-platform: OHCI generic platform driver 1015 [ 2.722440] ohci-platform 1c1a400.usb: Generic Platform OHCI controller 1016 [ 2.722472] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 1017 [ 2.722660] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 1018 [ 2.784588] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1019 [ 2.784597] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1020 [ 2.784604] usb usb2: Product: Generic Platform OHCI controller 1021 [ 2.784610] usb usb2: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1022 [ 2.784616] usb usb2: SerialNumber: 1c1a400.usb 1023 [ 2.785142] hub 2-0:1.0: USB hub found 1024 [ 2.785179] hub 2-0:1.0: 1 port detected 1025 [ 2.786552] usbcore: registered new interface driver usb-storage 1026 [ 2.787548] sun6i-rtc 1f00000.rtc: registered as rtc0 1027 [ 2.787589] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:18:20 UTC (1100) 1028 [ 2.787595] sun6i-rtc 1f00000.rtc: RTC enabled 1029 [ 2.787904] i2c /dev entries driver 1030 [ 2.788269] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator 1031 [ 2.790515] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) 1032 [ 2.790971] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator 1033 [ 2.791765] sunxi-mmc 1c0f000.mmc: Got CD GPIO 1034 [ 2.817094] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB 1035 [ 2.818298] ledtrig-cpu: registered to indicate activity on CPUs 1036 [ 2.818366] hid: raw HID events driver (C) Jiri Kosina 1037 [ 2.818492] usbcore: registered new interface driver usbhid 1038 [ 2.818495] usbhid: USB HID core driver 1039 [ 2.822552] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present! 1040 [ 2.823886] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok 1041 [ 2.826697] Initializing XFRM netlink socket 1042 [ 2.827233] NET: Registered protocol family 10 1043 [ 2.857808] mmc0: host does not support reading read-only switch, assuming write-enable 1044 [ 2.859811] mmc0: new high speed SDHC card at address 0001 1045 [ 2.861492] mmcblk0: mmc0:0001 SD16G 29.2 GiB 1046 [ 2.865099] mmcblk0: p1 1047 [ 2.874805] Segment Routing with IPv6 1048 [ 2.874935] NET: Registered protocol family 17 1049 [ 2.874968] NET: Registered protocol family 15 1050 [ 2.875052] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 1051 [ 2.875173] 8021q: 802.1Q VLAN Support v1.8 1052 [ 2.875226] Key type dns_resolver registered 1053 [ 2.875676] Registering SWP/SWPB emulation handler 1054 [ 2.875989] registered taskstats version 1 1055 [ 2.875996] Loading compiled-in X.509 certificates 1056 [ 2.882678] Loaded X.509 cert 'Build time autogenerated kernel key: 346848ecd67c995d675bab6785bece621761b48f' 1057 [ 2.882833] zswap: loaded using pool lzo/zbud 1058 [ 2.883460] Key type ._fscrypt registered 1059 [ 2.883466] Key type .fscrypt registered 1060 [ 2.883470] Key type fscrypt-provisioning registered 1061 [ 2.888704] Btrfs loaded, crc32c=crc32c-generic 1062 [ 2.910847] Key type encrypted registered 1063 [ 2.910867] AppArmor: AppArmor sha1 policy hashing enabled 1064 [ 2.922502] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator 1065 [ 2.923992] ehci-platform 1c1b000.usb: EHCI Host Controller 1066 [ 2.924024] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 1067 [ 2.924681] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 1068 [ 2.940390] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 1069 [ 2.940685] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1070 [ 2.940694] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1071 [ 2.940701] usb usb3: Product: EHCI Host Controller 1072 [ 2.940707] usb usb3: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1073 [ 2.940713] usb usb3: SerialNumber: 1c1b000.usb 1074 [ 2.941315] hub 3-0:1.0: USB hub found 1075 [ 2.941361] hub 3-0:1.0: 1 port detected 1076 [ 2.942246] ehci-platform 1c1c000.usb: EHCI Host Controller 1077 [ 2.942271] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 1078 [ 2.942549] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 1079 [ 2.956405] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 1080 [ 2.956670] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1081 [ 2.956679] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1082 [ 2.956686] usb usb4: Product: EHCI Host Controller 1083 [ 2.956692] usb usb4: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1084 [ 2.956698] usb usb4: SerialNumber: 1c1c000.usb 1085 [ 2.957214] hub 4-0:1.0: USB hub found 1086 [ 2.957253] hub 4-0:1.0: 1 port detected 1087 [ 2.958056] ehci-platform 1c1d000.usb: EHCI Host Controller 1088 [ 2.958079] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 1089 [ 2.958367] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 1090 [ 2.972406] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 1091 [ 2.972631] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1092 [ 2.972639] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1093 [ 2.972646] usb usb5: Product: EHCI Host Controller 1094 [ 2.972652] usb usb5: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1095 [ 2.972658] usb usb5: SerialNumber: 1c1d000.usb 1096 [ 2.973143] hub 5-0:1.0: USB hub found 1097 [ 2.973177] hub 5-0:1.0: 1 port detected 1098 [ 2.973960] ohci-platform 1c1b400.usb: Generic Platform OHCI controller 1099 [ 2.973984] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 1100 [ 2.974182] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 1101 [ 3.036585] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1102 [ 3.036593] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1103 [ 3.036599] usb usb6: Product: Generic Platform OHCI controller 1104 [ 3.036606] usb usb6: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1105 [ 3.036611] usb usb6: SerialNumber: 1c1b400.usb 1106 [ 3.037131] hub 6-0:1.0: USB hub found 1107 [ 3.037168] hub 6-0:1.0: 1 port detected 1108 [ 3.037947] ohci-platform 1c1c400.usb: Generic Platform OHCI controller 1109 [ 3.037969] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 1110 [ 3.038150] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 1111 [ 3.100581] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1112 [ 3.100590] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1113 [ 3.100596] usb usb7: Product: Generic Platform OHCI controller 1114 [ 3.100602] usb usb7: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1115 [ 3.100609] usb usb7: SerialNumber: 1c1c400.usb 1116 [ 3.101125] hub 7-0:1.0: USB hub found 1117 [ 3.101163] hub 7-0:1.0: 1 port detected 1118 [ 3.101928] ohci-platform 1c1d400.usb: Generic Platform OHCI controller 1119 [ 3.101951] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 1120 [ 3.102150] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 1121 [ 3.164579] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1122 [ 3.164588] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1123 [ 3.164594] usb usb8: Product: Generic Platform OHCI controller 1124 [ 3.164601] usb usb8: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1125 [ 3.164606] usb usb8: SerialNumber: 1c1d400.usb 1126 [ 3.165148] hub 8-0:1.0: USB hub found 1127 [ 3.165184] hub 8-0:1.0: 1 port detected 1128 [ 3.166828] of_cfs_init 1129 [ 3.166975] of_cfs_init: OK 1130 [ 3.167128] ALSA device list: 1131 [ 3.167134] #0: H3 Audio Codec 1132 [ 3.171088] Freeing unused kernel memory: 1024K 1133 [ 3.180630] Run /init as init process 1134 [ 3.180637] with arguments: 1135 [ 3.180641] /init 1136 [ 3.180644] with environment: 1137 [ 3.180648] HOME=/ 1138 [ 3.180651] TERM=linux 1139 [ 3.180655] ubootpart=5d748697-01 1140 [ 3.180658] ubootsource=mmc 1141 [ 3.180661] sunxi_ve_mem_reserve=0 1142 [ 3.180665] sunxi_g2d_mem_reserve=0 1143 [ 3.180668] sunxi_fb_mem_reserve=16 1144 [ 3.180671] cgroup_enable=memory 1145 [ 3.181169] process '/usr/bin/sh' started with executable stack 1146 [ 3.536446] usb 6-1: new low-speed USB device number 2 using ohci-platform 1147 [ 3.557964] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 1148 [ 3.568476] usb 8-1: new low-speed USB device number 2 using ohci-platform 1149 [ 3.621758] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator 1150 [ 3.622805] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver 1151 [ 3.622840] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9 1152 [ 3.623538] phy id_det change to device 1153 [ 3.623840] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1154 [ 3.623850] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1155 [ 3.623857] usb usb9: Product: MUSB HDRC host driver 1156 [ 3.623863] usb usb9: Manufacturer: Linux 5.8.5-sunxi musb-hcd 1157 [ 3.623869] usb usb9: SerialNumber: musb-hdrc.4.auto 1158 [ 3.626725] hub 9-0:1.0: USB hub found 1159 [ 3.626787] hub 9-0:1.0: 1 port detected 1160 [ 3.764499] usb 6-1: New USB device found, idVendor=046d, idProduct=c517, bcdDevice=38.10 1161 [ 3.764513] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1162 [ 3.764520] usb 6-1: Product: USB Receiver 1163 [ 3.764528] usb 6-1: Manufacturer: Logitech 1164 [ 3.777338] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C517.0001/input/input1 1165 [ 3.836652] hid-generic 0003:046D:C517.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 1166 [ 3.847104] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input2 1167 [ 3.847347] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input3 1168 [ 3.854443] usb 8-1: New USB device found, idVendor=04f3, idProduct=0234, bcdDevice=24.58 1169 [ 3.854452] usb 8-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 1170 [ 3.854458] usb 8-1: Product: OM 1171 [ 3.863274] input: OM as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:04F3:0234.0003/input/input7 1172 [ 3.904606] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/input/input4 1173 [ 3.904670] hid-generic 0003:04F3:0234.0003: input,hidraw1: USB HID v1.11 Mouse [OM] on usb-1c1d400.usb-1/input0 1174 [ 3.905044] hid-generic 0003:046D:C517.0002: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 1175 [ 3.962055] logitech-djreceiver 0003:046D:C517.0001: hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 1176 [ 4.055152] logitech-djreceiver 0003:046D:C517.0002: hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 1177 [ 4.132487] logitech-djreceiver 0003:046D:C517.0002: device of type 27 Mhz (0x02) connected on slot 3 1178 [ 4.135275] input: Logitech Wireless Keyboard PID:0062 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input8 1179 [ 4.135539] input: Logitech Wireless Keyboard PID:0062 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input9 1180 [ 4.135694] input: Logitech Wireless Keyboard PID:0062 System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input10 1181 [ 4.135997] hid-generic 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 1182 [ 4.220513] logitech-hidpp-device 0003:046D:0062.0004: HID++ 1.0 device connected. 1183 [ 4.270393] input: Logitech Wireless Keyboard PID:0062 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0002/0003:046D:0062.0004/input/input14 1184 [ 4.270647] logitech-hidpp-device 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 1185 [ 4.678457] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 1186 [ 5.450010] systemd[1]: System time before build time, advancing clock. 1187 [ 5.474717] systemd[1]: Inserted module 'autofs4' 1188 [ 5.538812] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 1189 [ 5.539612] systemd[1]: Detected architecture arm. 1190 [ 5.578227] systemd[1]: Set hostname to <orangepipc>. 1191 [ 6.326190] random: systemd: uninitialized urandom read (16 bytes read) 1192 [ 6.340659] random: systemd: uninitialized urandom read (16 bytes read) 1193 [ 6.345757] systemd[1]: Created slice system-serial\x2dgetty.slice. 1194 [ 6.346993] random: systemd: uninitialized urandom read (16 bytes read) 1195 [ 6.348558] systemd[1]: Created slice system-getty.slice. 1196 [ 6.349847] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. 1197 [ 6.352033] systemd[1]: Listening on Journal Socket. 1198 [ 6.353017] systemd[1]: Reached target Remote File Systems. 1199 [ 6.358504] systemd[1]: Starting Nameserver information manager... 1200 [ 6.360164] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 1201 [ 6.460333] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 1202 [ 7.732889] zram: Added device: zram0 1203 [ 7.736235] zram: Added device: zram1 1204 [ 7.737425] zram: Added device: zram2 1205 [ 7.915509] zram1: detected capacity change from 0 to 523481088 1206 [ 7.931373] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz) 1207 [ 7.940146] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 1208 [ 7.950406] sun8i-di 1400000.deinterlace: Device registered as /dev/video1 1209 [ 7.958626] cedrus 1c0e000.video-codec: Device registered as /dev/video0 1210 [ 7.960333] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1211 [ 7.972540] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1212 [ 7.984547] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1213 [ 7.985829] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1214 [ 7.986310] sun8i-ce 1c15000.crypto: Register cbc(aes) 1215 [ 7.986849] sun8i-ce 1c15000.crypto: Register ecb(aes) 1216 [ 7.987032] sun8i-ce 1c15000.crypto: Register cbc(des3_ede) 1217 [ 7.987175] sun8i-ce 1c15000.crypto: Register ecb(des3_ede) 1218 [ 7.987324] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1 1219 [ 8.098261] sun8i-thermal 1c25000.thermal-sensor: Thermal sensor ready! 1220 [ 8.188111] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 1221 [ 8.188176] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 1222 [ 8.188227] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 1223 [ 8.188269] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 1224 [ 8.213509] mousedev: PS/2 mouse device common for all mice 1225 [ 8.219506] lima 1c40000.gpu: bus rate = 200000000 1226 [ 8.219518] lima 1c40000.gpu: mod rate = 297000000 1227 [ 8.219636] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 1228 [ 8.220084] lima 1c40000.gpu: Failed to register cooling device 1229 [ 8.220237] Registered IR keymap rc-empty 1230 [ 8.220340] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 1231 [ 8.220637] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter 1232 [ 8.220853] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input15 1233 [ 8.221092] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1 1234 [ 8.235566] sunxi-ir 1f02000.ir: initialized sunXi IR driver 1235 [ 8.576844] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok 1236 [ 9.012447] Adding 511208k swap on /dev/zram1. Priority:5 extents:1 across:511208k SSFS 1237 [ 9.173670] zram0: detected capacity change from 0 to 52428800 1238 [ 11.255496] systemd[1]: Started Armbian ZRAM config. 1239 [ 11.262173] systemd[1]: Starting Armbian memory supported logging... 1240 [ 11.347659] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 1241 [ 11.347705] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 1242 [ 14.638421] systemd[1]: Started Armbian memory supported logging. 1243 [ 14.644934] systemd[1]: Starting Journal Service... 1244 [ 14.917410] systemd[1]: Started Journal Service. 1245 [ 14.978684] systemd-journald[537]: Received request to flush runtime journal from PID 1 1246 1247 ### armbian-release: 1248 1249 # PLEASE DO NOT EDIT THIS FILE 1250 BOARD=orangepipc 1251 BOARD_NAME="Orange Pi PC" 1252 BOARDFAMILY=sun8i 1253 BUILD_REPOSITORY_URL=https://github.com/armbian/build 1254 BUILD_REPOSITORY_COMMIT=e6fa811d-dirty 1255 DISTRIBUTION_CODENAME=buster 1256 DISTRIBUTION_STATUS=supported 1257 VERSION=20.08.1 1258 LINUXFAMILY=sunxi 1259 BRANCH=current 1260 ARCH=arm 1261 IMAGE_TYPE=stable 1262 BOARD_TYPE=conf 1263 INITRD_ARCH=arm 1264 KERNEL_IMAGE_TYPE=Image 1265 1266 ### boot environment: 1267 1268 verbosity=1 1269 bootlogo=false 1270 console=both 1271 disp_mode=1920x1080p60 1272 overlay_prefix=sun8i-h3 1273 rootdev=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da 1274 rootfstype=ext4 1275 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 1276 1277 ### lsusb: 1278 1279 Bus 008 Device 002: ID 04f3:0234 Elan Microelectronics Corp. Optical Mouse 1280 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1281 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1282 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1283 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1284 Bus 006 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser 1285 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1286 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1287 Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1288 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1289 Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1290 1291 ### lscpu: 1292 1293 Architecture: armv7l 1294 Byte Order: Little Endian 1295 CPU(s): 4 1296 On-line CPU(s) list: 0-3 1297 Thread(s) per core: 1 1298 Core(s) per socket: 4 1299 Socket(s): 1 1300 Vendor ID: ARM 1301 Model: 5 1302 Model name: Cortex-A7 1303 Stepping: r0p5 1304 CPU max MHz: 1368.0000 1305 CPU min MHz: 480.0000 1306 BogoMIPS: 65.14 1307 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1308 1309 ### cpuinfo: 1310 1311 processor : 0 1312 model name : ARMv7 Processor rev 5 (v7l) 1313 BogoMIPS : 65.14 1314 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1315 CPU implementer : 0x41 1316 CPU architecture: 7 1317 CPU variant : 0x0 1318 CPU part : 0xc07 1319 CPU revision : 5 1320 1321 processor : 1 1322 model name : ARMv7 Processor rev 5 (v7l) 1323 BogoMIPS : 65.14 1324 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1325 CPU implementer : 0x41 1326 CPU architecture: 7 1327 CPU variant : 0x0 1328 CPU part : 0xc07 1329 CPU revision : 5 1330 1331 processor : 2 1332 model name : ARMv7 Processor rev 5 (v7l) 1333 BogoMIPS : 65.14 1334 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1335 CPU implementer : 0x41 1336 CPU architecture: 7 1337 CPU variant : 0x0 1338 CPU part : 0xc07 1339 CPU revision : 5 1340 1341 processor : 3 1342 model name : ARMv7 Processor rev 5 (v7l) 1343 BogoMIPS : 65.14 1344 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1345 CPU implementer : 0x41 1346 CPU architecture: 7 1347 CPU variant : 0x0 1348 CPU part : 0xc07 1349 CPU revision : 5 1350 1351 Hardware : Allwinner sun8i Family 1352 Revision : 0000 1353 Serial : 02c00081abf8f0eb 1354 1355 ### meminfo: 1356 1357 MemTotal: 1022424 kB 1358 MemFree: 892916 kB 1359 MemAvailable: 925604 kB 1360 Buffers: 8480 kB 1361 Cached: 38096 kB 1362 SwapCached: 0 kB 1363 Active: 37248 kB 1364 Inactive: 20000 kB 1365 Active(anon): 11080 kB 1366 Inactive(anon): 1488 kB 1367 Active(file): 26168 kB 1368 Inactive(file): 18512 kB 1369 Unevictable: 0 kB 1370 Mlocked: 0 kB 1371 HighTotal: 262132 kB 1372 HighFree: 185128 kB 1373 LowTotal: 760292 kB 1374 LowFree: 707788 kB 1375 SwapTotal: 511208 kB 1376 SwapFree: 511208 kB 1377 Dirty: 1000 kB 1378 Writeback: 400 kB 1379 AnonPages: 10952 kB 1380 Mapped: 14560 kB 1381 Shmem: 1664 kB 1382 KReclaimable: 12244 kB 1383 Slab: 35500 kB 1384 SReclaimable: 12244 kB 1385 SUnreclaim: 23256 kB 1386 KernelStack: 1056 kB 1387 PageTables: 784 kB 1388 NFS_Unstable: 0 kB 1389 Bounce: 0 kB 1390 WritebackTmp: 0 kB 1391 CommitLimit: 1022420 kB 1392 Committed_AS: 64908 kB 1393 VmallocTotal: 245760 kB 1394 VmallocUsed: 9480 kB 1395 VmallocChunk: 0 kB 1396 Percpu: 752 kB 1397 CmaTotal: 131072 kB 1398 CmaFree: 92552 kB 1399 1400 ### virtual memory: 1401 1402 vm.admin_reserve_kbytes = 8192 1403 vm.block_dump = 0 1404 vm.compact_unevictable_allowed = 1 1405 vm.dirty_background_bytes = 0 1406 vm.dirty_background_ratio = 10 1407 vm.dirty_bytes = 0 1408 vm.dirty_expire_centisecs = 3000 1409 vm.dirty_ratio = 20 1410 vm.dirtytime_expire_seconds = 43200 1411 vm.dirty_writeback_centisecs = 500 1412 vm.extfrag_threshold = 500 1413 vm.highmem_is_dirtyable = 0 1414 vm.laptop_mode = 0 1415 vm.legacy_va_layout = 0 1416 vm.lowmem_reserve_ratio = 32 0 0 1417 vm.max_map_count = 65530 1418 vm.min_free_kbytes = 3463 1419 vm.mmap_min_addr = 4096 1420 vm.mmap_rnd_bits = 8 1421 vm.oom_dump_tasks = 1 1422 vm.oom_kill_allocating_task = 0 1423 vm.overcommit_kbytes = 0 1424 vm.overcommit_memory = 0 1425 vm.overcommit_ratio = 50 1426 vm.page-cluster = 0 1427 vm.panic_on_oom = 0 1428 vm.percpu_pagelist_fraction = 0 1429 vm.stat_interval = 1 1430 vm.swappiness = 100 1431 vm.user_reserve_kbytes = 31484 1432 vm.vfs_cache_pressure = 100 1433 vm.watermark_boost_factor = 15000 1434 vm.watermark_scale_factor = 10 1435 1436 ### ip addr: 1437 1438 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 1439 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 1440 inet XXX.XXX.0.1/8 scope host lo 1441 valid_lft forever preferred_lft forever 1442 inet6 ::1/128 scope host 1443 valid_lft forever preferred_lft forever 1444 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 1445 link/ether 02:81:ab:f8:f0:eb brd ff:ff:ff:ff:ff:ff 1446 1447 ### partitions: 1448 1449 major minor #blocks name 1450 1451 179 0 30578688 mmcblk0 1452 179 1 30268800 mmcblk0p1 1453 254 0 51200 zram0 1454 254 1 511212 zram1 1455 1456 ### df: 1457 1458 udev 431M 0 431M 0% /dev 1459 tmpfs 100M 3.0M 97M 3% /run 1460 /dev/mmcblk0p1 29G 2.1G 26G 8% / 1461 tmpfs 500M 0 500M 0% /dev/shm 1462 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 1463 tmpfs 500M 0 500M 0% /sys/fs/cgroup 1464 tmpfs 500M 4.0K 500M 1% /tmp 1465 /dev/zram0 49M 1.9M 44M 5% /var/log 1466 1467 ### lsblk: 1468 1469 NAME FSTYPE SIZE MOUNTPOINT UUID 1470 mmcblk0 29.2G 1471 └─mmcblk0p1 ext4 28.9G / 4b9e57b7-4690-4e61-8e27-b7f542b413da 1472 zram0 50M /var/log 1473 1474 ### zramctl: 1475 1476 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 1477 /dev/zram1 lzo-rle 499.2M 4K 73B 4K 4 [SWAP] 1478 /dev/zram0 zstd 50M 1.9M 314.5K 656K 4 /var/log 1479 1480 ### mtab: 1481 1482 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 1483 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 1484 /dev/zram0 /var/log ext4 rw,relatime,discard 0 0 1485 1486 ### mmc0:0001 info: 1487 1488 manfid: 0x000000 1489 cid: 003432534431364720000003bd013773 1490 fwrev: 0x0 1491 rca: 0x0001 1492 csd: 400e00325b590000e94b7f800a40001b 1493 ocr: 0x00200000 1494 type: SD 1495 date: 07/2019 1496 hwrev: 0x2 1497 dsr: 0x404 1498 serial: 0x000003bd 1499 erase_size: 512 1500 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block 1501 ssr: 000000000500000004049000080a190a000800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 1502 scr: 0285804200000000 1503 oemid: 0x3432 1504 preferred_erase_size: 4194304 1505 name: SD16G 1506 1507 ### Boot system health: 1508 1509 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 1510 06:58:54: 1368MHz 0.15 43% 23% 17% 0% 2% 0% 69.6°C 0/8 1511 06:58:55: 1368MHz 0.15 49% 16% 12% 2% 17% 0% 64.7°C 0/8 1512 06:58:55: 1368MHz 0.15 37% 8% 16% 1% 10% 1% 65.1°C 0/8 1513 06:58:56: 1368MHz 0.15 35% 11% 6% 1% 15% 0% 66.4°C 0/8 1514 06:58:56: 1368MHz 0.15 33% 7% 6% 1% 17% 0% 66.2°C 0/8 1515 1516 ### Activated 1 lzo-rle zram swap devices with 499 MB each 1517 1518 ### Activated Armbian ramlog partition with zstd compression 1519 1520 ### Activated 1 lzo-rle zram swap devices with 499 MB each 1521 1522 ### Activated Armbian ramlog partition with zstd compression 1523 1524 Thu Sep 3 16:17:10 CEST 2020 | Orange Pi PC | 20.08.1 | armhf | armv7l | 5.8.5-sunxi 1525 1526 ### dmesg: 1527 1528 [ 0.000000] Booting Linux on physical CPU 0x0 1529 [ 0.000000] Linux version 5.8.5-sunxi (root@desktop) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) XXX.XXX.1.20191209) #20.08.1 SMP Wed Sep 2 08:03:45 CEST 2020 1530 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d 1531 [ 0.000000] CPU: div instructions available: patching division code 1532 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 1533 [ 0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC 1534 [ 0.000000] Memory policy: Data cache writealloc 1535 [ 0.000000] cma: Reserved 128 MiB at 0x77c00000 1536 [ 0.000000] Zone ranges: 1537 [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] 1538 [ 0.000000] HighMem [mem 0x0000000070000000-0x000000007fffffff] 1539 [ 0.000000] Movable zone start for each node 1540 [ 0.000000] Early memory node ranges 1541 [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff] 1542 [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] 1543 [ 0.000000] On node 0 totalpages: 262144 1544 [ 0.000000] Normal zone: 1728 pages used for memmap 1545 [ 0.000000] Normal zone: 0 pages reserved 1546 [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 1547 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 1548 [ 0.000000] psci: probing for conduit method from DT. 1549 [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT 1550 [ 0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920 1551 [ 0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096 1552 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 1553 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 1554 [ 0.000000] Kernel command line: root=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=5d748697-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 1555 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) 1556 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) 1557 [ 0.000000] allocated 1048576 bytes of page_ext 1558 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 1559 [ 0.000000] Memory: 880656K/1048576K available (9216K kernel code, 1002K rwdata, 3268K rodata, 1024K init, 327K bss, 36848K reserved, 131072K cma-reserved, 131060K highmem) 1560 [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 with crng_init=0 1561 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 1562 [ 0.000000] ftrace: allocating 39954 entries in 79 pages 1563 [ 0.000000] ftrace: allocated 79 pages with 5 groups 1564 [ 0.000000] rcu: Hierarchical RCU implementation. 1565 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. 1566 [ 0.000000] Rude variant of Tasks RCU enabled. 1567 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 1568 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 1569 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 1570 [ 0.000000] GIC: Using split EOI/Deactivate mode 1571 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns 1572 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 1573 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 1574 [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 1575 [ 0.000014] Switching to timer-based delay loop, resolution 41ns 1576 [ 0.000237] Console: colour dummy device 80x30 1577 [ 0.000250] printk: console [tty1] enabled 1578 [ 0.000300] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 1579 [ 0.000311] pid_max: default: 32768 minimum: 301 1580 [ 0.000519] LSM: Security Framework initializing 1581 [ 0.000576] Yama: becoming mindful. 1582 [ 0.000717] AppArmor: AppArmor initialized 1583 [ 0.000776] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 1584 [ 0.000788] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) 1585 [ 0.001827] CPU: Testing write buffer coherency: ok 1586 [ 0.002189] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 1587 [ 0.002737] Setting up static identity map for 0x40100000 - 0x40100054 1588 [ 0.002855] rcu: Hierarchical SRCU implementation. 1589 [ 0.006031] smp: Bringing up secondary CPUs ... 1590 [ 0.016789] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 1591 [ 0.027636] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 1592 [ 0.038415] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 1593 [ 0.038510] smp: Brought up 1 node, 4 CPUs 1594 [ 0.038518] SMP: Total of 4 processors activated (192.00 BogoMIPS). 1595 [ 0.038521] CPU: All CPU(s) started in HYP mode. 1596 [ 0.038524] CPU: Virtualization extensions available. 1597 [ 0.039456] devtmpfs: initialized 1598 [ 0.046588] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 1599 [ 0.046930] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 1600 [ 0.046971] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) 1601 [ 0.051518] xor: measuring software checksum speed 1602 [ 0.090398] arm4regs : 1255.000 MB/sec 1603 [ 0.130458] 8regs : 874.000 MB/sec 1604 [ 0.170526] 32regs : 826.000 MB/sec 1605 [ 0.210589] neon : 1271.000 MB/sec 1606 [ 0.210593] xor: using function: neon (1271.000 MB/sec) 1607 [ 0.210659] pinctrl core: initialized pinctrl subsystem 1608 [ 0.211145] thermal_sys: Registered thermal governor 'fair_share' 1609 [ 0.211149] thermal_sys: Registered thermal governor 'bang_bang' 1610 [ 0.211153] thermal_sys: Registered thermal governor 'step_wise' 1611 [ 0.212178] NET: Registered protocol family 16 1612 [ 0.213725] DMA: preallocated 256 KiB pool for atomic coherent allocations 1613 [ 0.214186] audit: initializing netlink subsys (disabled) 1614 [ 0.214402] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1 1615 [ 0.215041] cpuidle: using governor ladder 1616 [ 0.215163] cpuidle: using governor menu 1617 [ 0.215672] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 1618 [ 0.215677] hw-breakpoint: maximum watchpoint size is 8 bytes. 1619 [ 0.237604] cryptd: max_cpu_qlen set to 1000 1620 [ 0.306828] raid6: neonx8 gen() 775 MB/s 1621 [ 0.374882] raid6: neonx8 xor() 582 MB/s 1622 [ 0.442976] raid6: neonx4 gen() 831 MB/s 1623 [ 0.511056] raid6: neonx4 xor() 629 MB/s 1624 [ 0.579149] raid6: neonx2 gen() 915 MB/s 1625 [ 0.647230] raid6: neonx2 xor() 652 MB/s 1626 [ 0.715317] raid6: neonx1 gen() 816 MB/s 1627 [ 0.783393] raid6: neonx1 xor() 565 MB/s 1628 [ 0.851543] raid6: int32x8 gen() 303 MB/s 1629 [ 0.919616] raid6: int32x8 xor() 176 MB/s 1630 [ 0.987692] raid6: int32x4 gen() 357 MB/s 1631 [ 1.055773] raid6: int32x4 xor() 205 MB/s 1632 [ 1.123846] raid6: int32x2 gen() 399 MB/s 1633 [ 1.191978] raid6: int32x2 xor() 213 MB/s 1634 [ 1.260057] raid6: int32x1 gen() 390 MB/s 1635 [ 1.328120] raid6: int32x1 xor() 192 MB/s 1636 [ 1.328124] raid6: using algorithm neonx2 gen() 915 MB/s 1637 [ 1.328127] raid6: .... xor() 652 MB/s, rmw enabled 1638 [ 1.328132] raid6: using neon recovery algorithm 1639 [ 1.329433] iommu: Default domain type: Translated 1640 [ 1.329800] SCSI subsystem initialized 1641 [ 1.330019] libata version 3.00 loaded. 1642 [ 1.330242] usbcore: registered new interface driver usbfs 1643 [ 1.330290] usbcore: registered new interface driver hub 1644 [ 1.330358] usbcore: registered new device driver usb 1645 [ 1.330449] mc: Linux media interface: v0.10 1646 [ 1.330477] videodev: Linux video capture interface: v2.00 1647 [ 1.330600] pps_core: LinuxPPS API ver. 1 registered 1648 [ 1.330604] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 1649 [ 1.330619] PTP clock support registered 1650 [ 1.330980] Advanced Linux Sound Architecture Driver Initialized. 1651 [ 1.331660] NetLabel: Initializing 1652 [ 1.331667] NetLabel: domain hash size = 128 1653 [ 1.331670] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 1654 [ 1.331744] NetLabel: unlabeled traffic allowed by default 1655 [ 1.332414] clocksource: Switched to clocksource arch_sys_counter 1656 [ 1.426354] VFS: Disk quotas dquot_6.6.0 1657 [ 1.426442] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 1658 [ 1.427022] AppArmor: AppArmor Filesystem Enabled 1659 [ 1.435288] NET: Registered protocol family 2 1660 [ 1.436008] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) 1661 [ 1.436051] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) 1662 [ 1.436145] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) 1663 [ 1.436256] TCP: Hash tables configured (established 8192 bind 8192) 1664 [ 1.436437] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) 1665 [ 1.436484] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) 1666 [ 1.436735] NET: Registered protocol family 1 1667 [ 1.437144] Trying to unpack rootfs image as initramfs... 1668 [ 2.092078] Freeing initrd memory: 9672K 1669 [ 2.093401] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 1670 [ 2.094536] Initialise system trusted keyrings 1671 [ 2.094589] Key type blacklist registered 1672 [ 2.094814] workingset: timestamp_bits=14 max_order=18 bucket_order=4 1673 [ 2.100356] zbud: loaded 1674 [ 2.101840] squashfs: version 4.0 (2009/01/31) Phillip Lougher 1675 [ 2.102784] fuse: init (API version 7.31) 1676 [ 2.105396] integrity: Platform Keyring initialized 1677 [ 2.210691] Key type asymmetric registered 1678 [ 2.210698] Asymmetric key parser 'x509' registered 1679 [ 2.210867] bounce: pool size: 64 pages 1680 [ 2.210927] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 1681 [ 2.211131] io scheduler mq-deadline registered 1682 [ 2.211138] io scheduler kyber registered 1683 [ 2.211304] io scheduler bfq registered 1684 [ 2.217035] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver 1685 [ 2.218723] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver 1686 [ 2.225529] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 1687 [ 2.227857] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator 1688 [ 2.228328] printk: console [ttyS0] disabled 1689 [ 2.228469] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a 16550A 1690 [ 2.228528] printk: console [ttyS0] enabled 1691 [ 2.244192] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a9f100) 1692 [ 2.244510] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9c000) 1693 [ 2.244575] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator 1694 [ 2.245467] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) 1695 [ 2.245865] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver 1696 [ 2.246111] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a9e6fc) 1697 [ 2.246121] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 1698 [ 2.246541] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 1699 [ 2.351364] random: fast init done 1700 [ 2.602582] Console: switching to colour frame buffer device 160x45 1701 [ 2.675189] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device 1702 [ 2.678785] brd: module loaded 1703 [ 2.685533] loop: module loaded 1704 [ 2.687552] libphy: Fixed MDIO Bus: probed 1705 [ 2.688068] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found 1706 [ 2.688076] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found 1707 [ 2.688199] dwmac-sun8i 1c30000.ethernet: PTP uses main clock 1708 [ 2.688247] dwmac-sun8i 1c30000.ethernet: supply phy not found, using dummy regulator 1709 [ 2.688354] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator 1710 [ 2.688775] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) 1711 [ 2.688795] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported 1712 [ 2.688801] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported 1713 [ 2.688807] dwmac-sun8i 1c30000.ethernet: COE Type 2 1714 [ 2.688813] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported 1715 [ 2.688819] dwmac-sun8i 1c30000.ethernet: Normal descriptors 1716 [ 2.688825] dwmac-sun8i 1c30000.ethernet: Chain mode enabled 1717 [ 2.689325] libphy: stmmac: probed 1718 [ 2.689886] dwmac-sun8i 1c30000.ethernet: Found internal PHY node 1719 [ 2.690312] libphy: mdio_mux: probed 1720 [ 2.690336] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY 1721 [ 2.690345] dwmac-sun8i 1c30000.ethernet: Powering internal PHY 1722 [ 2.703437] libphy: mdio_mux: probed 1723 [ 2.704624] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 1724 [ 2.704660] ehci-platform: EHCI generic platform driver 1725 [ 2.704886] ehci-platform 1c1a000.usb: EHCI Host Controller 1726 [ 2.704916] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 1727 [ 2.705346] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 1728 [ 2.720411] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 1729 [ 2.720680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1730 [ 2.720688] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1731 [ 2.720694] usb usb1: Product: EHCI Host Controller 1732 [ 2.720700] usb usb1: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1733 [ 2.720706] usb usb1: SerialNumber: 1c1a000.usb 1734 [ 2.721304] hub 1-0:1.0: USB hub found 1735 [ 2.721347] hub 1-0:1.0: 1 port detected 1736 [ 2.722263] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 1737 [ 2.722286] ohci-platform: OHCI generic platform driver 1738 [ 2.722458] ohci-platform 1c1a400.usb: Generic Platform OHCI controller 1739 [ 2.722480] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 1740 [ 2.722687] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 1741 [ 2.784608] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1742 [ 2.784617] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1743 [ 2.784623] usb usb2: Product: Generic Platform OHCI controller 1744 [ 2.784629] usb usb2: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1745 [ 2.784635] usb usb2: SerialNumber: 1c1a400.usb 1746 [ 2.785153] hub 2-0:1.0: USB hub found 1747 [ 2.785190] hub 2-0:1.0: 1 port detected 1748 [ 2.786556] usbcore: registered new interface driver usb-storage 1749 [ 2.787565] sun6i-rtc 1f00000.rtc: registered as rtc0 1750 [ 2.787607] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:11 UTC (11) 1751 [ 2.787613] sun6i-rtc 1f00000.rtc: RTC enabled 1752 [ 2.787922] i2c /dev entries driver 1753 [ 2.788302] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator 1754 [ 2.790542] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) 1755 [ 2.790982] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator 1756 [ 2.791691] sunxi-mmc 1c0f000.mmc: Got CD GPIO 1757 [ 2.817018] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB 1758 [ 2.818239] ledtrig-cpu: registered to indicate activity on CPUs 1759 [ 2.818327] hid: raw HID events driver (C) Jiri Kosina 1760 [ 2.818458] usbcore: registered new interface driver usbhid 1761 [ 2.818460] usbhid: USB HID core driver 1762 [ 2.822455] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present! 1763 [ 2.823954] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok 1764 [ 2.826728] Initializing XFRM netlink socket 1765 [ 2.827261] NET: Registered protocol family 10 1766 [ 2.855778] mmc0: host does not support reading read-only switch, assuming write-enable 1767 [ 2.857749] mmc0: new high speed SDHC card at address 0001 1768 [ 2.859366] mmcblk0: mmc0:0001 SD16G 29.2 GiB 1769 [ 2.863237] mmcblk0: p1 1770 [ 2.874872] Segment Routing with IPv6 1771 [ 2.874989] NET: Registered protocol family 17 1772 [ 2.875021] NET: Registered protocol family 15 1773 [ 2.875092] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 1774 [ 2.875206] 8021q: 802.1Q VLAN Support v1.8 1775 [ 2.875264] Key type dns_resolver registered 1776 [ 2.875715] Registering SWP/SWPB emulation handler 1777 [ 2.876024] registered taskstats version 1 1778 [ 2.876031] Loading compiled-in X.509 certificates 1779 [ 2.882751] Loaded X.509 cert 'Build time autogenerated kernel key: 346848ecd67c995d675bab6785bece621761b48f' 1780 [ 2.882909] zswap: loaded using pool lzo/zbud 1781 [ 2.883568] Key type ._fscrypt registered 1782 [ 2.883574] Key type .fscrypt registered 1783 [ 2.883577] Key type fscrypt-provisioning registered 1784 [ 2.888822] Btrfs loaded, crc32c=crc32c-generic 1785 [ 2.911172] Key type encrypted registered 1786 [ 2.911193] AppArmor: AppArmor sha1 policy hashing enabled 1787 [ 2.922918] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator 1788 [ 2.924478] ehci-platform 1c1b000.usb: EHCI Host Controller 1789 [ 2.924512] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 1790 [ 2.924965] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 1791 [ 2.940413] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 1792 [ 2.940717] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1793 [ 2.940726] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1794 [ 2.940733] usb usb3: Product: EHCI Host Controller 1795 [ 2.940739] usb usb3: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1796 [ 2.940746] usb usb3: SerialNumber: 1c1b000.usb 1797 [ 2.941402] hub 3-0:1.0: USB hub found 1798 [ 2.941453] hub 3-0:1.0: 1 port detected 1799 [ 2.942322] ehci-platform 1c1c000.usb: EHCI Host Controller 1800 [ 2.942347] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 1801 [ 2.942635] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 1802 [ 2.956413] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 1803 [ 2.956676] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1804 [ 2.956685] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1805 [ 2.956691] usb usb4: Product: EHCI Host Controller 1806 [ 2.956697] usb usb4: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1807 [ 2.956703] usb usb4: SerialNumber: 1c1c000.usb 1808 [ 2.957245] hub 4-0:1.0: USB hub found 1809 [ 2.957285] hub 4-0:1.0: 1 port detected 1810 [ 2.958094] ehci-platform 1c1d000.usb: EHCI Host Controller 1811 [ 2.958119] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 1812 [ 2.958410] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 1813 [ 2.972411] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 1814 [ 2.972646] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1815 [ 2.972654] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1816 [ 2.972660] usb usb5: Product: EHCI Host Controller 1817 [ 2.972666] usb usb5: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 1818 [ 2.972672] usb usb5: SerialNumber: 1c1d000.usb 1819 [ 2.973167] hub 5-0:1.0: USB hub found 1820 [ 2.973203] hub 5-0:1.0: 1 port detected 1821 [ 2.973981] ohci-platform 1c1b400.usb: Generic Platform OHCI controller 1822 [ 2.974005] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 1823 [ 2.974214] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 1824 [ 3.036615] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1825 [ 3.036624] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1826 [ 3.036630] usb usb6: Product: Generic Platform OHCI controller 1827 [ 3.036637] usb usb6: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1828 [ 3.036642] usb usb6: SerialNumber: 1c1b400.usb 1829 [ 3.037142] hub 6-0:1.0: USB hub found 1830 [ 3.037179] hub 6-0:1.0: 1 port detected 1831 [ 3.037977] ohci-platform 1c1c400.usb: Generic Platform OHCI controller 1832 [ 3.038000] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 1833 [ 3.038187] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 1834 [ 3.100603] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1835 [ 3.100612] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1836 [ 3.100619] usb usb7: Product: Generic Platform OHCI controller 1837 [ 3.100625] usb usb7: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1838 [ 3.100631] usb usb7: SerialNumber: 1c1c400.usb 1839 [ 3.101159] hub 7-0:1.0: USB hub found 1840 [ 3.101206] hub 7-0:1.0: 1 port detected 1841 [ 3.102000] ohci-platform 1c1d400.usb: Generic Platform OHCI controller 1842 [ 3.102023] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 1843 [ 3.102259] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 1844 [ 3.164595] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 1845 [ 3.164605] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1846 [ 3.164612] usb usb8: Product: Generic Platform OHCI controller 1847 [ 3.164618] usb usb8: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 1848 [ 3.164624] usb usb8: SerialNumber: 1c1d400.usb 1849 [ 3.165155] hub 8-0:1.0: USB hub found 1850 [ 3.165194] hub 8-0:1.0: 1 port detected 1851 [ 3.166856] of_cfs_init 1852 [ 3.166974] of_cfs_init: OK 1853 [ 3.167123] ALSA device list: 1854 [ 3.167129] #0: H3 Audio Codec 1855 [ 3.171031] Freeing unused kernel memory: 1024K 1856 [ 3.180689] Run /init as init process 1857 [ 3.180696] with arguments: 1858 [ 3.180699] /init 1859 [ 3.180702] with environment: 1860 [ 3.180706] HOME=/ 1861 [ 3.180710] TERM=linux 1862 [ 3.180714] ubootpart=5d748697-01 1863 [ 3.180718] ubootsource=mmc 1864 [ 3.180721] sunxi_ve_mem_reserve=0 1865 [ 3.180725] sunxi_g2d_mem_reserve=0 1866 [ 3.180728] sunxi_fb_mem_reserve=16 1867 [ 3.180731] cgroup_enable=memory 1868 [ 3.181212] process '/usr/bin/sh' started with executable stack 1869 [ 3.536457] usb 6-1: new low-speed USB device number 2 using ohci-platform 1870 [ 3.560482] usb 8-1: new low-speed USB device number 2 using ohci-platform 1871 [ 3.566278] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 1872 [ 3.625703] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator 1873 [ 3.626767] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver 1874 [ 3.626804] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9 1875 [ 3.627157] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 1876 [ 3.627173] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1877 [ 3.627180] usb usb9: Product: MUSB HDRC host driver 1878 [ 3.627187] usb usb9: Manufacturer: Linux 5.8.5-sunxi musb-hcd 1879 [ 3.627193] usb usb9: SerialNumber: musb-hdrc.4.auto 1880 [ 3.627951] phy id_det change to device 1881 [ 3.628827] hub 9-0:1.0: USB hub found 1882 [ 3.628885] hub 9-0:1.0: 1 port detected 1883 [ 3.764561] usb 6-1: New USB device found, idVendor=046d, idProduct=c517, bcdDevice=38.10 1884 [ 3.764574] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1885 [ 3.764581] usb 6-1: Product: USB Receiver 1886 [ 3.764587] usb 6-1: Manufacturer: Logitech 1887 [ 3.773804] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C517.0001/input/input1 1888 [ 3.786484] usb 8-1: New USB device found, idVendor=04f3, idProduct=0234, bcdDevice=24.58 1889 [ 3.786496] usb 8-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 1890 [ 3.786503] usb 8-1: Product: OM 1891 [ 3.795531] input: OM as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:04F3:0234.0002/input/input2 1892 [ 3.832700] hid-generic 0003:046D:C517.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 1893 [ 3.834120] hid-generic 0003:04F3:0234.0002: input,hidraw1: USB HID v1.11 Mouse [OM] on usb-1c1d400.usb-1/input0 1894 [ 3.843316] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input3 1895 [ 3.843564] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input4 1896 [ 3.900630] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input5 1897 [ 3.901083] hid-generic 0003:046D:C517.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 1898 [ 3.958075] logitech-djreceiver 0003:046D:C517.0001: hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 1899 [ 4.051090] logitech-djreceiver 0003:046D:C517.0003: hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 1900 [ 4.124547] logitech-djreceiver 0003:046D:C517.0003: device of type 27 Mhz (0x02) connected on slot 3 1901 [ 4.127495] input: Logitech Wireless Keyboard PID:0062 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input8 1902 [ 4.127768] input: Logitech Wireless Keyboard PID:0062 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input9 1903 [ 4.127943] input: Logitech Wireless Keyboard PID:0062 System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input10 1904 [ 4.128220] hid-generic 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 1905 [ 4.236580] logitech-hidpp-device 0003:046D:0062.0004: HID++ 1.0 device connected. 1906 [ 4.286469] input: Logitech Wireless Keyboard PID:0062 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input14 1907 [ 4.286722] logitech-hidpp-device 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 1908 [ 5.511647] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 1909 [ 6.351936] systemd[1]: System time before build time, advancing clock. 1910 [ 6.376743] systemd[1]: Inserted module 'autofs4' 1911 [ 6.443120] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 1912 [ 6.443863] systemd[1]: Detected architecture arm. 1913 [ 6.469959] systemd[1]: Set hostname to <orangepipc>. 1914 [ 7.167586] random: systemd: uninitialized urandom read (16 bytes read) 1915 [ 7.182132] random: systemd: uninitialized urandom read (16 bytes read) 1916 [ 7.182855] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 1917 [ 7.184264] random: systemd: uninitialized urandom read (16 bytes read) 1918 [ 7.184707] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. 1919 [ 7.186742] systemd[1]: Listening on udev Control Socket. 1920 [ 7.187642] systemd[1]: Reached target Local Encrypted Volumes. 1921 [ 7.192006] systemd[1]: Created slice User and Session Slice. 1922 [ 7.194085] systemd[1]: Listening on Journal Audit Socket. 1923 [ 7.197733] systemd[1]: Created slice system-serial\x2dgetty.slice. 1924 [ 7.381830] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 1925 [ 8.620473] zram: Added device: zram0 1926 [ 8.621135] zram: Added device: zram1 1927 [ 8.636913] zram: Added device: zram2 1928 [ 8.728105] sun8i-di 1400000.deinterlace: Device registered as /dev/video0 1929 [ 8.741689] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 1930 [ 8.771361] cedrus 1c0e000.video-codec: Device registered as /dev/video1 1931 [ 8.792583] zram1: detected capacity change from 0 to 523481088 1932 [ 8.867994] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz) 1933 [ 8.880494] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1934 [ 8.896764] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1935 [ 8.897393] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1936 [ 8.897764] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 1937 [ 8.898008] sun8i-ce 1c15000.crypto: Register cbc(aes) 1938 [ 8.898240] sun8i-ce 1c15000.crypto: Register ecb(aes) 1939 [ 8.898380] sun8i-ce 1c15000.crypto: Register cbc(des3_ede) 1940 [ 8.898505] sun8i-ce 1c15000.crypto: Register ecb(des3_ede) 1941 [ 8.898653] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1 1942 [ 8.970274] sun8i-thermal 1c25000.thermal-sensor: Thermal sensor ready! 1943 [ 9.035998] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 1944 [ 9.036054] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 1945 [ 9.036122] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 1946 [ 9.036164] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 1947 [ 9.044089] lima 1c40000.gpu: bus rate = 200000000 1948 [ 9.044103] lima 1c40000.gpu: mod rate = 297000000 1949 [ 9.044208] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 1950 [ 9.044698] lima 1c40000.gpu: Failed to register cooling device 1951 [ 9.045136] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1 1952 [ 9.094209] Registered IR keymap rc-empty 1953 [ 9.094353] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 1954 [ 9.095989] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter 1955 [ 9.096187] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input15 1956 [ 9.118646] mousedev: PS/2 mouse device common for all mice 1957 [ 9.119884] sunxi-ir 1f02000.ir: initialized sunXi IR driver 1958 [ 9.410435] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok 1959 [ 9.888511] Adding 511208k swap on /dev/zram1. Priority:5 extents:1 across:511208k SSFS 1960 [ 10.062075] zram0: detected capacity change from 0 to 52428800 1961 [ 12.142161] systemd[1]: Started Armbian ZRAM config. 1962 [ 12.148997] systemd[1]: Starting Armbian memory supported logging... 1963 [ 12.237530] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 1964 [ 12.237577] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 1965 [ 15.585893] systemd[1]: Started Armbian memory supported logging. 1966 [ 15.592268] systemd[1]: Starting Journal Service... 1967 [ 15.865713] systemd[1]: Started Journal Service. 1968 [ 15.926148] systemd-journald[538]: Received request to flush runtime journal from PID 1 1969 [ 16.524999] random: crng init done 1970 [ 16.525008] random: 7 urandom warning(s) missed due to ratelimiting 1971 1972 ### armbian-release: 1973 1974 # PLEASE DO NOT EDIT THIS FILE 1975 BOARD=orangepipc 1976 BOARD_NAME="Orange Pi PC" 1977 BOARDFAMILY=sun8i 1978 BUILD_REPOSITORY_URL=https://github.com/armbian/build 1979 BUILD_REPOSITORY_COMMIT=e6fa811d-dirty 1980 DISTRIBUTION_CODENAME=buster 1981 DISTRIBUTION_STATUS=supported 1982 VERSION=20.08.1 1983 LINUXFAMILY=sunxi 1984 BRANCH=current 1985 ARCH=arm 1986 IMAGE_TYPE=stable 1987 BOARD_TYPE=conf 1988 INITRD_ARCH=arm 1989 KERNEL_IMAGE_TYPE=Image 1990 1991 ### boot environment: 1992 1993 verbosity=1 1994 bootlogo=false 1995 console=both 1996 disp_mode=1920x1080p60 1997 overlay_prefix=sun8i-h3 1998 rootdev=UUID=4b9e57b7-4690-4e61-8e27-b7f542b413da 1999 rootfstype=ext4 2000 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 2001 2002 ### lsusb: 2003 2004 Bus 008 Device 002: ID 04f3:0234 Elan Microelectronics Corp. Optical Mouse 2005 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2006 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2007 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2008 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2009 Bus 006 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser 2010 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2011 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2012 Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2013 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2014 Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2015 2016 ### lscpu: 2017 2018 Architecture: armv7l 2019 Byte Order: Little Endian 2020 CPU(s): 4 2021 On-line CPU(s) list: 0-3 2022 Thread(s) per core: 1 2023 Core(s) per socket: 4 2024 Socket(s): 1 2025 Vendor ID: ARM 2026 Model: 5 2027 Model name: Cortex-A7 2028 Stepping: r0p5 2029 CPU max MHz: 1368.0000 2030 CPU min MHz: 480.0000 2031 BogoMIPS: 65.14 2032 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 2033 2034 ### cpuinfo: 2035 2036 processor : 0 2037 model name : ARMv7 Processor rev 5 (v7l) 2038 BogoMIPS : 65.14 2039 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 2040 CPU implementer : 0x41 2041 CPU architecture: 7 2042 CPU variant : 0x0 2043 CPU part : 0xc07 2044 CPU revision : 5 2045 2046 processor : 1 2047 model name : ARMv7 Processor rev 5 (v7l) 2048 BogoMIPS : 65.14 2049 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 2050 CPU implementer : 0x41 2051 CPU architecture: 7 2052 CPU variant : 0x0 2053 CPU part : 0xc07 2054 CPU revision : 5 2055 2056 processor : 2 2057 model name : ARMv7 Processor rev 5 (v7l) 2058 BogoMIPS : 65.14 2059 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 2060 CPU implementer : 0x41 2061 CPU architecture: 7 2062 CPU variant : 0x0 2063 CPU part : 0xc07 2064 CPU revision : 5 2065 2066 processor : 3 2067 model name : ARMv7 Processor rev 5 (v7l) 2068 BogoMIPS : 65.14 2069 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 2070 CPU implementer : 0x41 2071 CPU architecture: 7 2072 CPU variant : 0x0 2073 CPU part : 0xc07 2074 CPU revision : 5 2075 2076 Hardware : Allwinner sun8i Family 2077 Revision : 0000 2078 Serial : 02c00081abf8f0eb 2079 2080 ### meminfo: 2081 2082 MemTotal: 1022424 kB 2083 MemFree: 893632 kB 2084 MemAvailable: 924972 kB 2085 Buffers: 7996 kB 2086 Cached: 37516 kB 2087 SwapCached: 0 kB 2088 Active: 36880 kB 2089 Inactive: 20504 kB 2090 Active(anon): 12340 kB 2091 Inactive(anon): 1492 kB 2092 Active(file): 24540 kB 2093 Inactive(file): 19012 kB 2094 Unevictable: 0 kB 2095 Mlocked: 0 kB 2096 HighTotal: 262132 kB 2097 HighFree: 184520 kB 2098 LowTotal: 760292 kB 2099 LowFree: 709112 kB 2100 SwapTotal: 511208 kB 2101 SwapFree: 511208 kB 2102 Dirty: 268 kB 2103 Writeback: 100 kB 2104 AnonPages: 12092 kB 2105 Mapped: 14336 kB 2106 Shmem: 1664 kB 2107 KReclaimable: 12024 kB 2108 Slab: 35464 kB 2109 SReclaimable: 12024 kB 2110 SUnreclaim: 23440 kB 2111 KernelStack: 1104 kB 2112 PageTables: 772 kB 2113 NFS_Unstable: 0 kB 2114 Bounce: 0 kB 2115 WritebackTmp: 0 kB 2116 CommitLimit: 1022420 kB 2117 Committed_AS: 83508 kB 2118 VmallocTotal: 245760 kB 2119 VmallocUsed: 9524 kB 2120 VmallocChunk: 0 kB 2121 Percpu: 752 kB 2122 CmaTotal: 131072 kB 2123 CmaFree: 92268 kB 2124 2125 ### virtual memory: 2126 2127 vm.admin_reserve_kbytes = 8192 2128 vm.block_dump = 0 2129 vm.compact_unevictable_allowed = 1 2130 vm.dirty_background_bytes = 0 2131 vm.dirty_background_ratio = 10 2132 vm.dirty_bytes = 0 2133 vm.dirty_expire_centisecs = 3000 2134 vm.dirty_ratio = 20 2135 vm.dirty_writeback_centisecs = 500 2136 vm.dirtytime_expire_seconds = 43200 2137 vm.extfrag_threshold = 500 2138 vm.highmem_is_dirtyable = 0 2139 vm.laptop_mode = 0 2140 vm.legacy_va_layout = 0 2141 vm.lowmem_reserve_ratio = 32 0 0 2142 vm.max_map_count = 65530 2143 vm.min_free_kbytes = 3463 2144 vm.mmap_min_addr = 4096 2145 vm.mmap_rnd_bits = 8 2146 vm.oom_dump_tasks = 1 2147 vm.oom_kill_allocating_task = 0 2148 vm.overcommit_kbytes = 0 2149 vm.overcommit_memory = 0 2150 vm.overcommit_ratio = 50 2151 vm.page-cluster = 0 2152 vm.panic_on_oom = 0 2153 vm.percpu_pagelist_fraction = 0 2154 vm.stat_interval = 1 2155 vm.swappiness = 100 2156 vm.user_reserve_kbytes = 31484 2157 vm.vfs_cache_pressure = 100 2158 vm.watermark_boost_factor = 15000 2159 vm.watermark_scale_factor = 10 2160 2161 ### ip addr: 2162 2163 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 2164 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2165 inet XXX.XXX.0.1/8 scope host lo 2166 valid_lft forever preferred_lft forever 2167 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 2168 link/ether 02:81:ab:f8:f0:eb brd ff:ff:ff:ff:ff:ff 2169 2170 ### partitions: 2171 2172 major minor #blocks name 2173 2174 179 0 30578688 mmcblk0 2175 179 1 30268800 mmcblk0p1 2176 254 0 51200 zram0 2177 254 1 511212 zram1 2178 2179 ### df: 2180 2181 udev 431M 0 431M 0% /dev 2182 tmpfs 100M 1.8M 99M 2% /run 2183 /dev/mmcblk0p1 29G 2.1G 26G 8% / 2184 tmpfs 500M 0 500M 0% /dev/shm 2185 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 2186 tmpfs 500M 0 500M 0% /sys/fs/cgroup 2187 tmpfs 500M 4.0K 500M 1% /tmp 2188 /dev/zram0 49M 2.2M 43M 5% /var/log 2189 2190 ### lsblk: 2191 2192 NAME FSTYPE SIZE MOUNTPOINT UUID 2193 mmcblk0 29.2G 2194 `-mmcblk0p1 ext4 28.9G / 4b9e57b7-4690-4e61-8e27-b7f542b413da 2195 zram0 50M /var/log 2196 2197 ### zramctl: 2198 2199 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2200 /dev/zram1 lzo-rle 499.2M 4K 73B 4K 4 [SWAP] 2201 /dev/zram0 zstd 50M 2.2M 405.2K 736K 4 /var/log 2202 2203 ### mtab: 2204 2205 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2206 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2207 /dev/zram0 /var/log ext4 rw,relatime,discard 0 0 2208 2209 ### mmc0:0001 info: 2210 2211 manfid: 0x000000 2212 cid: 003432534431364720000003bd013773 2213 fwrev: 0x0 2214 rca: 0x0001 2215 csd: 400e00325b590000e94b7f800a40001b 2216 ocr: 0x00200000 2217 type: SD 2218 date: 07/2019 2219 hwrev: 0x2 2220 dsr: 0x404 2221 serial: 0x000003bd 2222 erase_size: 512 2223 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block 2224 ssr: 000000000500000004049000080a190a000800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 2225 scr: 0285804200000000 2226 oemid: 0x3432 2227 preferred_erase_size: 4194304 2228 name: SD16G 2229 2230 ### Boot system health: 2231 2232 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 2233 16:17:13: 1368MHz 0.52 42% 22% 16% 0% 3% 0% 60.1°C 0/8 2234 16:17:13: 1368MHz 0.52 51% 19% 18% 2% 11% 0% 58.4°C 0/8 2235 16:17:13: 1368MHz 0.52 45% 10% 3% 0% 31% 0% 53.0°C 0/8 2236 16:17:14: 1368MHz 0.64 42% 12% 18% 1% 10% 0% 57.3°C 0/8 2237 16:17:14: 1368MHz 0.64 29% 8% 12% 1% 6% 0% 56.3°C 0/8 2238 2239 ### lsusb: 2240 2241 Bus 008 Device 002: ID 04f3:0234 Elan Microelectronics Corp. Optical Mouse 2242 Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2243 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2244 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2245 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2246 Bus 006 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser 2247 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2248 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2249 Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 2250 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2251 Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2252 2253 /: Bus 09.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M 2254 /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 2255 |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 2256 /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 2257 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 2258 |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 2259 |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M 2260 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 2261 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 2262 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 2263 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 2264 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 2265 2266 ### Installed packages: 2267 2268 ii armbian-buster-desktop 20.08.1 all Armbian desktop for Debian buster 2269 ii armbian-config 20.08.1 all Armbian configuration utility 2270 ii armbian-firmware 20.08.1 all Linux firmware 2271 ii hostapd 3:2.9-102~armbian20.05.2+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 2272 ii htop 2.2.0-5~armbian20.08.1+1 armhf interactive processes viewer 2273 ii linux-base 4.6 all Linux image base package 2274 ii linux-buster-root-current-orangepipc 20.08.1 armhf Armbian tweaks for buster on orangepipc (current branch) 2275 ii linux-dtb-current-sunxi 20.08.1 armhf Linux DTB, version 5.8.5-sunxi 2276 ii linux-image-current-sunxi 20.08.1 armhf Linux kernel, version 5.8.5-sunxi 2277 ii linux-libc-dev:armhf 4.19.132-1 armhf Linux support headers for userspace development 2278 ii linux-u-boot-orangepipc-current 20.08.1 armhf Uboot loader 2020.04 2279 2280 ### Loaded modules: 2281 2282 Module Size Used by 2283 rfkill 20480 1 2284 snd_soc_hdmi_codec 20480 1 2285 sunxi_cir 20480 0 2286 mousedev 20480 0 2287 joydev 24576 0 2288 sun4i_gpadc_iio 16384 0 2289 dw_hdmi_cec 16384 0 2290 dw_hdmi_i2s_audio 16384 0 2291 input_leds 16384 0 2292 lima 45056 0 2293 industrialio 53248 1 sun4i_gpadc_iio 2294 gpu_sched 28672 1 lima 2295 sun8i_thermal 16384 0 2296 sun8i_ce 24576 0 2297 crypto_engine 16384 1 sun8i_ce 2298 sunxi_cedrus 32768 0 2299 sun8i_di 20480 0 2300 evdev 20480 6 2301 uio_pdrv_genirq 16384 0 2302 uio 16384 1 uio_pdrv_genirq 2303 display_connector 20480 0 2304 zram 24576 2 2305 cpufreq_dt 20480 0 2306 ip_tables 24576 0 2307 x_tables 24576 1 ip_tables 2308 autofs4 36864 2 2309 hid_logitech_hidpp 36864 0 2310 hid_logitech_dj 20480 0 2311 sy8106a_regulator 16384 1 2312 sunxi 20480 0 2313 phy_generic 20480 2 sunxi 2314 gpio_keys 20480 0 2315 2316 ### Current system health: 2317 2318 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 2319 16:25:22: 1368MHz 0.02 6% 1% 4% 0% 0% 0% 45.8°C 0/8 2320 16:25:22: 1368MHz 0.02 6% 3% 0% 2% 0% 0% 44.3°C 0/8 2321 16:25:23: 1368MHz 0.02 5% 3% 0% 1% 0% 0% 49.0°C 0/8 2322 16:25:23: 1368MHz 0.02 5% 3% 0% 1% 0% 0% 45.6°C 0/8 2323 16:25:24: 1368MHz 0.02 5% 4% 0% 0% 0% 0% 49.5°C 0/8 2324 16:25:27: 1368MHz 0.10 6% 1% 4% 0% 0% 0% 61.6°C 0/8 2325 16:25:27: 1368MHz 0.10 66% 1% 65% 0% 0% 0% 53.6°C 0/8 2326 16:25:28: 1368MHz 0.10 6% 4% 0% 1% 0% 0% 52.2°C 0/8 2327 16:25:28: 1368MHz 0.10 5% 3% 0% 1% 0% 0% 52.2°C 0/8 2328 16:25:29: 1368MHz 0.10 6% 4% 0% 1% 0% 0% 50.7°C 0/8 2329 2330 ### resolv.conf 2331 2332 -rw-r--r-- 1 root root 63 Sep 3 16:17 /etc/resolv.conf 2333 # Generated by NetworkManager 2334 search lan 2335 nameserver XXX.XXX.0.1 2336 2337 ### Current sysinfo: 2338 2339 Linux 5.8.5-sunxi (orangepipc) 09/03/20 _armv7l_ (4 CPU) 2340 2341 avg-cpu: %user %nice %system %iowait %steal %idle 2342 4.79 0.05 1.60 0.22 0.00 93.34 2343 2344 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn 2345 ram0 0.00 0.00 0.00 0 0 2346 ram1 0.00 0.00 0.00 0 0 2347 ram2 0.00 0.00 0.00 0 0 2348 ram3 0.00 0.00 0.00 0 0 2349 mmcblk0 12.19 395.61 3.54 204077 1824 2350 mmcblk0p1 11.91 389.53 3.54 200941 1824 2351 zram0 0.72 1.64 5.33 844 2748 2352 zram1 0.59 2.33 0.01 1204 4 2353 zram2 0.00 0.00 0.00 0 0 2354 2355 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 2356 r b swpd free buff cache si so bi bo in cs us sy id wa st 2357 0 0 0 549128 16296 160420 0 0 99 2 85 103 5 2 93 0 0 2358 2359 total used free shared buff/cache available 2360 Mem: 998Mi 289Mi 536Mi 5.0Mi 172Mi 679Mi 2361 Swap: 499Mi 0B 499Mi 2362 2363 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2364 /dev/zram1 lzo-rle 499.2M 4K 73B 4K 4 [SWAP] 2365 /dev/zram0 zstd 50M 2.3M 428K 804K 4 /var/log 2366 2367 16:25:29 up 8 min, 2 users, load average: 0.09, 0.17, 0.10 2368 2369 [ 2.720700] usb usb1: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 2370 [ 2.720706] usb usb1: SerialNumber: 1c1a000.usb 2371 [ 2.721304] hub 1-0:1.0: USB hub found 2372 [ 2.721347] hub 1-0:1.0: 1 port detected 2373 [ 2.722263] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 2374 [ 2.722286] ohci-platform: OHCI generic platform driver 2375 [ 2.722458] ohci-platform 1c1a400.usb: Generic Platform OHCI controller 2376 [ 2.722480] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 2377 [ 2.722687] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 2378 [ 2.784608] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 2379 [ 2.784617] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2380 [ 2.784623] usb usb2: Product: Generic Platform OHCI controller 2381 [ 2.784629] usb usb2: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 2382 [ 2.784635] usb usb2: SerialNumber: 1c1a400.usb 2383 [ 2.785153] hub 2-0:1.0: USB hub found 2384 [ 2.785190] hub 2-0:1.0: 1 port detected 2385 [ 2.786556] usbcore: registered new interface driver usb-storage 2386 [ 2.787565] sun6i-rtc 1f00000.rtc: registered as rtc0 2387 [ 2.787607] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:11 UTC (11) 2388 [ 2.787613] sun6i-rtc 1f00000.rtc: RTC enabled 2389 [ 2.787922] i2c /dev entries driver 2390 [ 2.788302] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator 2391 [ 2.790542] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) 2392 [ 2.790982] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator 2393 [ 2.791691] sunxi-mmc 1c0f000.mmc: Got CD GPIO 2394 [ 2.817018] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB 2395 [ 2.818239] ledtrig-cpu: registered to indicate activity on CPUs 2396 [ 2.818327] hid: raw HID events driver (C) Jiri Kosina 2397 [ 2.818458] usbcore: registered new interface driver usbhid 2398 [ 2.818460] usbhid: USB HID core driver 2399 [ 2.822455] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present! 2400 [ 2.823954] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok 2401 [ 2.826728] Initializing XFRM netlink socket 2402 [ 2.827261] NET: Registered protocol family 10 2403 [ 2.855778] mmc0: host does not support reading read-only switch, assuming write-enable 2404 [ 2.857749] mmc0: new high speed SDHC card at address 0001 2405 [ 2.859366] mmcblk0: mmc0:0001 SD16G 29.2 GiB 2406 [ 2.863237] mmcblk0: p1 2407 [ 2.874872] Segment Routing with IPv6 2408 [ 2.874989] NET: Registered protocol family 17 2409 [ 2.875021] NET: Registered protocol family 15 2410 [ 2.875092] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. 2411 [ 2.875206] 8021q: 802.1Q VLAN Support v1.8 2412 [ 2.875264] Key type dns_resolver registered 2413 [ 2.875715] Registering SWP/SWPB emulation handler 2414 [ 2.876024] registered taskstats version 1 2415 [ 2.876031] Loading compiled-in X.509 certificates 2416 [ 2.882751] Loaded X.509 cert 'Build time autogenerated kernel key: 346848ecd67c995d675bab6785bece621761b48f' 2417 [ 2.882909] zswap: loaded using pool lzo/zbud 2418 [ 2.883568] Key type ._fscrypt registered 2419 [ 2.883574] Key type .fscrypt registered 2420 [ 2.883577] Key type fscrypt-provisioning registered 2421 [ 2.888822] Btrfs loaded, crc32c=crc32c-generic 2422 [ 2.911172] Key type encrypted registered 2423 [ 2.911193] AppArmor: AppArmor sha1 policy hashing enabled 2424 [ 2.922918] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator 2425 [ 2.924478] ehci-platform 1c1b000.usb: EHCI Host Controller 2426 [ 2.924512] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 2427 [ 2.924965] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 2428 [ 2.940413] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 2429 [ 2.940717] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 2430 [ 2.940726] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2431 [ 2.940733] usb usb3: Product: EHCI Host Controller 2432 [ 2.940739] usb usb3: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 2433 [ 2.940746] usb usb3: SerialNumber: 1c1b000.usb 2434 [ 2.941402] hub 3-0:1.0: USB hub found 2435 [ 2.941453] hub 3-0:1.0: 1 port detected 2436 [ 2.942322] ehci-platform 1c1c000.usb: EHCI Host Controller 2437 [ 2.942347] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 2438 [ 2.942635] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 2439 [ 2.956413] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 2440 [ 2.956676] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 2441 [ 2.956685] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2442 [ 2.956691] usb usb4: Product: EHCI Host Controller 2443 [ 2.956697] usb usb4: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 2444 [ 2.956703] usb usb4: SerialNumber: 1c1c000.usb 2445 [ 2.957245] hub 4-0:1.0: USB hub found 2446 [ 2.957285] hub 4-0:1.0: 1 port detected 2447 [ 2.958094] ehci-platform 1c1d000.usb: EHCI Host Controller 2448 [ 2.958119] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 2449 [ 2.958410] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 2450 [ 2.972411] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 2451 [ 2.972646] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 2452 [ 2.972654] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2453 [ 2.972660] usb usb5: Product: EHCI Host Controller 2454 [ 2.972666] usb usb5: Manufacturer: Linux 5.8.5-sunxi ehci_hcd 2455 [ 2.972672] usb usb5: SerialNumber: 1c1d000.usb 2456 [ 2.973167] hub 5-0:1.0: USB hub found 2457 [ 2.973203] hub 5-0:1.0: 1 port detected 2458 [ 2.973981] ohci-platform 1c1b400.usb: Generic Platform OHCI controller 2459 [ 2.974005] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 2460 [ 2.974214] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 2461 [ 3.036615] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 2462 [ 3.036624] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2463 [ 3.036630] usb usb6: Product: Generic Platform OHCI controller 2464 [ 3.036637] usb usb6: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 2465 [ 3.036642] usb usb6: SerialNumber: 1c1b400.usb 2466 [ 3.037142] hub 6-0:1.0: USB hub found 2467 [ 3.037179] hub 6-0:1.0: 1 port detected 2468 [ 3.037977] ohci-platform 1c1c400.usb: Generic Platform OHCI controller 2469 [ 3.038000] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 2470 [ 3.038187] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 2471 [ 3.100603] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 2472 [ 3.100612] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2473 [ 3.100619] usb usb7: Product: Generic Platform OHCI controller 2474 [ 3.100625] usb usb7: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 2475 [ 3.100631] usb usb7: SerialNumber: 1c1c400.usb 2476 [ 3.101159] hub 7-0:1.0: USB hub found 2477 [ 3.101206] hub 7-0:1.0: 1 port detected 2478 [ 3.102000] ohci-platform 1c1d400.usb: Generic Platform OHCI controller 2479 [ 3.102023] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 2480 [ 3.102259] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 2481 [ 3.164595] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08 2482 [ 3.164605] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2483 [ 3.164612] usb usb8: Product: Generic Platform OHCI controller 2484 [ 3.164618] usb usb8: Manufacturer: Linux 5.8.5-sunxi ohci_hcd 2485 [ 3.164624] usb usb8: SerialNumber: 1c1d400.usb 2486 [ 3.165155] hub 8-0:1.0: USB hub found 2487 [ 3.165194] hub 8-0:1.0: 1 port detected 2488 [ 3.166856] of_cfs_init 2489 [ 3.166974] of_cfs_init: OK 2490 [ 3.167123] ALSA device list: 2491 [ 3.167129] #0: H3 Audio Codec 2492 [ 3.171031] Freeing unused kernel memory: 1024K 2493 [ 3.180689] Run /init as init process 2494 [ 3.180696] with arguments: 2495 [ 3.180699] /init 2496 [ 3.180702] with environment: 2497 [ 3.180706] HOME=/ 2498 [ 3.180710] TERM=linux 2499 [ 3.180714] ubootpart=5d748697-01 2500 [ 3.180718] ubootsource=mmc 2501 [ 3.180721] sunxi_ve_mem_reserve=0 2502 [ 3.180725] sunxi_g2d_mem_reserve=0 2503 [ 3.180728] sunxi_fb_mem_reserve=16 2504 [ 3.180731] cgroup_enable=memory 2505 [ 3.181212] process '/usr/bin/sh' started with executable stack 2506 [ 3.536457] usb 6-1: new low-speed USB device number 2 using ohci-platform 2507 [ 3.560482] usb 8-1: new low-speed USB device number 2 using ohci-platform 2508 [ 3.566278] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0 2509 [ 3.625703] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator 2510 [ 3.626767] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver 2511 [ 3.626804] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9 2512 [ 3.627157] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08 2513 [ 3.627173] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2514 [ 3.627180] usb usb9: Product: MUSB HDRC host driver 2515 [ 3.627187] usb usb9: Manufacturer: Linux 5.8.5-sunxi musb-hcd 2516 [ 3.627193] usb usb9: SerialNumber: musb-hdrc.4.auto 2517 [ 3.627951] phy id_det change to device 2518 [ 3.628827] hub 9-0:1.0: USB hub found 2519 [ 3.628885] hub 9-0:1.0: 1 port detected 2520 [ 3.764561] usb 6-1: New USB device found, idVendor=046d, idProduct=c517, bcdDevice=38.10 2521 [ 3.764574] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2522 [ 3.764581] usb 6-1: Product: USB Receiver 2523 [ 3.764587] usb 6-1: Manufacturer: Logitech 2524 [ 3.773804] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C517.0001/input/input1 2525 [ 3.786484] usb 8-1: New USB device found, idVendor=04f3, idProduct=0234, bcdDevice=24.58 2526 [ 3.786496] usb 8-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 2527 [ 3.786503] usb 8-1: Product: OM 2528 [ 3.795531] input: OM as /devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:04F3:0234.0002/input/input2 2529 [ 3.832700] hid-generic 0003:046D:C517.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 2530 [ 3.834120] hid-generic 0003:04F3:0234.0002: input,hidraw1: USB HID v1.11 Mouse [OM] on usb-1c1d400.usb-1/input0 2531 [ 3.843316] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input3 2532 [ 3.843564] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input4 2533 [ 3.900630] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/input/input5 2534 [ 3.901083] hid-generic 0003:046D:C517.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 2535 [ 3.958075] logitech-djreceiver 0003:046D:C517.0001: hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0 2536 [ 4.051090] logitech-djreceiver 0003:046D:C517.0003: hiddev0,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1 2537 [ 4.124547] logitech-djreceiver 0003:046D:C517.0003: device of type 27 Mhz (0x02) connected on slot 3 2538 [ 4.127495] input: Logitech Wireless Keyboard PID:0062 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input8 2539 [ 4.127768] input: Logitech Wireless Keyboard PID:0062 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input9 2540 [ 4.127943] input: Logitech Wireless Keyboard PID:0062 System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input10 2541 [ 4.128220] hid-generic 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 2542 [ 4.236580] logitech-hidpp-device 0003:046D:0062.0004: HID++ 1.0 device connected. 2543 [ 4.286469] input: Logitech Wireless Keyboard PID:0062 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C517.0003/0003:046D:0062.0004/input/input14 2544 [ 4.286722] logitech-hidpp-device 0003:046D:0062.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:0062] on usb-1c1b400.usb-1/input1:3 2545 [ 5.511647] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 2546 [ 6.351936] systemd[1]: System time before build time, advancing clock. 2547 [ 6.376743] systemd[1]: Inserted module 'autofs4' 2548 [ 6.443120] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 2549 [ 6.443863] systemd[1]: Detected architecture arm. 2550 [ 6.469959] systemd[1]: Set hostname to <orangepipc>. 2551 [ 7.167586] random: systemd: uninitialized urandom read (16 bytes read) 2552 [ 7.182132] random: systemd: uninitialized urandom read (16 bytes read) 2553 [ 7.182855] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 2554 [ 7.184264] random: systemd: uninitialized urandom read (16 bytes read) 2555 [ 7.184707] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. 2556 [ 7.186742] systemd[1]: Listening on udev Control Socket. 2557 [ 7.187642] systemd[1]: Reached target Local Encrypted Volumes. 2558 [ 7.192006] systemd[1]: Created slice User and Session Slice. 2559 [ 7.194085] systemd[1]: Listening on Journal Audit Socket. 2560 [ 7.197733] systemd[1]: Created slice system-serial-getty.slice. 2561 [ 7.381830] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 2562 [ 8.620473] zram: Added device: zram0 2563 [ 8.621135] zram: Added device: zram1 2564 [ 8.636913] zram: Added device: zram2 2565 [ 8.728105] sun8i-di 1400000.deinterlace: Device registered as /dev/video0 2566 [ 8.741689] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. 2567 [ 8.771361] cedrus 1c0e000.video-codec: Device registered as /dev/video1 2568 [ 8.792583] zram1: detected capacity change from 0 to 523481088 2569 [ 8.867994] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz) 2570 [ 8.880494] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 2571 [ 8.896764] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 2572 [ 8.897393] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 2573 [ 8.897764] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority 2574 [ 8.898008] sun8i-ce 1c15000.crypto: Register cbc(aes) 2575 [ 8.898240] sun8i-ce 1c15000.crypto: Register ecb(aes) 2576 [ 8.898380] sun8i-ce 1c15000.crypto: Register cbc(des3_ede) 2577 [ 8.898505] sun8i-ce 1c15000.crypto: Register ecb(des3_ede) 2578 [ 8.898653] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1 2579 [ 8.970274] sun8i-thermal 1c25000.thermal-sensor: Thermal sensor ready! 2580 [ 9.035998] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 2581 [ 9.036054] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 2582 [ 9.036122] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 2583 [ 9.036164] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus 2584 [ 9.044089] lima 1c40000.gpu: bus rate = 200000000 2585 [ 9.044103] lima 1c40000.gpu: mod rate = 297000000 2586 [ 9.044208] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 2587 [ 9.044698] lima 1c40000.gpu: Failed to register cooling device 2588 [ 9.045136] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1 2589 [ 9.094209] Registered IR keymap rc-empty 2590 [ 9.094353] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 2591 [ 9.095989] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter 2592 [ 9.096187] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input15 2593 [ 9.118646] mousedev: PS/2 mouse device common for all mice 2594 [ 9.119884] sunxi-ir 1f02000.ir: initialized sunXi IR driver 2595 [ 9.410435] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok 2596 [ 9.888511] Adding 511208k swap on /dev/zram1. Priority:5 extents:1 across:511208k SSFS 2597 [ 10.062075] zram0: detected capacity change from 0 to 52428800 2598 [ 12.142161] systemd[1]: Started Armbian ZRAM config. 2599 [ 12.148997] systemd[1]: Starting Armbian memory supported logging... 2600 [ 12.237530] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard 2601 [ 12.237577] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 2602 [ 15.585893] systemd[1]: Started Armbian memory supported logging. 2603 [ 15.592268] systemd[1]: Starting Journal Service... 2604 [ 15.865713] systemd[1]: Started Journal Service. 2605 [ 15.926148] systemd-journald[538]: Received request to flush runtime journal from PID 1 2606 [ 16.524999] random: crng init done 2607 [ 16.525008] random: 7 urandom warning(s) missed due to ratelimiting 2608 [ 18.888743] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.1:01] driver [Generic PHY] (irq=POLL) 2609 [ 18.897859] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found 2610 [ 18.897879] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available 2611 [ 18.897888] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW 2612 [ 18.897903] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/mii link mode 2613 [ 18.899907] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx 2614 [ 18.899938] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready 2615 [ 21.488644] broken atomic modeset userspace detected, disabling atomic 2616 [ 33.780515] vcc3v0: disabling 2617 [ 33.780536] vcc5v0: disabling 2618 [ 33.780546] usb0-vbus: disabling 2619 2620 2621 vm.admin_reserve_kbytes = 8192 2622 vm.block_dump = 0 2623 vm.compact_unevictable_allowed = 1 2624 vm.dirty_background_bytes = 0 2625 vm.dirty_background_ratio = 10 2626 vm.dirty_bytes = 0 2627 vm.dirty_expire_centisecs = 3000 2628 vm.dirty_ratio = 20 2629 vm.dirty_writeback_centisecs = 500 2630 vm.dirtytime_expire_seconds = 43200 2631 vm.extfrag_threshold = 500 2632 vm.highmem_is_dirtyable = 0 2633 vm.laptop_mode = 0 2634 vm.legacy_va_layout = 0 2635 vm.lowmem_reserve_ratio = 32 0 0 2636 vm.max_map_count = 65530 2637 vm.min_free_kbytes = 3463 2638 vm.mmap_min_addr = 4096 2639 vm.mmap_rnd_bits = 8 2640 vm.oom_dump_tasks = 1 2641 vm.oom_kill_allocating_task = 0 2642 vm.overcommit_kbytes = 0 2643 vm.overcommit_memory = 0 2644 vm.overcommit_ratio = 50 2645 vm.page-cluster = 0 2646 vm.panic_on_oom = 0 2647 vm.percpu_pagelist_fraction = 0 2648 vm.stat_interval = 1 2649 vm.swappiness = 100 2650 vm.user_reserve_kbytes = 31484 2651 vm.vfs_cache_pressure = 100 2652 vm.watermark_boost_factor = 15000 2653 vm.watermark_scale_factor = 10 2654 2655 ### interrupts: 2656 CPU0 CPU1 CPU2 CPU3 2657 17: 0 0 0 0 GICv2 50 Level timer@1c20c00 2658 18: 0 0 0 0 GICv2 29 Level arch_timer 2659 19: 32212 16287 15506 15837 GICv2 30 Level arch_timer 2660 22: 1258 0 0 0 GICv2 82 Level 1c02000.dma-controller 2661 23: 1732 0 0 0 GICv2 118 Level 1c0c000.lcd-controller 2662 24: 18893 0 0 0 GICv2 92 Level sunxi-mmc 2663 26: 0 0 0 0 GICv2 103 Level musb-hdrc.4.auto 2664 27: 0 0 0 0 GICv2 104 Level ehci_hcd:usb1 2665 28: 0 0 0 0 GICv2 105 Level ohci_hcd:usb2 2666 29: 2 0 0 0 GICv2 106 Level ehci_hcd:usb3 2667 30: 64 0 0 0 GICv2 107 Level ohci_hcd:usb6 2668 31: 0 0 0 0 GICv2 108 Level ehci_hcd:usb4 2669 32: 0 0 0 0 GICv2 109 Level ohci_hcd:usb7 2670 33: 2 0 0 0 GICv2 110 Level ehci_hcd:usb5 2671 34: 2117 0 0 0 GICv2 111 Level ohci_hcd:usb8 2672 38: 5651 0 0 0 GICv2 114 Level eth0 2673 42: 6 0 0 0 GICv2 32 Level ttyS0 2674 43: 1286 0 0 0 GICv2 120 Level 1ee0000.hdmi, dw-hdmi-cec 2675 44: 0 0 0 0 sun6i-r-intc 8 Level 1f00000.rtc 2676 46: 0 0 0 0 sun6i-r-intc 5 Level sunxi-ir 2677 47: 4000 0 0 0 GICv2 76 Level mv64xxx_i2c 2678 49: 0 0 0 0 GICv2 125 Level 1400000.deinterlace 2679 50: 0 0 0 0 GICv2 90 Level 1c0e000.video-codec 2680 51: 0 0 0 0 GICv2 126 Level sun8i-ce-ns 2681 52: 0 0 0 0 GICv2 129 Level gp 2682 53: 0 0 0 0 GICv2 130 Level gpmmu 2683 54: 0 0 0 0 GICv2 131 Level pp0 2684 55: 0 0 0 0 GICv2 132 Level ppmmu0 2685 56: 0 0 0 0 GICv2 134 Level pp1 2686 57: 0 0 0 0 GICv2 135 Level ppmmu1 2687 59: 2031 0 0 0 GICv2 63 Level ths 2688 60: 0 0 0 0 GICv2 152 Level arm-pmu 2689 61: 0 0 0 0 GICv2 153 Level arm-pmu 2690 62: 0 0 0 0 GICv2 154 Level arm-pmu 2691 63: 0 0 0 0 GICv2 155 Level arm-pmu 2692 108: 1 0 0 0 sunxi_pio_edge 44 Edge usb0-id-det 2693 131: 1 0 0 0 sunxi_pio_edge 3 Edge sw4 2694 IPI0: 0 0 0 0 CPU wakeup interrupts 2695 IPI1: 0 0 0 0 Timer broadcast interrupts 2696 IPI2: 7875 13277 11947 18592 Rescheduling interrupts 2697 IPI3: 1551 1859 962 1368 Function call interrupts 2698 IPI4: 0 0 0 0 CPU stop interrupts 2699 IPI5: 1508 286 289 317 IRQ work interrupts 2700 IPI6: 0 0 0 0 completion interrupts 2701 Err: 0 Please upload the whole output above to an online pasteboard service and provide the URL in the forum where you have been asked for this. There is something broken with network but I can confirm that I have no problem on my LAN and that orange pi pc board correctly receive ip address from DHCP and it's able to resolve and ping external hosts... Thanks Daniele. Edited September 18, 2020 by Werner Use spoiler for longer pastes
Igor Posted September 18, 2020 Posted September 18, 2020 My Orangepi PC have a broken SD card slot so I was not able to reproduce the problem on the exact same hardware. I choose similar one, Nanopi M1 and I have no issues. http://ix.io/2xXJ Reveal hidden contents _ _ ____ _ __ __ _ | \ | | _ \(_) | \/ / | | \| | |_) | | | |\/| | | | |\ | __/| | | | | | | |_| \_|_| |_| |_| |_|_| Welcome to Armbian 20.08.1 Buster with Linux 5.8.5-sunxi No end-user support: end of life System load: 1.25 0.63 0.25 Up time: 2 min Memory usage: 12 % of 998MB IP: 10.0.30.201 CPU temp: 82°C Usage of /: 4% of 29G [ General system configuration (beta): armbian-config ] igorp@nanopim1:~$ sudo su Verjetno vam je skrbnik sistemov že pridigal o varnosti, vendar si vseeno zapomnite naslednja pravila: #1) Spoštujte zasebnost drugih. #2) Premislite, preden izvedete ukaze. #3) Velika moč prinaša veliko odgovornost. [sudo] password for igorp: Prosimo, poskusite znova. [sudo] password for igorp: root@nanopim1:/home/igorp# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/2xXJ Please post the URL in the forum where you've been asked for. root@nanopim1:/home/igorp# apt update Zadetek:1 http://security.debian.org buster/updates InRelease Zadetek:2 http://deb.debian.org/debian buster InRelease Zadetek:3 http://deb.debian.org/debian buster-updates InRelease Zadetek:4 http://deb.debian.org/debian buster-backports InRelease Zadetek:5 https://imola.armbian.com/apt buster InRelease Branje seznama paketov ... Narejeno Gradnja drevesa odvisnosti Branje podatkov o stanju ... Narejeno 3 packages can be upgraded. Run 'apt list --upgradable' to see them. root@nanopim1:/home/igorp# date pet sep 18 10:58:59 CEST 2020
Werner Posted September 18, 2020 Posted September 18, 2020 On 9/18/2020 at 8:01 AM, Daniele said: Connection refused Expand external firewall issue?
Daniele Posted September 18, 2020 Author Posted September 18, 2020 On 9/18/2020 at 8:59 AM, Igor said: My Orangepi PC have a broken SD card slot so I was not able to reproduce the problem on the exact same hardware. I choose similar one, Nanopi M1 and I have no issues. http://ix.io/2xXJ Reveal hidden contents _ _ ____ _ __ __ _ | \ | | _ \(_) | \/ / | | \| | |_) | | | |\/| | | | |\ | __/| | | | | | | |_| \_|_| |_| |_| |_|_| Welcome to Armbian 20.08.1 Buster with Linux 5.8.5-sunxi No end-user support: end of life System load: 1.25 0.63 0.25 Up time: 2 min Memory usage: 12 % of 998MB IP: 10.0.30.201 CPU temp: 82°C Usage of /: 4% of 29G [ General system configuration (beta): armbian-config ] igorp@nanopim1:~$ sudo su Verjetno vam je skrbnik sistemov že pridigal o varnosti, vendar si vseeno zapomnite naslednja pravila: #1) Spoštujte zasebnost drugih. #2) Premislite, preden izvedete ukaze. #3) Velika moč prinaša veliko odgovornost. [sudo] password for igorp: Prosimo, poskusite znova. [sudo] password for igorp: root@nanopim1:/home/igorp# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/2xXJ Please post the URL in the forum where you've been asked for. root@nanopim1:/home/igorp# apt update Zadetek:1 http://security.debian.org buster/updates InRelease Zadetek:2 http://deb.debian.org/debian buster InRelease Zadetek:3 http://deb.debian.org/debian buster-updates InRelease Zadetek:4 http://deb.debian.org/debian buster-backports InRelease Zadetek:5 https://imola.armbian.com/apt buster InRelease Branje seznama paketov ... Narejeno Gradnja drevesa odvisnosti Branje podatkov o stanju ... Narejeno 3 packages can be upgraded. Run 'apt list --upgradable' to see them. root@nanopim1:/home/igorp# date pet sep 18 10:58:59 CEST 2020 Expand Thanks for your reply Igor, if you want I can give you ssh access to my board, so you can check by yourself the problem... let me know, thanks D. On 9/18/2020 at 8:59 AM, Werner said: external firewall issue? Expand But why only for this board? I have no problem updating raspberry pi with raspbian os, and so for other linux distros I'm using. This is first time I use armbian because I have four orange pi pc boards and from what I saw this is the best OS for them. Anyway I rebooted router with no luck, there is no additional firewall between orange pi and my router Thanks D.
Werner Posted September 18, 2020 Posted September 18, 2020 Just a guess. Sometimes trivial things are the easiest solutions
Igor Posted September 18, 2020 Posted September 18, 2020 On 9/18/2020 at 9:12 AM, Daniele said: But why only for this board? Expand Problem exists only if we can reproduce it. Let's wait if someone will. I can't.
Igor Posted September 18, 2020 Posted September 18, 2020 boot without attaching anything to the USB change network cable / port make sure to power via power connector, not via mUSB
Daniele Posted September 18, 2020 Author Posted September 18, 2020 On 9/18/2020 at 9:33 AM, Igor said: Problem exists only if we can reproduce it. Let's wait if someone will. I can't. Expand I don't know if it's a general armbian problem, probably it's only a my problem, what I can tell you for sure is that I tried two different boards and two different sd, so I am led to exclude an hardware issue. I need help because I don't know armbian and this problem is blocking, for this reason if you (or anyone who wants) want I can share ssh access. I don't really know how to move forward with this problem...
Igor Posted September 18, 2020 Posted September 18, 2020 On 9/18/2020 at 9:41 AM, Daniele said: I need help Expand Woooooho. Make sure to read this: https://github.com/armbian/build#support Twice.
Daniele Posted September 18, 2020 Author Posted September 18, 2020 Wait a moment: with another orange pi and the same card it worked. I try to understand what the difference is...
Igor Posted September 18, 2020 Posted September 18, 2020 On 9/18/2020 at 9:46 AM, Daniele said: Wait a moment: with another orange pi and the same card it worked. I try to understand what the difference is... Expand Hardware quality issues are possible even Oranges are actually among best made HW ... nothing that Armbian can do about.
Werner Posted September 18, 2020 Posted September 18, 2020 Rare occurrence but boards can be broken too. I had an issue with an OPi One that could not stay online for more than a few hours without freezing. The very same sd card inserted into another OPi One worked flawless for multiple days. At the bottom line and after wasting many hours of try'n'error I assume the current path from the barrel plug to the board or the barrel plug itself had a defective connection because powering via GPIO solved the issue.
Daniele Posted September 18, 2020 Author Posted September 18, 2020 Yes, probably it's broken hardware. It's a strange behaviour however, the board does not freeze and run well but some network traffic is filtered... bah.... Now I have a problem using orange pi pc microphone... D.
Werner Posted September 18, 2020 Posted September 18, 2020 There were a couple of threads relating to microphones. Try utilizing the search function (sort by date to get newer results first). I'll mark this one here as "solved" since it is - well - kind of ...
