dolphs Posted September 26, 2020 Posted September 26, 2020 Hi, I am trying to find a quicker way of customising my .config for eg orangepioneplus board as I do not require Bluetooth, WIFI etc. etc. So tried to put a config file ( KERNEL_CONFIGURE=yes | BRANCH=dev ) in one of these directories, but alas /home/armbian/userpatches and /home/armbian/userpatches/kernel/sunxi-dev Still failing after Reading these topics - user configurations - building armbian / Providing build configuration - build options So therefore can one explain ( quick tutorial ) how to achieve this, please? I start off with KERNEL_CONFIGUERE=yes" to store my custom .config file for this board ( sunxi-dev ). once this file exists I like to use it instead of the default provided .config file ( KERNEL_CONFIGURE set to “no” to compile kernel without changing default or custom provided configuration ). I do notice " Looking for user patches in [ userpatches/kernel/sunxi-dev ] " but it does not get picked up. So best shot is user provided kernel config section, but I still fail and as a workaround I always update (softlink) the .config file in " /home/armbian/config/kernel " but like to do it properly ;-) TiA!
Werner Posted September 26, 2020 Posted September 26, 2020 Moved to p2p since you shall not post requests in the new section
Igor Posted September 26, 2020 Posted September 26, 2020 3 hours ago, dolphs said: So tried to put a config file What was the name of your config file? In your case - orangepioneplus - it should be named as linux-sunxi64-current.config and placed in userpatches
dolphs Posted September 26, 2020 Author Posted September 26, 2020 ah now it seems to work: output.log:Displaying message: Using kernel config provided by user userpatches/linux-sunxi64-dev.config info output.log:Displaying message: Using kernel config provided by user userpatches/linux-sunxi64-dev.config info All the time missed the connection between the main ( predefined .configs ) at : /home/armbian/config/kernel. Same name simply needs to be saved to /home/armbian/userpatches/ , thus not .config as I stubbornly did till now. Thanks @Igor and also my sincere apologies @Werner for my attempt littering in the new section
Werner Posted September 26, 2020 Posted September 26, 2020 23 minutes ago, dolphs said: for my attempt littering in the new section No worries. There was no hint (yet) that this section should be dedicated to this and be free of requests. Everything is good. You can still use the information collected here to write a simple howto use userpatches folders and publish there
dolphs Posted September 27, 2020 Author Posted September 27, 2020 @Werner - I tried, hope it is worth to publish my " tutorial " post, also feel free to adjust. Perhaps I'll add some more screenshots where to find the unnecessary network drivers ( WiFi and Blutooth ) etc etc, but guess that is just my specific scenario for the OPiOnePlus board which is being used as a wireguard/ pihole server
