Hello, I have a cubitruck With armbian and it runs the most time fine. Now i'm Not AT Home and the cubi is Out, I See in my router That He is Not running. I Can't connect over ssh. Who can I Look after a reboot when i'm AT Home what is the problem for going down.
Thank you
On 10/19/2020 at 10:35 AM, Werner said:
The the common log files like dmesg or syslog.
Not sure if this will help. I had the same issue by the end of August with cubietruck (freezing not responding on lan or keyboard) but I thought that it was my bad as I played with the onboard wifi a while ago.
I had to disable zram & zram logging as the logs were lost after re-power on.
Well it seems that it was not the wifi nor I am sure yet what the issue is(was).
I disabled most of the servers and also webmin and the system was running fine for a week or so.
After enabling zram & zram logging again I had a freeze after 3 days (but no logs).
I am now up for 8 days with zram & zram logging disabled. I will probably enable them next week and see how this goes.
syslog shows the last entries at the 14.10.20, it seems to be the last day it runs, but in the syslog i cant see why
Oct 13 23:45:01 localhost CRON[31074]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Oct 13 23:45:01 localhost CRON[31075]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Oct 13 23:55:01 localhost CRON[32514]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Oct 13 23:59:01 localhost CRON[644]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 60 2)
Oct 14 00:00:01 localhost CRON[800]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Oct 14 00:00:02 localhost CRON[802]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Oct 14 00:00:22 localhost systemd[1]: Starting Rotate log files...
Oct 14 00:00:22 localhost systemd[1]: Starting Daily man-db regeneration...
Oct 14 00:00:23 localhost armbian-ramlog[876]: Mi 14. Okt 00:00:23 CEST 2020: Syncing logs to storage
Oct 14 00:00:23 localhost armbian-ramlog[876]: sending incremental file list
Oct 14 00:00:23 localhost armbian-ramlog[876]: alternatives.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: aptitude
Oct 14 00:00:23 localhost armbian-ramlog[876]: armbian-hardware-monitor.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: auth.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: bootstrap.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: btmp
Oct 14 00:00:23 localhost armbian-ramlog[876]: daemon.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: debug
Oct 14 00:00:23 localhost armbian-ramlog[876]: dpkg.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: faillog
Oct 14 00:00:23 localhost armbian-ramlog[876]: kern.log
Oct 14 00:00:23 localhost armbian-ramlog[876]: lastlog
Oct 14 00:00:23 localhost armbian-ramlog[876]: messages
dmesg shows no problems....
Last night, i have the Problem again.
dmesg says after a reboot
 dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.8.16-sunxi (root@xeon) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.14 SMP Tue Oct 20 22:15:32 CEST 2020
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Cubietech Cubietruck
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
[    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000bfcfffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfcfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfcfffff]
[    0.000000] On node 0 totalpages: 523520
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 326912 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920
[    0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 521792
[    0.000000] Kernel command line: root=UUID=19cf2f1d-1a31-4890-bc04-a2f1c4e4e021 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=ba110a34-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] allocated 2098176 bytes of page_ext
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 1948168K/2094080K available (9216K kernel code, 1028K rwdata, 3240K rodata, 1024K init, 328K bss, 47608K reserved, 98304K cma-reserved, 1307648K highmem)
[    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] ftrace: allocating 39966 entries in 79 pages
[    0.000000] ftrace: allocated 79 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018] Switching to timer-based delay loop, resolution 41ns
[    0.000556] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000894] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[    0.001257] Console: colour dummy device 80x30
[    0.001274] printk: console [tty1] enabled
[    0.001339] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001352] pid_max: default: 32768 minimum: 301
[    0.001596] LSM: Security Framework initializing
[    0.001660] Yama: becoming mindful.
[    0.001857] AppArmor: AppArmor initialized
[    0.001948] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001962] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003167] CPU: Testing write buffer coherency: ok
[    0.003620] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004457] Setting up static identity map for 0x40100000 - 0x40100054
[    0.004617] rcu: Hierarchical SRCU implementation.
[    0.008432] smp: Bringing up secondary CPUs ...
[    0.019352] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.019533] smp: Brought up 1 node, 2 CPUs
[    0.019543] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.019547] CPU: All CPU(s) started in HYP mode.
[    0.019550] CPU: Virtualization extensions available.
[    0.020889] devtmpfs: initialized
[    0.031068] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.031577] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.031621] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.035816] xor: measuring software checksum speed
[    0.075368]    arm4regs  :  1136.000 MB/sec
[    0.115418]    8regs     :   791.000 MB/sec
[    0.155472]    32regs    :   747.000 MB/sec
[    0.195534]    neon      :  1150.000 MB/sec
[    0.195538] xor: using function: neon (1150.000 MB/sec)
[    0.195634] pinctrl core: initialized pinctrl subsystem
[    0.196303] thermal_sys: Registered thermal governor 'fair_share'
[    0.196309] thermal_sys: Registered thermal governor 'bang_bang'
[    0.196315] thermal_sys: Registered thermal governor 'step_wise'
[    0.197333] NET: Registered protocol family 16
[    0.199274] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.199913] audit: initializing netlink subsys (disabled)
[    0.200251] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[    0.200900] cpuidle: using governor ladder
[    0.200930] cpuidle: using governor menu
[    0.201502] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.201508] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.228846] cryptd: max_cpu_qlen set to 1000
[    0.300159] raid6: neonx8   gen()   699 MB/s
[    0.368276] raid6: neonx8   xor()   526 MB/s
[    0.436409] raid6: neonx4   gen()   752 MB/s
[    0.504541] raid6: neonx4   xor()   571 MB/s
[    0.572678] raid6: neonx2   gen()   827 MB/s
[    0.640803] raid6: neonx2   xor()   590 MB/s
[    0.708956] raid6: neonx1   gen()   738 MB/s
[    0.777072] raid6: neonx1   xor()   511 MB/s
[    0.845203] raid6: int32x8  gen()   273 MB/s
[    0.913368] raid6: int32x8  xor()   160 MB/s
[    0.981494] raid6: int32x4  gen()   322 MB/s
[    1.049667] raid6: int32x4  xor()   186 MB/s
[    1.117787] raid6: int32x2  gen()   361 MB/s
[    1.185899] raid6: int32x2  xor()   192 MB/s
[    1.254091] raid6: int32x1  gen()   364 MB/s
[    1.322202] raid6: int32x1  xor()   173 MB/s
[    1.322206] raid6: using algorithm neonx2 gen() 827 MB/s
[    1.322209] raid6: .... xor() 590 MB/s, rmw enabled
[    1.322214] raid6: using neon recovery algorithm
[    1.324241] iommu: Default domain type: Translated
[    1.324699] SCSI subsystem initialized
[    1.325099] libata version 3.00 loaded.
[    1.325368] usbcore: registered new interface driver usbfs
[    1.325429] usbcore: registered new interface driver hub
[    1.325503] usbcore: registered new device driver usb
[    1.325610] mc: Linux media interface: v0.10
[    1.325643] videodev: Linux video capture interface: v2.00
[    1.325804] pps_core: LinuxPPS API ver. 1 registered
[    1.325809] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.325826] PTP clock support registered
[    1.326649] Advanced Linux Sound Architecture Driver Initialized.
[    1.327433] NetLabel: Initializing
[    1.327442] NetLabel:  domain hash size = 128
[    1.327445] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.327529] NetLabel:  unlabeled traffic allowed by default
[    1.328307] clocksource: Switched to clocksource arch_sys_counter
[    1.434293] VFS: Disk quotas dquot_6.6.0
[    1.434404] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.435098] AppArmor: AppArmor Filesystem Enabled
[    1.436134] simple-framebuffer bfd00000.framebuffer: framebuffer at 0xbfd00000, 0x300000 bytes, mapped to 0x(ptrval)
[    1.436150] simple-framebuffer bfd00000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
[    1.437253] Console: switching to colour frame buffer device 128x48
[    1.451346] simple-framebuffer bfd00000.framebuffer: fb0: simplefb registered!
[    1.460561] NET: Registered protocol family 2
[    1.461475] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.461531] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.461643] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.461766] TCP: Hash tables configured (established 8192 bind 8192)
[    1.461949] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.462025] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.462365] NET: Registered protocol family 1
[    1.462889] Trying to unpack rootfs image as initramfs...
[    2.241633] Freeing initrd memory: 9656K
[    2.242422] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    2.242782] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.244439] Initialise system trusted keyrings
[    2.244513] Key type blacklist registered
[    2.244852] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    2.250884] zbud: loaded
[    2.252790] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.254038] fuse: init (API version 7.31)
[    2.257492] integrity: Platform Keyring initialized
[    2.375704] Key type asymmetric registered
[    2.375715] Asymmetric key parser 'x509' registered
[    2.375945] bounce: pool size: 64 pages
[    2.376043] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.376384] io scheduler mq-deadline registered
[    2.376392] io scheduler kyber registered
[    2.376633] io scheduler bfq registered
[    2.380476] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
[    2.382498] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    2.395374] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.398457] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    2.399049] printk: console [ttyS0] disabled
[    2.399156] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 50, base_baud = 1500000) is a 16550A
[    2.399250] printk: console [ttyS0] enabled
[    2.400473] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 51, base_baud = 1500000) is a 16550A
[    2.400683] serial serial0: tty port ttyS2 registered
[    2.411055] brd: module loaded
[    2.420212] loop: module loaded
[    2.421434] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
[    2.421549] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
[    2.423440] libphy: Fixed MDIO Bus: probed
[    2.424082] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[    2.424433] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
[    2.424444] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
[    2.424574] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    2.424585] sun7i-dwmac 1c50000.ethernet: no reset control found
[    2.424619] sun7i-dwmac 1c50000.ethernet: no regulator found
[    2.424972] sun7i-dwmac 1c50000.ethernet: Version ID not available
[    2.424987] sun7i-dwmac 1c50000.ethernet:    DWMAC1000
[    2.424995] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
[    2.425004] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    2.425011] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    2.425753] libphy: stmmac: probed
[    2.441010] realtek: module verification failed: signature and/or required key missing - tainting kernel
[    2.450497] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.450531] ehci-platform: EHCI generic platform driver
[    2.451083] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.451109] ohci-platform: OHCI generic platform driver
[    2.452061] usbcore: registered new interface driver usb-storage
[    2.453350] sunxi-rtc 1c20d00.rtc: registered as rtc0
[    2.453404] sunxi-rtc 1c20d00.rtc: setting system clock to 2020-10-25T08:50:21 UTC (1603615821)
[    2.453606] i2c /dev entries driver
[    2.454931] axp20x-i2c 0-0034: AXP20x variant AXP209 found
[    2.462524] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
[    2.471365] ldo1: supplied by regulator-dummy
[    2.471762] ldo2: supplied by regulator-dummy
[    2.472916] ldo3: supplied by regulator-dummy
[    2.473637] ldo4: supplied by regulator-dummy
[    2.473900] ldo5: supplied by regulator-dummy
[    2.474599] dcdc2: supplied by regulator-dummy
[    2.475317] dcdc3: supplied by regulator-dummy
[    2.480538] random: fast init done
[    2.480740] axp20x-i2c 0-0034: Backup (RTC) battery charging is enabled
[    2.480882] axp20x-i2c 0-0034: AXP20X driver loaded
[    2.484940] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.485753] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[    2.487014] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
[    2.487156] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    2.512822] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    2.516602] ledtrig-cpu: registered to indicate activity on CPUs
[    2.516714] hid: raw HID events driver (C) Jiri Kosina
[    2.516906] usbcore: registered new interface driver usbhid
[    2.516910] usbhid: USB HID core driver
[    2.520564] debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
[    2.521977] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    2.525512] Initializing XFRM netlink socket
[    2.526160] NET: Registered protocol family 10
[    2.562092] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.565293] mmc0: new high speed SDHC card at address e624
[    2.567115] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[    2.573965]  mmcblk0: p1
[    2.589837] Segment Routing with IPv6
[    2.589977] NET: Registered protocol family 17
[    2.590022] NET: Registered protocol family 15
[    2.590121] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.590346] 8021q: 802.1Q VLAN Support v1.8
[    2.590419] Key type dns_resolver registered
[    2.590909] Registering SWP/SWPB emulation handler
[    2.591315] registered taskstats version 1
[    2.591325] Loading compiled-in X.509 certificates
[    2.599087] Loaded X.509 cert 'Build time autogenerated kernel key: 1db26793b2098835541128330c1baea0c341ef90'
[    2.599278] zswap: loaded using pool lzo/zbud
[    2.600143] Key type ._fscrypt registered
[    2.600151] Key type .fscrypt registered
[    2.600155] Key type fscrypt-provisioning registered
[    2.606787] Btrfs loaded, crc32c=crc32c-generic
[    2.634898] Key type encrypted registered
[    2.634923] AppArmor: AppArmor sha1 policy hashing enabled
[    2.653439] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
[    2.653553] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
[    2.708352] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    2.708398] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[    2.708430] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    2.708445] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[    2.709596] scsi host0: ahci-sunxi
[    2.710072] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 37
[    2.722095] of_cfs_init
[    2.722274] of_cfs_init: OK
[    2.722488] ALSA device list:
[    2.722498]   #0: sun4i-codec
[    3.022785] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.024769] ata1.00: supports DRM functions and may not be fully accessible
[    3.024783] ata1.00: ATA-9: Samsung SSD 840 EVO 120GB, EXT0BB6Q, max UDMA/133
[    3.024791] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32)
[    3.025423] ata1.00: supports DRM functions and may not be fully accessible
[    3.025851] ata1.00: configured for UDMA/133
[    3.026537] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 840  BB6Q PQ: 0 ANSI: 5
[    3.027495] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.028129] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[    3.028202] sd 0:0:0:0: [sda] Write Protect is off
[    3.028212] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.028398] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.030394]  sda: sda1
[    3.031846] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.037379] Freeing unused kernel memory: 1024K
[    3.052600] Run /init as init process
[    3.052612]   with arguments:
[    3.052617]     /init
[    3.052620]   with environment:
[    3.052624]     HOME=/
[    3.052628]     TERM=linux
[    3.052631]     ubootpart=ba110a34-01
[    3.052635]     ubootsource=mmc
[    3.052638]     sunxi_ve_mem_reserve=0
[    3.052642]     sunxi_g2d_mem_reserve=0
[    3.052645]     sunxi_fb_mem_reserve=16
[    3.052649]     cgroup_enable=memory
[    3.053170] process '/usr/bin/sh' started with executable stack
[    3.717088] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq
[    3.740409] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB
[    3.770573] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.772403] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.774154] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.781212] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.798579] mmc1: new high speed SDIO card at address 0001
[    4.024149] axp20x-gpio axp20x-gpio: DMA mask not set
[    4.041794] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
[    4.115532] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[    6.376038] random: crng init done
[    6.473990] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.325073] systemd[1]: Inserted module 'autofs4'
[    7.402450] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.403321] systemd[1]: Detected architecture arm.
[    7.436001] systemd[1]: Set hostname to <cubietruck>.
[    8.629038] systemd[1]: Listening on udev Kernel Socket.
[    8.630732] systemd[1]: Reached target System Time Synchronized.
[    8.631441] systemd[1]: Reached target Swap.
[    8.638161] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.639867] systemd[1]: Listening on udev Control Socket.
[    8.641196] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    8.649860] systemd[1]: Listening on Syslog Socket.
[    9.038777] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    9.125259] RPC: Registered named UNIX socket transport module.
[    9.125267] RPC: Registered udp transport module.
[    9.125270] RPC: Registered tcp transport module.
[    9.125273] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.875927] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   10.888531] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   11.127410] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0a97330)
[   11.127551] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0a97330)
[   11.128041] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0a96b74)
[   11.128554] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0a96b74)
[   11.129344] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[   11.129372] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a95600)
[   11.130043] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[   11.130065] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a95600)
[   11.132744] sun4i-drm display-engine: bound 1c16000.hdmi (ops sun4i_hdmi_ops [sun4i_drm_hdmi])
[   11.132767] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   11.132779] checking generic (bfd00000 300000) vs hw (0 ffffffff)
[   11.132784] fb0: switching to sun4i-drm-fb from simple
[   11.133449] Console: switching to colour dummy device 80x30
[   11.134512] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[   11.134605] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[   11.232700] sun4i-ss 1c15000.crypto-engine: Die ID 0
[   11.272426] Registered IR keymap rc-empty
[   11.272566] rc rc0: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0
[   11.297703] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[   11.297928] input: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0/input1
[   11.313429] sunxi-ir 1c21800.ir: initialized sunXi IR driver
[   11.648479] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[   11.765253] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   11.800923] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[   11.800998] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[   11.801056] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[   11.801102] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[   11.815956] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   11.817222] lima 1c40000.gpu: bus rate = 300000000
[   11.817284] lima 1c40000.gpu: mod rate = 384000000
[   11.817839] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   11.817851] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[   11.818112] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1
[   11.834757] axp20x-adc axp20x-adc: DMA mask not set
[   11.995686] asoc-simple-card sound: dit-hifi <-> 1c21000.spdif mapping ok
[   12.005355] ehci-platform 1c14000.usb: EHCI Host Controller
[   12.005396] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[   12.021941] ehci-platform 1c14000.usb: irq 33, io mem 0x01c14000
[   12.036426] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[   12.036823] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[   12.036833] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.036840] usb usb1: Product: EHCI Host Controller
[   12.036847] usb usb1: Manufacturer: Linux 5.8.16-sunxi ehci_hcd
[   12.036853] usb usb1: SerialNumber: 1c14000.usb
[   12.037783] hub 1-0:1.0: USB hub found
[   12.037886] hub 1-0:1.0: 1 port detected
[   12.039556] ehci-platform 1c1c000.usb: EHCI Host Controller
[   12.039631] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[   12.050525] ehci-platform 1c1c000.usb: irq 38, io mem 0x01c1c000
[   12.064491] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[   12.064906] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[   12.064918] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.064926] usb usb2: Product: EHCI Host Controller
[   12.064933] usb usb2: Manufacturer: Linux 5.8.16-sunxi ehci_hcd
[   12.064940] usb usb2: SerialNumber: 1c1c000.usb
[   12.065923] hub 2-0:1.0: USB hub found
[   12.066011] hub 2-0:1.0: 1 port detected
[   12.067577] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[   12.067983] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[   12.068776] ohci-platform 1c14400.usb: irq 34, io mem 0x01c14400
[   12.119472] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[   12.132818] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[   12.132833] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.132840] usb usb3: Product: Generic Platform OHCI controller
[   12.132847] usb usb3: Manufacturer: Linux 5.8.16-sunxi ohci_hcd
[   12.132854] usb usb3: SerialNumber: 1c14400.usb
[   12.134319] hub 3-0:1.0: USB hub found
[   12.134422] hub 3-0:1.0: 1 port detected
[   12.135854] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[   12.135894] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[   12.136197] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt failed with error -2
[   12.136209] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt
[   12.142502] ohci-platform 1c1c400.usb: irq 39, io mem 0x01c1c400
[   12.216932] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[   12.216947] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.216954] usb usb4: Product: Generic Platform OHCI controller
[   12.216962] usb usb4: Manufacturer: Linux 5.8.16-sunxi ohci_hcd
[   12.216968] usb usb4: SerialNumber: 1c1c400.usb
[   12.220581] hub 4-0:1.0: USB hub found
[   12.220683] hub 4-0:1.0: 1 port detected
[   12.222900] usb_phy_generic usb_phy_generic.0.auto: supply vcc not found, using dummy regulator
[   12.224509] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[   12.224549] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[   12.224718] phy id_det change to device
[   12.236800] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[   12.236814] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.236822] usb usb5: Product: MUSB HDRC host driver
[   12.236829] usb usb5: Manufacturer: Linux 5.8.16-sunxi musb-hcd
[   12.236835] usb usb5: SerialNumber: musb-hdrc.1.auto
[   12.237797] hub 5-0:1.0: USB hub found
[   12.237876] hub 5-0:1.0: 1 port detected
[   12.242381] Bluetooth: Core ver 2.22
[   12.242544] NET: Registered protocol family 31
[   12.242550] Bluetooth: HCI device and connection manager initialized
[   12.242577] Bluetooth: HCI socket layer initialized
[   12.242588] Bluetooth: L2CAP socket layer initialized
[   12.242620] Bluetooth: SCO socket layer initialized
[   12.350395] Bluetooth: HCI UART driver ver 2.3
[   12.350409] Bluetooth: HCI UART protocol H4 registered
[   12.350413] Bluetooth: HCI UART protocol BCSP registered
[   12.350500] Bluetooth: HCI UART protocol LL registered
[   12.350506] Bluetooth: HCI UART protocol ATH3K registered
[   12.350556] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.350892] Bluetooth: HCI UART protocol Broadcom registered
[   12.351240] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[   12.351402] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[   12.402228] usb 2-1: new high-speed USB device number 2 using ehci-platform
[   12.545375] cfg80211: failed to load regulatory.db
[   12.557611] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[   12.557626] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   12.557633] usb 2-1: Product: USB 2.0 Hub
[   12.558761] hub 2-1:1.0: USB hub found
[   12.558999] hub 2-1:1.0: 4 ports detected
[   12.708428] usb 3-1: new full-speed USB device number 2 using ohci-platform
[   12.725639] Bluetooth: hci0: BCM: chip id 63
[   12.728259] Bluetooth: hci0: BCM: features 0x07
[   12.737401] systemd[1]: Found device /dev/ttyS0.
[   12.752860] Bluetooth: hci0: BCM20702A
[   12.752885] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[   12.855159] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[   12.855170] Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd'
[   12.855174] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[   12.946662] usb 3-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[   12.946683] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   12.946698] usb 3-1: Product: FT232R USB UART
[   12.946713] usb 3-1: Manufacturer: FTDI
[   12.946727] usb 3-1: SerialNumber: A7031FBC
[   12.964402] usb 2-1.2: new full-speed USB device number 3 using ehci-platform
[   12.978834] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[   12.981226] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available
[   12.981928] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
[   13.102663] usbcore: registered new interface driver usbserial_generic
[   13.102724] usbserial: USB Serial support registered for generic
[   13.143230] usbcore: registered new interface driver ftdi_sio
[   13.143309] usbserial: USB Serial support registered for FTDI USB Serial Device
[   13.143676] ftdi_sio 3-1:1.0: FTDI USB Serial Device converter detected
[   13.143879] usb 3-1: Detected FT232RL
[   13.156237] usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB0
[   13.199247] usb 2-1.2: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
[   13.199262] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   13.199269] usb 2-1.2: Product: CUL433
[   13.199276] usb 2-1.2: Manufacturer: busware.de
[   13.224111] systemd[1]: Found device Samsung_SSD_840_EVO_120GB 1.
[   13.420619] usb 2-1.4: new full-speed USB device number 4 using ehci-platform
[   13.579819] systemd[1]: Reached target Bluetooth.
[   13.581276] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   13.581923] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   13.582271] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   13.582687] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   13.583437] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   13.593031] systemd[1]: Mounting /media/Platte...
[   13.604560] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   13.657025] usb 2-1.4: New USB device found, idVendor=1b1f, idProduct=c00f, bcdDevice= 9.67
[   13.657042] usb 2-1.4: New USB device strings: Mfr=4, Product=14, SerialNumber=36
[   13.657050] usb 2-1.4: Product: HM-CFG-USB
[   13.657056] usb 2-1.4: Manufacturer: eQ-3
[   13.657063] usb 2-1.4: SerialNumber: MEQ0232057
[   13.670576] hid-generic 0003:1B1F:C00F.0001: hiddev0,hidraw0: USB HID v1.10 Device [eQ-3 HM-CFG-USB] on usb-1c1c000.usb-1.4/input0
[   13.767206] cdc_acm 2-1.2:1.0: ttyACM0: USB ACM device
[   13.769828] usbcore: registered new interface driver cdc_acm
[   13.769837] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   14.131959] EXT4-fs (sda1): recovery complete
[   14.170297] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   14.673749] zram: Added device: zram0
[   14.679615] zram: Added device: zram1
[   14.681260] zram: Added device: zram2
[   14.826848] zram1: detected capacity change from 0 to 1053261824
[   15.160685] Adding 1028572k swap on /dev/zram1.  Priority:5 extents:1 across:1028572k SSFS
[   15.400055] zram0: detected capacity change from 0 to 52428800
[   15.734235] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   15.734298] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[   18.720742] systemd[1]: systemd-rfkill.service: Succeeded.
[   21.260850] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[   21.303781] systemd[1]: Started Armbian memory supported logging.
[   21.314614] systemd[1]: Starting Journal Service...
[   21.747242] systemd[1]: Started Journal Service.
[   21.857114] systemd-journald[525]: Received request to flush runtime journal from PID 1
[   28.444219] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[   28.447561] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
[   28.447581] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
[   28.447595] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
[   28.447606] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
[   28.447626] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii link mode
[   31.368606] ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
[   31.368634] ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
[   32.553239] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   32.553290] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   33.768376] vcc3v0: disabling
[   33.768421] vcc5v0: disabling
[   33.768463] usb0-vbus: disabling
Syslog shows this entries as last
Oct 25 00:00:01 localhost CRON[25691]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Oct 25 00:01:00 localhost systemd[1]: Starting Daily man-db regeneration...
Oct 25 00:01:00 localhost systemd[1]: Starting Rotate log files...
Oct 25 00:01:00 localhost armbian-ramlog[25803]: So 25. Okt 00:01:00 CEST 2020: Syncing logs to storage
Oct 25 00:01:00 localhost armbian-ramlog[25803]: sending incremental file list
Oct 25 00:01:00 localhost armbian-ramlog[25803]: armbian-hardware-monitor.log
Oct 25 00:01:00 localhost armbian-ramlog[25803]: auth.log
Oct 25 00:01:01 localhost armbian-ramlog[25803]: lastlog
Oct 25 00:01:01 localhost armbian-ramlog[25803]: messages
messages
Edited by Werner
Use spoiler for longer pastes
Today i had the Problem again, i will now tried the solution from @lampra with dissable ZRAM, and will see .
Is it enough to  ENABLED=false in the  /etc/default/armbian-ramlog   ?
I just used systemctl, after your tests you can enable and start the services again. I also disabled zram not only logging, but you could test by disabling only ram logging. Please note that I did this in order to be able to trace the issue but since i disabled the two services there is no issue
root@cubietruck:~# uptime
 20:17:52 up 12 days, 20:20,  1 user,  load average: 2.74, 2.77, 2.67
systemctl stop armbian-ramlog.service
systemctl disable armbian-ramlog.service
systemctl stop armbian-zram-config.service
systemctl disable armbian-zram-config.service
Edit: Well i forgot to say that i did experience 1 issue twice the past 12 days with transmission crashing but I am not sure if this is relevant.  Though I never had issues with transmission on cubietrack using armbian for the past few years. We probably need to alter the unit file so that the daemon restarts after crashing. Here is the log:
Oct 25 20:43:39 cubietruck systemd[1]: transmission-daemon.service: Main process exited, code=killed, status=7/BUS
Oct 25 20:43:39 cubietruck systemd[1]: transmission-daemon.service: Failed with result 'signal'.
Edited by lampra
Am 27.10.2020 um 18:31 schrieb Coolzero1982:
That was not the solution....
Going Down is farther a problem.
dont't the solution for me....
The logs shows now this
Syslog, at 08:21 AM the Log shows a lot of Massages,, because of the Message Log ist this the time of the restart.
 dmesg
[    3.052617]     /init
[    3.052624]     HOME=/
The message Log shows the last Log at last day on a similar time
Oct 31 07:19:51 localhost kernel: [52463.375652] [  32674]  1000 32674   456658   441358  1826816        0             0 perl
Oct 31 07:19:51 localhost kernel: [52463.375661] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/fhem.service,task=perl,pid=864,uid=1000
Oct 31 07:19:53 localhost kernel: [52464.140558] oom_reaper: reaped process 864 (perl), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Nov  1 08:21:12 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0
Nov  1 08:21:12 localhost kernel: [    0.000000] Linux version 5.8.16-sunxi (root@xeon) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.14 SMP Tue Oct 20 22:15:32 CEST 2020
Nov  1 08:21:12 localhost kernel: [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
Nov  1 08:21:12 localhost kernel: [    0.000000] CPU: div instructions available: patching division code
Nov  1 08:21:12 localhost kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Nov  1 08:21:12 localhost kernel: [    0.000000] OF: fdt: Machine model: Cubietech Cubietruck
Nov  1 08:21:12 localhost kernel: [    0.000000] Memory policy: Data cache writealloc
Nov  1 08:21:12 localhost kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
Nov  1 08:21:12 localhost kernel: [    0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
Nov  1 08:21:12 localhost kernel: [    0.000000] Zone ranges:
I don't know what i can do.....
Can i make a rollback in armbian?
Edited by Werner
Now, i have for 4 Days no Problem, and then today is the problem back, i don't no whats that....
Laut syslog müßte hier der Abstürzt gekommen sein
Nov  5 11:45:02 localhost CRON[5051]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov  5 11:48:35 localhost rngd[464]: stats: bits received from HRNG source: 2840064
Nov  5 11:48:35 localhost rngd[464]: stats: bits sent to kernel pool: 2792288
Nov  5 11:48:35 localhost rngd[464]: stats: entropy added to kernel pool: 2792288
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2 successes: 142
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2 failures: 0
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov  5 11:48:35 localhost rngd[464]: stats: HRNG source speed: (min=71.436; avg=109.711; max=190.735)Mibits/s
Nov  5 11:48:35 localhost rngd[464]: stats: FIPS tests speed: (min=955.400; avg=6361.504; max=11003.521)Kibits/s
Nov  5 11:48:35 localhost rngd[464]: stats: Lowest ready-buffers level: 2
Nov  5 11:48:35 localhost rngd[464]: stats: Entropy starvations: 0
Nov  5 11:48:35 localhost rngd[464]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov  5 11:55:01 localhost CRON[6705]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
In message ist der letzte eintrag deutlich früher
Nov  5 06:01:02 localhost kernel: [313958.471867] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/fhem.service,task=perl,pid=14478,uid=1000
Nov  5 06:01:03 localhost kernel: [313959.142637] oom_reaper: reaped process 14478 (perl), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
31 minutes ago, Coolzero1982 said:
fhem.service
It seems to me that this service is "eating" your memory.
If you can live without it, you could stop it for some days as a test. Though I am not an expert.
Then an option may be to reach out to their creators and ask if there might be a memory leak issue?
13 hours ago, Coolzero1982 said:
it must run ever
In this case you can assume (not with certainty) that the issue is originating from fhem.service (same error logged twice before freeze). Reach out to the developers and report the issue.
Then you could check if there was an update of fhem before the freezes started and downgrade if possible. At the same time you could check if scheduled periodic (eg. once a day or more) reboots may be used as a workaround until the main issue is resolved.
PS: you can now re-enable zram and ram logging.
Am 5.11.2020 um 20:58 schrieb lampra:
Now a few days everything run's fine, and now the Problem is back
The last messages in "messages" are this
Nov 11 00:33:48 localhost kernel: [454680.731222] [  19841]  1000 19841   453513   438156  1810432        0             0 perl
Nov 11 00:33:48 localhost kernel: [454680.731231] [  19933]  1000 19933    40085     4942   178176        0             0 node /usr/local
Nov 11 00:33:48 localhost kernel: [454680.731240] [  20030]  1000 20030     2722      127    20480        0             0 ssh
Nov 11 00:33:48 localhost kernel: [454680.731255] [  10072]  1000 10072   453404   437922  1810432        0             0 perl
Nov 11 00:33:48 localhost kernel: [454680.731263] [  10095]  1000 10095   453513   438041  1810432        0             0 perl
Nov 11 00:33:48 localhost kernel: [454680.731272] [  10100]  1000 10100   453513   438041  1808384        0             0 perl
Nov 11 00:33:48 localhost kernel: [454680.731277] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/fhem.service,task=perl,pid=19841,uid=1000
Nov 11 00:33:49 localhost kernel: [454681.241335] oom_reaper: reaped process 19841 (perl), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Nov 11 04:17:35 localhost rsyslogd: action '*' treated as ':omusrmsg:*' - please use ':omusrmsg:*' syntax instead, '*' will not be supported in the future [v8.1901.0 try https://www.rsyslog.com/e/2184 ]
Nov 11 04:17:35 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Nov 11 04:17:35 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="473" x-info="https://www.rsyslog.com"] start
Nov 11 04:17:35 localhost rsyslogd: action 'action-10-builtin:ompipe' suspended (module 'builtin:ompipe'), retry 0. There should be messages before this one giving the reason for suspension. [v8.1901.0 try https://www.rsyslog.com/e/2007 ]
Nov 11 04:17:35 localhost rsyslogd: action 'action-10-builtin:ompipe' suspended (module 'builtin:ompipe'), next retry is Wed Nov 11 04:18:05 2020, retry nbr 0. There should be messages before this one giving the reason for suspension. [v8.1901.0 try https://www.rsyslog.com/e/2007 ]
and in sylog
Nov 11 00:33:48 localhost kernel: [454680.731359] Out of memory: Killed process 19841 (perl) total-vm:1814052kB, anon-rss:1752172kB, file-rss:452kB, shmem-rss:0kB, UID:1000 pgtables:1768kB oom_score_adj:0
Nov 11 00:33:49 localhost systemd[1]: fhem.service: Main process exited, code=killed, status=9/KILL
Nov 11 00:33:58 localhost systemd[1]: fhem.service: Failed with result 'signal'.
Nov 11 00:33:59 localhost systemd[1]: fhem.service: Service RestartSec=100ms expired, scheduling restart.
Nov 11 00:33:59 localhost systemd[1]: fhem.service: Scheduled restart job, restart counter is at 9.
Nov 11 00:33:59 localhost systemd[1]: Stopped FHEM Home Automation.
Nov 11 00:33:59 localhost systemd[1]: Starting FHEM Home Automation...
Nov 11 00:34:00 localhost systemd[1]: Started FHEM Home Automation.
Nov 11 00:34:29 localhost hmland[604]: usb-transfer took more than 100ms (134ms), this may lead to timing problems!
Nov 11 00:34:38 localhost hmland[604]: usb-transfer took more than 100ms (131ms), this may lead to timing problems!
Nov 11 00:35:01 localhost CRON[10325]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 11 04:17:35 localhost fake-hwclock[235]: Current system time: 2020-11-11 03:17:28
Nov 11 04:17:35 localhost fake-hwclock[235]: fake-hwclock saved clock information is in the past: 2020-11-01 13:48:10
Nov 11 04:17:35 localhost fake-hwclock[235]: To set system time to this saved clock anyway, use "force"
Nov 11 04:17:35 localhost systemd-remount-fs[245]: mount: /etc/fstab: parse error at line 3 -- ignored
Fhem shout can be the problem i will post it in the Fhem Forum
I see a lot of Ram use
Nov 11 00:32:51 localhost kernel: [454623.580814] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/fhem.service,task=perl,pid=9922,uid=1000
Nov 11 00:32:52 localhost kernel: [454624.358596] oom_reaper: reaped process 9922 (perl), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Nov 11 00:33:48 localhost kernel: [454680.730475] perl invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
Nov 11 00:33:48 localhost kernel: [454680.730496] CPU: 1 PID: 10072 Comm: perl Tainted: G         C  E     5.8.16-sunxi #20.08.14
Nov 11 00:33:48 localhost kernel: [454680.730500] Hardware name: Allwinner sun7i (A20) Family
Nov 11 00:33:48 localhost kernel: [454680.730537] [<c010d6cd>] (unwind_backtrace) from [<c0109a7d>] (show_stack+0x11/0x14)
Nov 11 00:33:48 localhost kernel: [454680.730555] [<c0109a7d>] (show_stack) from [<c056e1c9>] (dump_stack+0x75/0x84)
Nov 11 00:33:48 localhost kernel: [454680.730572] [<c056e1c9>] (dump_stack) from [<c020d70b>] (dump_header+0x43/0x16a)
Nov 11 00:33:48 localhost kernel: [454680.730587] [<c020d70b>] (dump_header) from [<c020ce73>] (oom_kill_process+0x123/0x12c)
Nov 11 00:33:48 localhost kernel: [454680.730597] [<c020ce73>] (oom_kill_process) from [<c020d59f>] (out_of_memory+0x19b/0x260)
Nov 11 00:33:48 localhost kernel: [454680.730613] [<c020d59f>] (out_of_memory) from [<c0243c63>] (__alloc_pages_nodemask+0x913/0xc40)
Nov 11 00:33:48 localhost kernel: [454680.730627] [<c0243c63>] (__alloc_pages_nodemask) from [<c0230273>] (__pte_alloc+0x1f/0x118)
Nov 11 00:33:48 localhost kernel: [454680.730639] [<c0230273>] (__pte_alloc) from [<c0230d7d>] (copy_page_range+0x455/0x554)
Nov 11 00:33:48 localhost kernel: [454680.730655] [<c0230d7d>] (copy_page_range) from [<c011949b>] (dup_mm+0x21f/0x340)
Nov 11 00:33:48 localhost kernel: [454680.730667] [<c011949b>] (dup_mm) from [<c011a759>] (copy_process+0xf75/0x1218)
Nov 11 00:33:48 localhost kernel: [454680.730679] [<c011a759>] (copy_process) from [<c011ab5f>] (_do_fork+0x63/0x344)
Nov 11 00:33:48 localhost kernel: [454680.730692] [<c011ab5f>] (_do_fork) from [<c011b07f>] (sys_clone+0x5b/0x74)
Nov 11 00:33:48 localhost kernel: [454680.730704] [<c011b07f>] (sys_clone) from [<c0100061>] (ret_fast_syscall+0x1/0x62)
Nov 11 00:33:48 localhost kernel: [454680.730710] Exception stack(0xed05ffa8 to 0xed05fff0)
Nov 11 00:33:48 localhost kernel: [454680.730720] ffa0:                   b6f69078 b6f694d0 01200011 00000000 00000000 00000000
Nov 11 00:33:48 localhost kernel: [454680.730730] ffc0: b6f69078 b6f694d0 00000000 00000078 00000000 00000000 b6f69010 00000001
Nov 11 00:33:48 localhost kernel: [454680.730737] ffe0: 00000078 bea008d8 b6e15253 b6db7746
Nov 11 00:33:48 localhost kernel: [454680.730742] Mem-Info:
Nov 11 00:33:48 localhost kernel: [454680.730761] active_anon:459843 inactive_anon:5141 isolated_anon:0
Nov 11 00:33:48 localhost kernel: [454680.730761]  active_file:268 inactive_file:308 isolated_file:32
Nov 11 00:33:48 localhost kernel: [454680.730761]  unevictable:4 dirty:0 writeback:0
Nov 11 00:33:48 localhost kernel: [454680.730761]  slab_reclaimable:3671 slab_unreclaimable:7421
Nov 11 00:33:48 localhost kernel: [454680.730761]  mapped:1636 shmem:5228 pagetables:4752 bounce:0
Nov 11 00:33:48 localhost kernel: [454680.730761]  free:21875 free_pcp:0 free_cma:10211
Nov 11 00:33:48 localhost kernel: [454680.730774] Node 0 active_anon:1839372kB inactive_anon:20564kB active_file:1072kB inactive_file:1232kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:6544kB dirty:0kB writeback:0kB shmem:20912kB writeback_tmp:0kB all_unreclaimable? no
Nov 11 00:33:48 localhost kernel: [454680.730793] Normal free:83348kB min:3436kB low:4292kB high:5148kB reserved_highatomic:0KB active_anon:571240kB inactive_anon:5144kB active_file:120kB inactive_file:560kB unevictable:0kB writepending:0kB present:786432kB managed:749504kB mlocked:0kB kernel_stack:1168kB pagetables:5592kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:40844kB
Nov 11 00:33:48 localhost kernel: [454680.730795] lowmem_reserve[]: 0 10216 0
Nov 11 00:33:48 localhost kernel: [454680.730816] HighMem free:4152kB min:5840kB low:7360kB high:8880kB reserved_highatomic:0KB active_anon:1268132kB inactive_anon:15420kB active_file:1000kB inactive_file:1232kB unevictable:16kB writepending:0kB present:1307648kB managed:1307648kB mlocked:16kB kernel_stack:0kB pagetables:13416kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Nov 11 00:33:48 localhost kernel: [454680.730818] lowmem_reserve[]: 0 0 0
Nov 11 00:33:48 localhost kernel: [454680.730825] Normal: 855*4kB (UMEC) 416*8kB (UMEC) 669*16kB (UMEC) 283*32kB (MEC) 145*64kB (UMEC) 46*128kB (UMEC) 20*256kB (UMEC) 11*512kB (UEC) 4*1024kB (UC) 1*2048kB (E) 6*4096kB (C) = 83148kB
Nov 11 00:33:48 localhost kernel: [454680.730864] HighMem: 875*4kB (UM) 123*8kB (UM) 1*16kB (U) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4500kB
Nov 11 00:33:48 localhost kernel: [454680.730891] 5810 total pagecache pages
Nov 11 00:33:48 localhost kernel: [454680.730897] 0 pages in swap cache
Nov 11 00:33:48 localhost kernel: [454680.730901] Swap cache stats: add 0, delete 0, find 0/0
Nov 11 00:33:48 localhost kernel: [454680.730904] Free swap  = 0kB
Nov 11 00:33:48 localhost kernel: [454680.730907] Total swap = 0kB
Nov 11 00:33:48 localhost kernel: [454680.730910] 523520 pages RAM
Nov 11 00:33:48 localhost kernel: [454680.730913] 326912 pages HighMem/MovableOnly
Nov 11 00:33:48 localhost kernel: [454680.730916] 9232 pages reserved
Nov 11 00:33:48 localhost kernel: [454680.730919] 24576 pages cma reserved
Nov 11 00:33:48 localhost kernel: [454680.730923] Tasks state (memory values in pages):
Nov 11 00:33:48 localhost kernel: [454680.730926] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Nov 11 00:33:48 localhost kernel: [454680.730954] [    247]     0   247     8052      869    63488        0             0 systemd-journal
Nov 11 00:33:48 localhost kernel: [454680.730963] [    279]     0   279     4114      155    18432        0         -1000 systemd-udevd
Nov 11 00:33:48 localhost kernel: [454680.730975] [    391]     0   391     1812      767    14336        0             0 haveged
Nov 11 00:33:48 localhost kernel: [454680.730984] [    392]   108   392     1344       80    14336        0             0 rpcbind
Nov 11 00:33:48 localhost kernel: [454680.730993] [    443]     0   443      742       50    12288        0             0 alsactl
Nov 11 00:33:48 localhost kernel: [454680.731003] [    454]   104   454     1386      152    14336        0          -900 dbus-daemon
Nov 11 00:33:48 localhost kernel: [454680.731011] [    463]     0   463     6796       34    18432        0             0 rngd
Nov 11 00:33:48 localhost kernel: [454680.731019] [    468]     0   468     2243      176    16384        0             0 wpa_supplicant
Nov 11 00:33:48 localhost kernel: [454680.731028] [    473]     0   473     2658      166    20480        0             0 systemd-logind
Nov 11 00:33:48 localhost kernel: [454680.731036] [    480]     0   480     6117      230    24576        0             0 rsyslogd
Nov 11 00:33:48 localhost kernel: [454680.731044] [    483]     0   483     5687     1234    28672        0             0 networkd-dispat
Nov 11 00:33:48 localhost kernel: [454680.731052] [    490]     0   490     1914       51    16384        0             0 cron
Nov 11 00:33:48 localhost kernel: [454680.731061] [    491]     0   491    17360      476    47104        0             0 NetworkManager
Nov 11 00:33:48 localhost kernel: [454680.731069] [    596]     0   596     8819     1266    36864        0             0 unattended-upgr
Nov 11 00:33:48 localhost kernel: [454680.731077] [    604]     0   604     2537       68    12288        0             0 hmland
Nov 11 00:33:48 localhost kernel: [454680.731085] [    628]     0   628     2220      137    18432        0         -1000 sshd
Nov 11 00:33:48 localhost kernel: [454680.731094] [    638]   105   638     2753       65    12288        0             0 chronyd
Nov 11 00:33:48 localhost kernel: [454680.731103] [    643]   105   643      806       59    12288        0             0 chronyd
Nov 11 00:33:48 localhost kernel: [454680.731112] [    706]     0   706    49871     1598    55296        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731120] [    757]    33   757    49881     1015    47104        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731129] [    759]    33   759    49881     1015    47104        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731138] [    762]    33   762    49881     1015    47104        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731147] [    763]    33   763    49881     1015    47104        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731155] [    764]    33   764    49877      996    47104        0             0 apache2
Nov 11 00:33:48 localhost kernel: [454680.731163] [    806]     0   806     8986      159    26624        0             0 polkitd
Nov 11 00:33:48 localhost kernel: [454680.731171] [    973]     0   973     1560      212    14336        0             0 dhclient
Nov 11 00:33:48 localhost kernel: [454680.731180] [   1032]     0  1032      959       20    12288        0             0 agetty
Nov 11 00:33:48 localhost kernel: [454680.731189] [   1034]     0  1034     1620       23    14336        0             0 agetty
Nov 11 00:33:48 localhost kernel: [454680.731197] [   1062]     0  1062     1374       64    12288        0             0 oscam.armel
Nov 11 00:33:48 localhost kernel: [454680.731206] [   1064]     0  1064     6627      344    22528        0             0 oscam.armel
Nov 11 00:33:48 localhost kernel: [454680.731214] [   1078]     0  1078      482       59     8192        0             0 osemu.armel
free -h
              total        used        free      shared  buff/cache   available
Mem:          2,0Gi       1,8Gi       130Mi       7,0Mi        86Mi       149Mi
Swap:            0B          0B          0B
Edited by TRS-80
put long output inside spoiler
To my understanding zram is swap substitute. If you re-enable zram then you will have 1giga swap.
Given that you had zram enabled during the first freeze I don't expect that this is a solution.
Does Fhem ram usage increase overtime?
a few Days, every think looks fine and run fine, and now today the cubie goes down again.
in the fhem log, i can see the problem must be between this time
2020.11.18 07:46:14.951 1: [Freezemon] myFreezemon: possible freeze starting at 07:46:12, delay is 2.946 possibly caused by: fn-NotifyFn(Wetter) fn-NotifyFn(rd_Batterie) fn-NotifyFn(rd_Batterie_Level) tmr-Weather_GetUpdate(YahooWetter)
2020.11.18 17:53:50.437 1: Including fhem.cfg
The syslog shows
Nov 18 00:00:01 localhost CRON[28090]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 18 00:00:36 localhost systemd[1]: Starting Rotate log files...
Nov 18 00:00:36 localhost systemd[1]: Starting Daily man-db regeneration...
Nov 18 00:00:36 localhost armbian-ramlog[28188]: Mi 18. Nov 00:00:36 CET 2020: Syncing logs to storage
Nov 18 00:00:37 localhost armbian-ramlog[28188]: sending incremental file list
Nov 18 00:00:37 localhost armbian-ramlog[28188]: alternatives.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: aptitude
Nov 18 00:00:37 localhost armbian-ramlog[28188]: armbian-hardware-monitor.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: auth.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: bootstrap.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: btmp
Nov 18 00:00:37 localhost armbian-ramlog[28188]: daemon.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: debug
Nov 18 00:00:37 localhost armbian-ramlog[28188]: dpkg.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: faillog
Nov 18 00:00:37 localhost armbian-ramlog[28188]: kern.log
Nov 18 00:00:37 localhost armbian-ramlog[28188]: lastlog
Nov 18 17:53:42 localhost systemd-udevd[295]: Using default interface naming scheme 'v240'.
Nov 18 17:53:42 localhost systemd-udevd[295]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 18 17:53:42 localhost systemd-udevd[295]: link_config: could not get ethtool features for eth0
Nov 18 17:53:42 localhost fake-hwclock[224]: Current system time: 2020-11-18 16:53:27
Nov 18 17:53:42 localhost fake-hwclock[224]: fake-hwclock saved clock information is in the past: 2020-11-13 17:52:33
Nov 18 17:53:42 localhost fake-hwclock[224]: To set system time to this saved clock anyway, use "force"
Nov 18 17:53:42 localhost systemd-udevd[295]: Could not set offload features of eth0: Device or resource busy
Nov 18 17:53:42 localhost systemd-udevd[292]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 18 17:53:42 localhost systemd-udevd[296]: Using default interface naming scheme 'v240'.
Nov 18 17:53:42 localhost systemd-udevd[296]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 18 17:53:42 localhost systemd[1]: Starting Flush Journal to Persistent Storage...
Nov 18 17:53:42 localhost systemd-remount-fs[235]: mount: /etc/fstab: parse error at line 3 -- ignored
Nov 18 17:53:42 localhost resolvconf[246]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Nov 18 17:53:42 localhost armbian-zram-config[370]: Setting up swapspace version 1, size = 1004,5 MiB (1053257728 bytes)
Nov 18 17:53:42 localhost armbian-zram-config[370]: no label, UUID=c16f78da-d665-4661-a22a-93ef733f9f77
Nov 18 17:53:42 localhost armbian-zram-config[370]: mke2fs 1.44.5 (15-Dec-2018)
Nov 18 17:53:42 localhost armbian-zram-config[370]: Discarding device blocks:  4096/12800#010#010#010#010#010#010#010#010#010#010#010           #010#010#010#010#010#010#010#010#010#010#010done
Nov 18 17:53:42 localhost armbian-zram-config[370]: Creating filesystem with 12800 4k blocks and 12800 inodes
Nov 18 17:53:42 localhost armbian-zram-config[370]: Allocating group tables: 0/1#010#010#010   #010#010#010done
Nov 18 17:53:42 localhost armbian-zram-config[370]: Writing inode tables: 0/1#010#010#010   #010#010#010done
Nov 18 17:53:42 localhost armbian-zram-config[370]: Writing superblocks and filesystem accounting information: 0/1#010#010#010   #010#010#010done
Nov 18 17:53:42 localhost armbian-ramlog[480]: Mounting /dev/zram0 as /var/log/
Nov 18 17:53:42 localhost armbian-ramlog[480]: Mi 18. Nov 17:53:36 CET 2020: Loading logs from storage
Nov 18 17:53:42 localhost armbian-ramlog[480]: sending incremental file list
Nov 18 17:53:42 localhost armbian-ramlog[480]: ./
Nov 18 17:53:42 localhost armbian-ramlog[480]: alternatives.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: aptitude
Nov 18 17:53:42 localhost armbian-ramlog[480]: armbian-hardware-monitor.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: auth.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: bootstrap.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: btmp
Nov 18 17:53:42 localhost armbian-ramlog[480]: daemon.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: debug
Nov 18 17:53:42 localhost armbian-ramlog[480]: dpkg.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: faillog
Nov 18 17:53:42 localhost armbian-ramlog[480]: kern.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: lastlog
Nov 18 17:53:42 localhost armbian-ramlog[480]: messages
Nov 18 17:53:42 localhost armbian-ramlog[480]: syslog
Nov 18 17:53:42 localhost armbian-ramlog[480]: user.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: wtmp
Nov 18 17:53:42 localhost armbian-ramlog[480]: apache2/
Nov 18 17:53:42 localhost armbian-ramlog[480]: apache2/access.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: apache2/error.log
Nov 18 17:53:42 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0
Nov 18 17:53:42 localhost kernel: [    0.000000] Linux version 5.8.16-sunxi (root@xeon) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.14 SMP Tue Oct 20 22:15:32 CEST 2020
Nov 18 17:53:42 localhost kernel: [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
Nov 18 17:53:42 localhost kernel: [    0.000000] CPU: div instructions available: patching division code
Nov 18 17:53:42 localhost kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Nov 18 17:53:42 localhost kernel: [    0.000000] OF: fdt: Machine model: Cubietech Cubietruck
Nov 18 17:53:42 localhost kernel: [    0.000000] Memory policy: Data cache writealloc
Nov 18 17:53:42 localhost kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
Nov 18 17:53:42 localhost kernel: [    0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
Nov 18 17:53:42 localhost kernel: [    0.000000] Zone ranges:
Nov 18 17:53:42 localhost kernel: [    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
Nov 18 17:53:42 localhost kernel: [    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000bfcfffff]
Nov 18 17:53:42 localhost kernel: [    0.000000] Movable zone start for each node
Nov 18 17:53:42 localhost kernel: [    0.000000] Early memory node ranges
Nov 18 17:53:42 localhost kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfcfffff]
Nov 18 17:53:42 localhost kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfcfffff]
Nov 18 17:53:42 localhost kernel: [    0.000000] On node 0 totalpages: 523520
Nov 18 17:53:42 localhost kernel: [    0.000000]   Normal zone: 1728 pages used for memmap
Nov 18 17:53:42 localhost kernel: [    0.000000]   Normal zone: 0 pages reserved
Nov 18 17:53:42 localhost kernel: [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
Nov 18 17:53:42 localhost kernel: [    0.000000]   HighMem zone: 326912 pages, LIFO batch:63
Nov 18 17:53:42 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Nov 18 17:53:42 localhost kernel: [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
Nov 18 17:53:42 localhost kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920
Nov 18 17:53:42 localhost kernel: [    0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096
Nov 18 17:53:42 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1
Nov 18 17:53:42 localhost kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 521792
Nov 18 17:53:42 localhost kernel: [    0.000000] Kernel command line: root=UUID=19cf2f1d-1a31-4890-bc04-a2f1c4e4e021 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=ba110a34-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
Nov 18 17:53:42 localhost kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    0.000000] allocated 2098176 bytes of page_ext
Nov 18 17:53:42 localhost kernel: [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
Nov 18 17:53:42 localhost kernel: [    0.000000] Memory: 1948168K/2094080K available (9216K kernel code, 1028K rwdata, 3240K rodata, 1024K init, 328K bss, 47608K reserved, 98304K cma-reserved, 1307648K highmem)
Nov 18 17:53:42 localhost kernel: [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 with crng_init=0
Nov 18 17:53:42 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Nov 18 17:53:42 localhost kernel: [    0.000000] ftrace: allocating 39966 entries in 79 pages
Nov 18 17:53:42 localhost kernel: [    0.000000] ftrace: allocated 79 pages with 5 groups
Nov 18 17:53:42 localhost kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Nov 18 17:53:42 localhost kernel: [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
Nov 18 17:53:42 localhost kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
Nov 18 17:53:42 localhost kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Nov 18 17:53:42 localhost kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Nov 18 17:53:42 localhost kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Nov 18 17:53:42 localhost kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
Nov 18 17:53:42 localhost kernel: [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Nov 18 17:53:42 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Nov 18 17:53:42 localhost kernel: [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Nov 18 17:53:42 localhost kernel: [    0.000017] Switching to timer-based delay loop, resolution 41ns
Nov 18 17:53:42 localhost kernel: [    0.000552] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Nov 18 17:53:42 localhost kernel: [    0.000890] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
Nov 18 17:53:42 localhost kernel: [    0.001248] Console: colour dummy device 80x30
Nov 18 17:53:42 localhost kernel: [    0.001266] printk: console [tty1] enabled
Nov 18 17:53:42 localhost kernel: [    0.001332] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Nov 18 17:53:42 localhost kernel: [    0.001344] pid_max: default: 32768 minimum: 301
Nov 18 17:53:42 localhost kernel: [    0.001588] LSM: Security Framework initializing
Nov 18 17:53:42 localhost kernel: [    0.001651] Yama: becoming mindful.
Nov 18 17:53:42 localhost kernel: [    0.001857] AppArmor: AppArmor initialized
Nov 18 17:53:42 localhost kernel: [    0.001949] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    0.001964] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    0.003190] CPU: Testing write buffer coherency: ok
Nov 18 17:53:42 localhost kernel: [    0.003650] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Nov 18 17:53:42 localhost kernel: [    0.004486] Setting up static identity map for 0x40100000 - 0x40100054
Nov 18 17:53:42 localhost kernel: [    0.004651] rcu: Hierarchical SRCU implementation.
Nov 18 17:53:42 localhost kernel: [    0.008469] smp: Bringing up secondary CPUs ...
Nov 18 17:53:42 localhost kernel: [    0.019383] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Nov 18 17:53:42 localhost kernel: [    0.019558] smp: Brought up 1 node, 2 CPUs
Nov 18 17:53:42 localhost kernel: [    0.019570] SMP: Total of 2 processors activated (96.00 BogoMIPS).
Nov 18 17:53:42 localhost kernel: [    0.019574] CPU: All CPU(s) started in HYP mode.
Nov 18 17:53:42 localhost kernel: [    0.019577] CPU: Virtualization extensions available.
Nov 18 17:53:42 localhost kernel: [    0.020908] devtmpfs: initialized
Nov 18 17:53:42 localhost kernel: [    0.031085] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
Nov 18 17:53:42 localhost kernel: [    0.031609] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Nov 18 17:53:42 localhost kernel: [    0.031653] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    0.035821] xor: measuring software checksum speed
Nov 18 17:53:42 localhost kernel: [    0.075399]    arm4regs  :  1136.000 MB/sec
Nov 18 17:53:42 localhost kernel: [    0.115450]    8regs     :   791.000 MB/sec
Nov 18 17:53:42 localhost kernel: [    0.155502]    32regs    :   747.000 MB/sec
Nov 18 17:53:42 localhost kernel: [    0.195564]    neon      :  1150.000 MB/sec
Nov 18 17:53:42 localhost kernel: [    0.195569] xor: using function: neon (1150.000 MB/sec)
Nov 18 17:53:42 localhost kernel: [    0.195664] pinctrl core: initialized pinctrl subsystem
Nov 18 17:53:42 localhost kernel: [    0.196343] thermal_sys: Registered thermal governor 'fair_share'
Nov 18 17:53:42 localhost kernel: [    0.196350] thermal_sys: Registered thermal governor 'bang_bang'
Nov 18 17:53:42 localhost kernel: [    0.196356] thermal_sys: Registered thermal governor 'step_wise'
Nov 18 17:53:42 localhost kernel: [    0.197388] NET: Registered protocol family 16
Nov 18 17:53:42 localhost kernel: [    0.199307] DMA: preallocated 256 KiB pool for atomic coherent allocations
Nov 18 17:53:42 localhost kernel: [    0.199937] audit: initializing netlink subsys (disabled)
Nov 18 17:53:42 localhost kernel: [    0.200269] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
Nov 18 17:53:42 localhost kernel: [    0.200915] cpuidle: using governor ladder
Nov 18 17:53:42 localhost kernel: [    0.200946] cpuidle: using governor menu
Nov 18 17:53:42 localhost kernel: [    0.201514] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Nov 18 17:53:42 localhost kernel: [    0.201520] hw-breakpoint: maximum watchpoint size is 8 bytes.
Nov 18 17:53:42 localhost kernel: [    0.228905] cryptd: max_cpu_qlen set to 1000
Nov 18 17:53:42 localhost kernel: [    0.300198] raid6: neonx8   gen()   699 MB/s
Nov 18 17:53:42 localhost kernel: [    0.368333] raid6: neonx8   xor()   524 MB/s
Nov 18 17:53:42 localhost kernel: [    0.436463] raid6: neonx4   gen()   752 MB/s
Nov 18 17:53:42 localhost kernel: [    0.504595] raid6: neonx4   xor()   569 MB/s
Nov 18 17:53:42 localhost kernel: [    0.572728] raid6: neonx2   gen()   827 MB/s
Nov 18 17:53:42 localhost kernel: [    0.640846] raid6: neonx2   xor()   590 MB/s
Nov 18 17:53:42 localhost kernel: [    0.709006] raid6: neonx1   gen()   738 MB/s
Nov 18 17:53:42 localhost kernel: [    0.777131] raid6: neonx1   xor()   511 MB/s
Nov 18 17:53:42 localhost kernel: [    0.845248] raid6: int32x8  gen()   273 MB/s
Nov 18 17:53:42 localhost kernel: [    0.913414] raid6: int32x8  xor()   160 MB/s
Nov 18 17:53:42 localhost kernel: [    0.981592] raid6: int32x4  gen()   323 MB/s
Nov 18 17:53:42 localhost kernel: [    1.049709] raid6: int32x4  xor()   186 MB/s
Nov 18 17:53:42 localhost kernel: [    1.117853] raid6: int32x2  gen()   361 MB/s
Nov 18 17:53:42 localhost kernel: [    1.185955] raid6: int32x2  xor()   192 MB/s
Nov 18 17:53:42 localhost kernel: [    1.254140] raid6: int32x1  gen()   365 MB/s
Nov 18 17:53:42 localhost kernel: [    1.322249] raid6: int32x1  xor()   173 MB/s
Nov 18 17:53:42 localhost kernel: [    1.322254] raid6: using algorithm neonx2 gen() 827 MB/s
Nov 18 17:53:42 localhost kernel: [    1.322257] raid6: .... xor() 590 MB/s, rmw enabled
Nov 18 17:53:42 localhost kernel: [    1.322262] raid6: using neon recovery algorithm
Nov 18 17:53:42 localhost kernel: [    1.324264] iommu: Default domain type: Translated
Nov 18 17:53:42 localhost kernel: [    1.324714] SCSI subsystem initialized
Nov 18 17:53:42 localhost kernel: [    1.325090] libata version 3.00 loaded.
Nov 18 17:53:42 localhost kernel: [    1.325366] usbcore: registered new interface driver usbfs
Nov 18 17:53:42 localhost kernel: [    1.325425] usbcore: registered new interface driver hub
Nov 18 17:53:42 localhost armbian-ramlog[480]: apache2/other_vhosts_access.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: apt/
Nov 18 17:53:42 localhost armbian-ramlog[480]: apt/history.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: apt/term.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: chrony/
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/CCcam-bcommands.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/CCcam-changes.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/CCcam-iusers.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/NewCS-watchdog.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/OSEmu.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/OScam.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/gbox-watchdog.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: ipc/sBox-watchdog.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: private/
Nov 18 17:53:42 localhost armbian-ramlog[480]: sysstat/
Nov 18 17:53:42 localhost armbian-ramlog[480]: unattended-upgrades/
Nov 18 17:53:42 localhost armbian-ramlog[480]: unattended-upgrades/unattended-upgrades-shutdown.log
Nov 18 17:53:42 localhost armbian-ramlog[480]: sent 1,343,120 bytes  received 621 bytes  895,827.33 bytes/sec
Nov 18 17:53:42 localhost kernel: [    1.325499] usbcore: registered new device driver usb
Nov 18 17:53:42 localhost armbian-ramlog[480]: total size is 1,340,587  speedup is 1.00
Nov 18 17:53:42 localhost systemd[1]: Started Flush Journal to Persistent Storage.
Nov 18 17:53:42 localhost kernel: [    1.325606] mc: Linux media interface: v0.10
Nov 18 17:53:42 localhost kernel: [    1.325638] videodev: Linux video capture interface: v2.00
Nov 18 17:53:42 localhost kernel: [    1.325796] pps_core: LinuxPPS API ver. 1 registered
Nov 18 17:53:42 localhost systemd[1]: Starting Create Volatile Files and Directories...
Nov 18 17:53:42 localhost kernel: [    1.325801] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Nov 18 17:53:42 localhost kernel: [    1.325825] PTP clock support registered
Nov 18 17:53:42 localhost kernel: [    1.326470] Advanced Linux Sound Architecture Driver Initialized.
Nov 18 17:53:42 localhost systemd[1]: Started Create Volatile Files and Directories.
Nov 18 17:53:42 localhost systemd[1]: Starting RPC bind portmap service...
Nov 18 17:53:42 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Nov 18 17:53:42 localhost systemd[1]: Condition check resulted in Network Time Synchronization being skipped.
Nov 18 17:53:42 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Nov 18 17:53:42 localhost systemd[1]: Started RPC bind portmap service.
Nov 18 17:53:42 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 18 17:53:42 localhost systemd[1]: Reached target System Initialization.
Nov 18 17:53:42 localhost systemd[1]: Starting Armbian hardware optimization...
Nov 18 17:53:42 localhost systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 18 17:53:42 localhost systemd[1]: Starting Armbian hardware monitoring...
Nov 18 17:53:42 localhost systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 18 17:53:42 localhost systemd[1]: Started Daily apt download activities.
Nov 18 17:53:42 localhost systemd[1]: Started Daily apt upgrade and clean activities.
Nov 18 17:53:42 localhost systemd[1]: Started Daily man-db regeneration.
Nov 18 17:53:42 localhost systemd[1]: Listening on PC/SC Smart Card Daemon Activation Socket.
Nov 18 17:53:42 localhost systemd[1]: Reached target Sockets.
Nov 18 17:53:42 localhost systemd[1]: Started Clean PHP session files every 30 mins.
Nov 18 17:53:42 localhost systemd[1]: Started Daily rotation of log files.
Nov 18 17:53:42 localhost systemd[1]: Reached target Timers.
Nov 18 17:53:42 localhost systemd[1]: Reached target RPC Port Mapper.
Nov 18 17:53:42 localhost systemd[1]: Reached target Remote File Systems (Pre).
Nov 18 17:53:42 localhost systemd[1]: Reached target Remote File Systems.
Nov 18 17:53:42 localhost systemd[1]: Started Armbian hardware monitoring.
Nov 18 17:53:42 localhost systemd[1]: Started Armbian hardware optimization.
Nov 18 17:53:42 localhost systemd[1]: Reached target Basic System.
Nov 18 17:53:42 localhost systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Nov 18 17:53:42 localhost systemd[1]: Starting rng-tools.service...
Nov 18 17:53:42 localhost systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Nov 18 17:53:42 localhost systemd[1]: Started Manage Sound Card State (restore and store).
Nov 18 17:53:42 localhost systemd[1]: Started Swapspace, a dynamic swap space manager.
Nov 18 17:53:42 localhost rng-tools[548]: Starting Hardware RNG entropy gatherer daemon: rngd.
Nov 18 17:53:42 localhost systemd[1]: Starting System Logging Service...
Nov 18 17:53:42 localhost alsactl[551]: alsactl 1.1.8 daemon started
Nov 18 17:53:42 localhost rngd[556]: rngd 2-unofficial-mt.14 starting up...
Nov 18 17:53:42 localhost rngd[556]: entropy feed to the kernel ready
Nov 18 17:53:42 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Nov 18 17:53:42 localhost systemd[1]: Started Regular background program processing daemon.
Nov 18 17:53:42 localhost systemd[1]: Starting Resets System Activity Data Collector...
Nov 18 17:53:42 localhost systemd[1]: Starting Initialize hardware monitoring sensors...
Nov 18 17:53:42 localhost systemd[1]: Started D-Bus System Message Bus.
Nov 18 17:53:42 localhost cron[563]: (CRON) INFO (pidfile fd = 3)
Nov 18 17:53:42 localhost cron[563]: (*system*) WRONG FILE OWNER (/etc/crontab)
Nov 18 17:53:42 localhost rsyslogd: action '*' treated as ':omusrmsg:*' - please use ':omusrmsg:*' syntax instead, '*' will not be supported in the future [v8.1901.0 try https://www.rsyslog.com/e/2184 ]
Nov 18 17:53:42 localhost rsyslogd: error during parsing file /etc/rsyslog.conf, on or before line 94: warnings occured in file '/etc/rsyslog.conf' around line 94 [v8.1901.0 try https://www.rsyslog.com/e/2207 ]
Nov 18 17:53:42 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Nov 18 17:53:42 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="557" x-info="https://www.rsyslog.com"] start
Nov 18 17:53:42 localhost cron[563]: (CRON) INFO (Running @reboot jobs)
Nov 18 17:53:42 localhost rsyslogd: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.1901.0 try https://www.rsyslog.com/e/2039 ]
Nov 18 17:53:42 localhost rsyslogd: action 'action-10-builtin:ompipe' suspended (module 'builtin:ompipe'), retry 0. There should be messages before this one giving the reason for suspension. [v8.1901.0 try https://www.rsyslog.com/e/2007 ]
Nov 18 17:53:42 localhost rsyslogd: action 'action-10-builtin:ompipe' suspended (module 'builtin:ompipe'), next retry is Wed Nov 18 17:54:12 2020, retry nbr 0. There should be messages before this one giving the reason for suspension. [v8.1901.0 try https://www.rsyslog.com/e/2007 ]
Nov 18 17:53:42 localhost kernel: [    1.327254] NetLabel: Initializing
Nov 18 17:53:42 localhost kernel: [    1.327261] NetLabel:  domain hash size = 128
Nov 18 17:53:42 localhost kernel: [    1.327264] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Nov 18 17:53:42 localhost kernel: [    1.327350] NetLabel:  unlabeled traffic allowed by default
Nov 18 17:53:42 localhost kernel: [    1.328149] clocksource: Switched to clocksource arch_sys_counter
Nov 18 17:53:42 localhost kernel: [    1.434133] VFS: Disk quotas dquot_6.6.0
Nov 18 17:53:42 localhost kernel: [    1.434243] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 18 17:53:42 localhost kernel: [    1.434945] AppArmor: AppArmor Filesystem Enabled
Nov 18 17:53:42 localhost kernel: [    1.435990] simple-framebuffer bfd00000.framebuffer: framebuffer at 0xbfd00000, 0x300000 bytes, mapped to 0x(ptrval)
Nov 18 17:53:42 localhost kernel: [    1.436005] simple-framebuffer bfd00000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
Nov 18 17:53:42 localhost kernel: [    1.437485] Console: switching to colour frame buffer device 128x48
Nov 18 17:53:42 localhost kernel: [    1.451586] simple-framebuffer bfd00000.framebuffer: fb0: simplefb registered!
Nov 18 17:53:42 localhost kernel: [    1.460782] NET: Registered protocol family 2
Nov 18 17:53:42 localhost kernel: [    1.461701] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    1.461759] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    1.461871] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    1.461994] TCP: Hash tables configured (established 8192 bind 8192)
Nov 18 17:53:42 localhost kernel: [    1.462184] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    1.462248] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Nov 18 17:53:42 localhost kernel: [    1.462581] NET: Registered protocol family 1
Nov 18 17:53:42 localhost kernel: [    1.463099] Trying to unpack rootfs image as initramfs...
Nov 18 17:53:42 localhost kernel: [    2.241538] Freeing initrd memory: 9656K
Nov 18 17:53:42 localhost kernel: [    2.242326] hw perfevents: no interrupt-affinity property for /pmu, guessing.
Nov 18 17:53:42 localhost kernel: [    2.242689] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
Nov 18 17:53:42 localhost kernel: [    2.244381] Initialise system trusted keyrings
Nov 18 17:53:42 localhost kernel: [    2.244448] Key type blacklist registered
Nov 18 17:53:42 localhost kernel: [    2.244801] workingset: timestamp_bits=14 max_order=19 bucket_order=5
Nov 18 17:53:42 localhost kernel: [    2.250821] zbud: loaded
Nov 18 17:53:42 localhost kernel: [    2.252737] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Nov 18 17:53:42 localhost kernel: [    2.253978] fuse: init (API version 7.31)
Nov 18 17:53:42 localhost kernel: [    2.257322] integrity: Platform Keyring initialized
Nov 18 17:53:42 localhost kernel: [    2.374772] Key type asymmetric registered
Nov 18 17:53:42 localhost kernel: [    2.374783] Asymmetric key parser 'x509' registered
Nov 18 17:53:42 localhost kernel: [    2.374997] bounce: pool size: 64 pages
Nov 18 17:53:42 localhost kernel: [    2.375089] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Nov 18 17:53:42 localhost kernel: [    2.375386] io scheduler mq-deadline registered
Nov 18 17:53:42 localhost kernel: [    2.375395] io scheduler kyber registered
Nov 18 17:53:42 localhost kernel: [    2.375606] io scheduler bfq registered
Nov 18 17:53:42 localhost kernel: [    2.379470] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.381565] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
Nov 18 17:53:42 localhost kernel: [    2.394399] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Nov 18 17:53:42 localhost kernel: [    2.397492] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.398089] printk: console [ttyS0] disabled
Nov 18 17:53:42 localhost kernel: [    2.398192] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 50, base_baud = 1500000) is a 16550A
Nov 18 17:53:42 localhost kernel: [    2.398285] printk: console [ttyS0] enabled
Nov 18 17:53:42 localhost kernel: [    2.399411] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 51, base_baud = 1500000) is a 16550A
Nov 18 17:53:42 localhost kernel: [    2.399629] serial serial0: tty port ttyS2 registered
Nov 18 17:53:42 localhost kernel: [    2.410240] brd: module loaded
Nov 18 17:53:42 localhost kernel: [    2.419172] loop: module loaded
Nov 18 17:53:42 localhost kernel: [    2.420448] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.420591] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.422524] libphy: Fixed MDIO Bus: probed
Nov 18 17:53:42 localhost kernel: [    2.423193] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.423401] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
Nov 18 17:53:42 localhost kernel: [    2.423410] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
Nov 18 17:53:42 localhost kernel: [    2.423555] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Nov 18 17:53:42 localhost kernel: [    2.423567] sun7i-dwmac 1c50000.ethernet: no reset control found
Nov 18 17:53:42 localhost kernel: [    2.423597] sun7i-dwmac 1c50000.ethernet: no regulator found
Nov 18 17:53:42 localhost kernel: [    2.423981] sun7i-dwmac 1c50000.ethernet: Version ID not available
Nov 18 17:53:42 localhost kernel: [    2.423994] sun7i-dwmac 1c50000.ethernet: 	DWMAC1000
Nov 18 17:53:42 localhost kernel: [    2.424003] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Nov 18 17:53:42 localhost kernel: [    2.424012] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Nov 18 17:53:42 localhost kernel: [    2.424018] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Nov 18 17:53:42 localhost kernel: [    2.424832] libphy: stmmac: probed
Nov 18 17:53:42 localhost kernel: [    2.439878] realtek: module verification failed: signature and/or required key missing - tainting kernel
Nov 18 17:53:42 localhost kernel: [    2.450090] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Nov 18 17:53:42 localhost kernel: [    2.450126] ehci-platform: EHCI generic platform driver
Nov 18 17:53:42 localhost kernel: [    2.450709] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Nov 18 17:53:42 localhost kernel: [    2.450741] ohci-platform: OHCI generic platform driver
Nov 18 17:53:42 localhost kernel: [    2.451708] usbcore: registered new interface driver usb-storage
Nov 18 17:53:42 localhost kernel: [    2.452985] sunxi-rtc 1c20d00.rtc: registered as rtc0
Nov 18 17:53:42 localhost kernel: [    2.453040] sunxi-rtc 1c20d00.rtc: setting system clock to 2020-11-18T16:53:22 UTC (1605718402)
Nov 18 17:53:42 localhost kernel: [    2.453242] i2c /dev entries driver
Nov 18 17:53:42 localhost kernel: [    2.454575] axp20x-i2c 0-0034: AXP20x variant AXP209 found
Nov 18 17:53:42 localhost kernel: [    2.462184] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
Nov 18 17:53:42 localhost kernel: [    2.471082] ldo1: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.471478] ldo2: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.472637] ldo3: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.473360] ldo4: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.473590] ldo5: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.474285] dcdc2: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.474988] dcdc3: supplied by regulator-dummy
Nov 18 17:53:42 localhost kernel: [    2.480255] random: fast init done
Nov 18 17:53:42 localhost kernel: [    2.480460] axp20x-i2c 0-0034: Backup (RTC) battery charging is enabled
Nov 18 17:53:42 localhost kernel: [    2.480606] axp20x-i2c 0-0034: AXP20X driver loaded
Nov 18 17:53:42 localhost kernel: [    2.484525] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
Nov 18 17:53:42 localhost kernel: [    2.485341] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.486633] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.486782] sunxi-mmc 1c0f000.mmc: Got CD GPIO
Nov 18 17:53:42 localhost kernel: [    2.512485] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
Nov 18 17:53:42 localhost kernel: [    2.516289] ledtrig-cpu: registered to indicate activity on CPUs
Nov 18 17:53:42 localhost kernel: [    2.516390] hid: raw HID events driver (C) Jiri Kosina
Nov 18 17:53:42 localhost kernel: [    2.516560] usbcore: registered new interface driver usbhid
Nov 18 17:53:42 localhost kernel: [    2.516564] usbhid: USB HID core driver
Nov 18 17:53:42 localhost kernel: [    2.520015] debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
Nov 18 17:53:42 localhost kernel: [    2.521572] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
Nov 18 17:53:42 localhost kernel: [    2.525086] Initializing XFRM netlink socket
Nov 18 17:53:42 localhost kernel: [    2.525759] NET: Registered protocol family 10
Nov 18 17:53:42 localhost kernel: [    2.561850] mmc0: host does not support reading read-only switch, assuming write-enable
Nov 18 17:53:42 localhost kernel: [    2.565057] mmc0: new high speed SDHC card at address e624
Nov 18 17:53:42 localhost kernel: [    2.567017] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Nov 18 17:53:42 localhost kernel: [    2.574317]  mmcblk0: p1
Nov 18 17:53:42 localhost kernel: [    2.587847] Segment Routing with IPv6
Nov 18 17:53:42 localhost kernel: [    2.587983] NET: Registered protocol family 17
Nov 18 17:53:42 localhost kernel: [    2.588027] NET: Registered protocol family 15
Nov 18 17:53:42 localhost kernel: [    2.588198] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 18 17:53:42 localhost kernel: [    2.588413] 8021q: 802.1Q VLAN Support v1.8
Nov 18 17:53:42 localhost kernel: [    2.588490] Key type dns_resolver registered
Nov 18 17:53:42 localhost kernel: [    2.588976] Registering SWP/SWPB emulation handler
Nov 18 17:53:42 localhost kernel: [    2.589418] registered taskstats version 1
Nov 18 17:53:42 localhost kernel: [    2.589428] Loading compiled-in X.509 certificates
Nov 18 17:53:42 localhost kernel: [    2.597208] Loaded X.509 cert 'Build time autogenerated kernel key: 1db26793b2098835541128330c1baea0c341ef90'
Nov 18 17:53:42 localhost kernel: [    2.597403] zswap: loaded using pool lzo/zbud
Nov 18 17:53:42 localhost kernel: [    2.598240] Key type ._fscrypt registered
Nov 18 17:53:42 localhost kernel: [    2.598249] Key type .fscrypt registered
Nov 18 17:53:42 localhost kernel: [    2.598253] Key type fscrypt-provisioning registered
Nov 18 17:53:42 localhost kernel: [    2.604949] Btrfs loaded, crc32c=crc32c-generic
Nov 18 17:53:42 localhost kernel: [    2.632798] Key type encrypted registered
Nov 18 17:53:42 localhost kernel: [    2.632823] AppArmor: AppArmor sha1 policy hashing enabled
Nov 18 17:53:42 localhost kernel: [    2.651154] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.651267] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [    2.708190] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
Nov 18 17:53:42 localhost kernel: [    2.708235] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
Nov 18 17:53:42 localhost kernel: [    2.708265] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
Nov 18 17:53:42 localhost kernel: [    2.708280] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
Nov 18 17:53:42 localhost kernel: [    2.709476] scsi host0: ahci-sunxi
Nov 18 17:53:42 localhost kernel: [    2.709949] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 37
Nov 18 17:53:42 localhost kernel: [    2.721832] of_cfs_init
Nov 18 17:53:42 localhost kernel: [    2.721984] of_cfs_init: OK
Nov 18 17:53:42 localhost kernel: [    2.722193] ALSA device list:
Nov 18 17:53:42 localhost kernel: [    2.722202]   #0: sun4i-codec
Nov 18 17:53:42 localhost kernel: [    3.022605] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 18 17:53:42 localhost kernel: [    3.024549] ata1.00: supports DRM functions and may not be fully accessible
Nov 18 17:53:42 localhost kernel: [    3.024563] ata1.00: ATA-9: Samsung SSD 840 EVO 120GB, EXT0BB6Q, max UDMA/133
Nov 18 17:53:42 localhost kernel: [    3.024570] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32)
Nov 18 17:53:42 localhost kernel: [    3.025236] ata1.00: supports DRM functions and may not be fully accessible
Nov 18 17:53:42 localhost kernel: [    3.025676] ata1.00: configured for UDMA/133
Nov 18 17:53:42 localhost kernel: [    3.026322] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 840  BB6Q PQ: 0 ANSI: 5
Nov 18 17:53:42 localhost kernel: [    3.027314] scsi 0:0:0:0: Attached scsi generic sg0 type 0
Nov 18 17:53:42 localhost kernel: [    3.028078] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Nov 18 17:53:42 localhost kernel: [    3.028258] sd 0:0:0:0: [sda] Write Protect is off
Nov 18 17:53:42 localhost kernel: [    3.028271] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Nov 18 17:53:42 localhost kernel: [    3.028399] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 18 17:53:42 localhost kernel: [    3.030379]  sda: sda1
Nov 18 17:53:42 localhost kernel: [    3.031824] sd 0:0:0:0: [sda] Attached SCSI disk
Nov 18 17:53:42 localhost kernel: [    3.036291] Freeing unused kernel memory: 1024K
Nov 18 17:53:42 localhost kernel: [    3.048473] Run /init as init process
Nov 18 17:53:42 localhost kernel: [    3.048484]   with arguments:
Nov 18 17:53:42 localhost kernel: [    3.048490]     /init
Nov 18 17:53:42 localhost kernel: [    3.048494]   with environment:
Nov 18 17:53:42 localhost kernel: [    3.048498]     HOME=/
Nov 18 17:53:42 localhost kernel: [    3.048501]     TERM=linux
Nov 18 17:53:42 localhost kernel: [    3.048505]     ubootpart=ba110a34-01
Nov 18 17:53:42 localhost kernel: [    3.048508]     ubootsource=mmc
Nov 18 17:53:42 localhost kernel: [    3.048512]     sunxi_ve_mem_reserve=0
Nov 18 17:53:42 localhost kernel: [    3.048516]     sunxi_g2d_mem_reserve=0
Nov 18 17:53:42 localhost kernel: [    3.048519]     sunxi_fb_mem_reserve=16
Nov 18 17:53:42 localhost kernel: [    3.048523]     cgroup_enable=memory
Nov 18 17:53:42 localhost kernel: [    3.049054] process '/usr/bin/sh' started with executable stack
Nov 18 17:53:42 localhost kernel: [    3.748277] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq
Nov 18 17:53:42 localhost kernel: [    3.780248] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB
Nov 18 17:53:42 localhost kernel: [    3.802372] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 18 17:53:42 localhost kernel: [    3.803974] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 18 17:53:42 localhost kernel: [    3.805589] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 18 17:53:42 localhost kernel: [    3.808586] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 18 17:53:42 localhost kernel: [    3.825106] mmc1: new high speed SDIO card at address 0001
Nov 18 17:53:42 localhost kernel: [    4.002352] axp20x-gpio axp20x-gpio: DMA mask not set
Nov 18 17:53:42 localhost kernel: [    4.010700] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
Nov 18 17:53:42 localhost kernel: [    4.085803] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
Nov 18 17:53:42 localhost kernel: [    4.930834] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
Nov 18 17:53:42 localhost kernel: [    7.036242] random: systemd: uninitialized urandom read (16 bytes read)
Nov 18 17:53:42 localhost kernel: [    7.053500] random: systemd: uninitialized urandom read (16 bytes read)
Nov 18 17:53:42 localhost kernel: [    7.055776] random: systemd: uninitialized urandom read (16 bytes read)
Nov 18 17:53:42 localhost kernel: [    7.537425] RPC: Registered named UNIX socket transport module.
Nov 18 17:53:42 localhost kernel: [    7.537435] RPC: Registered udp transport module.
Nov 18 17:53:42 localhost kernel: [    7.537439] RPC: Registered tcp transport module.
Nov 18 17:53:42 localhost kernel: [    7.537442] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 18 17:53:42 localhost kernel: [    7.621677] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
Nov 18 17:53:42 localhost kernel: [    9.398316] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
Nov 18 17:53:42 localhost kernel: [    9.406426] cedrus 1c0e000.video-codec: Device registered as /dev/video0
Nov 18 17:53:42 localhost kernel: [    9.506487] sun4i-ss 1c15000.crypto-engine: Die ID 0
Nov 18 17:53:42 localhost kernel: [    9.605905] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0a97330)
Nov 18 17:53:42 localhost kernel: [    9.606086] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0a97330)
Nov 18 17:53:42 localhost kernel: [    9.606604] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0a96b74)
Nov 18 17:53:42 localhost kernel: [    9.607010] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0a96b74)
Nov 18 17:53:42 localhost kernel: [    9.607851] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
Nov 18 17:53:42 localhost kernel: [    9.607885] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a95600)
Nov 18 17:53:42 localhost kernel: [    9.608812] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
Nov 18 17:53:42 localhost kernel: [    9.608843] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a95600)
Nov 18 17:53:42 localhost kernel: [    9.641763] sun4i-drm display-engine: bound 1c16000.hdmi (ops sun4i_hdmi_ops [sun4i_drm_hdmi])
Nov 18 17:53:42 localhost kernel: [    9.641787] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Nov 18 17:53:42 localhost kernel: [    9.641800] checking generic (bfd00000 300000) vs hw (0 ffffffff)
Nov 18 17:53:42 localhost kernel: [    9.641807] fb0: switching to sun4i-drm-fb from simple
Nov 18 17:53:42 localhost kernel: [    9.660761] Console: switching to colour dummy device 80x30
Nov 18 17:53:42 localhost kernel: [    9.662310] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
Nov 18 17:53:42 localhost kernel: [    9.662411] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
Nov 18 17:53:42 localhost kernel: [    9.718797] Registered IR keymap rc-empty
Nov 18 17:53:42 localhost kernel: [    9.718947] rc rc0: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0
Nov 18 17:53:42 localhost kernel: [    9.757655] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
Nov 18 17:53:42 localhost kernel: [    9.757924] input: sunxi-ir as /devices/platform/soc/1c21800.ir/rc/rc0/input1
Nov 18 17:53:42 localhost kernel: [    9.780519] sunxi-ir 1c21800.ir: initialized sunXi IR driver
Nov 18 17:53:42 localhost kernel: [   10.064999] axp20x-adc axp20x-adc: DMA mask not set
Nov 18 17:53:42 localhost kernel: [   10.149498] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Nov 18 17:53:42 localhost kernel: [   10.151461] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
Nov 18 17:53:42 localhost kernel: [   10.155108] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Nov 18 17:53:42 localhost kernel: [   10.167145] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Nov 18 17:53:42 localhost kernel: [   10.167161] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
Nov 18 17:53:42 localhost kernel: [   10.173659] ehci-platform 1c14000.usb: EHCI Host Controller
Nov 18 17:53:42 localhost kernel: [   10.173704] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
Nov 18 17:53:42 localhost kernel: [   10.251639] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
Nov 18 17:53:42 localhost kernel: [   10.251714] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
Nov 18 17:53:42 localhost kernel: [   10.251772] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
Nov 18 17:53:42 localhost kernel: [   10.251820] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
Nov 18 17:53:42 localhost kernel: [   10.252577] ehci-platform 1c14000.usb: irq 33, io mem 0x01c14000
Nov 18 17:53:42 localhost kernel: [   10.276052] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
Nov 18 17:53:42 localhost kernel: [   10.276593] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
Nov 18 17:53:42 localhost kernel: [   10.276606] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 18 17:53:42 localhost kernel: [   10.276614] usb usb1: Product: EHCI Host Controller
Nov 18 17:53:42 localhost kernel: [   10.276621] usb usb1: Manufacturer: Linux 5.8.16-sunxi ehci_hcd
Nov 18 17:53:42 localhost kernel: [   10.276627] usb usb1: SerialNumber: 1c14000.usb
Nov 18 17:53:42 localhost kernel: [   10.277576] hub 1-0:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.277642] hub 1-0:1.0: 1 port detected
Nov 18 17:53:42 localhost kernel: [   10.278976] ehci-platform 1c1c000.usb: EHCI Host Controller
Nov 18 17:53:42 localhost kernel: [   10.279036] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
Nov 18 17:53:42 localhost kernel: [   10.281111] lima 1c40000.gpu: bus rate = 300000000
Nov 18 17:53:42 localhost kernel: [   10.281125] lima 1c40000.gpu: mod rate = 384000000
Nov 18 17:53:42 localhost kernel: [   10.281975] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 1
Nov 18 17:53:42 localhost kernel: [   10.323617] ehci-platform 1c1c000.usb: irq 38, io mem 0x01c1c000
Nov 18 17:53:42 localhost kernel: [   10.336288] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
Nov 18 17:53:42 localhost kernel: [   10.336680] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
Nov 18 17:53:42 localhost kernel: [   10.336690] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 18 17:53:42 localhost kernel: [   10.336697] usb usb2: Product: EHCI Host Controller
Nov 18 17:53:42 localhost kernel: [   10.336704] usb usb2: Manufacturer: Linux 5.8.16-sunxi ehci_hcd
Nov 18 17:53:42 localhost kernel: [   10.336710] usb usb2: SerialNumber: 1c1c000.usb
Nov 18 17:53:42 localhost kernel: [   10.337739] hub 2-0:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.337815] hub 2-0:1.0: 1 port detected
Nov 18 17:53:42 localhost kernel: [   10.339096] ohci-platform 1c14400.usb: Generic Platform OHCI controller
Nov 18 17:53:42 localhost kernel: [   10.339138] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
Nov 18 17:53:42 localhost kernel: [   10.339614] ohci-platform 1c14400.usb: irq 34, io mem 0x01c14400
Nov 18 17:53:42 localhost kernel: [   10.370077] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
Nov 18 17:53:42 localhost kernel: [   10.410177] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
Nov 18 17:53:42 localhost kernel: [   10.410191] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 18 17:53:42 localhost kernel: [   10.410199] usb usb3: Product: Generic Platform OHCI controller
Nov 18 17:53:42 localhost kernel: [   10.410206] usb usb3: Manufacturer: Linux 5.8.16-sunxi ohci_hcd
Nov 18 17:53:42 localhost kernel: [   10.410213] usb usb3: SerialNumber: 1c14400.usb
Nov 18 17:53:42 localhost kernel: [   10.411619] hub 3-0:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.411813] hub 3-0:1.0: 1 port detected
Nov 18 17:53:42 localhost kernel: [   10.413347] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
Nov 18 17:53:42 localhost kernel: [   10.413406] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
Nov 18 17:53:42 localhost kernel: [   10.417787] ohci-platform 1c1c400.usb: irq 39, io mem 0x01c1c400
Nov 18 17:53:42 localhost kernel: [   10.485019] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
Nov 18 17:53:42 localhost kernel: [   10.485045] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 18 17:53:42 localhost kernel: [   10.485052] usb usb4: Product: Generic Platform OHCI controller
Nov 18 17:53:42 localhost kernel: [   10.485060] usb usb4: Manufacturer: Linux 5.8.16-sunxi ohci_hcd
Nov 18 17:53:42 localhost kernel: [   10.485066] usb usb4: SerialNumber: 1c1c400.usb
Nov 18 17:53:42 localhost kernel: [   10.488719] hub 4-0:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.488798] hub 4-0:1.0: 1 port detected
Nov 18 17:53:42 localhost kernel: [   10.490748] usb_phy_generic usb_phy_generic.0.auto: supply vcc not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [   10.492231] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
Nov 18 17:53:42 localhost kernel: [   10.492270] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
Nov 18 17:53:42 localhost kernel: [   10.492413] phy id_det change to device
Nov 18 17:53:42 localhost kernel: [   10.492652] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
Nov 18 17:53:42 localhost kernel: [   10.492662] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 18 17:53:42 localhost kernel: [   10.492668] usb usb5: Product: MUSB HDRC host driver
Nov 18 17:53:42 localhost kernel: [   10.492675] usb usb5: Manufacturer: Linux 5.8.16-sunxi musb-hcd
Nov 18 17:53:42 localhost kernel: [   10.492682] usb usb5: SerialNumber: musb-hdrc.1.auto
Nov 18 17:53:42 localhost kernel: [   10.493616] hub 5-0:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.493690] hub 5-0:1.0: 1 port detected
Nov 18 17:53:42 localhost kernel: [   10.497070] asoc-simple-card sound: dit-hifi <-> 1c21000.spdif mapping ok
Nov 18 17:53:42 localhost kernel: [   10.516495] Bluetooth: Core ver 2.22
Nov 18 17:53:42 localhost kernel: [   10.516673] NET: Registered protocol family 31
Nov 18 17:53:42 localhost kernel: [   10.516679] Bluetooth: HCI device and connection manager initialized
Nov 18 17:53:42 localhost kernel: [   10.516708] Bluetooth: HCI socket layer initialized
Nov 18 17:53:42 localhost kernel: [   10.516719] Bluetooth: L2CAP socket layer initialized
Nov 18 17:53:42 localhost kernel: [   10.516753] Bluetooth: SCO socket layer initialized
Nov 18 17:53:42 localhost kernel: [   10.680281] usb 2-1: new high-speed USB device number 2 using ehci-platform
Nov 18 17:53:42 localhost kernel: [   10.695312] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
Nov 18 17:53:42 localhost kernel: [   10.759515] Bluetooth: HCI UART driver ver 2.3
Nov 18 17:53:42 localhost kernel: [   10.759529] Bluetooth: HCI UART protocol H4 registered
Nov 18 17:53:42 localhost kernel: [   10.759534] Bluetooth: HCI UART protocol BCSP registered
Nov 18 17:53:42 localhost kernel: [   10.759706] Bluetooth: HCI UART protocol LL registered
Nov 18 17:53:42 localhost kernel: [   10.759712] Bluetooth: HCI UART protocol ATH3K registered
Nov 18 17:53:42 localhost kernel: [   10.759776] Bluetooth: HCI UART protocol Three-wire (H5) registered
Nov 18 17:53:42 localhost kernel: [   10.760287] Bluetooth: HCI UART protocol Broadcom registered
Nov 18 17:53:42 localhost kernel: [   10.760512] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [   10.760649] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
Nov 18 17:53:42 localhost kernel: [   10.837076] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Nov 18 17:53:42 localhost kernel: [   10.837090] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Nov 18 17:53:42 localhost kernel: [   10.837097] usb 2-1: Product: USB 2.0 Hub
Nov 18 17:53:42 localhost kernel: [   10.838246] hub 2-1:1.0: USB hub found
Nov 18 17:53:42 localhost kernel: [   10.838456] hub 2-1:1.0: 4 ports detected
Nov 18 17:53:42 localhost kernel: [   10.944267] usb 3-1: new full-speed USB device number 2 using ohci-platform
Nov 18 17:53:42 localhost kernel: [   10.981799] cfg80211: failed to load regulatory.db
Nov 18 17:53:42 localhost kernel: [   11.145360] Bluetooth: hci0: BCM: chip id 63
Nov 18 17:53:42 localhost kernel: [   11.147981] Bluetooth: hci0: BCM: features 0x07
Nov 18 17:53:42 localhost kernel: [   11.171842] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available
Nov 18 17:53:42 localhost kernel: [   11.172345] Bluetooth: hci0: BCM20702A
Nov 18 17:53:42 localhost kernel: [   11.172360] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
Nov 18 17:53:42 localhost kernel: [   11.176844] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
Nov 18 17:53:42 localhost kernel: [   11.186421] usb 3-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
Nov 18 17:53:42 localhost kernel: [   11.186453] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 18 17:53:42 localhost kernel: [   11.186472] usb 3-1: Product: FT232R USB UART
Nov 18 17:53:42 localhost kernel: [   11.186479] usb 3-1: Manufacturer: FTDI
Nov 18 17:53:42 localhost kernel: [   11.186494] usb 3-1: SerialNumber: A7031FBC
Nov 18 17:53:42 localhost kernel: [   11.244304] usb 2-1.2: new full-speed USB device number 3 using ehci-platform
Nov 18 17:53:42 localhost kernel: [   11.303763] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Nov 18 17:53:42 localhost kernel: [   11.303774] Bluetooth: hci0: BCM: 'brcm/BCM20702A1.hcd'
Nov 18 17:53:42 localhost kernel: [   11.303778] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
Nov 18 17:53:42 localhost kernel: [   11.393206] usbcore: registered new interface driver usbserial_generic
Nov 18 17:53:42 localhost kernel: [   11.393288] usbserial: USB Serial support registered for generic
Nov 18 17:53:42 localhost kernel: [   11.446026] usbcore: registered new interface driver ftdi_sio
Nov 18 17:53:42 localhost kernel: [   11.446100] usbserial: USB Serial support registered for FTDI USB Serial Device
Nov 18 17:53:42 localhost kernel: [   11.446465] ftdi_sio 3-1:1.0: FTDI USB Serial Device converter detected
Nov 18 17:53:42 localhost kernel: [   11.446705] usb 3-1: Detected FT232RL
Nov 18 17:53:42 localhost kernel: [   11.454182] usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB0
Nov 18 17:53:42 localhost kernel: [   11.474645] usb 2-1.2: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
Nov 18 17:53:42 localhost kernel: [   11.474660] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 18 17:53:42 localhost kernel: [   11.474667] usb 2-1.2: Product: CUL433
Nov 18 17:53:42 localhost kernel: [   11.474674] usb 2-1.2: Manufacturer: busware.de
Nov 18 17:53:42 localhost kernel: [   11.676258] usb 2-1.4: new full-speed USB device number 4 using ehci-platform
Nov 18 17:53:42 localhost kernel: [   11.894199] usb 2-1.4: New USB device found, idVendor=1b1f, idProduct=c00f, bcdDevice= 9.67
Nov 18 17:53:42 localhost kernel: [   11.894213] usb 2-1.4: New USB device strings: Mfr=4, Product=14, SerialNumber=36
Nov 18 17:53:42 localhost kernel: [   11.894221] usb 2-1.4: Product: HM-CFG-USB
Nov 18 17:53:42 localhost kernel: [   11.894227] usb 2-1.4: Manufacturer: eQ-3
Nov 18 17:53:42 localhost kernel: [   11.894234] usb 2-1.4: SerialNumber: MEQ0232057
Nov 18 17:53:42 localhost kernel: [   11.899648] hid-generic 0003:1B1F:C00F.0001: hiddev0,hidraw0: USB HID v1.10 Device [eQ-3 HM-CFG-USB] on usb-1c1c000.usb-1.4/input0
Nov 18 17:53:42 localhost kernel: [   12.029291] cdc_acm 2-1.2:1.0: ttyACM0: USB ACM device
Nov 18 17:53:42 localhost kernel: [   12.031857] usbcore: registered new interface driver cdc_acm
Nov 18 17:53:42 localhost kernel: [   12.031867] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Nov 18 17:53:42 localhost kernel: [   12.153894] EXT4-fs (sda1): recovery complete
Nov 18 17:53:42 localhost kernel: [   12.171345] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Nov 18 17:53:42 localhost kernel: [   12.660352] zram: Added device: zram0
Nov 18 17:53:42 localhost kernel: [   12.662335] zram: Added device: zram1
Nov 18 17:53:42 localhost kernel: [   12.666905] zram: Added device: zram2
Nov 18 17:53:42 localhost kernel: [   12.795806] zram1: detected capacity change from 0 to 1053261824
Nov 18 17:53:42 localhost kernel: [   13.896246] Adding 1028572k swap on /dev/zram1.  Priority:5 extents:1 across:1028572k SSFS
Nov 18 17:53:42 localhost kernel: [   14.226065] zram0: detected capacity change from 0 to 52428800
Nov 18 17:53:42 localhost kernel: [   16.552975] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
Nov 18 17:53:42 localhost kernel: [   16.553034] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
Nov 18 17:53:42 localhost kernel: [   19.688400] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
Nov 18 17:53:42 localhost kernel: [   22.413392] random: crng init done
Nov 18 17:53:42 localhost kernel: [   22.413409] random: 7 urandom warning(s) missed due to ratelimiting
Nov 18 17:53:42 localhost systemd[1]: Starting WPA supplicant...
Nov 18 17:53:42 localhost systemd[1]: Starting Network Manager...
Nov 18 17:53:42 localhost CRON[579]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Nov 18 17:53:42 localhost systemd[1]: Starting Login Service...
Nov 18 17:53:42 localhost systemd[1]: Starting Save/Restore Sound Card State...
Nov 18 17:53:43 localhost systemd[1]: Starting Clean php session files...
Nov 18 17:53:43 localhost systemd[1]: Started System Logging Service.
Nov 18 17:53:43 localhost systemd[1]: Started rng-tools.service.
Nov 18 17:53:43 localhost systemd[1]: Started Resets System Activity Data Collector.
Nov 18 17:53:43 localhost wpa_supplicant[576]: Successfully initialized wpa_supplicant
Nov 18 17:53:43 localhost sensors[591]: axp20x_usb-isa-0000
Nov 18 17:53:43 localhost sensors[591]: Adapter: ISA adapter
Nov 18 17:53:43 localhost sensors[591]: in0:          +0.02 V  (min =  +4.00 V)
Nov 18 17:53:43 localhost sensors[591]: curr1:        +0.00 A  (max =  +0.90 A)
Nov 18 17:53:43 localhost sensors[591]: axp20x_battery-isa-0000
Nov 18 17:53:43 localhost sensors[591]: in0:          +0.00 V
Nov 18 17:53:43 localhost systemd[1]: Started Save/Restore Sound Card State.
Nov 18 17:53:43 localhost systemd[1]: Started Initialize hardware monitoring sensors.
Nov 18 17:53:43 localhost systemd[1]: Reached target Sound Card.
Nov 18 17:53:43 localhost systemd[1]: Started WPA supplicant.
Nov 18 17:53:43 localhost systemd[1]: Started Login Service.
Nov 18 17:53:43 localhost NetworkManager[578]: <info>  [1605718423.9751] NetworkManager (version 1.14.6) is starting... (for the first time)
Nov 18 17:53:43 localhost NetworkManager[578]: <info>  [1605718423.9903] Read config: /etc/NetworkManager/NetworkManager.conf (lib: no-mac-addr-change.conf) (etc: 10-override-wifi-random-mac-disable.conf, 20-override-wifi-powersave-disable.conf)
Nov 18 17:53:44 localhost NetworkManager[578]: <info>  [1605718424.0143] wifi-nl80211: (wlan0): using nl80211 for WiFi device control
Nov 18 17:53:44 localhost loadcpufreq[562]: Loading cpufreq kernel modules...done (none).
Nov 18 17:53:44 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Nov 18 17:53:44 localhost NetworkManager[578]: <info>  [1605718424.2061] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Nov 18 17:53:44 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Nov 18 17:53:44 localhost NetworkManager[578]: <info>  [1605718424.2278] manager[0xfdc010]: monitoring kernel firmware directory '/lib/firmware'.
Nov 18 17:53:44 localhost NetworkManager[578]: <info>  [1605718424.2354] monitoring ifupdown state file '/run/network/ifstate'.
Nov 18 17:53:44 localhost systemd[1]: Started Network Manager.
Nov 18 17:53:44 localhost systemd[1]: Reached target Network.
Nov 18 17:53:44 localhost systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Nov 18 17:53:44 localhost systemd[1]: Started Unattended Upgrades Shutdown.
Nov 18 17:53:44 localhost systemd[1]: Starting Permit User Sessions...
Nov 18 17:53:44 localhost systemd[1]: Starting chrony, an NTP client/server...
Nov 18 17:53:44 localhost dbus-daemon[568]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=578 comm="/usr/sbin/NetworkManager --no-daemon ")
Nov 18 17:53:44 localhost systemd[1]: Starting FHEM Home Automation...
Edited by TRS-80
put long output inside spoiler
Maybe do some scheduled reboot every night (or two, or whatever you feel is appropriate) as a temporary work-around until the memory leak is found.  Because it might take them a while to figure that out (and they will likely also need your help/feedback).
If scheduled in the middle of the night (assuming everything comes back up OK) you probably would not even notice it?
I meant plain old cron.  Not very elegant, but not terrible, either, as a temporary workaround, IMO.
I don't know anything about watchdogs (outside understanding the general concept).  Maybe someone else can speak to that.
Edited by TRS-80
clarity
Yes that would give you every third day at 01:00, with the caveat that you may get a slightly shorter interval at the end of the month, depending on how many days are in that month (which does not really matter for your purposes).
Maybe sure and check the cron tab is working first (do one like 5 min from now).  Also make sure all your services come back up properly when you test.
And remember, this is a work around.  ;)  Continue to diagnose the original issue (memory leak) as time and energy allow.
I don't know why, but the Cubie runs now 15 Days without any problem.....
But the load is not good, but i don't know why
  ____      _     _      _                   _
 / ___|   _| |__ (_) ___| |_ _ __ _   _  ___| | __
| |  | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ /
| |__| |_| | |_) | |  __/ |_| |  | |_| | (__|   <
 \____\__,_|_.__/|_|\___|\__|_|   \__,_|\___|_|\_\
Welcome to Armbian 20.08.17 Buster with Linux 5.8.16-sunxi
System load:   376%             Up time:       15 days 23:39
Memory usage:  13% of 1.96G     IP:            192.168.188.47
CPU temp:      43°C             Usage of /:    47% of 7.2G      storage/:      1% of 110G
[ General system configuration (beta): armbian-config ]
Last login: Wed Dec  2 19:25:18 2020 from 192.168.188.52
dmesg liefert ein paar rote eintröge
[   11.171842] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-1        1), device may have limited channels available
[   11.186421] usb 3-1: New USB device found, idVendor=0403, idProduct=6001, bcd        Device= 6.00
[   11.446100] usbserial: USB Serial support registered for FTDI USB Serial Devi        ce
[   11.474645] usb 2-1.2: New USB device found, idVendor=03eb, idProduct=204b, b        cdDevice= 0.00
[   11.474660] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber        =0
[   21.103211] systemd[1]: Started Armbian memory supported logging.
[   21.116526] systemd[1]: Starting Journal Service...
[   21.547262] systemd[1]: Started Journal Service.
[   21.663334] systemd-journald[525]: Received request to flush runtime journal        from PID 1
[   28.650370] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8        211E Gigabit Ethernet] (irq=POLL)
[   28.658233] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support fou        nd
[   28.658252] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabl        ed
[   28.658265] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters ava        ilable
[   28.658275] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
[   28.658293] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii link        mode
[   31.368246] ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
[   31.368273] ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0        type 10 failed: err=-5
[   31.753708] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow        control rx/tx
[   31.753764] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   33.768178] vcc3v0: disabling
[   33.768195] vcc5v0: disabling
[   33.768223] usb0-vbus: disabling
[1120462.079020] 8<--- cut here ---
[1120462.079036] Unable to handle kernel paging request at virtual address 00e94        f20
[1120462.079046] pgd = f29bac8c
[1120462.079049] [00e94f20] *pgd=00000000
[1120462.079062] Internal error: Oops: 5 [#1] SMP THUMB2
[1120462.084136] Modules linked in: zram cdc_acm ftdi_sio usbserial hci_uart btr        tl btbcm bluetooth snd_soc_spdif_tx brcmfmac ecdh_generic evdev brcmutil ecc axp        20x_battery lima axp20x_adc cfg80211 gpu_sched sun4i_gpadc_iio sun4i_ts sunxi_ci        r pwm_sun4i sun4i_drm_hdmi rfkill sun4i_ss sunxi_cedrus(C) uio_pdrv_genirq uio d        isplay_connector cpufreq_dt sunrpc ip_tables x_tables autofs4 axp20x_usb_power i        ndustrialio pinctrl_axp209 sunxi sun4i_gpadc phy_generic pwrseq_simple realtek(E        )
10c)
[1120462.443185] [<c0135b07>] (kthread) from [<c0100159>] (ret_from_fork+0x11/0x        38)
[1120462.450588] Exception stack(0xed4b5fb0 to 0xed4b5ff8)
[1120462.455821] 5fa0:                                     00000000 00000000 000        00000 00000000
[1120462.464184] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 000        00000 00000000
[1120462.472545] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[1120462.479344] Code: 9a01 4629 9b00 4630 (6a25) 69e6
[1120462.484508] ---[ end trace 18598cd5734e3bd7 ]---
[1120582.613729] ieee80211 phy0: brcmf_escan_timeout: timer expired
vmstat
 vmstat
procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
 0  0      0 182060 162756 1439764    0    0     0    13   11    1  5  7 88  0  0
Tasks: 116 total,   1 running, 114 sleeping,   0 stopped,   1 zombie
%Cpu(s):  0,3 us,  5,5 sy,  0,0 ni, 94,2 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Mem :   2008,9 total,    178,3 free,    265,1 used,   1565,5 buff/cache
MiB Swap:   1004,5 total,   1004,5 free,      0,0 used.   1661,7 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 3599 root      20   0       0      0      0 I   9,9   0,0   0:42.40 kworker/0:2-events_freezable_power_
 4953 root      20   0    9372   2564   2048 R   1,3   0,1   0:00.39 top
 1149 root      19  -1   26600   4500   2796 S   0,7   0,2 135:05.87 oscam.armel
 3084 fhem      20   0  165124 125888   9936 S   0,7   6,1 265:19.25 perl
 3560 root      20   0   10228   5240   4464 S   0,3   0,3   0:00.81 sshd
    1 root      20   0   32216   6976   5148 S   0,0   0,3   2:49.55 systemd
    2 root      20   0       0      0      0 S   0,0   0,0   0:02.26 kthreadd
Can you provide the output of:
df -h
In my case /dev/zram0 was 50M and most of it was occupied. Probably because the installation was some years ago and since then I upgrade the system leaving all the logs from all the packages that I have installed.
I had a freeze and I show in the journal errors due to full /dev/zram0
So I cleaned /var/log and /var/log.hdd from ancient logs and increased /dev/zram0 to 100M.
It has been 5 days now that the system is up without issues.
The load reported is probably a bug, if you upgrade to 20.11 its ok
here the output
 df -h
Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
udev            952M       0  952M    0% /dev
tmpfs           201M    3,1M  198M    2% /run
/dev/mmcblk0p1  7,2G    3,3G  3,8G   47% /
tmpfs          1005M       0 1005M    0% /dev/shm
tmpfs           5,0M    4,0K  5,0M    1% /run/lock
tmpfs          1005M       0 1005M    0% /sys/fs/cgroup
tmpfs          1005M    1,0M 1004M    1% /tmp
/dev/sda1       110G    398M  104G    1% /media/Platte
/dev/zram0       49M    1,6M   44M    4% /var/log
tmpfs           201M       0  201M    0% /run/user/0
