andyb1973 Posted October 26, 2020 Posted October 26, 2020 Armbianmonitor: http://ix.io/2C7f hello, my orangepi3 after the updates of firmware of these days seems to loose eth0, at reboot take eth0 and eth0:avahi with class 169 ip. i made backups (i use a sd to restore the mmc mouting hd and then copy the gzip image) so i have not problems to restore but, i suspect, the previus version is working but the new one not. sorry for my worst english... ab
Igor Posted October 26, 2020 Posted October 26, 2020 "Linux 5.9.0-sunxi64" Please at least use supported builds when asking for attention and help on our expense - 5.9.y is currently broken due to changes in NIC driver.
Werner Posted October 26, 2020 Posted October 26, 2020 Quote DISTRIBUTION_CODENAME=stretch DISTRIBUTION_STATUS=eos BRANCH=dev Three reasons to not further investigate...
andyb1973 Posted October 27, 2020 Author Posted October 27, 2020 oh my mistake, i didnt understand that was a dev version.. can i change it with armbian config or must change to buster? so in last 3 years, i was a very lucky guy thank you for all
Werner Posted October 27, 2020 Posted October 27, 2020 Try using armbian-config to switch to current or legacy branch
andyb1973 Posted October 27, 2020 Author Posted October 27, 2020 found the point Werner, thank you... running change, soon i update this thread ab
andyb1973 Posted October 27, 2020 Author Posted October 27, 2020 ok i made the change of kernel (i'm not very keen on that).. but i had to restore my previous backup (causa the update send my eth in 169 as said). ok, i restored and by armbian config i swicthed to che current versione and not the dev one. now: if i run ap update i see the list of packets to update and there is the new firmware of 5.9.. uhm... if i read well, now after armbian config into curretn versione DISTRIBUTION_CODENAME=stretch DISTRIBUTION_STATUS=eos VERSION=20.08.13 LINUXFAMILY=sunxi64 BRANCH=dev yet dev??? (http://ix.io/2Cdq) thank you in advance
