Guest Posted October 31, 2020 Posted October 31, 2020 Hi, i am using a tinkerboard s to run pihole, wireguard and a maria database. It worked quite a while without any issues. Just after I had to start over with the tinkerboard, the issues began. My main issue is, that after I restart the tinkerboard i do not get access right away to the internet. I have to open the pihole admin webpage first, just then I am able to get a normal internet connection. That works then without issues until another restart. I addressed my issue already in the pihole forum and the moderator suggested to ask here since in his opinion it might be an issue with the privacy extension of IPv6. I am honestly no expert and struggle quite a bit to get this issue fixed. Maybe somebody has an idea where I have to look and maybe can tell me which IPv6 addresses (fe80, fd00, ...) I have to use between pihole and my router to get it to work. thank you in advanced.
Werner Posted October 31, 2020 Posted October 31, 2020 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
Guest Posted October 31, 2020 Posted October 31, 2020 (edited) Hi Thank you for that. Did not know where to start. Unfortunately it does not work as expected. I get following print out, the link is missing though Quote System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for. I tried it within the armbian-config as well. Same result. EDIT I have unfortunately reached the maximum number of posts today. https://pastebin.com/nDqAXRDG Edited October 31, 2020 by MiCado I have unfortunately reached the maximum number of posts today.
Werner Posted October 31, 2020 Posted October 31, 2020 Hm you can use armbianmonitor -U as workaround (note the uppercase U) and put the output to some paste service.
Werner Posted November 1, 2020 Posted November 1, 2020 Hm nothing odd here. As far from what I can tell you is that Armbian has full IPv6 support like any other distribution does and does not alter the source distributions (Debian Buster or Ubuntu Focal to say) network config. You can check the rockchip kernel configuration used either on Github or in your /boot directory. All Armbian does is enable DHCP so the board can obtain an address from your router on first boot. From this point on everything is userspace and out of Armbian's reach. That being said moved to p2p since most likely an userspace issue.
Guest Posted November 2, 2020 Posted November 2, 2020 Thank you that you checked it. I am still not sure why it keeps breaking. Maybe it has something to do that network-manager and dhcpcd5 are both active and maybe fighting over IP addresses. Will have a look at the kernel configuration, but that is most likely way out of my comfort zone. Thanks again.
Werner Posted November 2, 2020 Posted November 2, 2020 No clue. I have a Pihole running on Armbian Buster for years now and never had issues with it. Never tried with Focal though.
guidol Posted November 2, 2020 Posted November 2, 2020 2 hours ago, Werner said: No clue. I have a Pihole running on Armbian Buster for years now and never had issues with it. Never tried with Focal though. I didnt got any diiference in function between buster & focal with pihole - but Iam only uing IPv4
xwiggen Posted November 2, 2020 Posted November 2, 2020 On 10/31/2020 at 3:32 PM, MiCado said: Hi, i am using a tinkerboard s to run pihole, wireguard and a maria database. It worked quite a while without any issues. Just after I had to start over with the tinkerboard, the issues began. My main issue is, that after I restart the tinkerboard i do not get access right away to the internet. I have to open the pihole admin webpage first, just then I am able to get a normal internet connection. That works then without issues until another restart. I addressed my issue already in the pihole forum and the moderator suggested to ask here since in his opinion it might be an issue with the privacy extension of IPv6. I am honestly no expert and struggle quite a bit to get this issue fixed. Maybe somebody has an idea where I have to look and maybe can tell me which IPv6 addresses (fe80, fd00, ...) I have to use between pihole and my router to get it to work. thank you in advanced. I had similar issues with both dhcp clients enabled for ipv4 and ipv6 on the pihole, it's an issue with dhclient ipv6. My solution; Disable DHCP4/6 on the router and enable it on the pihole (SLAAC+RA,rapid commit), add static addresses for IPV6 and IPV4 (include router as gateway for both instances). in the router, set the dns4/dns6 settings to pihole and enable RFC5006 to allow for DNSv6 advertisement.
Werner Posted November 2, 2020 Posted November 2, 2020 Not necessarly related to the issue itself butI remember a few years ago I had very poor performance in resolving DNS entries with my Pihole. Actually disabling RFC5006 solved this. So when experimenting with this option keep an eye on the performance if it goes down.
