webbbn Posted October 15, 2016 Share Posted October 15, 2016 Nope, but we added support for AIR based on available information recently and already built test images (more or less by accident): Armbian_5.20_Nanopiair_Debian_jessie_3.4.112.7z Armbian_5.20_Nanopiair_Ubuntu_xenial_3.4.112.7z Unless you are able to attach a serial console to the 4-pin header it's useless to even try them out. Two questions from our side: is the 4-pin header to provide power and attach a serial console populated or not? if the eMMC pre-flashed? Please get back to us with this information first, we will then update the NanoPi Air thread and might ask potential Air users a few questions. Thanks! None of the headers are populated. The box comes with the headers, but they're not soldered on. I populated all the headers, connected a USB-serial adapter to the serial console and tried powering it up. I don't see anything on the console, and no LEDs blink, so I don't think there is anything installed on the eMMC. I'll try your images and see what they do. Where is the NanoPi air thread? I didn't see it. Edit: It turns out that my USB-serial adapter must not provide enough current to boot. I powered from USB without an sdcard, and now the blue LED is flashing. I'm not seeing anything over the serial console, but there could be a problem with the configuration of my USB-serial. I'm not sure what the baud rate is for starters... Edit2: I'm an idiot! I soldered a dual row 90 degree header on the console pins and the other (single) row, then a single row along the rest of the row. The back (console) row aligns with the single row, and I had the USB-uart on the wrong pins. Now I am able to power the board from my USB-uart, and it boots from eMMC with the console at 115200, so it does come pre-installed with FriendlyArm Ubuntu on the eMMC. Edit3: The provided Ubuntu image works perfectly. It appears to be finding the wireless correctly, but I haven't tried configuring it yet. Link to comment Share on other sites More sharing options...
arox Posted October 15, 2016 Share Posted October 15, 2016 None of the headers are populated. The box comes with the headers, but they're not soldered on. I populated all the headers, connected a USB-serial adapter to the serial console and tried powering it up. I don't see anything on the console, and no LEDs blink, so I don't think there is anything installed on the eMMC. I'll try your images and see what they do. Where is the NanoPi air thread? I didn't see it. Edit: It turns out that my USB-serial adapter must not provide enough current to boot. I powered from USB without an sdcard, and now the blue LED is flashing. I'm not seeing anything over the serial console, but there could be a problem with the configuration of my USB-serial. I'm not sure what the baud rate is for starters... Edit2: I'm an idiot! I soldered a dual row 90 degree header on the console pins and the other (single) row, then a single row along the rest of the row. The back (console) row aligns with the single row, and I had the USB-uart on the wrong pins. Now I am able to power the board from my USB-uart, and it boots from eMMC with the console at 115200, so it does come pre-installed with FriendlyArm Ubuntu on the eMMC. Edit3: The provided Ubuntu image works perfectly. It appears to be finding the wireless correctly, but I haven't tried configuring it yet. Do they load g_ether and provide a config for usb0 ? Link to comment Share on other sites More sharing options...
webbbn Posted October 15, 2016 Share Posted October 15, 2016 Do they load g_ether and provide a config for usb0 ? No. The only modules loaded by default are: bcmdhd, cfg80211, and compat, and the only network interfaces are lo and (unconfigured) wlan0. Link to comment Share on other sites More sharing options...
arox Posted October 15, 2016 Share Posted October 15, 2016 No. The only modules loaded by default are: bcmdhd, cfg80211, and compat, and the only network interfaces are lo and (unconfigured) wlan0. Thanks. I ordered a neo and an air. I hope I will at least be able to use the armbian setup of the neo to get access to the air threw micro-usb without first playing with the iron ? Link to comment Share on other sites More sharing options...
webbbn Posted October 15, 2016 Share Posted October 15, 2016 Thanks. I ordered a neo and an air. I hope I will at least be able to use the armbian setup of the neo to get access to the air threw micro-usb without first playing with the iron ? At the very least, if you have a Linux system, you should be able to mount the root FS and edit files that way. BTW, I was talking about the default installation, not Armbian. Armbian doesn't appear to load g_ether by default either. Link to comment Share on other sites More sharing options...
arox Posted October 16, 2016 Share Posted October 16, 2016 Armbian doesn't appear to load g_ether by default either. The most practical would be to load g_serial and present a terminal on OTG port. Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 Armbian doesn't appear to load g_ether by default either. As soon as we have the Air in our hands we'll try two things: support flashing directly to eMMC (should work since yesterday since Zador added UUID support to boot script and fstab for all sunxi devices) enable g_serial as we currently already do on the other non-Ethernet board: Orange Pi Lite And since the eMMC is already populated with a bootable OS image and there seems to be no FEL boot button users would need a super small special SD card image to enter FEL mode which makes the whole 'flash to eMMC directly' approach somewhat useless Neither FEL button nor FEL jumper settings (as done on the CHIP for example) really sucks. At the very least, if you have a Linux system, you should be able to mount the root FS and edit files that way. You would need to bring the device in FEL mode before. If you're able to do so the rest is simply https://github.com/zador-blood-stained/fel-mass-storage Link to comment Share on other sites More sharing options...
arox Posted October 16, 2016 Share Posted October 16, 2016 enable g_serial as we currently already do on the other non-Ethernet board: Orange Pi Lite Seems reasonable : an armbian user who purchase this card would want to first try/save fa system by configuring network access and then install armbian if he is not satisfied or want to unify his configs. And I do not want to solder ports on a board before being sure I need them for a project : it is awfully difficult to unsolder ... I do not understand FA : flashing the eMMC has a cost for them, but what is the interest if you cannot log in ? Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 I do not understand FA : flashing the eMMC has a cost for them, but what is the interest if you cannot log in ? Well, they chose to let only the elite users make use of the Air. You should have a second Linux host available to enter Wi-Fi credentials on a SD card that will then replace the eMMC's contents (no, please don't ask why that complicated). So currently Air seems to come with a pre-populated OS image in eMMC you can't access in any reasonable way (solder iron needed). Due to missing FEL button this also prevents flashing an OS image to eMMC without the intermediate step to burn fel-sdboot.img to a small SD card and boot from there to expose the eMMC to a connected host. There's also no need to backup the eMMC contents since the OS there is unaccessible anyway. In other words: They pretty much prevented any reasonable access to the Air so far Link to comment Share on other sites More sharing options...
arox Posted October 16, 2016 Share Posted October 16, 2016 Well, they chose to let only the elite users make use of the Air. Well, the elite users may have achieve a level of study that allows them to calculate that $18 for a nanopi air is twice as much as $9 for a CHIP. The only advantage is that the "air" can be embedded more easily - and that is perhaps why they considered playing with the iron before even be able to test the board was not a problem. But for two lines of code missing in boot scripts, it is a bit ridiculous ... Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 But for two lines of code missing in boot scripts, it is a bit ridiculous ... Well, this commit enabled g_serial for Orange Pi Lite (and I believe we will do the same for NanoPi Air as well). Maybe FA simply missed the existence of g_serial module (or maybe even worse they tried to implement g_ether just to realize that in their kernel fork a patch might be missing?). Edit: unfortunately currently NanoPi Air comes with a pre-populated eMMC (with a more or less unaccessible OS image for whatever reasons) so it's necessary to flash the fel-sdboot.img OS image that's part of fel-mass-storage, burn it to an SD card and boot the Air from this mini image to enter FEL mode correctly (everything else will fail, always use Etcher since the verify process will show you this) Anyway: If the NanoPi Air would come with an unpopulated eMMC then it would be just this to get it up and running (from OS X in this case): Download and install Etcher Download Armbian image for NanoPi Air Double click sunxi-armbian-flasher-osx.app Use a Micro USB cable to connect the Air to your Mac 20 seconds later the Air is in FEL mode and Etcher will be started asking you to burn the OS image to it If Etcher is finished, unplug the USB cable, wait 3 seconds, re-plug it Wait until /dev/cu.usb* appears and then do 'screen /dev/cu.usb* 115200 –L' to setup Armbian Follow these instructions to setup Wi-Fi (zero feedback so far -- not so great) No need for an SD card at all, no need to solder or connect anything else than the Micro USB cable (BTW: you should do this on an USB3 port that has to provide 900mA since USB2's 500 mA might not be enough) Link to comment Share on other sites More sharing options...
zador.blood.stained Posted October 16, 2016 Share Posted October 16, 2016 I do not understand FA : flashing the eMMC has a cost for them, but what is the interest if you cannot log in ? I don't think it would cost much for mass production. And it is possible that decision to ship with unsoldered headers (including Ethernet port) was made after the decision to pre-populate eMMC with OS image. In other words: They pretty much prevented any reasonable access to the Air so far From my perspective for boards with eMMC an ideal user experience would be a special button or jumper which would force booting from onboard SPI flash pre-populated with something close to "fel-mass-storage" payload, so you would get eMMC exposed via g_mass_storage on OTG port. 1 Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 Got a couple of NanoPi NEO Airs today. Anyone tried Armbian on them yet? I imagine the standard NEO image will work, but how hard will it be to install it onto the internal flash? The NanoPi Air commits from today might get everything to work: https://github.com/igorpecovnik/lib/commits/master (at least they should activate eMMC and enable serial console on the Micro USB port using g_serial module -- the foundation to flash to eMMC directly is Zador's work and has been finished before) I tested it not with an Air (since none around) but with a NEO 'simulating' eMMC. Connected the board using the Micro USB connector to an USB port of my MacBook, then burned the image to the 'USB Mass storage device' (in my case SD card, in your case eMMC), then disconnected cable and reconnected and a minute later /dev/cu.usbmodem1421 appeared and I connected with screen to finish installation. Please keep in mind that you need an SD card with a minimal SPL on it that forces the Air into FEL mode (see here how/why) and that currently if you're using our build system to create a fresh image for the Air the nand-sata-install script doesn't work (needs some time to adjust it to get also UUID support if I understood correctly). Feedback welcomed. In case things work not as expected please understand that we've to wait for physical dev samples to arrive to make any real progress. All work currently done is only by looking in FriendlyARM's github account and wiki and listening to you users (who are great BTW!) Link to comment Share on other sites More sharing options...
webbbn Posted October 16, 2016 Share Posted October 16, 2016 If you think you have an image to test, I'm willing to test it. I don't have a Mac, but I do have Windows and Linux if Linux is required or easier to test on. Link to comment Share on other sites More sharing options...
Igor Posted October 16, 2016 Share Posted October 16, 2016 Check here, daily automated build, NanoPiAir was just added: http://image.armbian.com/betaimages/ 1 Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 If you think you have an image to test, I'm willing to test it. I don't have a Mac, but I do have Windows and Linux if Linux is required or easier to test on. Please test Armbian_5.21.161016_Nanopiair_Ubuntu_xenial_3.4.112.7z. And of course both Windows and Linux are fine. Simply follow the descriptions here: https://github.com/zador-blood-stained/fel-mass-storage (any SBC with Armbian will do it too and sunxi-fel is already installed there) https://github.com/igorpecovnik/lib/issues/493#issuecomment-252751466 (to setup Wi-Fi) Link to comment Share on other sites More sharing options...
webbbn Posted October 16, 2016 Share Posted October 16, 2016 Please test Armbian_5.21.161016_Nanopiair_Ubuntu_xenial_3.4.112.7z. And of course both Windows and Linux are fine. Simply follow the descriptions here: https://github.com/zador-blood-stained/fel-mass-storage (any SBC with Armbian will do it too and sunxi-fel is already installed there) https://github.com/igorpecovnik/lib/issues/493#issuecomment-252751466 (to setup Wi-Fi) I'm not sure I fully understand what I have to with this image. I booted it, and it came up just fine, then rebooted after a few minutes (not sure what that was about). Now it's booted, and it added a COM device that I'm able to log into, which is nice. I'm not sure what I do with the sunxi-fel, though. Link to comment Share on other sites More sharing options...
Igor Posted October 17, 2016 Share Posted October 17, 2016 I'm not sure I fully understand what I have to with this image. I booted it, and it came up just fine, then rebooted after a few minutes (not sure what that was about). Now it's booted, and it added a COM device that I'm able to log into, which is nice. I'm not sure what I do with the sunxi-fel, though. If it works, that's good ... our Air boards should be here this week. There is also an option to burn image directly to internal eMMC. Officially is under testing but it should work. General note: Link to beta image(s) is(are) changed since date is a part of filename. Since we can't have a full archive, old images are automatically removed. Only the last one remains. http://image.armbian.com/betaimages & browse for correct one ... or I can make some linking magic if direct linking is more desirable. Link to comment Share on other sites More sharing options...
tkaiser Posted October 17, 2016 Share Posted October 17, 2016 I'm not sure what I do with the sunxi-fel, though. That was meant to burn the OS image directly to eMMC (feedback needed) and then setting up Wi-Fi would be interesting (feedback needed). Please keep in mind that it's already confirmed that the Air image can boot from SD card and works as long as Wi-Fi/BT aren't considered (since tested with NEO). Link to comment Share on other sites More sharing options...
webbbn Posted October 17, 2016 Share Posted October 17, 2016 Please keep in mind that you need an SD card with a minimal SPL on it that forces the Air into FEL mode (see here how/why) and that currently if you're using our build system to create a fresh image for the Air the nand-sata-install script doesn't work (needs some time to adjust it to get also UUID support if I understood correctly). That was meant to burn the OS image directly to eMMC (feedback needed) and then setting up Wi-Fi would be interesting (feedback needed). Please keep in mind that it's already confirmed that the Air image can boot from SD card and works as long as Wi-Fi/BT aren't considered (since tested with NEO). I think the part that I was missing is how to bring the NEO Air into FEL mode. Now I see that there is a fel-sdboot.img that is in that repo, which must be the missing piece. I didn't see the last sentence that mentions booting that image. Maybe that should be moved to the top of the README, since I believe it has to happen before the other parts of the README will work, right? Once I boot that image and connect via USB, will it show another drive that I then write the provided image to? In any case, I'll try again tonight add see what happends. Link to comment Share on other sites More sharing options...
webbbn Posted October 18, 2016 Share Posted October 18, 2016 Clearly I'm missing some crucial information. I wrote the fel-sdboot.img to an sdcard and booted it, connected to USB. A device came up that has the same IDs as described in the fel-mass-storage instructions, but what do I do to write the image? The page you keep referring me to stops at detecting the device. I don't see any instructions on how to then write an image file to the device. The closest I can see is "sunxi-fel write address file", but I don't know what the address should be. Link to comment Share on other sites More sharing options...
tkaiser Posted October 18, 2016 Share Posted October 18, 2016 The page you keep referring me to stops at detecting the device. I don't see any instructions on how to then write an image file to the device. on Windows you would execute start.bat on Linux or OS X (alternative) you would execute start.sh All that's necessary is contained in these two small scripts. Link to comment Share on other sites More sharing options...
Igor Posted October 18, 2016 Share Posted October 18, 2016 Perhaps "run start" should be in the readme. It looks like this:1.start.bat 2.hold FEL button and connect power "Connect device in FEL mode and press <Enter>" Press any key to continue . . . 100% [================================================] 4575 kB, 813.5 kB/s 100% [================================================] 21 kB, 730.7 kB/s 100% [================================================] 2230 kB, 813.4 kB/s 100% [================================================] 0 kB, 49.2 kB/s Press any key to continue . . . 3. Check serial console: U-Boot 2016.09-armbian-fel-mass-storage-dirty (Sep 28 2016 - 12:21:11 +0300) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 1 GiB Using default environment In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 (FEL boot) ## Executing script at 43100000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 2229486 Bytes = 2.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Using machid 0x1029 from environment Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 1024MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2004620! ion_reserve_common: ion reserve: [0x50000000, 0x60000000]! Loading, please wait... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... Starting g_mass_storage script https://github.com/zador-blood-stained/fel-mass-storage Exporting MMC 0 (SD) (/dev/mmcblk0) Done Link to comment Share on other sites More sharing options...
zador.blood.stained Posted October 18, 2016 Share Posted October 18, 2016 Clearly I'm missing some crucial information. I wrote the fel-sdboot.img to an sdcard and booted it, connected to USB. A device came up that has the same IDs as described in the fel-mass-storage instructions, but what do I do to write the image? The page you keep referring me to stops at detecting the device. I don't see any instructions on how to then write an image file to the device. The closest I can see is "sunxi-fel write address file", but I don't know what the address should be. I'll extend this page in the future. On Windows you need to install WinUSB driver for the device with Zadig and then run "start.bat". On Linux/OS X you need to compile and install sunxi-tools and then run "start.sh" Link to comment Share on other sites More sharing options...
tkaiser Posted October 18, 2016 Share Posted October 18, 2016 http://image.armbian.com/betaimages/Armbian_5.21.161019_Nanopiair_Ubuntu_xenial_3.4.112.7z (available in a few hours) should contain everything that's needed to get up and running with NanoPi Air: nmtui/nmcli installed by default and Wi-Fi ready to be configured through network-manager. I just hope we did everything right regarding driver/firmware -- if I understood correctly Igor&Co still can't test since no dev samples around. Link to comment Share on other sites More sharing options...
Wazou Posted October 18, 2016 Share Posted October 18, 2016 Thanks guys for being on top of the things with the NanoPi Neo > NanoPi Air ARMbian release ! I'm currently firing up my NanoPi AIR cluster with the FA ubuntu but I'm now planning to switch to Armbian. But one of my major issue at the moment is to get the I2S up & running and so far it has not been a successful ride with the FA Ubuntu image. Is that something that will be implemented within the armbian release for the AIR ? Cheers; Link to comment Share on other sites More sharing options...
cctsao1008 Posted October 19, 2016 Share Posted October 19, 2016 Check here, daily automated build, NanoPiAir was just added: http://image.armbian.com/betaimages/ it's great!!! Link to comment Share on other sites More sharing options...
webbbn Posted October 19, 2016 Share Posted October 19, 2016 To complete the steps, after running start.sh a new drive was detected (/dev/sdd). I then dd'ed the Armbian image to /dev/sdd and power cycled the board, and it appears to have worked. A new tty device was created, which brings up a console login. There is a wlan0 network interface, but I wasn't able to configure it because nmcli is missing. The latest version of the firmware was not available yet, so I'm using yesterday's version, which apparently doesn't have it yet. After going though that, wouldn't it be easier to just have a small boot disk image that contains the full image and automatically dd's the image to the eMMC partition on boot? Link to comment Share on other sites More sharing options...
tkaiser Posted October 19, 2016 Share Posted October 19, 2016 one of my major issue at the moment is to get the I2S up & running and so far it has not been a successful ride with the FA Ubuntu image. Is that something that will be implemented within the armbian release for the AIR ? This is supposed to work after adjusting fex settings so the correct pin mappings are defined. Please have a look at FA wiki which pins are exposed on the header and look through this here: http://forum.armbian.com/index.php/topic/759-tutorial-i2s-on-orange-pi-h3/ It's important that multiplexed pins are only defined once as active (so better set gpio_used = 0 for example). None of us has a NEO PCB rev 1.1 or Air currently, we also lack the equipment to test I2S and SPDIF properly so we have to wait for users adopting these changes and submitting a correct fex file to Armbian. After going though that, wouldn't it be easier to just have a small boot disk image that contains the full image and automatically dd's the image to the eMMC partition on boot? This is normal behaviour (but requires a few fixes to nand_sata_install script now). Zador changed boot device selection so that this is now more flexible so that stuff like directly burning to eMMC is possible. After nand_sata_install script has been fixed it's simply up to the user to do it the usual way (flashing to SD card and then transferring to eMMC) or to flash directly. Please keep in mind that we support over 40 devices and that we do not focus only on the smallest and most limited devices around. If FA would have designed the Air properly (providing a FEL button) then a lot of the hassles necessary now could've been saved. Link to comment Share on other sites More sharing options...
Wazou Posted October 19, 2016 Share Posted October 19, 2016 This is supposed to work after adjusting fex settings so the correct pin mappings are defined. Please have a look at FA wiki which pins are exposed on the header and look through this here: http://forum.armbian.com/index.php/topic/759-tutorial-i2s-on-orange-pi-h3/ Thank you very much; confirming I2S working on the latest pre-release of the NanoAIR using MAX98357A (PCM Input Class D Audio Power Amplifiers) Cheers ! 1 Link to comment Share on other sites More sharing options...
