I have a friend who is blind and cannot use the standard ncurses armbian-config gui.
Is there a way to switch to a simple text version, and if not what are the chances of a text version option in the near future?
?Peter
There is no such thing like a simple text version nor is such a feature planned in near or far future. However if anyone is up for the task we do accept PRs providing new features.
Also note that using armbian-config is entirely optional. You can do everything this tool does also the usual way. Be it network config or installing stuff.
You can check out the source to get an idea what happens behind the scenes if you use the tool. Spolier: Its no rocket science :)
https://github.com/armbian/config
Hi the only thing we would need to do is configure WiFi via the command line, as we can't do it using armbian-config.
Creating a wpa_supplicant.conf file with a relevant ssid and psk didn't work, and if I purge network-manager all networking is lost including ethernet.
What would be the correct method to configure Wifi via the command line on an Orange Pi Zero (the latest Armbian Buster, kernel 5.8.4)
Peter
ร—
ร—
