TheGuv Posted January 6, 2021 Share Posted January 6, 2021 I'm trying this on my Helios64 RK3399 system but I'm getting severe glitches and missing 'tiles', many long pauses and freezes in the desktop and a bunch of GPU errors and soft resets in the logs. I actually wanted to run Kodi but upon investigating 3-5 seconds pauses when using the GUI I discovered the desktop is also affected. Interestingly video plays fine in Kodi, it's moving around any menu functions triggers the issue. I installed the Buster legacy 4.4.213-rk3399 image and then the MM Framework with recommended packages and rebooted. There is no HDMI port on the Helios64 board so I'm using a USB-C DP->HDMI adapter which works fine on the basic installation. Trouble started after installing the MM Framework. Syslog has a bunch of errors similar to: [ 80.234576] mali ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000008016D17F00 Reason: Memory is not mapped on the GPU raw fault status: 0xF002C0 decoded fault status: SLAVE FAULT exception type 0xC0: TRANSLATION_FAULT access type 0x2: READ source id 0xF0 pid: 2412 [ 80.234721] mali ff9a0000.gpu: error detected from slot 0, job status 0x00000004 (TERMINATED) [ 80.236756] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 0 [ 85.344471] mali ff9a0000.gpu: JS: Job Hard-Stopped (took more than 50 ticks at 100 ms/tick) [ 85.844538] mali ff9a0000.gpu: JS: Job has been on the GPU for too long (JS_RESET_TICKS_SS/DUMPING timeout hit). Issueing GPU soft-reset to resolve. [ 85.844578] mali ff9a0000.gpu: Preparing to soft-reset GPU: Waiting (upto 3000 ms) for all jobs to complete soft-stop [ 88.844625] mali ff9a0000.gpu: Resetting GPU (allowing up to 500 ms) [ 88.844647] mali ff9a0000.gpu: Register state: [ 88.844656] mali ff9a0000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009 [ 88.844665] mali ff9a0000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000001 [ 88.844673] mali ff9a0000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0x96825100 [ 88.844682] mali ff9a0000.gpu: JS1_STATUS=0x00000000 JS1_HEAD_LO=0x9650c100 [ 88.844691] mali ff9a0000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000 [ 88.844699] mali ff9a0000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000 [ 88.844708] mali ff9a0000.gpu: GPU_IRQ_MASK=0x00000000 JOB_IRQ_MASK=0x00000000 MMU_IRQ_MASK=0x00000000 [ 88.844717] mali ff9a0000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000 [ 88.844725] mali ff9a0000.gpu: SHADER_CONFIG=0x00010000 L2_MMU_CONFIG=0x00000000 [ 88.844734] mali ff9a0000.gpu: TILER_CONFIG=0x00000001 JM_CONFIG=0x00000038 [ 88.844840] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 0 [ 88.844854] mali ff9a0000.gpu: Reset complete [ 88.965817] mali ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000800F91C700 Reason: Memory is not mapped on the GPU raw fault status: 0xF002C0 decoded fault status: SLAVE FAULT exception type 0xC0: TRANSLATION_FAULT access type 0x2: READ source id 0xF0 pid: 2412 [ 113.438992] mali ff9a0000.gpu: JS: Job Hard-Stopped (took more than 50 ticks at 100 ms/tick) [ 113.939036] mali ff9a0000.gpu: JS: Job has been on the GPU for too long (JS_RESET_TICKS_SS/DUMPING timeout hit). Issueing GPU soft-reset to resolve. [ 113.939078] mali ff9a0000.gpu: Preparing to soft-reset GPU: Waiting (upto 3000 ms) for all jobs to complete soft-stop [ 116.939136] mali ff9a0000.gpu: Resetting GPU (allowing up to 500 ms) [ 116.939157] mali ff9a0000.gpu: Register state: [ 116.939166] mali ff9a0000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009 [ 116.939175] mali ff9a0000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000003 [ 116.939183] mali ff9a0000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0x9c05e240 [ 116.939192] mali ff9a0000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0x9c3c2100 [ 116.939201] mali ff9a0000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000 [ 116.939209] mali ff9a0000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000 [ 116.939218] mali ff9a0000.gpu: GPU_IRQ_MASK=0x00000000 JOB_IRQ_MASK=0x00000000 MMU_IRQ_MASK=0x00000000 [ 116.939226] mali ff9a0000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000 [ 116.939235] mali ff9a0000.gpu: SHADER_CONFIG=0x00010000 L2_MMU_CONFIG=0x00000000 [ 116.939243] mali ff9a0000.gpu: TILER_CONFIG=0x00000001 JM_CONFIG=0x00000038 [ 116.939299] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 0 [ 116.939370] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 1 [ 116.939453] mali ff9a0000.gpu: Reset complete [ 116.939641] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 0 I'm not sure where to go next so looking for the clue bus... 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 7, 2021 Author Share Posted January 7, 2021 16 hours ago, TheGuv said: which works fine on the basic installation. Trouble started after installing the MM Framework. Please "armbianmonitor -u" of the basic installation and also after installing the multimedia integration 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted January 7, 2021 Share Posted January 7, 2021 04.01.2021 в 12:18, JMCC сказал: What are the steps you follow in Libreelec to enable that feature? Can you do the same in our Kodi? LE uses its own settings management system (including audio), which consists of many different additional components (these are not components of KODI itself). For Armbian + mediascript, you must first set the necessary settings in the system (if the system supports them, not all settings are possible in Armbian) and then switch to KODI. In Armbian, the KODI application is limited in setting different hardware settings, it uses system settings. 1 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 7, 2021 Author Share Posted January 7, 2021 1 hour ago, balbes150 said: LE uses its own settings management system Yes, that was my guess. But I wanted the user to do some homework and check it for himself. I personally don't own any surround audio equipment, so if he cares for the feature, he will need to contribute some effort. Otherwise, I won't care either to implement it. 0 Quote Link to comment Share on other sites More sharing options...
TheGuv Posted January 7, 2021 Share Posted January 7, 2021 7 hours ago, JMCC said: Please "armbianmonitor -u" of the basic installation and also after installing the multimedia integration Sure. Basic install: http://ix.io/2Lac After MMF installation: http://ix.io/2L9G Thank you for the help. 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 7, 2021 Author Share Posted January 7, 2021 2 hours ago, TheGuv said: Sure. Basic install: http://ix.io/2Lac After MMF installation: http://ix.io/2L9G Thank you for the help. I tried to reproduce on my NanoPC-t4, but USB-C DP out does not work out of the box, at least with my adapter. I'll need to debug and fix that before getting into the mali issue. 0 Quote Link to comment Share on other sites More sharing options...
TheGuv Posted January 8, 2021 Share Posted January 8, 2021 22 hours ago, JMCC said: I tried to reproduce on my NanoPC-t4, but USB-C DP out does not work out of the box, at least with my adapter. I'll need to debug and fix that before getting into the mali issue. OK, that's unlucky. I bought two and only one worked. Good luck and let me know if I can help in any way. 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 8, 2021 Author Share Posted January 8, 2021 Just now, TheGuv said: I bought two and only one worked Can you share the models? 0 Quote Link to comment Share on other sites More sharing options...
TheGuv Posted January 9, 2021 Share Posted January 9, 2021 On 1/8/2021 at 6:04 PM, JMCC said: Can you share the models? Sure. The one that worked was this Choetech one from amazon. 0 Quote Link to comment Share on other sites More sharing options...
Dee Cheung Posted January 10, 2021 Share Posted January 10, 2021 My Helios64 have the same issue, I use Google USB Type-C to HDMI Adapter. 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 11, 2021 Author Share Posted January 11, 2021 17 hours ago, Dee Cheung said: My Helios64 have the same issue, I use Google USB Type-C to HDMI Adapter. Sorry, my USB-C to DP/HDMI converter is broken, and I have no plans to make room in my budget for a new one, at least for now. So I cannot debug or fix this problem. TBH, I am very surprised there is people using the Helios64 as a desktop device, I always considered it a NAS 1 Quote Link to comment Share on other sites More sharing options...
Dee Cheung Posted January 11, 2021 Share Posted January 11, 2021 1 hour ago, JMCC said: Sorry, my USB-C to DP/HDMI converter is broken, and I have no plans to make room in my budget for a new one, at least for now. So I cannot debug or fix this problem. TBH, I am very surprised there is people using the Helios64 as a desktop device, I always considered it a NAS Not only as a NAS, but also as a media server. 0 Quote Link to comment Share on other sites More sharing options...
TheGuv Posted January 11, 2021 Share Posted January 11, 2021 4 hours ago, JMCC said: Sorry, my USB-C to DP/HDMI converter is broken That's a shame. I tried to message you about this but apparently I'm only allowed 0 messages per day. I guess that goes with the 1 forum post per day 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 11, 2021 Author Share Posted January 11, 2021 2 minutes ago, TheGuv said: That's a shame. Yeah, I bought to my mother one of those Chinese CHUWI laptops, tried to use the adapter, but probably the USB-C port was not compliant and broke it. That is my punishment for cheaping out on my mother's laptop gift 0 Quote Link to comment Share on other sites More sharing options...
TheGuv Posted January 12, 2021 Share Posted January 12, 2021 On 1/11/2021 at 7:37 PM, JMCC said: That is my punishment for cheaping out on my mother's laptop gift LOL. If you promise not to test it on that fine laptop your mother has, I'll send you one. PM me your Amazon wish-list with it on, or just send your address (whatever is better for you). 2 Quote Link to comment Share on other sites More sharing options...
Dee Cheung Posted January 13, 2021 Share Posted January 13, 2021 13 hours ago, TheGuv said: LOL. If you promise not to test it on that fine laptop your mother has, I'll send you one. PM me your Amazon wish-list with it on, or just send your address (whatever is better for you). I think use GitHub Sponsors it is an other good option. 0 Quote Link to comment Share on other sites More sharing options...
Fnoeoe Posted January 24, 2021 Share Posted January 24, 2021 Hi guys I have a question. I have a Dietpi installed and installed the MM framework. In my case everything is running fine. Exept Nextflix in Kodi because of the missing Widevine DRM. Or maybe it's just the Mali DRM which should do that job. Is there anybody out there who is using Netflix successfully with the MM framework? 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted January 24, 2021 Author Share Posted January 24, 2021 10 hours ago, Fnoeoe said: I have a Dietpi installed No support for anything other than Armbian 10 hours ago, Fnoeoe said: the missing Widevine DRM. Yes, I realized it recently. Only 32-bit userspace will have Widevine DRM. I thought to make Kodi run in a 32-bit docker container, but there is no ETA for that project. 1 Quote Link to comment Share on other sites More sharing options...
tar.elda Posted February 2, 2021 Share Posted February 2, 2021 I bumped into two issues while using the image on RockPro64. 1. HDMI display doesn't work on startup. Cable has to be plugged after bootup process. Relevant logs: [ 26.831117] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 26.831146] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 26.831161] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 26.831173] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 26.831186] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 26.831197] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property I haven't encountered this issue while using ayufan images. So I guess it has something to do with Armbian legacy kernel build. 2. As my main target is using as mpeg-ts playback devices, obviously I immediately tested playback with some udp multicast stream. One stream played okay, but the other one failed after few minutes with following error: [ 216.494654] ------------[ cut here ]------------ [ 216.494671] WARNING: at drivers/gpu/drm/drm_atomic_helper.c:1398 [ 216.494675] Modules linked in: af_packet lz4hc lz4hc_compress zlib midgard_kbase rockchip_saradc uio_pdrv_genirq uio lzo zram ip_tables x_tables autofs4 [ 216.494717] CPU: 3 PID: 318 Comm: kworker/3:2 Not tainted 4.4.213-rockchip64 #4 [ 216.494721] Hardware name: Pine64 RockPro64 (DT) [ 216.494742] Workqueue: events rockchip_drm_atomic_work [ 216.494747] task: ffffffc0ed092a00 task.stack: ffffffc0ec0c0000 [ 216.494757] PC is at drm_atomic_helper_commit_hw_done+0x60/0x98 [ 216.494763] LR is at rockchip_atomic_commit_complete+0xac/0xf0 [ 216.494768] pc : [<ffffff80086a165c>] lr : [<ffffff80086de1f0>] pstate: 20000145 [ 216.494771] sp : ffffffc0ec0c3cd0 [ 216.494775] x29: ffffffc0ec0c3cd0 x28: 0000000000000000 [ 216.494781] x27: 0000000000000000 x26: 0000000000000000 [ 216.494787] x25: ffffffc0f7f1e9e8 x24: 0000000000000000 [ 216.494792] x23: 0000000000000000 x22: ffffffc0ec568840 [ 216.494798] x21: ffffffc0ed209800 x20: 0000000000000000 [ 216.494803] x19: ffffffc0db50c028 x18: 0000000030d00800 [ 216.494809] x17: 0000000000000000 x16: 0000000000000000 [ 216.494815] x15: 0000000000000000 x14: 0000000000000000 [ 216.494820] x13: 0000000000000000 x12: 0000000000000000 [ 216.494826] x11: 0000000000000000 x10: 0000000000000000 [ 216.494831] x9 : 0000000000000000 x8 : 0000000000000000 [ 216.494837] x7 : 0000000000000000 x6 : ffffffc0db50c1a0 [ 216.494843] x5 : 000000326814cc83 x4 : 0000000000000008 [ 216.494848] x3 : 0000000000000000 x2 : ffffff80086e9000 [ 216.494854] x1 : ffffffc0df6b7680 x0 : ffffffc0ed209600 [ 216.494861] PC: 0xffffff80086a15dc: [ 216.494865] 15dc 17ffffd0 a94153f3 a9425bf5 a94363f7 a9446bf9 a94573fb a8c97bfd d65f03c0 [ 216.494880] 15fc a9bd7bfd 910003fd a90153f3 a9025bf5 52800014 aa0003f5 aa1e03e0 d503201f [ 216.494894] 161c f94002a0 b944b800 6b14001f 540002ed f9401aa1 937d7e80 f8606821 b4000221 [ 216.494908] 163c f94016a1 f8606836 b40001d6 f94012a1 f8606833 f941fe60 f940ec00 b4000040 [ 216.494922] 165c d4210000 91104273 aa1303e0 9416e0d6 910102c0 97e96bd3 aa1303e0 9416e0fa [ 216.494936] 167c 11000694 17ffffe7 a94153f3 a9425bf5 a8c37bfd d65f03c0 a9b87bfd 910003fd [ 216.494950] 169c a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0003f5 12001c20 f0007bba [ 216.494964] 16bc f0003456 9139235a 9136aed6 b90073e0 aa1e03e0 d503201f 9100a6c0 52800019 [ 216.494979] LR: 0xffffff80086de170: [ 216.494984] e170 aa1303e0 f9401696 97ff0df4 aa1303e1 aa1403e0 97ff15bd aa1303e1 aa1403e0 [ 216.494998] e190 97ff0c4a aa1403e0 97fff2af 394902c0 34000120 f9411ec0 b50000e0 f9400e80 [ 216.495012] e1b0 52800001 940b1856 b140041f 9a9f9000 f9011ec0 f9411ec0 b4000080 2a1803e2 [ 216.495026] e1d0 2a1703e1 940b31a8 aa1303e1 52800022 aa1403e0 97ff16a7 aa1303e0 97ff0d04 [ 216.495040] e1f0 aa1303e1 aa1403e0 97ff0c95 aa1303e1 aa1403e0 97ff0b49 aa1303e0 97ff0e2d [ 216.495054] e210 aa1303e0 97ffa83f aa1503e0 97ebda7b a94153f3 a9425bf5 a94363f7 a8c47bfd [ 216.495069] e230 d65f03c0 a9b97bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb [ 216.495083] e250 aa0003f5 aa0103f3 aa1e03e0 12001c59 d503201f 52800001 aa1303e0 f94016b8 [ 216.495097] SP: 0xffffffc0ec0c3c50: [ 216.495102] 3c50 ec568840 ffffffc0 00000000 00000000 00000000 00000000 f7f1e9e8 ffffffc0 [ 216.495116] 3c70 00000000 00000000 00000000 00000000 00000000 00000000 ec0c3cd0 ffffffc0 [ 216.495130] 3c90 086de1f0 ffffff80 ec0c3cd0 ffffffc0 086a165c ffffff80 20000145 00000000 [ 216.495144] 3cb0 ec0c3d00 ffffffc0 086de1e8 ffffff80 ffffffff ffffffff ebb9e000 ffffffc0 [ 216.495158] 3cd0 ec0c3d00 ffffffc0 086de1f0 ffffff80 ed209800 ffffffc0 ebb9e000 ffffffc0 [ 216.495172] 3cf0 df6b7e00 ffffffc0 db481c28 ffffffc0 ec0c3d40 ffffffc0 086de9b8 ffffff80 [ 216.495186] 3d10 db481d20 ffffffc0 db481d20 ffffffc0 f7f1e9c0 ffffffc0 00000000 00000000 [ 216.495200] 3d30 f7f23200 ffffffc0 09598fa8 ffffff80 ec0c3d60 ffffffc0 080ce748 ffffff80 [ 216.495216] X0: 0xffffffc0ed209580: [ 216.495220] 9580 db50c710 ffffffc0 db50dc70 ffffffc0 00000000 00000000 00000000 00000000 [ 216.495235] 95a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495248] 95c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495262] 95e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495276] 9600 00000000 00000000 ed209640 ffffffc0 00000000 00000000 00000000 00000000 [ 216.495290] 9620 ec03ee00 ffffffc0 00000000 00000000 081d4c08 ffffff80 00000000 00000000 [ 216.495304] 9640 00000002 00000020 60382b00 0000007f 00000000 00000000 00000000 00000000 [ 216.495318] 9660 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495333] X1: 0xffffffc0df6b7600: [ 216.495337] 7600 df761840 ffffffc0 df7c2750 ffffffc0 df7618b8 ffffffc0 df7618b8 ffffffc0 [ 216.495351] 7620 00000001 00000000 00000000 00000000 00000000 00000000 07f7da5a 00000000 [ 216.495365] 7640 de4efe70 ffffffc0 df7c22d8 ffffffc0 de4efee8 ffffffc0 de4efee8 ffffffc0 [ 216.495379] 7660 00000001 00000000 00000000 00000000 ec015960 ffffffc0 00000046 00000000 [ 216.495393] 7680 db50c028 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495408] 76a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495421] 76c0 ec568840 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495435] 76e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495450] X2: 0xffffff80086e8f80: [ 216.495454] 8f80 6b0500df 54fffde1 39408865 12001c84 d34110a5 6b0400bf 54fffd48 79404465 [ 216.495469] 8fa0 d34520a5 6b05009f 17ffffd5 f9400067 b864d8e7 36780067 1ac420c7 2a070042 [ 216.495483] 8fc0 11000484 17ffffbd f9400068 b865d908 36080068 1ac520e8 2a080042 110004a5 [ 216.495497] 8fe0 17ffffe0 f942ee61 927e24a3 1ac62042 b8636825 0a2200a2 b8236822 17ffffcc [ 216.495511] 9000 a9bc7bfd 910003fd a90153f3 a9025bf5 a90363f7 aa0003f3 aa0103f6 aa1e03e0 [ 216.495525] 9020 91188277 d503201f f941fe74 aa1703e0 f940f2d5 9415c263 aa1303e0 97ffe61d [ 216.495539] 9040 aa1303e0 aa1603e1 97fff601 b9422680 34002180 f942e660 f9400800 b9425001 [ 216.495554] 9060 34000481 39495c06 721f08df 540001c0 b9446e62 d3410cc3 6b42207f 540003a1 [ 216.495569] X6: 0xffffffc0db50c120: [ 216.495573] c120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495587] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495601] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495615] c180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495629] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495643] c1c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495657] c1e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495670] c200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495689] X19: 0xffffffc0db50bfa8: [ 216.495694] bfa8 eb7d1400 ffffffc0 0943a068 ffffff80 00000000 00000000 00000000 00000000 [ 216.495708] bfc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495722] bfe8 00000000 00000000 00000000 00000000 00000000 00000000 eb4e5740 ffffffc0 [ 216.495736] c008 eb4e6200 ffffffc0 0870f2e4 ffffff80 08fb32e2 ffffff80 00002a80 00000000 [ 216.495750] c028 ebb9e000 ffffffc0 f7f93150 ffffffc0 db512038 ffffffc0 ebb9e4c0 ffffffc0 [ 216.495764] c048 00000000 00000000 00120012 dead4ead ffffffff 00000000 ffffffff ffffffff [ 216.495778] c068 db50c068 ffffffc0 db50c068 ffffffc0 ec0cf000 ffffffc0 00000000 00000000 [ 216.495792] c088 def2fcb8 ffffffc0 def2fcd8 ffffffc0 db50c778 ffffffc0 00000040 cccccccc [ 216.495808] X21: 0xffffffc0ed209780: [ 216.495812] 9780 e2419900 ffffffc0 e2419700 ffffffc0 00000000 00000000 00000000 00000000 [ 216.495826] 97a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495840] 97c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495854] 97e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495868] 9800 ebb9e000 ffffffc0 00000000 00000000 ed209580 ffffffc0 ed209780 ffffffc0 [ 216.495882] 9820 df6b7680 ffffffc0 df6b76c0 ffffffc0 df6b7280 ffffffc0 00000002 00000000 [ 216.495896] 9840 df6b7f00 ffffffc0 df6b7bc0 ffffffc0 e798bcb8 ffffffc0 00000000 00000000 [ 216.495910] 9860 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.495924] X22: 0xffffffc0ec5687c0: [ 216.495929] 87c0 ffffffff 0000003f ffffffff 0000003f ffffffff 0000003f 00000000 00000000 [ 216.495943] 87e0 00000000 00000000 de0c5100 ffffffc0 00000000 00000000 00000000 00000000 [ 216.495957] 8800 00000000 00000000 00000000 00000000 0943a068 ffffff80 0943a0d8 ffffff80 [ 216.495971] 8820 0943bac0 ffffff80 ed2612e8 ffffffc0 080d5a30 ffffff80 00000000 00000000 [ 216.495985] 8840 db50c028 ffffffc0 00000002 00000000 7ffffffe 00000000 00020002 dead4ead [ 216.495999] 8860 ffffffff 00000000 ffffffff ffffffff ec568870 ffffffc0 ec568870 ffffffc0 [ 216.496013] 8880 00000000 00000000 00010001 dead4ead ffffffff 00000000 ffffffff ffffffff [ 216.496028] 88a0 def2fae0 ffffffc0 def2fae0 ffffffc0 00000000 00000000 00000000 dead4ead [ 216.496043] X25: 0xffffffc0f7f1e968: [ 216.496047] e968 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.496062] e988 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 216.496075] e9a8 00000000 00000000 00000000 00000000 00000000 00000000 06a806a8 dead4ead [ 216.496089] e9c8 ffffffff 00000000 ffffffff ffffffff 00000003 00000000 00000006 00000000 [ 216.496103] e9e8 f7f1e9e8 ffffffc0 f7f1e9e8 ffffffc0 00000003 00000002 eb409000 ffffffc0 [ 216.496118] ea08 f3191300 ffffffc0 00000000 00000000 f7f1b5c8 ffffffc0 00000800 00000001 [ 216.496132] ea28 080cc948 ffffff80 f7f1e9c0 ffffffc0 00100003 ffffffff ffffffff 00000000 [ 216.496146] ea48 00000000 00000000 00000000 00000000 00000000 00000000 00000200 dead0000 [ 216.496162] X29: 0xffffffc0ec0c3c50: [ 216.496166] 3c50 ec568840 ffffffc0 00000000 00000000 00000000 00000000 f7f1e9e8 ffffffc0 [ 216.496180] 3c70 00000000 00000000 00000000 00000000 00000000 00000000 ec0c3cd0 ffffffc0 [ 216.496194] 3c90 086de1f0 ffffff80 ec0c3cd0 ffffffc0 086a165c ffffff80 20000145 00000000 [ 216.496208] 3cb0 ec0c3d00 ffffffc0 086de1e8 ffffff80 ffffffff ffffffff ebb9e000 ffffffc0 [ 216.496222] 3cd0 ec0c3d00 ffffffc0 086de1f0 ffffff80 ed209800 ffffffc0 ebb9e000 ffffffc0 [ 216.496236] 3cf0 df6b7e00 ffffffc0 db481c28 ffffffc0 ec0c3d40 ffffffc0 086de9b8 ffffff80 [ 216.496251] 3d10 db481d20 ffffffc0 db481d20 ffffffc0 f7f1e9c0 ffffffc0 00000000 00000000 [ 216.496265] 3d30 f7f23200 ffffffc0 09598fa8 ffffff80 ec0c3d60 ffffffc0 080ce748 ffffff80 [ 216.496283] ---[ end trace 98f3fddab2149696 ]--- [ 216.496289] Call trace: [ 216.496295] Exception stack(0xffffffc0ec0c3af0 to 0xffffffc0ec0c3c20) [ 216.496302] 3ae0: ffffffc0db50c028 0000008000000000 [ 216.496308] 3b00: ffffffc0ec0c3cd0 ffffff80086a165c 0000000020000145 0000000000000003 [ 216.496314] 3b20: ffffffc0ec0c3b40 ffffff800811b430 ffffffc0f7f1ab80 ffffff80093f8b80 [ 216.496320] 3b40: ffffffc0ec0c3c40 ffffff80081d4dc8 ffffffc0ec5fa600 ffffffc0db50dc70 [ 216.496326] 3b60: ffffff80086e8c5c 0000000000000008 000000000000083c 0000000000000002 [ 216.496332] 3b80: ffffffc0f7f1e9e8 0000000000000000 0000000000000000 0000000000000000 [ 216.496338] 3ba0: ffffffc0ed209600 ffffffc0df6b7680 ffffff80086e9000 0000000000000000 [ 216.496343] 3bc0: 0000000000000008 000000326814cc83 ffffffc0db50c1a0 0000000000000000 [ 216.496349] 3be0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 216.496355] 3c00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 216.496363] [<ffffff80086a165c>] drm_atomic_helper_commit_hw_done+0x60/0x98 [ 216.496371] [<ffffff80086de1f0>] rockchip_atomic_commit_complete+0xac/0xf0 [ 216.496377] [<ffffff80086de9b8>] rockchip_drm_atomic_work+0x20/0x30 [ 216.496387] [<ffffff80080ce748>] process_one_work+0x228/0x364 [ 216.496393] [<ffffff80080cf1a0>] worker_thread+0x284/0x390 [ 216.496399] [<ffffff80080d4040>] kthread+0xe0/0xf0 [ 216.496407] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20 Also both streams exhibited similiar behaviour in regard of the quality. There are noticeable white pixels on the displayed characters contours. I've seen this also with ayufan images. I wonder if it is my setup issues or other also experience it? 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 2, 2021 Author Share Posted February 2, 2021 2 hours ago, tar.elda said: playback with some udp multicast stream Can you give us some example stream that is showing this behavior? 0 Quote Link to comment Share on other sites More sharing options...
tar.elda Posted February 4, 2021 Share Posted February 4, 2021 On 2/2/2021 at 5:36 PM, JMCC said: Can you give us some example stream that is showing this behavior? I don't think I can share the clips from the stream, because these are not FTA broadcasts. Regarding quality I took these photos - https://1drv.ms/u/s!Aged3pqR0ymHpAa9XG3MOtbHBlFL?e=R5vqye . This is the exactly the same clip captured with ffmpeg without any conversions. First one is with playback from RockPro64, while second from my reference notebook. As you can see on first photo there are many white dots on the hair line in contratry to completely smooth other. Also I partially resolved the issue, because I found out that this kind of artifacts occurs while Mali is upscaling. Broadcast is 1920x1080 whilst my TV panel is native 4k@120Hz. Using drm-mode 1920x1080@50 or 1920x1080@60 fixed it immediately. Stream that crashed is 20Mbps CBR high quality broadcast, but unfortunately yesterday I wasn't able to reproduce the issue. I will be trying to do so in the meantime. Getting back to my first issue. It is getting weirder. I haven't been able to make X to start with lightdm. When I launched it manually from ssh session (lightdm stopped) everything worked okay. Any tips? 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 4, 2021 Author Share Posted February 4, 2021 2 hours ago, tar.elda said: Getting back to my first issue I think that is a different issue, probably not related to the media framework. Do you experience the same behavior on a fresh Armbian install, without the multimedia packages? 2 hours ago, tar.elda said: I don't think I can share the clips from the stream If you find some clip showing the wrong behavior that you can share, please do. Otherwise, we cannot look into the issue. All my clips are playing fine in different screens and resolutions. 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted February 5, 2021 Share Posted February 5, 2021 When testing the latest legacy kernel on P1, I found that when installing the media script, it replaces the kernel. Have you linked the script to a specific kernel ? 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 5, 2021 Author Share Posted February 5, 2021 3 minutes ago, balbes150 said: Have you linked the script to a specific kernel ? The meta-package depends on "linux-image-legacy-rockchip64 | linux-image-legacy-rk3399", but it doesn't specify any version. Source here What exactly is being replaced? 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted February 5, 2021 Share Posted February 5, 2021 4 минуты назад, JMCC сказал: The meta-package depends on "linux-image-legacy-rockchip64 | linux-image-legacy-rk3399", but it doesn't specify any version. For P1, a different kernel is used (station-p1) and even when I put the kernel on freeze, it is still replaced with the one in the network reps (but in the network reps it is not correct). This breaks the whole system. IMHO the script should not depend on the kernel, from trying to install only the version registered in it. 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 5, 2021 Author Share Posted February 5, 2021 1 hour ago, balbes150 said: IMHO the script should not depend on the kernel The dependency is there to prevent it from being installed on Current/Dev. That would result in a broken desktop, due to Mali binaries replacing the Mesa libs, but the Mali kernel driver missing. 1 hour ago, balbes150 said: For P1, a different kernel is used (station-p1) I can add that other kernel as an alternative to the package dependencies. However, the ideal situation would be to merge the changes into some of the existing RK3399 kernels. But we can discuss this on a more appropriate thread. For the time being, I will just add that dependency, that will respond to the immediate need. 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted February 5, 2021 Share Posted February 5, 2021 1 час назад, JMCC сказал: For the time being, I will just add that dependency, that will respond to the immediate need. You don't need to change anything. I found a solution-changed the patches so that can now use a common core for p1. 1 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 5, 2021 Author Share Posted February 5, 2021 5 minutes ago, balbes150 said: I found a solution-changed the patches so that can now use a common core for p1. That's great! 5 minutes ago, balbes150 said: You don't need to change anything. Well, modified packages are already on the process of upload and sync . Anyway, that will buy us some time until we get everything sorted out into rockchip64, and I can make some later update removing the "station-p1/station-m1" alternative. 0 Quote Link to comment Share on other sites More sharing options...
dpapavas Posted February 5, 2021 Share Posted February 5, 2021 On 2/4/2021 at 11:46 AM, tar.elda said: Getting back to my first issue. It is getting weirder. I haven't been able to make X to start with lightdm. When I launched it manually from ssh session (lightdm stopped) everything worked okay. Any tips? I've been having similar issues and in my case, it seems to be related to the specific mode, so that it might have to do, to some extent, with the HDMI cable used. For me, the default terminal mode is 3840x2160p60, probably because it is the best mode seen as supported by the display, but at this mode the HDMI link can't be established most of the time. My understanding is that disconnecting and reconnecting the cable forces the driver to retry and sometimes it manages to establish the link and it works. Setting the mode manually to 3840x2160p30 results in reliable HDMI operation. You might want to try setting a lower mode, by putting something like the following in "/boot/armbianEnv.txt": Quote extraargs=video=3840x2160@30 If this results in getting a signal during kernel boot-up, which is then lost once lightdm starts, you'll need to also set a lower mode for X. That said, I've also tried a libreelec image, which seemed to work every time (although I didn't boot it up more than a couple of times), so this may well also be related in part to the kernel, or the configuration used in Armbian. Apart from that, I'm also having a hard time getting Armbian and the RK3399 Legacy Multimedia Framework to work for 4K HDR video on a Rock Pi 4B. It seems to work fine for all other modes but a couple of 10-bit HDR HEVC videos I've tried either result in choppy reproduction where a few seconds of video are displayed, after which the image freezes while sound continues, or playback is smooth but with incorrect colors. In each case, the display switches to the correct resolution and refresh rate, but it does not switch to HDR mode. I add a grepped version of dmesg below, showing seemingly relevant messages, including several error messages which might, or might not be normal: [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 1.472998] iommu: Adding device ff650000.vpu_service to group 0 [ 1.473203] iommu: Adding device ff8f0000.vop to group 2 [ 1.473300] iommu: Adding device ff900000.vop to group 3 [ 2.464585] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree [ 2.464599] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed [ 2.464624] rk-vcodec ff650000.vpu_service: no regulator for vcodec [ 2.465017] rk-vcodec ff650000.vpu_service: probe device [ 2.465333] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled [ 2.466106] rk-vcodec ff650000.vpu_service: could not find power_model node [ 2.466117] rk-vcodec ff650000.vpu_service: init success [ 2.466503] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree [ 2.466517] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed [ 2.466536] rk-vcodec ff660000.rkvdec: no regulator for vcodec [ 2.467085] rk-vcodec ff660000.rkvdec: probe device [ 2.467321] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled [ 2.467740] rk-vcodec ff660000.rkvdec: could not find power_model node [ 2.467748] rk-vcodec ff660000.rkvdec: init success [ 2.479429] rockchip-vop ff900000.vop: missing rockchip,grf property [ 2.479705] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008d47290) [ 2.479749] rockchip-vop ff8f0000.vop: missing rockchip,grf property [ 2.479939] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008d47290) [ 2.480204] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 2.480219] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.480325] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.481023] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008d3bbc0) [ 3.315328] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 3840x2160p30, type: 11 [ 4.140435] vcca1v8_hdmi: 1800 mV [ 4.146203] vcca0v9_hdmi: 900 mV [ 4.829054] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-codec[0]' [ 4.829078] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-codec[0]' [ 4.830099] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 4.880580] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree [ 4.880592] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed [ 4.880729] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree [ 4.880740] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed [ 4.881811] #1: HDMI-CODEC [ 35.614277] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply from device tree [ 35.614291] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply property in node /power-management@ff310000/power-controller failed [ 35.614398] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 [ 95.708357] rk_vcodec: vpu_service_ioctl:1890: error: unknown vpu service ioctl cmd 40086c01 [ 95.848892] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 3840x2160p24, type: 11 [ 95.879288] dwhdmi-rockchip ff940000.hdmi: Rate 296703000 missing; compute N dynamically [ 105.693585] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 [ 178.595257] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 3840x2160p24, type: 11 [ 178.626142] dwhdmi-rockchip ff940000.hdmi: Rate 296703000 missing; compute N dynamically [ 178.955692] rk-vcodec ff660000.rkvdec: resetting... [ 178.955762] rk-vcodec ff660000.rkvdec: reset done [ 178.955768] rk-vcodec ff660000.rkvdec: reset done [ 180.476956] rk-vcodec ff660000.rkvdec: resetting... [ 180.477023] rk-vcodec ff660000.rkvdec: reset done [ 180.477029] rk-vcodec ff660000.rkvdec: reset done ... [ 273.326954] rk-vcodec ff660000.rkvdec: resetting... [ 273.327025] rk-vcodec ff660000.rkvdec: reset done [ 273.327031] rk-vcodec ff660000.rkvdec: reset done [ 274.327763] rk-vcodec ff660000.rkvdec: resetting... [ 274.327832] rk-vcodec ff660000.rkvdec: reset done [ 274.327838] rk-vcodec ff660000.rkvdec: reset done [ 275.902475] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 My terminal video mode is "3840x2160p30", while the interface in kodi-gbm is set to "1920x1080p60". The shown messages are taken after booting up and playing two separated HDR videos, the first playing smoothly in false color, while the second plays back intermittently in correct (albeit SDR) color. You can use the mode update messages as markers to figure out what happens when. Note that on the exact same hardware (including the HDMI cable) a libreelec image seems to work correctly, at least to the extent that it switches the display to HDR mode and shows a correct-looking picture. I've tried comparing the device trees used in libreelec and Armbian for clues as to what might be missing and, although there are some differences, I didn't manage to get anywhere. Any pointers on what to try or where to look next would be welcome. 0 Quote Link to comment Share on other sites More sharing options...
JMCC Posted February 5, 2021 Author Share Posted February 5, 2021 10 minutes ago, dpapavas said: where to look next Probably some Kernel patches being used in LibreELEC. I am not sure whether they updated to mainline yet, or are still using legacy, check that out too. 0 Quote Link to comment Share on other sites More sharing options...
