I’m helping my friend set up Helios64 with OpenMediaVault as a media server. We’d manage to set it up as per your documentation mentioned on your wiki page but are stuck on SD-Card to eMMC migration. As after migrating with no error so far we’re still unable to boot the system without the SD-Card in Helios64.
We still couldn’t figure out what could be the problem? Can you guys help?
I've been running into the same issue for about a week or two, haven't had the time to dig into it though.
armbian-config says the "Boot from eMMC - System on eMMC" step went fine but device won't boot after that. Haven't hooked a serial cable to it to see where it fails.
I'm unable to reproduce the issue. Just tried a fresh install of Armbian Buster 20.11.4 on microSD card then used armbian-config to install boot and system on eMMC (option 2)... and it works as expected.
What does the serial console output when you boot the system ? We need to see where your system stops.
When did you do the migration SD card to eMMC, before or after installing OMV ?
I seem to have a very similar issue, although I'm not using OMV.
Fresh Debian installation (Armbian_20.11.4_Helios64_buster_current_5.9.14.img.xz) on MicroSD card, followed by update/upgrade, then tried to move to eMMC using the armbian-config menus (option 2). After a shutdown, removed MicroSD, but system refuses to boot. Replacing MicroSD card allows it to boot successfully again.
Following sucessfully restarting with MicroSD in place, this is lsblk output:
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda           8:0    0  3.7T  0 disk
└─sda1        8:1    0  3.7T  0 part
sdb           8:16   0  3.7T  0 disk
└─sdb1        8:17   0  3.7T  0 part
sdc           8:32   0  3.7T  0 disk
└─sdc1        8:33   0  3.7T  0 part
sdd           8:48   0  3.7T  0 disk
└─sdd1        8:49   0  3.7T  0 part
sde           8:64   0  3.7T  0 disk
└─sde1        8:65   0  3.7T  0 part
mmcblk0     179:0    0 29.7G  0 disk
└─mmcblk0p1 179:1    0 29.4G  0 part /
zram0       251:0    0   50M  0 disk /var/log
zram1       251:1    0  1.9G  0 disk [SWAP]
and this is output from dmesg | grep mmc:
[    2.887657] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.887687] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.887702] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.887763] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    2.888262] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.901160] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.916678] mmc1: CQHCI version 5.10
[    2.941878] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.978696] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.008237] mmc1: mmc_select_hs200 failed, error -110
[    3.008251] mmc1: error -110 whilst initialising MMC card
[    3.118200] mmc1: mmc_select_hs200 failed, error -110
[    3.118214] mmc1: error -110 whilst initialising MMC card
[    3.126622] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 214
[    3.126649] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    3.127754] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[    3.130391]  mmcblk0: p1
[    3.255877] mmc1: mmc_select_hs200 failed, error -110
[    3.255890] mmc1: error -110 whilst initialising MMC card
[    3.431916] mmc1: mmc_select_hs200 failed, error -110
[    3.431927] mmc1: error -110 whilst initialising MMC card
[   17.372909] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   18.620355] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
On running armbian-config again to view eMMC transfer menu, only options 1 & 5 are available.
I'm not very familiar with Linux-based hardware diagnosis (yet!), but but might there may be an issue with the on-board eMMC?
@chango yes, it seems something wrong with the on-board eMMC. You shouldn't be able to move to eMMC if it wasn't detected.
Could you attach serial console output since power on?
Edited by aprayoga
@aprayoga Unfortunately I have no success with obtaining serial output. I've tried using both my MacBook Pro laptop and Manjaro desktop, and neither produces any serial output. The tty never shows up when connected to the Manjaro box, and only sometimes shows up on the MBP (/dev/tty.usbserial-DT03OFSJ), but then using screen to that device produces no output (I did initial setup via ssh instead). Is any of this useful diagnostic info stored anywhere else?
Curiously the eMMC has shown up on some subsequent boots, with the following output in dmesg | grep mmc:
[    2.890213] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.890242] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.890257] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.890320] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    2.890806] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.903703] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.919237] mmc1: CQHCI version 5.10
[    2.944409] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.981416] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.018199] mmc1: Command Queue Engine enabled
[    3.018220] mmc1: new HS200 MMC card at address 0001
[    3.018927] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    3.019196] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[    3.019471] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[    3.019722] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
[    3.021212]  mmcblk1: p1
[    3.198007] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 213
[    3.198034] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    3.199120] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[    3.201559]  mmcblk0: p1
[   17.507968] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   18.800952] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
On seeing this I tried again to go through the steps to transfer the system to eMMC, but was then surprised to see the HDDs thrashing. Seems the installer requires/expects all mounts to be in /mnt/, but I have a ZFS pool mounted by its default off /poolname instead. After moving the pool mountpoint I retried the install-to-eMMC process, which went fast & smoothly (apparently), but then on powering onwithout the SD card I got the familiar static System LED, and un-pingable IP (MAC address is pre-assigned to an IP by router). Replacing the SD card allows booting again.
So it seems there's some issue with the transfer/boot process with eMMC, and with serial connection. Sometimes eMMC shows up, sometimes not. Serial connection never works. While I understand this is a tinkerers' device in many respects, I would also expect the basic hardware to both function and be tested. Any possible advice on which way to proceed with this?
Edited by chango
typo
The port speed on the Rockchip UART is insane. its 1500000.
so just in case you haven't been specifying try like
screen /dev/ttyUARTPATH 1500000
I managed to get the serial console working via my Manjaro box (after trimming the USB-C cable sheathing as suggested in other threads; still no success using MacBook Pro though). The serial output is shown below, indicating such a possible eMMC issue ("Loading Environment from MMC... *** Warning - bad CRC, using default environment"):
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67806
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xdd6b0
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Dec 15 2020 - 08:45:45 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3185 bytes read in 18 ms (171.9 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
166 bytes read in 15 ms (10.7 KiB/s)
14273382 bytes read in 1378 ms (9.9 MiB/s)
27507200 bytes read in 2630 ms (10 MiB/s)
81968 bytes read in 38 ms (2.1 MiB/s)
2698 bytes read in 34 ms (77.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    14273318 Bytes = 13.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f514a000, end f5ee6b26 ... OK
   Loading Device Tree to 00000000f50cd000, end 00000000f5149fff ... OK
Starting kernel ...
I've repeated the process multiple times, removing the partition (with fdisk), wiping the bootloader and partition superblock (as mentioned in the wiki troubleshooting page), and re-copying using nand-sata-install, but with the same result each time. Rebooting with the SD card in place shows the same error, but continues to boot from the SD card instead.
I'm uncertain how to proceed from here. Having working on-board eMMC is a key addition to this board over the comparative unreliability of using Micro-SD. Given that the eMMC is soldered to the board, I'm guessing this requires a replacement board to resolve?
Am 6.1.2021 um 14:19 schrieb chango:
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Scanning mmc 0:1...
   Image Name:   uInitrd
Starting kernel ...
I received the Helios64 last week and wanted to set it up right now. Ran into the exact same issue. As I had no luck with connecting my MacBook Air via Serial Console, I did it headless with the SD Card. After copying the boot partition from SD to the eMMC, it booted once without an issue. After trying to install OMV via softy it just does not boot anymore. I will be back on the SD Card and unwilling to touch that procedure again if it is not flawless.
@bunducafe After following up with the Kobol support team via email on this, I tried direct installation to eMMC via USB-C cable, but that produced the same results. It ended up with me sending it back for a replacement, which their team handled fast and smoothly to their credit, and my replacement board works well as expected, and is now running 24/7 from eMMC.
I suggest persisting to trying to find a way to connect via the USB-C serial console, as this will give you sufficient info to see what may be happening and how to proceed. For me I had to cut back the USB-C cable sheathing about 1.5-2mm or so to get a snug fit in the socket, and I also had the benefit of having another computer with Linux on to help diagnose.
Hm, is there a possibilty that the old bootloader name is again the used in the newer kernels? I can get it working with the workaround in the troubleshooting section:
Zitat
sudo mkdir -p /mnt/system
sudo mount /dev/mmcblk1p1 /mnt/system
sudo ln -sf rk3399-kobol-helios64.dtb /mnt/system/boot/dtb/rockchip/rk3399-helios64.dtb
sudo umount /mnt/system
sudo poweroff
Then the machine boots without any issues.
Zitat
After boot successfully to eMMC, we strongly suggest to update the bootloader using armbian-config.
Here I am unsure what I have to do? Excersise the same procedure again - e.g. in armbian-config: Select Boot from eMMC - system on eMMC ?
Then I do fear that it won't boot as expected as I have done this several times now...
vor 2 Stunden schrieb chango:
Hm, I guess I have to go the same route as I am unable to boot again with emmc. Also in the boot settings I only have two points left I can chose. So will have to contact the support team directly I suppose.
After I could not boot at all tonight, I am somewhat puzzled what I should do. There is a possibility that the SDcard just went dead but neither could I boot from the eMMC. After several reboots with a freshly installed SD the helios is booting up again but of course all the setup is lost.
Bottom line: Is there a way to easily delete the emmc partition and tell the helios64 to boot from SD card immediately? And if so: How ;) I cannot get it done via the armbian-config unfortunately.
What do you mean?
Have you managed to get serial console working?
Have you checked our wiki?
Am 15.2.2021 um 08:20 schrieb aprayoga:
What do you mean?
Unfortunately I cannot get the console working with neither MacBook nor iMac. It's really frustrating.
Beyond that: I shortened the P10 jumper in order to boot from SD card, yet, it does not boot. No flashing light, just the steady blue one, no heartbeat.
So, what else am I supposed to try to get the Helios64 boot again from SD card? Funnily I did not change anything from the last time, I just switched the Helios off while I was away...
At least I could get it booted again. I did a clean install onto a fresh SD card with the latest Armbian-Image kernel 5.10. It did boot up but of course I am losing all my configs with OpenMediavault etc. That's the output of the dmesg, there seems something wrong with both mmc and sd. How can I solve that issue in order to get a system that works and where I can then do all the config with OMV and after that reboot / shutdown and boot again...?!
Zitat
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.12-rockchip64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 20:55:02 CET 2021
[    0.000000] Machine model: Helios64
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11776 pages used for memmap
[    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072
[    0.000000] pcpu-alloc: s94040 r8192 d28840 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=e4e3bcd6-3f03-4362-bbe0-f1654138c5d8 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=aaedb48e-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[    0.000000] Memory: 3741216K/4061184K available (14848K kernel code, 2632K rwdata, 5968K rodata, 4352K init, 580K bss, 188896K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Rude variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000400d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001521] Console: colour dummy device 80x25
[    0.001590] printk: console [tty1] enabled
[    0.001722] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001743] pid_max: default: 32768 minimum: 301
[    0.001913] LSM: Security Framework initializing
[    0.001957] Yama: becoming mindful.
[    0.002102] AppArmor: AppArmor initialized
[    0.002205] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002237] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005938] rcu: Hierarchical SRCU implementation.
[    0.007116] Platform MSI: interrupt-controller@fee20000 domain created
[    0.007761] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.010303] EFI services will not be available.
[    0.011016] smp: Bringing up secondary CPUs ...
[    0.012189] Detected VIPT I-cache on CPU1
[    0.012239] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012258] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000
[    0.012337] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013754] Detected VIPT I-cache on CPU2
[    0.013803] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013824] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000
[    0.013899] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015344] Detected VIPT I-cache on CPU3
[    0.015393] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015413] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000
[    0.015489] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016906] CPU features: detected: Spectre-v2
[    0.016913] CPU features: detected: Spectre-v4
[    0.016919] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.016927] Detected PIPT I-cache on CPU4
[    0.016962] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.016977] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000
[    0.017025] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018285] Detected PIPT I-cache on CPU5
[    0.018324] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018340] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000
[    0.018388] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.018581] smp: Brought up 1 node, 6 CPUs
[    0.018612] SMP: Total of 6 processors activated.
[    0.018623] CPU features: detected: 32-bit EL0 Support
[    0.018633] CPU features: detected: CRC32 instructions
[    0.018645] CPU features: detected: 32-bit EL1 Support
[    0.045384] CPU: All CPU(s) started at EL2
[    0.045454] alternatives: patching kernel code
[    0.049230] devtmpfs: initialized
[    0.068108] Registered cp15_barrier emulation handler
[    0.068133] Registered setend emulation handler
[    0.068367] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.068440] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.071488] pinctrl core: initialized pinctrl subsystem
[    0.072159] DMI not present or invalid.
[    0.072754] NET: Registered protocol family 16
[    0.076050] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.077530] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.078267] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.078349] audit: initializing netlink subsys (disabled)
[    0.078609] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[    0.079885] thermal_sys: Registered thermal governor 'fair_share'
[    0.079892] thermal_sys: Registered thermal governor 'bang_bang'
[    0.079900] thermal_sys: Registered thermal governor 'step_wise'
[    0.079906] thermal_sys: Registered thermal governor 'user_space'
[    0.080402] cpuidle: using governor menu
[    0.080729] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.080949] ASID allocator initialised with 65536 entries
[    0.082302] Serial: AMBA PL011 UART driver
[    0.144998] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.145012] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.145021] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.145030] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.151592] cryptd: max_cpu_qlen set to 1000
[    0.228327] raid6: neonx8   gen()  1665 MB/s
[    0.296494] raid6: neonx8   xor()  1234 MB/s
[    0.364660] raid6: neonx4   gen()  1690 MB/s
[    0.432829] raid6: neonx4   xor()  1278 MB/s
[    0.500993] raid6: neonx2   gen()  1511 MB/s
[    0.569167] raid6: neonx2   xor()  1175 MB/s
[    0.637345] raid6: neonx1   gen()  1179 MB/s
[    0.705514] raid6: neonx1   xor()   934 MB/s
[    0.773708] raid6: int64x8  gen()   995 MB/s
[    0.841893] raid6: int64x8  xor()   578 MB/s
[    0.910022] raid6: int64x4  gen()   988 MB/s
[    0.978179] raid6: int64x4  xor()   591 MB/s
[    1.046326] raid6: int64x2  gen()   927 MB/s
[    1.114481] raid6: int64x2  xor()   524 MB/s
[    1.182660] raid6: int64x1  gen()   724 MB/s
[    1.250792] raid6: int64x1  xor()   391 MB/s
[    1.250799] raid6: using algorithm neonx4 gen() 1690 MB/s
[    1.250805] raid6: .... xor() 1278 MB/s, rmw enabled
[    1.250813] raid6: using neon recovery algorithm
[    1.252294] vcc12v_dcin_bkup: supplied by vcc12v_dcin
[    1.252740] vcc12v_hdd: supplied by vcc12v_dcin_bkup
[    1.267163] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
[    1.267651] pcie_power: supplied by vcc5v0_perdev
[    1.267773] vcc5v0_usb: supplied by vcc5v0_perdev
[    1.267866] vcc5v0_typec: supplied by vcc5v0_usb
[    1.267928] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
[    1.268551] vcc5v0_sys: supplied by vcc12v_dcin_bkup
[    1.269112] vcc3v3_sys_s3: supplied by vcc5v0_sys
[    1.269171] vcc0v9_s3: supplied by vcc3v3_sys_s3
[    1.269258] avdd_1v8_s0: supplied by vcc3v3_sys_s3
[    1.269334] vcc3v0_sd: supplied by vcc3v3_sys_s3
[    1.270365] usblan_power: supplied by vcc5v0_usb
[    1.270966] iommu: Default domain type: Translated
[    1.274458] vgaarb: loaded
[    1.274973] SCSI subsystem initialized
[    1.275219] libata version 3.00 loaded.
[    1.275489] usbcore: registered new interface driver usbfs
[    1.275545] usbcore: registered new interface driver hub
[    1.275593] usbcore: registered new device driver usb
[    1.276348] pps_core: LinuxPPS API ver. 1 registered
[    1.276356] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.276373] PTP clock support registered
[    1.276705] EDAC MC: Ver: 3.0.0
[    1.277920] NetLabel: Initializing
[    1.277929] NetLabel:  domain hash size = 128
[    1.277935] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.278029] NetLabel:  unlabeled traffic allowed by default
[    1.278532] clocksource: Switched to clocksource arch_sys_counter
[    1.403077] VFS: Disk quotas dquot_6.6.0
[    1.403159] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.404054] AppArmor: AppArmor Filesystem Enabled
[    1.413342] NET: Registered protocol family 2
[    1.414344] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.414624] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.415164] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.415831] TCP: Hash tables configured (established 32768 bind 32768)
[    1.416031] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.416197] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.416534] NET: Registered protocol family 1
[    1.416578] NET: Registered protocol family 44
[    1.416594] PCI: CLS 0 bytes, default 64
[    1.416836] Trying to unpack rootfs image as initramfs...
[    2.414167] Freeing initrd memory: 13532K
[    2.415537] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.415994] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    2.416774] kvm [1]: IPA Size Limit: 40 bits
[    2.417919] kvm [1]: vgic-v2@fff20000
[    2.417957] kvm [1]: GIC system register CPU interface enabled
[    2.418213] kvm [1]: vgic interrupt IRQ18
[    2.418546] kvm [1]: Hyp mode initialized successfully
[    2.429838] Initialise system trusted keyrings
[    2.429892] Key type blacklist registered
[    2.430121] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    2.436558] zbud: loaded
[    2.438312] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.439174] fuse: init (API version 7.32)
[    2.440542] integrity: Platform Keyring initialized
[    2.507161] xor: measuring software checksum speed
[    2.511079]    8regs           :  2531 MB/sec
[    2.514458]    32regs          :  2917 MB/sec
[    2.518596]    arm64_neon      :  2399 MB/sec
[    2.518603] xor: using function: 32regs (2917 MB/sec)
[    2.518619] Key type asymmetric registered
[    2.518626] Asymmetric key parser 'x509' registered
[    2.518679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.518901] io scheduler mq-deadline registered
[    2.518910] io scheduler kyber registered
[    2.519041] io scheduler bfq registered
[    2.538472] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.538502] OF: /pcie@f8000000: Missing device_type
[    2.538568] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.538599] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.548685] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.548699] dma-pl330 ff6d0000.dma-controller:     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.550215] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.550227] dma-pl330 ff6e0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.555994] vdd_log: supplied by regulator-dummy
[    2.557436] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.560708] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 44, base_baud = 1500000) is a 16550A
[    2.561740] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 45, base_baud = 1500000) is a 16550A
[    2.562024] printk: console [ttyS2] enabled
[    2.563533] Serial: AMBA driver
[    2.565129] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.577285] loop: module loaded
[    2.585985] libphy: Fixed MDIO Bus: probed
[    2.586749] tun: Universal TUN/TAP device driver, 1.6
[    2.587905] thunder_xcv, ver 1.0
[    2.587951] thunder_bgx, ver 1.0
[    2.588001] nicpf, ver 1.0
[    2.589212] e1000e: Intel(R) PRO/1000 Network Driver
[    2.589218] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.589273] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.589280] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.589318] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    2.589324] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.589641] sky2: driver version 1.30
[    2.590397] VFIO - User Level meta-driver version: 0.3
[    2.609900] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.609925] ehci-pci: EHCI PCI platform driver
[    2.609976] ehci-platform: EHCI generic platform driver
[    2.612377] ehci-platform fe380000.usb: EHCI Host Controller
[    2.612405] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    2.612903] ehci-platform fe380000.usb: irq 38, io mem 0xfe380000
[    2.626548] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.626808] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.626819] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.626828] usb usb1: Product: EHCI Host Controller
[    2.626836] usb usb1: Manufacturer: Linux 5.10.12-rockchip64 ehci_hcd
[    2.626844] usb usb1: SerialNumber: fe380000.usb
[    2.627529] hub 1-0:1.0: USB hub found
[    2.627571] hub 1-0:1.0: 1 port detected
[    2.628367] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.628389] ohci-pci: OHCI PCI platform driver
[    2.628444] ohci-platform: OHCI generic platform driver
[    2.628764] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.628796] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
[    2.628930] ohci-platform fe3a0000.usb: irq 39, io mem 0xfe3a0000
[    2.690753] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[    2.690765] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.690773] usb usb2: Product: Generic Platform OHCI controller
[    2.690781] usb usb2: Manufacturer: Linux 5.10.12-rockchip64 ohci_hcd
[    2.690789] usb usb2: SerialNumber: fe3a0000.usb
[    2.691335] hub 2-0:1.0: USB hub found
[    2.691377] hub 2-0:1.0: 1 port detected
[    2.693011] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.693036] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    2.693215] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[    2.693283] xhci-hcd xhci-hcd.0.auto: irq 76, io mem 0xfe900000
[    2.693716] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.693727] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.693735] usb usb3: Product: xHCI Host Controller
[    2.693743] usb usb3: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    2.693751] usb usb3: SerialNumber: xhci-hcd.0.auto
[    2.694289] hub 3-0:1.0: USB hub found
[    2.694330] hub 3-0:1.0: 1 port detected
[    2.694712] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.694729] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    2.694746] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.694826] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.694979] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.694989] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.694998] usb usb4: Product: xHCI Host Controller
[    2.695006] usb usb4: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    2.695014] usb usb4: SerialNumber: xhci-hcd.0.auto
[    2.695539] hub 4-0:1.0: USB hub found
[    2.695579] hub 4-0:1.0: 1 port detected
[    2.696086] usbcore: registered new interface driver usb-storage
[    2.698950] mousedev: PS/2 mouse device common for all mice
[    2.700425] i2c /dev entries driver
[    2.704490] pca953x 2-0020: using no AI
[    2.714280] rk808 0-001b: chip id: 0x0
[    2.718706] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.718738] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.719872] vdd_center: supplied by vcc5v0_sys
[    2.720511] vdd_cpu_l: supplied by vcc5v0_sys
[    2.720856] vcc_ddr_s3: supplied by vcc5v0_sys
[    2.721537] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    2.722182] vcc1v8_dvp: supplied by vcc5v0_sys
[    2.722739] vcc3v0_touch: supplied by vcc5v0_sys
[    2.724080] vcc1v8_s3: supplied by vcc5v0_sys
[    2.724369] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    2.725538] vcc_sdio_s0: supplied by vcc5v0_sys
[    2.726074] vcca3v0_codec: supplied by vcc5v0_sys
[    2.727303] vcc1v5_s3: supplied by vcc5v0_sys
[    2.727824] vcca1v8_codec: supplied by vcc5v0_sys
[    2.729027] vcc3v0_s3: supplied by vcc5v0_sys
[    2.729182] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    2.729204] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    2.729752] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    2.733859] rk808-rtc rk808-rtc: registered as rtc0
[    2.734430] rk808-rtc rk808-rtc: setting system clock to 2021-02-18T20:29:54 UTC (1613680194)
[    2.737589] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.739005] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    2.739100] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    2.739206] vdd_cpu_b: supplied by vcc5v0_sys
[    2.742205] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.742707] random: fast init done
[    2.743807] vdd_gpu: supplied by vcc5v0_sys
[    2.751509] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    2.753360] sdhci: Secure Digital Host Controller Interface driver
[    2.753366] sdhci: Copyright(c) Pierre Ossman
[    2.753394] Synopsys Designware Multimedia Card Interface Driver
[    2.754809] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.755799] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.755843] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.755862] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.755966] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    2.756695] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.757859] mmc2: CQHCI version 5.10
[    2.759691] ledtrig-cpu: registered to indicate activity on CPUs
[    2.760892] hid: raw HID events driver (C) Jiri Kosina
[    2.761034] usbcore: registered new interface driver usbhid
[    2.761041] usbhid: USB HID core driver
[    2.766951] drop_monitor: Initializing network drop monitor service
[    2.767756] NET: Registered protocol family 10
[    2.769899] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.783175] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.825441] Segment Routing with IPv6
[    2.825546] NET: Registered protocol family 17
[    2.825722] 8021q: 802.1Q VLAN Support v1.8
[    2.825788] Key type dns_resolver registered
[    2.826373] registered taskstats version 1
[    2.826388] Loading compiled-in X.509 certificates
[    2.829956] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
[    2.836587] zswap: loaded using pool zstd/z3fold
[    2.836964] Key type ._fscrypt registered
[    2.836973] Key type .fscrypt registered
[    2.836979] Key type fscrypt-provisioning registered
[    2.840208] Btrfs loaded, crc32c=crc32c-generic
[    2.852911] mmc2: Command Queue Engine enabled
[    2.852934] mmc2: new HS200 MMC card at address 0001
[    2.853669] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    2.853942] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[    2.854166] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[    2.854348] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
[    2.863462] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    2.864750] dwmmc_rockchip fe320000.mmc: All phases bad!
[    2.864763] mmc1: tuning execution failed: -5
[    2.864783] mmc1: error -5 whilst initialising SD card
[    2.869425] Key type encrypted registered
[    2.869451] AppArmor: AppArmor sha1 policy hashing enabled
[    2.890650] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.920278] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.920330] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.920351] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.975807] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.975822] pci_bus 0000:00: root bus resource [bus 00-1f]
[    2.975833] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    2.975845] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    2.975900] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    2.976053] pci 0000:00:00.0: supports D1
[    2.976062] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.981955] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.982206] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    2.982276] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    2.982286] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    2.982322] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    2.982331] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    2.982367] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    2.982374] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    2.982410] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    2.982418] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    2.982453] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    2.982460] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    2.982497] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    2.982551] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    2.982591] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    2.982954] pci 0000:01:00.0: PME# supported from D3hot
[    2.983202] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    2.988846] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    2.988877] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    2.988894] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    2.988905] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    2.988925] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    2.988934] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    2.988942] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    2.988951] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    2.988959] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    2.988967] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    2.988975] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    2.988983] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    2.988991] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    2.988999] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    2.989010] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.989024] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    2.989261] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    2.989602] pcieport 0000:00:00.0: PME: Signaling with IRQ 90
[    2.989978] pcieport 0000:00:00.0: AER: enabled with IRQ 90
[    2.990323] ahci 0000:01:00.0: version 3.0
[    2.990349] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    2.990957] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    2.991058] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    2.991072] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    2.991565] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    2.994706] scsi host0: ahci
[    2.995523] scsi host1: ahci
[    2.996104] scsi host2: ahci
[    2.996726] scsi host3: ahci
[    2.997340] scsi host4: ahci
[    2.997569] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91
[    2.997580] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92
[    2.997591] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93
[    2.997600] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 94
[    2.997610] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 95
[    3.005625] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.006793] of_cfs_init
[    3.006830] of_cfs_init: OK
[    3.026567] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.149513] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 213
[    3.149550] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    3.151031] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[    3.154964]  mmcblk1: p1
[    3.176573] usb 3-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[    3.176584] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.176593] usb 3-1: Product: USB2.0 Hub
[    3.176602] usb 3-1: Manufacturer: VIA Labs, Inc.
[    3.239079] hub 3-1:1.0: USB hub found
[    3.239206] hub 3-1:1.0: 4 ports detected
[    3.302864] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.313074] ata1: SATA link down (SStatus 0 SControl 300)
[    3.451939] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.451952] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.451961] usb 4-1: Product: USB3.0 Hub
[    3.451969] usb 4-1: Manufacturer: VIA Labs, Inc.
[    3.479086] hub 4-1:1.0: USB hub found
[    3.479261] hub 4-1:1.0: 4 ports detected
[    3.786566] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.909063] ata2.00: ATA-8: TOSHIBA HDWQ140, FJ1M, max UDMA/100
[    3.909078] ata2.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.911325] ata2.00: configured for UDMA/100
[    3.911994] scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA HDWQ140  FJ1M PQ: 0 ANSI: 5
[    3.913463] sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    3.913546] sd 1:0:0:0: [sda] Write Protect is off
[    3.913562] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.913700] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.122632] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.128810] sd 1:0:0:0: [sda] Attached SCSI disk
[    4.143639] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    4.143650] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.143659] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
[    4.143667] usb 4-1.4: Manufacturer: Realtek
[    4.143675] usb 4-1.4: SerialNumber: 000000001
[    4.386569] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.387241] ata3.00: ATA-10: WDC WD40EFRX-68N32N0, 82.00A82, max UDMA/133
[    4.387252] ata3.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.387955] ata3.00: configured for UDMA/133
[    4.388600] scsi 2:0:0:0: Direct-Access     ATA      WDC WD40EFRX-68N 0A82 PQ: 0 ANSI: 5
[    4.389918] sd 2:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    4.389935] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[    4.390007] sd 2:0:0:0: [sdb] Write Protect is off
[    4.390024] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    4.390144] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.406908] sd 2:0:0:0: [sdb] Attached SCSI disk
[    4.866632] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.867318] ata4.00: ATA-10: WDC WD40EFRX-68N32N0, 82.00A82, max UDMA/133
[    4.867332] ata4.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.868043] ata4.00: configured for UDMA/133
[    4.868493] scsi 3:0:0:0: Direct-Access     ATA      WDC WD40EFRX-68N 0A82 PQ: 0 ANSI: 5
[    4.869675] sd 3:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    4.869691] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[    4.869764] sd 3:0:0:0: [sdc] Write Protect is off
[    4.869780] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    4.869899] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.876493] sd 3:0:0:0: [sdc] Attached SCSI disk
[    5.342566] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.344807] ata5.00: ATA-9: SanDisk SSD PLUS 1000GB, UH5100RL, max UDMA/133
[    5.344818] ata5.00: 1953529856 sectors, multi 1: LBA48 NCQ (depth 32)
[    5.351152] ata5.00: configured for UDMA/133
[    5.351717] scsi 4:0:0:0: Direct-Access     ATA      SanDisk SSD PLUS 00RL PQ: 0 ANSI: 5
[    5.353119] sd 4:0:0:0: [sdd] 1953529856 512-byte logical blocks: (1.00 TB/932 GiB)
[    5.353194] sd 4:0:0:0: [sdd] Write Protect is off
[    5.353210] sd 4:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    5.353329] sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.358940] sd 4:0:0:0: [sdd] Attached SCSI disk
[    5.364773] Freeing unused kernel memory: 4352K
[    5.374697] Run /init as init process
[    5.374707]   with arguments:
[    5.374714]     /init
[    5.374721]   with environment:
[    5.374728]     HOME=/
[    5.374735]     TERM=linux
[    5.374741]     ubootpart=aaedb48e-01
[    5.374747]     cgroup_enable=memory
[    5.374754]     cgroup_memory=1
[    5.995020] input: adc-keys as /devices/platform/adc-keys/input/input1
[    6.070078] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    6.070103] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    6.070332] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    6.070780] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    6.070803] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    6.070817] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    6.070840] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    6.070966] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    6.070978] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    6.076019] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    6.079766] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    6.079796] rk_gmac-dwmac fe300000.ethernet:     DWMAC1000
[    6.079808] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[    6.079819] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[    6.079830] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    6.079840] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    6.079849] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    6.080042] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    6.080055] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    6.080065] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    6.202486] libphy: stmmac: probed
[    6.202511] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    6.202558] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    6.489660] async_tx: api initialized (async)
[    6.901656] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.472040] systemd[1]: Inserted module 'autofs4'
[    7.522709] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.523696] systemd[1]: Detected architecture arm64.
[    7.559627] systemd[1]: Set hostname to <helios64>.
[    7.685169] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[    7.945883] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
[    8.018446] random: systemd: uninitialized urandom read (16 bytes read)
[    8.026729] random: systemd: uninitialized urandom read (16 bytes read)
[    8.027217] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.027716] random: systemd: uninitialized urandom read (16 bytes read)
[    8.031916] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.032327] systemd[1]: Reached target Swap.
[    8.032607] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.032697] systemd[1]: Reached target Paths.
[    8.033583] systemd[1]: Listening on udev Control Socket.
[    8.138359] lm75 2-004c: supply vs not found, using dummy regulator
[    8.139185] lm75 2-004c: hwmon2: sensor 'lm75'
[    8.168581] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.785988] zram: Added device: zram0
[    8.787351] zram: Added device: zram1
[    8.788460] zram: Added device: zram2
[    8.901647] zram0: detected capacity change from 0 to 1991770112
[    8.953661] input: beeper as /devices/platform/beeper/input/input2
[    9.082124] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[    9.085465] rockchip-vop ff900000.vop: Adding to iommu group 3
[    9.147867] sd 1:0:0:0: Attached scsi generic sg0 type 0
[    9.148102] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    9.148262] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    9.148389] sd 4:0:0:0: Attached scsi generic sg3 type 0
[    9.153590] random: crng init done
[    9.153608] random: 7 urandom warning(s) missed due to ratelimiting
[    9.170375] mc: Linux media interface: v0.10
[    9.179153] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[    9.198762] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[    9.201398] [drm] unsupported AFBC format[3231564e]
[    9.203236] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[    9.203594] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[    9.205545] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    9.206180] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    9.207179] videodev: Linux video capture interface: v2.00
[    9.216788] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[    9.217532] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[    9.220233] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    9.220265] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
[    9.220421] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[    9.220444] xhci-hcd xhci-hcd.3.auto: irq 75, io mem 0xfe800000
[    9.220887] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    9.220895] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.220901] usb usb5: Product: xHCI Host Controller
[    9.220906] usb usb5: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    9.220911] usb usb5: SerialNumber: xhci-hcd.3.auto
[    9.221590] hub 5-0:1.0: USB hub found
[    9.221633] hub 5-0:1.0: 1 port detected
[    9.221969] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    9.221987] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
[    9.222002] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    9.222061] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.222169] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    9.222175] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.222180] usb usb6: Product: xHCI Host Controller
[    9.222185] usb usb6: Manufacturer: Linux 5.10.12-rockchip64 xhci-hcd
[    9.222190] usb usb6: SerialNumber: xhci-hcd.3.auto
[    9.222623] Adding 1945084k swap on /dev/zram0.  Priority:5 extents:1 across:1945084k SSFS
[    9.222899] hub 6-0:1.0: USB hub found
[    9.222931] hub 6-0:1.0: 1 port detected
[    9.265854] panfrost ff9a0000.gpu: clock rate = 500000000
[    9.269484] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[    9.269498] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[    9.269505] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[    9.269510] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[    9.271337] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    9.275083] rkvdec ff660000.video-codec: Adding to iommu group 1
[    9.276079] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[    9.278453] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[    9.283006] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    9.283308] rockchip-rga ff680000.rga: HW Version: 0x03.02
[    9.284431] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[    9.284678] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[    9.296807] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video2
[    9.419021] zram1: detected capacity change from 0 to 52428800
[    9.475232] zram2: detected capacity change from 0 to 1991770112
[    9.585748] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard
[    9.707567] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[    9.707605] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[    9.735313] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    9.875237] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[    9.890757] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
[    9.890779] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
                       US6,570,884, US6,115,776, and US6,327,625.
[    9.891017] usbcore: registered new interface driver r8152
[   10.210810] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   11.976613] systemd-journald[733]: Received request to flush runtime journal from PID 1
[   12.722842] EXT4-fs (mmcblk1p1): resizing filesystem from 445440 to 7709728 blocks
[   22.760053] EXT4-fs (mmcblk1p1): resized to 3670016 blocks
[   33.762575] vcc5v0_typec: disabling
[   33.917350] EXT4-fs (mmcblk1p1): resized to 7340032 blocks
[   35.130202] EXT4-fs (mmcblk1p1): resized filesystem to 7709728
[   37.116868] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   37.119828] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   37.119851] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   37.120333] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   41.219394] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   41.219456] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
root@helios64:~#
Hi folks,
just a heads up in this thread (maybe related to others experiencing boot issues with Helios64 and OMV5):
If you use the setup: OMV5, Multiple Hdds, LUKS encryption + UnionFS
then it is very likely that the machine does not come up instead is booting into revocery mode. That's because it cannot find any mountpoints because of LUKS. In order to get the helios booting again you have to add a "nofail" into the mergerfs option.
Unfortunately the merferfs pool does not getting mounted automatically once you decrypted the hdds within LUKS Plugin. That's a bit of a nuisance but it is bearable if you do not boot your machine every day. In my case I had to remove the nofail, the mergerfs did mount immediately and then I did put the nofail in again. There might be a more elegant possibility but at least it is a remedy to get the helios working again.
Jump over to the OMV-forums and do a search for LUKS + UnionFS + nofail and you find several threads about that issue.
I have no idea if it is better to swith to the merferfsfolder plugin because I have no knowledge so far if I just can change the plugins without any errors.
Thanks for this, I'll try on my end too. I think many people follow the "perfect media server" guides which pretty much have this setup
