Dezo Posted January 6, 2021 Posted January 6, 2021 (edited) Hi, is there a way, how to check that image in download section is ok? I have Odroid HC4 with good PSU, both old and new card, flashed by Etcher and Rufus, keyboard plugged in USB, no SATA disks at the moment. I'm able to boot Focal 4.9 kernel (however with some errors after the boot). I've removed Petitboot with flasherase first, I've checked SHA checksum. Edit: File I've downloaded is: Armbian_20.11.6_Odroidhc4_focal_current_5.9.14.img.xz SHA: 9930f984eca2a72b3c22953ee6381c95da528b2a355dd9f429da38d1409f7b1f *Armbian_2 Any ideas what is wrong? Thank you. Edited January 6, 2021 by Dezo
Werner Posted January 6, 2021 Posted January 6, 2021 2 minutes ago, Dezo said: is there a way, how to check that image in download section is ok? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-integrity
Solution Igor Posted January 6, 2021 Solution Posted January 6, 2021 13 minutes ago, Dezo said: is there a way, how to check that image in download section is ok? First you need to tell us filename of that image so we can verify. Also there is an archive in the bottom of the download pages - checking previous build is also one of the options. This was added on last minute: https://github.com/armbian/build/commit/ab9faf847affd34cd8c0a1e867e93c2edbb5f8e8 1
Igor Posted January 6, 2021 Posted January 6, 2021 2 hours ago, Igor said: so we can verify. Now the problem is that my only C4 is racked for CI tests and can't do much ... previous images are known to work. Try them - and it would be good to know if upgrade also gets your here. It looks like this is the problem: diff --git a/config/bootscripts/boot-meson64.cmd b/config/bootscripts/boot-meson64.cmd index c191762a6..46b8b4ce7 100644 --- a/config/bootscripts/boot-meson64.cmd +++ b/config/bootscripts/boot-meson64.cmd @@ -2,9 +2,10 @@ # # Please edit /boot/armbianEnv.txt to set supported parameters # -setenv load_addr "0x34000000" -setenv initrd_high "0xffffffff" -setenv fdt_high "0xffffffff" + +setenv load_addr "0x32000000" +setenv kernel_addr_r "0x34000000" +setenv fdt_addr_r "0x4080000" setenv overlay_error "false" # default values setenv rootdev "/dev/mmcblk1p1"
Igor Posted January 6, 2021 Posted January 6, 2021 Fix is coming up, images are rebuilding ... version - once uploaded - 20.11.7 will be fine. Tested. https://github.com/armbian/build/commit/e2104390d9998462ba30202cd55134f349ce8d7a Fixed.
NicoD Posted January 9, 2021 Posted January 9, 2021 I also got my Odroid HC4. Doing my first tests. USB seems very buggy with the Ubuntu Mate 20.04 from Odroid. This seems better with Armbian focal legacy desktop. Tho there no sata is found, while that does work with the Odroid HC4 Mate image. I'll try a lot more images to see if/what difference there is. Haven't checked any mainline yet. It does seem to have performance issue's when overclocked(2Ghz/2.1Ghz). It sometimes performs worse than with default clocks. Weird. I'm a bit surprised about how good it is for gaming. I like it a lot, but it did cost me a lot. Tho also bit my own fault. I first bought it from AmeriDroid. It was stuck in transit for a +month. So I got my money back and bought another at a Belgian seller. A lot more expensive. A day after I got my HC4 from the Belgian seller the one from AmeriDroid arrived. If only I had waited a few more days I'd have saved about 40euro. Buying from Hardkernel would have been even more cheap I'd guess. I may send it back to AmeriDroid without fees. Luckily. I really wanted a HC4, but 2 is too much 1
Igor Posted January 9, 2021 Posted January 9, 2021 3 hours ago, NicoD said: This seems better with Armbian focal legacy desktop. Tho there no sata is found Its disabled. This is the first hw with sata. https://github.com/armbian/build/blob/master/config/kernel/linux-meson64-legacy.config#L2282
Werner Posted January 10, 2021 Posted January 10, 2021 12 hours ago, NicoD said: I may send it back to AmeriDroid without fees Or donate it to the lab
NicoD Posted January 10, 2021 Posted January 10, 2021 4 hours ago, Werner said: Or donate it to the lab If it was a cheaper board I'd do that. This is one of the most expensive I've bought. PSU is also a 15V 60W brick. Adds to the cost. I rather save my money to buy an Odroid Go Super next month. I never wanted a handheld so much, except when the Gameboy came out maybe. HC4 also suddenly became a gaming rig with 500GB of retro games on HDD. Too many games, I can't find the ones I want since thousands to browse thru. 1
Igor Posted January 10, 2021 Posted January 10, 2021 Can you try legacy image by switching to nightly and update - if SATA works now?
NicoD Posted January 10, 2021 Posted January 10, 2021 44 minutes ago, Igor said: Can you try legacy image by switching to nightly and update - if SATA works now? Ok. I'll check in a few hours. Cyclocross now.
NicoD Posted January 10, 2021 Posted January 10, 2021 2 hours ago, Igor said: Can you try legacy image by switching to nightly and update - if SATA works now? No luck. Focal legacy in nightly and updated/rebooted. No sata devices. Let me know if you need something more tested. It's good to know that USB works perfectly in Armbian. So I know it's a Hardkernels Ubuntu mate problem.
Igor Posted January 10, 2021 Posted January 10, 2021 3 hours ago, NicoD said: Focal legacy in nightly and updated/rebooted. Did you switch to nightly builds via armbian-config and update? Nightly images are not updated yet. Still uploading.
NicoD Posted January 10, 2021 Posted January 10, 2021 5 minutes ago, Igor said: Did you switch to nightly builds via armbian-config and update? Yes I did. armbian-firmware and armbian-config were updated if I remember correct. But after reboot no sata device was detected. Not ssd nor hdd.
Igor Posted January 10, 2021 Posted January 10, 2021 Just now, NicoD said: Yes I did. armbian-firmware and armbian-config were updated if I remember correct. If kernel was not updated, then it can't work ... if you can, build from sources.
NicoD Posted January 10, 2021 Posted January 10, 2021 1 minute ago, Igor said: if you can, build from sources. ok. Does it matter what image it is? Since I already got a working focal legacy image I can as well build a bionic or buster. I'll boot my pc for it. Haven't gotten to installing balbes image to my N2+ to build on that.
Igor Posted January 10, 2021 Posted January 10, 2021 1 minute ago, NicoD said: ok. Does it matter what image it is? This is the change - you need to rebuild kernel from master branch which doesn't support native building yet.
NicoD Posted January 10, 2021 Posted January 10, 2021 8 minutes ago, Igor said: This is the change - you need to rebuild kernel from master branch which doesn't support native building yet. ok, good you say it. I was just downloading the desktop branche.
NicoD Posted January 11, 2021 Posted January 11, 2021 @IgorI've just been able to build armbian focal legacy for the HC4. Still no sata devices. I had Murphy on my side for very long. Used my pc cause I thought it would be faster. Was months ago that I used it to build an image. So my build environment was still Bionic. Installed focal in virtualbox. Build the image. When finished I was unable to mount my USB sdreader. And suddenly Windows10 crashed. Rebooted, started the virtual focal again... and again windows crashed... I thought, now I'm sick of this. Let's take the trusty RockPiX. I let it run in the night. I got up..., no space left on eMMC to finish the build. I then took an external ssd. Started the build. Suddenly also no space left from +200GB. It had double mounted the drive. Both mounts showed the same files. One without space, the other with space. So I rebooted... And I couldn't log into my RockPiX anymore. Cycled back to login screen after login. So I put the ssd in my pc and installed focal directly onto it... And my bios didn't want any of it. I can only manually choose to boot my installed focal ssd. I did finally manage to build the image and write it to sd. It only took me about 19 hours to have a working build. Kernel 4.9.250-meson64. Fully updated. Latest available kernel. Also switched to nightly. Then armbian-config, armbian-firmware and armbian-zsh are updated. Nothing more. Now building Focal mainline. I have not yet tried any mainline image on the HC4.
NicoD Posted January 11, 2021 Posted January 11, 2021 Good news. SATA works on mainline focal 5.10.6. Also my 5Ghz wifi dongle works out of the box. I've got everything I could want. After that ordeal I'm so happy to have things working as should 1
