axeleroy Posted February 4, 2021 Posted February 4, 2021 (edited) Hi, I'm very pleased with my Helios 64, but since I updated to Armbian 20.11.6 (from 20.08.11 or 21, not really sure) it reboots at random times: it can run fine for over two weeks and reboot twice in 36 hours, always when idling. It's running OMV as well a multiple Docker containers: PiHole, Wireguard, Nginx, Transmission, restic-server and n8n. Is it a common issue? What fixes do you recommend? What should I look for to diagnose the issue? Thank you. Edit: forgot to mention that I'm using SnapRAID and mergerFS, as well as NFS shares. Edited February 4, 2021 by axeleroy
Werner Posted February 4, 2021 Posted February 4, 2021 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
axeleroy Posted February 4, 2021 Author Posted February 4, 2021 Oh, I didn't know about this utility. Here are the logs: http://ix.io/2Ok2
axeleroy Posted February 6, 2021 Author Posted February 6, 2021 It happened again. Should I try updating to the Armbian version that jiust came out? When should I run armbianmonitor (whenever I can or just after a reboot?) and what should I be looking for (because nothing seems odd to me, but I'm not that of an advanced user) Thanks !
gprovost Posted February 8, 2021 Posted February 8, 2021 @axeleroy Hi, could try to the following tweak and then report to us if it helps stabilizing your system. Run armbian-config, go to -> System -> CPU And set: Minimum CPU speed = 1200000 Maximum CPU speed = 1200000 CPU governor = performance
axeleroy Posted February 10, 2021 Author Posted February 10, 2021 Updating to the latest Armbian seems to have improved stability, though it has only been 72 hours since the update, I might be talking too quickly. @gprovost Do I need rebooting after applying this configuration? Out of curiosity: how does it improve stability?
Eric Poscher-Mika Posted February 11, 2021 Posted February 11, 2021 Am 8.2.2021 um 04:25 schrieb gprovost: @axeleroy Hi, could try to the following tweak and then report to us if it helps stabilizing your system. Run armbian-config, go to -> System -> CPU And set: Minimum CPU speed = 1200000 Maximum CPU speed = 1200000 CPU governor = performance Does it make a difference which minimum Speed is used? I would prefer to set the lowest CPU Speed as minimum to save energy use when there is low CPU usage.
gprovost Posted February 15, 2021 Posted February 15, 2021 @Eric Poscher-Mika Doesn't matter which speed you choose, the purpose of this temporary workaround is to disable variable frequency and use a fixed one. So you can choose the lowest if it fulfills your needs in term of compute power.
axeleroy Posted February 28, 2021 Author Posted February 28, 2021 Hi, quick update: no reboots in the two weeks following the frequency tweak. Reboot still happened shortly after my February 11 post (but before I applied gprovost's advice).
bunducafe Posted June 7, 2021 Posted June 7, 2021 Am 8.2.2021 um 04:25 schrieb gprovost: @axeleroy Hi, could try to the following tweak and then report to us if it helps stabilizing your system. Run armbian-config, go to -> System -> CPU And set: Minimum CPU speed = 1200000 Maximum CPU speed = 1200000 CPU governor = performance I had a similar issue with random reboots. Did DM @axelroy directly and also "tweaked" the system. I am running the helios now for almost 2 weeks without issues with the following settings: Min CPU speed = 400 MHz Max CPU speed = 1400 MHz CPU governor = on demand So it seems that the helios was rebooting when having to deal with intensive tasks - in my case: performing a SnapRAID scrub. Anyhow: Now I am at maximum speed of 1400MHz whereas the helios could perform even on 1800MHz. The question is if this is a problem by design? Or is there a way to fix it in order to let the machine run full CPU speed and performance governor? I am happy with the machine, no doubt, at the end this is rather a question of how I can achieve the maximum speed if needed. 1
