I thought I'd rebuild the NAS with the latest image in the hope that it would be more stable. Unfortunately my hopes were in vain. I was in the middle of doing an rsync and it crashed with a kernel panic. Had a look on the forum and implemented the two suggestions of limiting the cpu to 1200MHz and tweaking the voltages. CPU @ 50c as reported in the login header. Anyway after updating the setting I reboot it and it crashed immediately ! The same SMP issue that seems to have been plaguing this board since release :(
[  231.154881] reboot: Restarting system
DDR Version 1.24 20191016
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 323
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 82367
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xe5674
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Jan 05 2021 - 00:07:57 +0100)
SoC: Rockchip rk3399
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3279 bytes read in 5 ms (639.6 KiB/s)
## Executing script at 00500000
dev: vdd_log @ vdd-log
dev: vdd_center @ DCDC_REG1
Boot script loaded from mmc 1
166 bytes read in 4 ms (40 KiB/s)
16185666 bytes read in 695 ms (22.2 MiB/s)
27507200 bytes read in 1172 ms (22.4 MiB/s)
81968 bytes read in 12 ms (6.5 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3cd0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    16185602 Bytes = 15.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f4f80000, end f5eef902 ... OK
   Loading Device Tree to 00000000f4f03000, end 00000000f4f7ffff ... OK
Starting kernel ...
[   23.337713] Internal error: Oops: 96000021 [#1] PREEMPT SMP
[   23.338213] Modules linked in: r8152 snd_soc_hdmi_codec snd_soc_rockchip_i2s snd_soc_core snd_pcm_dmaengine leds_pwm snd_pcm pwm_fan gpio_charger snd_timer snd rockchip_vdec(C) panfrost hantro_vpu(C) soundcore rockchip_rga gpu_sched rockchipdrm v4l2_h264 fusb302 videobuf2_dma_contig videobuf2_dma_sg dw_mipi_dsi v4l2_mem2mem videobuf2_vmalloc tcpm dw_hdmi videobuf2_memops analogix_dp typec drm_kms_helper videobuf2_v4l2 videobuf2_common cec videodev rc_core mc drm sg drm_panel_orientation_quirks gpio_beeper cpufreq_dt zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) nfsd auth_rpcgss nfs_acl zcommon(POE) lockd znvpair(POE) zavl(POE) grace icp(POE) spl(OE) ledtrig_netdev sunrpc lm75 ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac mdio_xpcs adc_keys
[   23.345003] CPU: 4 PID: 0 Comm: swapper/4 Tainted: P         C OE     5.9.14-rockchip64 #20.11.4
[   23.345778] Hardware name: Helios64 (DT)
[   23.346130] pstate: 80000085 (Nzcv daIf -PAN -UAO BTYPE=--)
[   23.346650] pc : flush_smp_call_function_queue+0x40/0x250
[   23.346658] lr : flush_smp_call_function_queue+0x28/0x250
[   23.347617] sp : ffff800011afbf20
[   23.347620] x29: ffff800011afbf20 x28: ffff0000f6ead700
[   23.348397] x27: 0000000000000001 x26: ffff800011522db0
[   23.348402] x25: 0000000000000004 x24: 0000000000000000
[   23.349350] x23: ffff800011bc3df0 x22: 0000000000000001
[   23.349358] x21: ffff8000e6283000 x20: ffff800011525a40
[   23.350300] x19: ffff800011522db0 x18: 0000000000000000
[   23.350306] x17: 0000000000000000 x16: 0000000000000000
[   23.351246] x15: 0000000000000000 x14: 00000000000000ef
[   23.351251] x13: 00000000000001b5 x12: 0000000000000002
[   23.351255] x11: 0000000000000001 x10: 0000000000000a30
[   23.352666] x9 : ffff800011bc3e80 x8 : ffff0000f6eae190
[   23.352672] x7 : 00000000ffffffff x6 : 000000003d5e8871
[   23.353615] x5 : 00ffffffffffffff x4 : ffff8000e6283000
[   23.353622] x3 : ca72b5330aec0004 x2 : ffff800011839988
[   23.354564] x1 : 0000000000000000 x0 : 0000000000000004
[   23.354571] Call trace:
[   23.355269]  flush_smp_call_function_queue+0x40/0x250
[   23.355277]  generic_smp_call_function_single_interrupt+0x14/0x20
[   23.356265]  handle_IPI+0x10c/0x3c8
[   23.356274]  gic_handle_irq+0x168/0x170
[   23.356927]  el1_irq+0xb8/0x180
[   23.356933]  arch_cpu_idle+0x14/0x20
[   23.356939]  do_idle+0x1fc/0x270
[   23.356946]  cpu_startup_entry+0x28/0x60
[   23.358179]  secondary_start_kernel+0x16c/0x180
[   23.358189] Code: d2800001 f8605855 8b150283 f9800071 (c85f7c60)
[   23.359142] ---[ end trace d7f9c88f93daf07b ]---
[   23.359147] Kernel panic - not syncing: Fatal exception in interrupt
[   23.360124] SMP: stopping secondary CPUs
[   23.360484] Kernel Offset: disabled
[   23.360489] CPU features: 0x0240022,2000200c
[   23.360491] Memory Limit: none
[   23.361461] Rebooting in 90 seconds..
i had the same issues butt pinning min and max frequency to 1416 MHz and setting the governor to performance did the trick for me. It was not necessary to tweak any voltages.
good luck!
17 hours ago, gprovost said:
@SymbiosisSystems Have you tried each tweak individually ?
Hi Gauthier, no I did them both together. If you think I'll have more success with one rather than both which would you suggest ? This new build seems to be unstable again which is a step backwards. CPU running at 1.2GHz is at 48c without any NAS transfers occuring.
I don't own this device (yet), but I'm considering getting one from the next batch.
So I did a little research into its mainlining status. The board should benefit from the RK3399 being a popular SoC for SBCs.
The mainline kernel contains a device tree file that was added by this commit back in October.
The dts file contains this comment:
 * The system doesn't run stable with cpu freq enabled, so disallow the lower
 * frequencies until this problem is properly understood and resolved.
After the comment, all CPU frequencies except the respective highest one on each cluster are disabled.
I'm not sure whether the current Armbian kernel also does this (it does disable additional higher overclocked frequencies which aren't present in the mainline kernel).
Unfortunately, there is no reason given for the choice of the highest frequencies.
But I'd give them a try. That would be 1416MHz for the A53 cluster and 1800 MHz for the A72 cluster.
@edwinistrator we did recommend the Debian maintainer to try the following tweak at that time,
Hi Uwe,
Can you try to add the following in /etc/sysfs.conf
devices/system/cpu/cpufreq/policy0/scaling_min_freq = 1416000
devices/system/cpu/cpufreq/policy4/scaling_min_freq = 1800000
devices/system/cpu/cpufreq/policy0/scaling_max_freq = 1416000
devices/system/cpu/cpufreq/policy4/scaling_max_freq = 1800000
Then reboot your system.
and according to Uwe, it does improve the stability.
currently we still use the lower freq but we are considering to also disable those lower freq and maybe also disable DVFS (just use one fixed clock speed), since we received many instability reported and some has good outcome when cpu clock limited to 1200 MHz.
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x82
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 79784
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
16181568 bytes read in 696 ms (22.2 MiB/s)
27507200 bytes read in 1168 ms (22.5 MiB/s)
81968 bytes read in 13 ms (6 MiB/s)
   Image Name:   uInitrd
   Data Size:    16181504 Bytes = 15.4 MiB
   Loading Ramdisk to f4f81000, end f5eef900 ... OK
   Loading Device Tree to 00000000f4f04000, end 00000000f4f80fff ... OK
Starting kernel ...
[   24.738473] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: sched_ttwu_pending+0x160/0x160
[   24.739419] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.9.14-rockchip64 #20.11.4
[   24.740194] Hardware name: Helios64 (DT)
[   24.740546] Call trace:
[   24.740772]  dump_backtrace+0x0/0x200
[   24.741103]  show_stack+0x18/0x28
[   24.741406]  dump_stack+0xc0/0x11c
[   24.741714]  panic+0x164/0x364
[   24.741992]  __stack_chk_fail+0x3c/0x40
[   24.742336]  send_call_function_single_ipi+0x0/0x20
[   24.742775]  flush_smp_call_function_queue+0x114/0x250
[   24.743234]  generic_smp_call_function_single_interrupt+0x14/0x20
[   24.743779]  handle_IPI+0x10c/0x3c8
[   24.744096]  gic_handle_irq+0x168/0x170
[   24.744440]  el1_irq+0xb8/0x180
[   24.744724]  arch_cpu_idle+0x14/0x20
[   24.745046]  do_idle+0x1fc/0x270
[   24.745337]  cpu_startup_entry+0x24/0x60
[   24.745690]  secondary_start_kernel+0x16c/0x180
[   24.746099] SMP: stopping secondary CPUs
[   24.746456] Kernel Offset: disabled
[   24.746770] CPU features: 0x0240022,2000200c
[   24.747149] Memory Limit: none
[   24.747435] Rebooting in 90 seconds..
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x82
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
   Image Name:   uInitrd
Starting kernel ...
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x82
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 322
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 80909
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
16181568 bytes read in 691 ms (22.3 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
[   40.035068] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: sched_ttwu_pending+0x160/0x160
[   40.036021] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.9.14-rockchip64 #20.11.4
[   40.036797] Hardware name: Helios64 (DT)
[   40.037148] Call trace:
[   40.037375]  dump_backtrace+0x0/0x200
[   40.037705]  show_stack+0x18/0x28
[   40.038006]  dump_stack+0xc0/0x11c
[   40.038314]  panic+0x164/0x364
[   40.038591]  __stack_chk_fail+0x3c/0x40
[   40.038935]  send_call_function_single_ipi+0x0/0x20
[   40.039372]  flush_smp_call_function_queue+0x114/0x250
[   40.039832]  generic_smp_call_function_single_interrupt+0x14/0x20
[   40.040377]  handle_IPI+0x10c/0x3c8
[   40.040695]  gic_handle_irq+0x168/0x170
[   40.041039]  el1_irq+0xb8/0x180
[   40.041324]  arch_cpu_idle+0x14/0x20
[   40.041646]  do_idle+0x1fc/0x270
[   40.041937]  cpu_startup_entry+0x24/0x60
[   40.042288]  secondary_start_kernel+0x16c/0x180
[   40.042698] SMP: stopping secondary CPUs
[   40.043054] Kernel Offset: disabled
[   40.043365] CPU features: 0x0240022,2000200c
[   40.043746] Memory Limit: none
[   40.044033] Rebooting in 90 seconds..
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 324
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 80419
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
3279 bytes read in 6 ms (533.2 KiB/s)
16181568 bytes read in 697 ms (22.1 MiB/s)
27507200 bytes read in 1174 ms (22.3 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
[   38.759473] Internal error: Oops: 9600004e [#1] PREEMPT SMP
[   38.759976] Modules linked in: snd_soc_hdmi_codec r8152 fusb302 pwm_fan hantro_vpu(C) leds_pwm rockchip_vdec(C) snd_soc_rockchip_i2s gpio_charger v4l2_h264 panfrost tcpm snd_soc_core rockchip_rga videobuf2_dma_contig snd_pcm_dmaengine typec v4l2_mem2mem gpu_sched snd_pcm videobuf2_dma_sg videobuf2_vmalloc videobuf2_memops snd_timer videobuf2_v4l2 snd videobuf2_common soundcore videodev sg mc rockchipdrm dw_mipi_dsi dw_hdmi analogix_dp drm_kms_helper cec rc_core drm drm_panel_orientation_quirks gpio_beeper cpufreq_dt zfs(POE) zunicode(POE) zzstd(OE) nfsd zlua(OE) auth_rpcgss zcommon(POE) nfs_acl znvpair(POE) zavl(POE) lockd icp(POE) grace spl(OE) ledtrig_netdev lm75 sunrpc ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac mdio_xpcs adc_keys
[   38.766762] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.9.14-rockchip64 #20.11.4
[   38.767536] Hardware name: Helios64 (DT)
[   38.767890] pstate: 20000085 (nzCv daIf -PAN -UAO BTYPE=--)
[   38.768392] pc : __update_load_avg_se+0x44/0x310
[   38.768808] lr : update_load_avg+0x4e4/0x5f0
[   38.769186] sp : ffff800011b03d40
[   38.769483] x29: ffff800011b03d40 x28: ffff0000f6eae580
[   38.769956] x27: 0000000000000001 x26: ffff800011522db0
[   38.770428] x25: 0000000000000005 x24: ffff0000f6fa00c0
[   38.770900] x23: ffff0000f77c7c40 x22: 0000000000000005
[   38.771372] x21: 0000000903da1aad x20: ffff0000f6fa00c0
[   38.771844] x19: ffff0000f77c7cc0 x18: 0000000000000004
[   38.772315] x17: 0000000000000001 x16: 0000000000000019
[   38.772786] x15: ffff80001185a098 x14: ffffffffffffffff
[   38.773257] x13: 000000000000021e x12: 000000000000010f
[   38.773729] x11: 0000000000000001 x10: 0000000000000a30
[   38.774200] x9 : 0000000000000000 x8 : 0000000000000000
[   38.774672] x7 : 0000000000000000 x6 : ffff0000f6fa0180
[   38.775143] x5 : 0000000000000060 x4 : 0000000903d89800
[   38.775614] x3 : 00000000000182ad x2 : ffff0000f6fa00c0
[   38.776085] x1 : ffff0000f77c7cc0 x0 : 0000000903da1aad
[   38.776557] Call trace:
[   38.776781]  __update_load_avg_se+0x44/0x310
[   38.777163]  update_load_avg+0x4e4/0x5f0
[   38.777515]  enqueue_entity+0x68/0x228
[   38.777851]  enqueue_task_fair+0x94/0x450
[   38.778210]  ttwu_do_activate+0x88/0x150
[   38.778561]  sched_ttwu_pending+0xbc/0x160
[   38.778931]  flush_smp_call_function_queue+0x114/0x250
[   38.779390]  generic_smp_call_function_single_interrupt+0x14/0x20
[   38.779932]  handle_IPI+0x10c/0x3c8
[   38.780248]  gic_handle_irq+0x168/0x170
[   38.780592]  el1_irq+0xb8/0x180
[   38.780876]  arch_cpu_idle+0x14/0x20
[   38.781198]  do_idle+0x1fc/0x270
[   38.781488]  cpu_startup_entry+0x24/0x60
[   38.781841]  secondary_start_kernel+0x16c/0x180
[   38.782251] Code: eb040003 540008e4 d34afc65 b40007e5 (a90153f3)
[   38.782801] ---[ end trace 750eb2db6f8efac2 ]---
[   38.783213] Kernel panic - not syncing: Fatal exception in interrupt
[   38.783776] SMP: stopping secondary CPUs
[   38.784134] Kernel Offset: disabled
[   38.784447] CPU features: 0x0240022,2000200c
[   38.784826] Memory Limit: none
[   38.785113] Rebooting in 90 seconds..
Could you guys update to latest  kernel (linux-image-current-rockchip64_21.02.3_arm64 / LK 5.10.21)  and revert to ondemand governor with the full range of frequency in case you were on performance mode.
Also remove any vdd voltage tweak you might have put in /boot/boot.cmd. If you had vdd tweak you will need to rebuild u-boot boot script after removing the lines in /boot/boot.cmd
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Let us know how the new kernel improves the stability.
@gprovost I started with a clean install and it crashed on the second boot
root@helios64:/usr/src# [ 2364.037435] reboot: Restarting system
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 80224
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xe5b60
RunBL31 0x40000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Mar 08 2021 - 14:54:58 +0000)
Reset cause: unknown reset
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
3185 bytes read in 6 ms (517.6 KiB/s)
239 bytes read in 5 ms (45.9 KiB/s)
15761964 bytes read in 671 ms (22.4 MiB/s)
28582400 bytes read in 1212 ms (22.5 MiB/s)
81913 bytes read in 13 ms (6 MiB/s)
2698 bytes read in 7 ms (376 KiB/s)
Moving Image from 0x2080000 to 0x2200000, end=3de0000
   Image Name:   uInitrd
   Data Size:    15761900 Bytes = 15 MiB
   Loading Ramdisk to f4fe7000, end f5eef1ec ... OK
   Loading Device Tree to 00000000f4f6a000, end 00000000f4fe6fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.21-rockchip64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021
[    0.000000] Machine model: Helios64
[    0.000000] printk: debug: ignoring loglevel setting.
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11776 pages used for memmap
[    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072
[    0.000000] pcpu-alloc: s94040 r8192 d28840 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=c559a861-be25-4b41-a161-d0c3d75c0089 rootwait rootfstype=ext4 console=ttyS2,1500000  consoleblank=0 loglevel=7 ubootpart=559a8d18-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[    0.000000] Memory: 3739356K/4061184K available (14848K kernel code, 2632K rwdata, 5972K rodata, 4352K init, 580K bss, 190756K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000400d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001524] Console: colour dummy device 80x25
[    0.001667] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001692] pid_max: default: 32768 minimum: 301
[    0.001863] LSM: Security Framework initializing
[    0.001910] Yama: becoming mindful.
[    0.002060] AppArmor: AppArmor initialized
[    0.002169] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002206] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005936] rcu: Hierarchical SRCU implementation.
[    0.007138] Platform MSI: interrupt-controller@fee20000 domain created
[    0.007809] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.010351] EFI services will not be available.
[    0.011075] smp: Bringing up secondary CPUs ...
[    0.012248] Detected VIPT I-cache on CPU1
[    0.012297] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012316] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000
[    0.012394] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013822] Detected VIPT I-cache on CPU2
[    0.013871] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013891] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000
[    0.013969] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015426] Detected VIPT I-cache on CPU3
[    0.015476] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015496] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000
[    0.015573] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.017000] CPU features: detected: Spectre-v2
[    0.017008] CPU features: detected: Spectre-v4
[    0.017013] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.017021] Detected PIPT I-cache on CPU4
[    0.017058] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.017074] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000
[    0.017122] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018390] Detected PIPT I-cache on CPU5
[    0.018428] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018443] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000
[    0.018493] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.018689] smp: Brought up 1 node, 6 CPUs
[    0.018800] SMP: Total of 6 processors activated.
[    0.018816] CPU features: detected: 32-bit EL0 Support
[    0.018831] CPU features: detected: CRC32 instructions
[    0.018845] CPU features: detected: 32-bit EL1 Support
[    0.045641] CPU: All CPU(s) started at EL2
[    0.045723] alternatives: patching kernel code
[    0.049507] devtmpfs: initialized
[    0.066223] Registered cp15_barrier emulation handler
[    0.066254] Registered setend emulation handler
[    0.066496] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066574] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069593] pinctrl core: initialized pinctrl subsystem
[    0.070271] D
                [    2.973586] hub 4-0:1.0: USB hub found
[    2.974010] hub 4-0:1.0: 1 port detected
[    2.974843] usbcore: registered new interface driver usb-storage
[    2.978120] mousedev: PS/2 mouse device common for all mice
[    2.980065] i2c /dev entries driver
[    2.984491] pca953x 2-0020: using no AI
[    2.995085] rk808 0-001b: chip id: 0x0
[    2.999340] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.999912] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.000461] rk808-regulator rk808-regulator: max buck steps per change: 4
[    3.002229] vdd_center: supplied by vcc5v0_sys
[    3.003283] vdd_cpu_l: supplied by vcc5v0_sys
[    3.004019] vcc_ddr_s3: supplied by vcc5v0_sys
[    3.005073] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    3.006165] vcc1v8_dvp: supplied by vcc5v0_sys
[    3.007048] vcc3v0_touch: supplied by vcc5v0_sys
[    3.008797] vcc1v8_s3: supplied by vcc5v0_sys
[    3.009469] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    3.011213] vcc_sdio_s0: supplied by vcc5v0_sys
[    3.012120] vcca3v0_codec: supplied by vcc5v0_sys
[    3.013722] vcc1v5_s3: supplied by vcc5v0_sys
[    3.014656] vcca1v8_codec: supplied by vcc5v0_sys
[    3.016272] vcc3v0_s3: supplied by vcc5v0_sys
[    3.016809] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    3.017439] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    3.018481] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    3.022605] rk808-rtc rk808-rtc: registered as rtc0
[    3.023604] rk808-rtc rk808-rtc: setting system clock to 2021-03-10T11:07:27 UTC (1615374447)
[    3.027503] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.029360] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    3.029969] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    3.030523] vdd_cpu_b: supplied by vcc5v0_sys
[    3.033916] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.035784] vdd_gpu: supplied by vcc5v0_sys
[    3.043886] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    3.046572] sdhci: Secure Digital Host Controller Interface driver
[    3.047121] sdhci: Copyright(c) Pierre Ossman
[    3.047539] Synopsys Designware Multimedia Card Interface Driver
[    3.049424] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.049899] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    3.050571] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    3.051166] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    3.051733] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    3.053152] mmc2: CQHCI version 5.10
[    3.053179] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    3.054732] ledtrig-cpu: registered to indicate activity on CPUs
[    3.056460] hid: raw HID events driver (C) Jiri Kosina
[    3.057048] usbcore: registered new interface driver usbhid
[    3.057541] usbhid: USB HID core driver
[    3.064233] drop_monitor: Initializing network drop monitor service
[    3.065623] NET: Registered protocol family 10
[    3.067044] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.079975] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    3.081839] random: fast init done
[    3.123736] Segment Routing with IPv6
[    3.124157] NET: Registered protocol family 17
[    3.124716] 8021q: 802.1Q VLAN Support v1.8
[    3.125159] Key type dns_resolver registered
[    3.126138] registered taskstats version 1
[    3.126514] Loading compiled-in X.509 certificates
[    3.130527] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
[    3.137778] zswap: loaded using pool zstd/z3fold
[    3.138651] Key type ._fscrypt registered
[    3.139012] Key type
                       [    3.224615] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.225271] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    3.226070] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    3.283163] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.283756] pci_bus 0000:00: root bus resource [bus 00-1f]
[    3.284246] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    3.284856] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    3.285743] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    3.286444] pci 0000:00:00.0: supports D1
[    3.286805] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.290638] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.292531] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.293010] mmc1: tuning execution failed: -5
[    3.293210] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.294357] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    3.294954] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.295578] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    3.296086] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    3.296708] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    3.297216] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    3.297839] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    3.298363] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    3.298985] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    3.299491] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    3.300113] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    3.300621] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    3.301203] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    3.301826] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    3.302807] pci 0000:01:00.0: PME# supported from D3hot
[    3.303526] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    3.305928] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.310526] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    3.311137] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    3.311753] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    3.312393] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    3.313006] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    3.313560] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    3.314160] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    3.314714] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    3.315298] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    3.315853] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    3.316436] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    3.316990] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    3.317573] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    3.318140] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    3.318728] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.319175] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    3.320003] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.320867] pcieport 0000:00:00.0: PME: Signaling with IRQ 90
[    3.321239] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.321716] pcieport 0000:00:00.0: AER: enabled with IRQ 90
[    3.323027] ahci 0000:01:00.0: version 3.0
[    3.323414] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    3.324527] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    3.325206] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    3.325951] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    3.330459] scsi host0: ahci
[    3.331492] scsi host1: ahci
[    3.332382] scsi host2: ahci
[    3.333289] scsi host3: ahci
[    3.334241] scsi host4: ahci
[    3.334725] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91
[    3.335381] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92
[    3.336036] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93
[    3.336689] ata4: SATA max UDMA/133
                                       [    3.513730] hub 3-1:1.0: USB hub found
[    3.514326] hub 3-1:1.0: 4 ports detected
[    3.608402] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.726641] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.727367] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.727998] usb 4-1: Product: USB3.0 Hub
[    3.728447] usb 4-1: Manufacturer: VIA Labs, Inc.
[    3.753626] hub 4-1:1.0: USB hub found
[    3.754118] hub 4-1:1.0: 4 ports detected
[    4.409996] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.431015] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    4.431754] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.432401] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
[    4.432859] usb 4-1.4: Manufacturer: Realtek
[    4.433240] usb 4-1.4: SerialNumber: 000000001
[   11.729949] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   11.808574] ata1.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   11.809182] ata1.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   11.820003] ata1.00: configured for UDMA/133
[   11.820837] scsi 0:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   11.822879] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   11.823581] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   11.824125] sd 0:0:0:0: [sda] Write Protect is off
[   11.824562] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   11.825145] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   11.873965]  sda: sda1 sda9
[   11.877143] sd 0:0:0:0: [sda] Attached SCSI disk
[   12.477951] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   12.555883] ata2.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   12.556492] ata2.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   12.567234] ata2.00: configured for UDMA/133
[   12.568173] scsi 1:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   12.570272] sd 1:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   12.570973] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[   12.571505] sd 1:0:0:0: [sdb] Write Protect is off
[   12.571943] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[   12.572507] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.617370]  sdb: sdb1 sdb9
[   12.620574] sd 1:0:0:0: [sdb] Attached SCSI disk
[   13.165945] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.187308] ata3.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.187915] ata3.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.198672] ata3.00: configured for UDMA/133
[   13.199640] scsi 2:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.201727] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.202466] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[   13.203000] sd 2:0:0:0: [sdc] Write Protect is off
[   13.203438] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   13.204003] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.244245]  sdc: sdc1 sdc9
[   13.246586] sd 2:0:0:0: [sdc] Attached SCSI disk
[   13.797942] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.820705] ata4.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.821312] ata4.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.832097] ata4.00: configured for UDMA/133
[   13.832865] scsi 3:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.834772] sd 3:0:0:0: [sdd] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.835474] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[   13.836007] sd 3:0:0:0: [sdd] Write Protect is off
[   13.836444] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[   13.837011] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.893427]  sdd: sdd1 sdd9
[   13.895638] sd 3:0:0:0: [sdd] Attached SCSI disk
[   14.148588] ata5: SATA link down (SStatus 0 SControl 300)
[   14.152099] Freeing unused kernel memory: 4352K
[   14.152664] Run /init as init process
[   14.153000]   with arguments:
[   14.153271]     /init
[   14.153481]     earlyprintk
[   14.153735]   with environment:
[   14.154049]     HOME=/
[   14.154267]     TERM=linux
[   14.154515]     ubootpart=559a8d18-01
[   14.154846]     cgroup_enable=memory
[   14.155168]     cgroup_memory=1
Loading, please wait...
Starting version 241
[   14.838015] input: adc-keys as /devices/platform/adc-keys/input/input1
[   14.967490] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   14.968106] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   14.968926] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   14.971392] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   14.972042] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   14.972553] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[   14.973789] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   14.975171] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   14.975816] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   14.981532] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   14.985056] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   14.985807] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   14.986550] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[   14.987228] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[   14.987897] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   14.988471] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   14.989105] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   14.989995] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   14.990538] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   14.991062] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   15.138606] libphy: stmmac: probed
[   15.139044] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   15.140240] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Begin: Loading essential drivers ... [   15.364910] async_tx: api initialized (async)
done.
[   15.668210] random: crng init done
done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
/dev/mmcblk1p1: clean, 103924/2212736 files, 755764/7709728 blocks
done.
[   15.895923] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... /scripts/local-bottom/mdadm: 2: /scripts/local-bottom/mdadm: rm: not found
done.
[   16.910411] systemd[1]: Inserted module 'autofs4'
[   16.978251] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   16.981044] systemd[1]: Detected architecture arm64.
Welcome to Armbian 21.02.3 Buster!
[   17.021760] systemd[1]: Set hostname to <helios64-archive.home>.
[   18.233090] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[   18.254671] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[   18.258079] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[   18.396385] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
[   18.542402] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[   18.554599] systemd[1]: Listening on LVM2 poll daemon socket.
[  OK  ] Listening on LVM2 poll daemon socket.
[   18.566063] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Reached target Slices.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on Device-mapper event daemon FIFOs.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Journal Socket.
         Starting Nameserver information manager...
         Mounting POSIX Message Queue File System...
         Starting Create list of re…odes for the current kernel...
         Starting Availability of block devices...
         Mounting Kernel Debug File System...
         Mounting Huge Pages File System...
         Starting Monitoring of LVM…meventd or progress polling...
         Starting Remount Root and Kernel File Systems...
         Mounting RPC Pipe File System...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Set the console keyboard layout...
         Starting Load Kernel Modules...
[   18.966672] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[  OK  ] Reached target Paths.
         Mounting NFSD configuration filesystem...
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Create list of req… nodes for the current kernel.
[  OK  ] Started Availability of block devices.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Huge Pages File System.
[   19.065200] lm75 2-004c: supply vs not found, using dummy regulator
[  OK  ] Started Remount Root and Kernel File Systems.
[   19.066958] lm75 2-004c: hwmon4: sensor 'lm75'
[  OK  ] Started Nameserver information manager.
[   19.088106] RPC: Registered named UNIX socket transport module.
[   19.088641] RPC: Registered udp transport module.
[   19.089061] RPC: Registered tcp transport module.
[   19.089479] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  OK  ] Mounted RPC Pipe File System.
[  OK  ] Started Monitoring of LVM2… dmeventd or progress polling.
[  OK  ] Started Load Kernel Modules.
         Mounting Kernel Configuration File System...
         Mounting FUSE Control File System...
         Starting Apply Kernel Variables...
         Starting pNFS block layout mapping daemon...
         Starting Create System Users...
         Starting Load/Save Random Seed...
[   19.260012] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[  OK  ] Mounted NFSD configuration filesystem.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started pNFS block layout mapping daemon.
[  OK  ] Started Create System Users.
[  OK  ] Started Load/Save Random Seed.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting Mount /tmp as tmp…e access to the root device...
[  OK  ] Mounted Mount /tmp as tmpf…ite access to the root device.
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Started udev Coldplug all Devices.
         Starting Helper to synchronize boot up for ifupdown...
         Starting udev Wait for Complete Device Initialization...
[  OK  ] Started Helper to synchronize boot up for ifupdown.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
[   19.974919] input: beeper as /devices/platform/beeper/input/input2
[  OK  ] Found device /dev/ttyS2.
[   20.130057] mc: Linux media interface: v0.10
[   20.175392] videodev: Linux video capture interface: v2.00
[   20.202349] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   20.207895] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   20.210203] sd 2:0:0:0: Attached scsi generic sg2 type 0
[   20.211582] sd 3:0:0:0: Attached scsi generic sg3 type 0
[   20.219807] panfrost ff9a0000.gpu: clock rate = 500000000
[   20.225622] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   20.226226] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   20.226439] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   20.227611] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   20.228641] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   20.232998] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[   20.242188] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   20.245857] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   20.249699] rockchip-vop ff900000.vop: Adding to iommu group 3
[   20.255295] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   20.255824] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
[   20.256688] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[   20.257548] xhci-hcd xhci-hcd.3.auto: irq 75, io mem 0xfe800000
[   20.258653] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   20.259396] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.260038] usb usb5: Product: xHCI Host Controller
[   20.260475] usb usb5: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.261044] usb usb5: SerialNumber: xhci-hcd.3.auto
[   20.262227] hub 5-0:1.0: USB hub found
[   20.262370] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   20.262628] hub 5-0:1.0: 1 port detected
[   20.263503] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   20.264236] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   20.264740] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
[   20.265427] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   20.267143] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   20.267919] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   20.268812] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   20.269549] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.270227] usb usb6: Product: xHCI Host Controller
[   20.270601] [drm] unsupported AFBC format[3231564e]
[   20.270667] usb usb6: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.270674] usb usb6: SerialNumber: xhci-hcd.3.auto
[   20.271324] hub 6-0:1.0: USB hub found
[   20.272529] hub 6-0:1.0: 1 port detected
[   20.279092] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   20.280404] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[   20.282105] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   20.283533] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   20.299262] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   20.311560] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   20.313446] rkvdec ff660000.video-codec: Adding to iommu group 1
[   20.332730] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   20.336075] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   20.343154] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[   20.345164] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[   20.569001] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   20.698015] spl: loading out-of-tree module taints kernel.
[   20.698019] spl: loading out-of-tree module taints kernel.
[   20.698392] spl: module verification failed: signature and/or required key missing - tainting kernel
[   20.721126] icp: module license 'CDDL' taints kernel.
[   20.721259] icp: module license 'CDDL' taints kernel.
[   20.721263] icp: module license 'CDDL' taints kernel.
[   20.721267] Disabling lock debugging due to kernel taint
[   20.762479] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[   20.815290] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   20.902627] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   20.918306] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
[   20.918792] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
[   20.918792]          US6,570,884, US6,115,776, and US6,327,625.
[   20.918792]
[   20.920626] usbcore: registered new interface driver r8152
[   21.123908] ZFS: Loaded module v2.0.1-1, ZFS pool version 5000, ZFS filesystem version 5
[  OK  ] Started udev Wait for Complete Device Initialization.
         Starting Install ZFS kernel module...
[   21.314154] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[  OK  ] Started Install ZFS kernel module.
         Starting Import ZFS pools by cache file...
[   21.712877] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[***   ] (1 of 2) A start job is running for… to be Configured (15s / no limit)
[   ***] (2 of 2) A start job is running for…ols by cache file (33s / no limit)
[  OK  ] Started Import ZFS pools by cache file.
[   52.827166] systemd[1]: Reached target ZFS pool import target.
[  OK  ] Reached target ZFS pool import target.
[   52.845084] systemd[1]: Starting Wait for ZFS Volume (zvol) links in /dev...
[   52.871453] systemd[1]: Starting Mount ZFS filesystems...
[   52.922670] systemd[1]: Started Wait for ZFS Volume (zvol) links in /dev.
[  OK  ] Started Wait for ZFS Volume (zvol) links in /dev.
[   52.934880] systemd[1]: Reached target ZFS volumes are ready.
[  OK  ] Reached target ZFS volumes are ready.
[   53.063912] systemd[1]: Started Mount ZFS filesystems.
[  OK  ] Started Mount ZFS filesystems.
[   53.066410] systemd[1]: Reached target Local File Systems.
[  OK  ] Reached target Local File Systems.
[   53.078262] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
[   53.086943] systemd[1]: Starting Armbian ZRAM config...
         Starting folder2ram systemd service...
         Starting Cleanup monit state file...
         Starting Raise network interfaces...
         Starting Cleanup PHP session files...
         Starting Set console font and keymap...
         Starting Preprocess NFS configuration...
[  OK  ] Started Cleanup monit state file.
[  OK  ] Started Preprocess NFS configuration.
[  OK  ] Started Cleanup PHP session files.
         Starting NFSv4 ID-name mapping service...
[  OK  ] Reached target NFS client services.
[  OK  ] Started NFSv4 ID-name mapping service.
[   53.427252] zram: Added device: zram0
[   53.428187] zram: Added device: zram1
[   53.429178] zram: Added device: zram2
[   53.586179] zram0: detected capacity change from 0 to 1991770112
[   53.677988] Adding 1945084k swap on /dev/zram0.  Priority:5 extents:1 across:1945084k SSFS
[  OK  ] Started Raise network interfaces.
[   53.829290] zram1: detected capacity change from 0 to 52428800
[  OK  ] Started Armbian ZRAM config.
         Starting Armbian memory supported logging...
[   54.011350] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   54.012006] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[  OK  ] Started folder2ram systemd service.
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Armbian memory supported logging.
         Starting Journal Service...
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[   56.427750] systemd-journald[2052]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Network Name Resolution...
         Starting RPC bind portmap service...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily man-db regeneration.
[  OK  ] Started Trigger anacron every hour.
[  OK  ] Started Clean PHP session files every 30 mins.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started Daily rotation of log files.
         Starting Armbian hardware optimization...
         Starting Armbian hardware monitoring...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Started RPC bind portmap service.
[  OK  ] Started Armbian hardware monitoring.
[  OK  ] Reached target RPC Port Mapper.
[  OK  ] Started Armbian hardware optimization.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
         Starting Login Service...
         Starting fan speed regulator...
         Starting WPA supplicant...
[  OK  ] Started Self Monitoring an…ing Technology (SMART) Daemon.
[  OK  ] Started Run anacron jobs.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Network Manager...
         Starting System Logging Service...
         Starting Dispatcher daemon for systemd-networkd...
         Starting Resets System Activity Data Collector...
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[   57.527770] Unable to handle kernel paging request at virtual address ffff800015511a9c
[   57.528471] Mem abort info:
[   57.528722]   ESR = 0x86000007
[   57.528995]   EC = 0x21: IABT (current EL), IL = 32 bits
[   57.529463]   SET = 0, FnV = 0
[   57.529735]   EA = 0, S1PTW = 0
[   57.530023] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000003669000
[   57.530611] [ffff800015511a9c] pgd=00000000f7fff003, p4d=00000000f7fff003, pud=00000000f7ffe003, pmd=000000004ae15003, pte=0000000000000000
[   57.531724] Internal error: Oops: 86000007 [#1] PREEMPT SMP
[   57.532217] Modules linked in: zram zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) zcommon(POE) znvpair(POE) zavl(POE) icp(POE) spl(OE) r8152 snd_soc_hdmi_codec snd_soc_rockchip_i2s hantro_vpu(C) leds_pwm snd_soc_core rockchip_vdec(C) snd_pcm_dmaengine v4l2_h264 snd_pcm gpio_charger videobuf2_dma_contig snd_timer rockchip_rga videobuf2_dma_sg v4l2_mem2mem videobuf2_vmalloc rockchipdrm snd videobuf2_memops panfrost dw_mipi_dsi videobuf2_v4l2 dw_hdmi fusb302 sg gpu_sched videobuf2_common tcpm analogix_dp videodev soundcore typec drm_kms_helper mc cec rc_core drm drm_panel_orientation_quirks gpio_beeper cpufreq_dt nfsd auth_rpcgss nfs_acl lockd grace ledtrig_netdev lm75 sunrpc ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys pwm_fan
[   57.539202] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.10.21-rockchip64 #21.02.3
[   57.539980] Hardware name: Helios64 (DT)
[   57.540330] pstate: 600003c5 (nZCv DAIF -PAN -UAO -TCO BTYPE=--)
[   57.540863] pc : 0xffff800015511a9c
[   57.541182] lr : debug_smp_processor_id+0x14/0x30
[   57.541597] sp : ffff800011c13ca0
[   57.541891] x29: ffff800011c13ca0 x28: ffff000040311d00
[   57.542366] x27: ffff000040004300 x26: ffff800011cf3de0
[   57.542839] x25: 0000000000000001 x24: 0000000000000000
[   57.543312] x23: 0000000060000085 x22: ffff800011cf3f50
[   57.543785] x21: ffff8000118b99c8 x20: ffff0000f77c8980
[   57.544257] x19: ffff800011580980 x18: 0000000000000000
[   57.544730] x17: 0000000000000000 x16: 0000000000000000
[   57.545207] x15: 00000147d2570b46 x14: 000000000000008b
[   57.545682] x13: 0000000000000006 x12: 0000000000000001
[   57.546158] x11: 0000000000000040 x10: ffff80001194ef28
[   57.546634] x9 : ffff80001194ef20 x8 : ffff000040400270
[   57.547108] x7 : 0000000000000000 x6 : 0000000000000000
[   57.547583] x5 : ffff000040400248 x4 : ffff8000e6248000
[   57.548056] x3 : 0000000000010001 x2 : ffff80001156a000
[   57.548535] x1 : ffff8000112a1000 x0 : 0000000000000003
[   57.549012] Call trace:
[   57.549235]  0xffff800015511a9c
[   57.549519]  rcu_nmi_enter+0x40/0x150
[   57.549847]  rcu_irq_enter+0x10/0x70
[   57.550167]  enter_from_kernel_mode.isra.5+0x28/0x40
[   57.550606]  el1_abort+0x28/0x70
[   57.550895]  el1_sync_handler+0x64/0xe8
[   57.551238]  el1_sync+0x7c/0x100
[   57.551525]  0xffff800011cf3f50
[   57.551809]  generic_smp_call_function_single_interrupt+0x14/0x20
[   57.552347]  ipi_handler+0x7c/0x370
[   57.552661]  handle_percpu_devid_fasteoi_ipi+0x9c/0x1f0
[   57.553123]  generic_handle_irq+0x30/0x48
[   57.553479]  __handle_domain_irq+0x94/0x108
[   57.553854]  gic_handle_irq+0xc0/0x140
[   57.554187]  el1_irq+0xc0/0x180
[   57.554470]  arch_cpu_idle+0x18/0x28
[   57.554799]  do_idle+0x204/0x278
[   57.555089]  cpu_startup_entry+0x28/0x60
[   57.555440]  secondary_start_kernel+0x170/0x180
[   57.555846] Code: bad PC value
[   57.556130] ---[ end trace 294ef7d2162ef754 ]---
[   57.556539] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[   57.557145] SMP: stopping secondary CPUs
[   57.557498] Kernel Offset: disabled
[   57.557809] CPU features: 0x0240022,6100200c
[   57.558185] Memory Limit: none
[   57.558470] Rebooting in 20 seconds..
... and on the third boot it just seems to stall
DDR Version 1.24 20191016
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 323
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 80786
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
SoC: Rockchip rk3399
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
238 bytes read in 4 ms (57.6 KiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
Starting kernel ...
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001510] Console: colour dummy device 80x25
[    0.001654] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001680] pid_max: default: 32768 minimum: 301
[    0.001850] LSM: Security Framework initializing
[    0.001896] Yama: becoming mindful.
[    0.002047] AppArmor: AppArmor initialized
[    0.002155] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002192] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005910] rcu: Hierarchical SRCU implementation.
[    0.007107] Platform MSI: interrupt-controller@fee20000 domain created
[    0.007765] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.010310] EFI services will not be available.
[    0.011034] smp: Bringing up secondary CPUs ...
[    0.012213] Detected VIPT I-cache on CPU1
[    0.012263] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012283] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000
[    0.012360] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013783] Detected VIPT I-cache on CPU2
[    0.013833] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013852] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000
[    0.013928] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015378] Detected VIPT I-cache on CPU3
[    0.015428] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015448] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000
[    0.015524] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016954] CPU features: detected: Spectre-v2
[    0.016961] CPU features: detected: Spectre-v4
[    0.016966] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.016974] Detected PIPT I-cache on CPU4
[    0.017011] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.017026] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000
[    0.017074] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018346] Detected PIPT I-cache on CPU5
[    0.018384] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018400] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000
[    0.018450] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.018635] smp: Brought up 1 node, 6 CPUs
[    0.018746] SMP: Total of 6 processors activated.
[    0.018762] CPU features: detected: 32-bit EL0 Support
[    0.018776] CPU features: detected: CRC32 instructions
[    0.018791] CPU features: detected: 32-bit EL1 Support
[    0.045624] CPU: All CPU(s) started at EL2
[    0.045707] alternatives: patching kernel code
[    0.049499] devtmpfs: initialized
[    0.066204] Registered cp15_barrier emulation handler
[    0.066234] Registered setend emulation handler
[    0.066477] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066554] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069568] pinctrl core: initialized pinctrl subsystem
[    0.070247] D2-0:1.0: USB hub found
[    2.957870] hub 2-0:1.0: 1 port detected
[    2.959913] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.960419] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    2.961265] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[    2.962175] xhci-hcd xhci-hcd.0.auto: irq 76, io mem 0xfe900000
[    2.963100] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.963830] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.964466] usb usb3: Product: xHCI Host Controller
[    2.964900] usb usb3: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[    2.965469] usb usb3: SerialNumber: xhci-hcd.0.auto
[    2.966487] hub 3-0:1.0: USB hub found
[    2.966869] hub 3-0:1.0: 1 port detected
[    2.967560] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.968056] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    2.968738] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.969391] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.970265] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.970996] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.971633] usb usb4: Product: xHCI Host Controller
[    2.972066] usb usb4: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[    2.972635] usb usb4: SerialNumber: xhci-hcd.0.auto
[    2.973580] hub 4-0:1.0: USB hub found
[    2.974003] hub 4-0:1.0: 1 port detected
[    2.974836] usbcore: registered new interface driver usb-storage
[    2.978117] mousedev: PS/2 mouse device common for all mice
[    2.980064] i2c /dev entries driver
[    2.984484] pca953x 2-0020: using no AI
[    2.995428] rk808 0-001b: chip id: 0x0
[    2.999647] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.000219] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.000770] rk808-regulator rk808-regulator: max buck steps per change: 4
[    3.002536] vdd_center: supplied by vcc5v0_sys
[    3.003588] vdd_cpu_l: supplied by vcc5v0_sys
[    3.004323] vcc_ddr_s3: supplied by vcc5v0_sys
[    3.005379] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    3.006510] vcc1v8_dvp: supplied by vcc5v0_sys
[    3.007397] vcc3v0_touch: supplied by vcc5v0_sys
[    3.009146] vcc1v8_s3: supplied by vcc5v0_sys
[    3.009815] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    3.011556] vcc_sdio_s0: supplied by vcc5v0_sys
[    3.012466] vcca3v0_codec: supplied by vcc5v0_sys
[    3.014090] vcc1v5_s3: supplied by vcc5v0_sys
[    3.014999] vcca1v8_codec: supplied by vcc5v0_sys
[    3.016611] vcc3v0_s3: supplied by vcc5v0_sys
[    3.017147] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    3.017777] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    3.018817] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    3.022936] rk808-rtc rk808-rtc: registered as rtc0
[    3.023935] rk808-rtc rk808-rtc: setting system clock to 2021-03-10T11:09:07 UTC (1615374547)
[    3.027822] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.029682] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    3.030291] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    3.030842] vdd_cpu_b: supplied by vcc5v0_sys
[    3.034236] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.036109] vdd_gpu: supplied by vcc5v0_sys
[    3.044188] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    3.046848] sdhci: Secure Digital Host Controller Interface driver
[    3.047398] sdhci: Copyright(c) Pierre Ossman
[    3.047819] Synopsys Designware Multimedia Card Interface Driver
[    3.049711] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.050178] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    3.050859] dwmmc_rockchip fe320000.mmc: Using internal
                                                          [    3.283567] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.285827] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.286333] mmc1: tuning execution failed: -5
[    3.287194] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.287787] pci_bus 0000:00: root bus resource [bus 00-1f]
[    3.288278] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    3.288889] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address
    [    3.297220] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.298195] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    3.298791] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.299414] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    3.299921] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    3.300542] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    3.301050] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    3.301673] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    3.302195] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.302862] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    3.303547] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    3.304056] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    3.304678] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    3.305187] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    3.305769] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    3.306411] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    3.307379] pci 0000:01:00.0: PME# supported from D3hot
[    3.308083] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    3.314563] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.315046] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    3.315982] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    3.316598] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    3.317240] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    3.317853] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    3.318423] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    3.319010] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    3.319564] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    3.320148] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    3.320703] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    3.321287] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    3.321840] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    3.322438] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    3.322992] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    3.323581] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.324028] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    3.324861] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.325712] pcieport 0000:00:00.0: PME: Signaling with IRQ 90
[    3.326615] pcieport 0000:00:00.0: AER: enabled with IRQ 90
[    3.327448] ahci 0000:01:00.0: version 3.0
[    3.327836] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    3.328969] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    3.329647] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    3.330401] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    3.334988] scsi host0: ahci
[    3.336065] scsi host1: ahci
[    3.336948] scsi host2: ahci
[    3.337820] scsi host3: ahci
[    3.338683] scsi host4: ahci
[    3.339168] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91
[    3.339825] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92
[    3.340479] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93
[    3.341131] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 94
[    3.341784] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 95
[    3.350496] input: gpio-keys as /devices/platform/gpio-keys/input/input0
        [    3.578059] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.727113] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.727838] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.728469] usb 4-1: Product: USB3.0 Hub
[    3.728919] usb 4-1: Manufacturer: VIA Labs, Inc.
[    3.753658] hub 4-1:1.0: USB hub found
[    3.754123] hub 4-1:1.0: 4 ports detected
[    4.409995] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.431009] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    4.431748] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.432394] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
[    4.432851] usb 4-1.4: Manufacturer: Realtek
[    4.433233] usb 4-1.4: SerialNumber: 000000001
[   11.853950] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   11.922007] ata1.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   11.922615] ata1.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   11.933432] ata1.00: configured for UDMA/133
[   11.934539] scsi 0:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   11.936688] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   11.937389] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   11.937983] sd 0:0:0:0: [sda] Write Protect is off
[   11.938423] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   11.939043] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   11.987321]  sda: sda1 sda9
[   11.990547] sd 0:0:0:0: [sda] Attached SCSI disk
[   12.589949] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   12.668155] ata2.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   12.668762] ata2.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   12.679512] ata2.00: configured for UDMA/133
[   12.680364] scsi 1:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   12.682276] sd 1:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   12.682978] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[   12.683511] sd 1:0:0:0: [sdb] Write Protect is off
[   12.683948] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[   12.684514] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.729676]  sdb: sdb1 sdb9
[   12.732877] sd 1:0:0:0: [sdb] Attached SCSI disk
[   13.277925] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.295051] ata3.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.295656] ata3.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.306397] ata3.00: configured for UDMA/133
[   13.307127] scsi 2:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.309006] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.309714] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[   13.310341] sd 2:0:0:0: [sdc] Write Protect is off
[   13.310781] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   13.311348] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.351995]  sdc: sdc1 sdc9
[   13.355265] sd 2:0:0:0: [sdc] Attached SCSI disk
[   13.901923] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.926228] ata4.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.926830] ata4.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.937473] ata4.00: configured for UDMA/133
[   13.938216] scsi 3:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.940100] sd 3:0:0:0: [sdd] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.940808] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[   13.941341] sd 3:0:0:0: [sdd] Write Protect is off
[   13.941779] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[   13.942390] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.990947]  sdd: sdd1 sdd9
[   13.994199] sd 3:0:0:0: [sdd] Attached SCSI disk
[   14.252646] ata5: SATA link down (SStatus 0 SControl 300)
[   14.256173] Freeing unused kernel memory: 4352K
[   14.256747] Run /init as init process
[   14.257083]   with arguments:
[   14.257354]     /init
[   14.257564]     earlyprintk
[   14.257818]   with environment:
[   14.258145]     HOME=/
[   14.258364]     TERM=linux
[   14.258613]     ubootpart=559a8d18-01
[   14.258942]     cgroup_enable=memory
[   14.259265]     cgroup_memory=1
[   14.900381] input: adc-keys as /devices/platform/adc-keys/input/input1
[   15.003286] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   15.004379] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   15.005332] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   15.007096] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   15.007928] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   15.008436] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[   15.008949] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   15.009864] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   15.010687] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   15.016265] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   15.022033] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   15.022681] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   15.023150] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[   15.023810] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[   15.024470] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   15.024935] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   15.025556] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   15.026449] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   15.026979] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   15.027497] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   15.191982] libphy: stmmac: probed
[   15.192344] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   15.193457] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Begin: Loading essential drivers ... [   15.485606] async_tx: api initialized (async)
done.
[   15.769808] random: crng init done
done.
/dev/mmcblk1p1: recovering journal
/dev/mmcblk1p1: clean, 103923/2212736 files, 755762/7709728 blocks
done.
[   16.184263] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
done.
done.
[   17.149143] systemd[1]: Inserted module 'autofs4'
[   17.216889] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   17.219720] systemd[1]: Detected architecture arm64.
[   17.256687] systemd[1]: Set hostname to <helios64-archive.home>.
[   18.404002] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[   18.424391] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[   18.427437] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[   18.555155] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
[   18.689868] systemd[1]: Listening on Journal Socket.
[   18.709509] systemd[1]: Mounting POSIX Message Queue File System...
[   18.740337] systemd[1]: Listening on RPCbind Server Activation Socket.
[   18.865080] lm75 2-004c: supply vs not found, using dummy regulator
[   18.866397] lm75 2-004c: hwmon4: sensor 'lm75'
[   19.015582] RPC: Registered named UNIX socket transport module.
[   19.016118] RPC: Registered udp transport module.
[   19.016536] RPC: Registered tcp transport module.
[   19.016954] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   19.156151] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[   19.228327] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   20.154137] input: beeper as /devices/platform/beeper/input/input2
[   20.258596] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   20.263487] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   20.263961] mc: Linux media interface: v0.10
[   20.264239] sd 2:0:0:0: Attached scsi generic sg2 type 0
[   20.267927] sd 3:0:0:0: Attached scsi generic sg3 type 0
[   20.298775] videodev: Linux video capture interface: v2.00
[   20.371121] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   20.384165] panfrost ff9a0000.gpu: clock rate = 500000000
[   20.397581] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   20.401483] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   20.403165] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   20.403692] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 5
[   20.403887] rockchip-vop ff900000.vop: Adding to iommu group 3
[   20.404648] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[   20.405778] xhci-hcd xhci-hcd.2.auto: irq 75, io mem 0xfe800000
[   20.406779] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   20.407516] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.408152] usb usb5: Product: xHCI Host Controller
[   20.408583] usb usb5: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.409149] usb usb5: SerialNumber: xhci-hcd.2.auto
[   20.410203] hub 5-0:1.0: USB hub found
[   20.410592] hub 5-0:1.0: 1 port detected
[   20.411301] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   20.411802] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6
[   20.412484] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   20.413351] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   20.414077] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   20.414840] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   20.418176] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   20.419048] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   20.419788] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.420428] usb usb6: Product: xHCI Host Controller
[   20.420893] usb usb6: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.421237] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   20.421475] usb usb6: SerialNumber: xhci-hcd.2.auto
[   20.422853] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   20.423381] hub 6-0:1.0: USB hub found
[   20.423829] hub 6-0:1.0: 1 port detected
[   20.425305] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   20.429554] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   20.436234] [drm] unsupported AFBC format[3231564e]
[   20.438158] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[   20.443914] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   20.446204] rkvdec ff660000.video-codec: Adding to iommu group 1
[   20.447586] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   20.448880] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[   20.451691] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   20.453981] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   20.455780] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[   20.457419] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[   20.461833] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   20.462985] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   20.464177] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   20.698771] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   20.762342] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[   20.874216] spl: loading out-of-tree module taints kernel.
[   20.874220] spl: loading out-of-tree module taints kernel.
[   20.874624] spl: module verification failed: signature and/or required key missing - tainting kernel
[   20.897633] icp: module license 'CDDL' taints kernel.
[   20.897637] icp: module license 'CDDL' taints kernel.
[   20.897641] icp: module license 'CDDL' taints kernel.
[   20.897657] Disabling lock debugging due to kernel taint
[   20.898373] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   20.914133] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
[   20.914604] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
[   20.914604]          US6,570,884, US6,115,776, and US6,327,625.
[   20.914604]
[   20.916166] usbcore: registered new interface driver r8152
[   20.953724] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   21.318101] ZFS: Loaded module v2.0.1-1, ZFS pool version 5000, ZFS filesystem version 5
[   21.473993] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   21.850423] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[**    ] (1 of 2) A start job is running for…ols by cache file (14s / no limit)
[   ***] (2 of 2) A start job is running for… to be Configured (33s / no limit)
[   52.743958] systemd[1]: Reached target ZFS pool import target.
[   52.765037] systemd[1]: Starting Mount ZFS filesystems...
[   52.787636] systemd[1]: Starting Wait for ZFS Volume (zvol) links in /dev...
[   52.874927] systemd[1]: Started Wait for ZFS Volume (zvol) links in /dev.
[   52.887118] systemd[1]: Reached target ZFS volumes are ready.
[   53.003514] systemd[1]: Started Mount ZFS filesystems.
[   53.006792] systemd[1]: Reached target Local File Systems.
[   53.018269] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   53.027450] systemd[1]: Starting Cleanup monit state file...
[   53.355173] zram: Added device: zram0
[   53.356163] zram: Added device: zram1
[   53.357036] zram: Added device: zram2
[   53.480829] zram0: detected capacity change from 0 to 1991770112
[   53.554028] Adding 1945084k swap on /dev/zram0.  Priority:5 extents:1 across:1945084k SSFS
[  113.557886] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[  113.558444] rcu:     0-...0: (1 GPs behind) idle=376/1/0x4000000000000000 softirq=2672/2673 fqs=7501
[  113.559235] rcu:     5-...0: (0 ticks this GP) idle=476/1/0x4000000000000000 softirq=4866/4866 fqs=7501
[  113.560046]  (detected by 3, t=15002 jiffies, g=3093, q=116)
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 80005
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xe5b60
RunBL31 0x40000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Mar 08 2021 - 14:54:58 +0000)
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 1:1...
15761964 bytes read in 671 ms (22.4 MiB/s)
28582400 bytes read in 1211 ms (22.5 MiB/s)
81913 bytes read in 13 ms (6 MiB/s)
2698 bytes read in 7 ms (376 KiB/s)
Moving Image from 0x2080000 to 0x2200000, end=3de0000
   Image Name:   uInitrd
   Data Size:    15761900 Bytes = 15 MiB
   Loading Ramdisk to f4fe7000, end f5eef1ec ... OK
   Loading Device Tree to 00000000f4f6a000, end 00000000f4fe6fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.21-rockchip64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021
[    0.000000] Machine model: Helios64
[    0.000000] printk: debug: ignoring loglevel setting.
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 11776 pages used for memmap
[    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072
[    0.000000] pcpu-alloc: s94040 r8192 d28840 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=c559a861-be25-4b41-a161-d0c3d75c0089 rootwait rootfstype=ext4 console=ttyS2,1500000  consoleblank=0 loglevel=7 ubootpart=559a8d18-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[    0.000000] Memory: 3739356K/4061184K available (14848K kernel code, 2632K rwdata, 5972K rodata, 4352K init, 580K bss, 190756K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000400d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001517] Console: colour dummy device 80x25
[    0.001661] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001687] pid_max: default: 32768 minimum: 301
[    0.001856] LSM: Security Framework initializing
[    0.001903] Yama: becoming mindful.
[    0.002053] AppArmor: AppArmor initialized
[    0.002160] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002197] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005911] rcu: Hierarchical SRCU implementation.
[    0.007101] Platform MSI: interrupt-controller@fee20000 domain created
[    0.007768] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.010320] EFI services will not be available.
[    0.011043] smp: Bringing up secondary CPUs ...
[    0.012224] Detected VIPT I-cache on CPU1
[    0.012274] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.012294] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000
[    0.012372] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.013801] Detected VIPT I-cache on CPU2
[    0.013850] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.013871] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000
[    0.013947] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.015402] Detected VIPT I-cache on CPU3
[    0.015449] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.015470] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000
[    0.015545] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.016973] CPU features: detected: Spectre-v2
[    0.016980] CPU features: detected: Spectre-v4
[    0.016985] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.016993] Detected PIPT I-cache on CPU4
[    0.017031] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.017046] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000
[    0.017094] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.018360] Detected PIPT I-cache on CPU5
[    0.018400] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.018416] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000
[    0.018465] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.018650] smp: Brought up 1 node, 6 CPUs
[    0.018762] SMP: Total of 6 processors activated.
[    0.018777] CPU features: detected: 32-bit EL0 Support
[    0.018792] CPU features: detected: CRC32 instructions
[    0.018806] CPU features: detected: 32-bit EL1 Support
[    0.045593] CPU: All CPU(s) started at EL2
[    0.045675] alternatives: patching kernel code
[    0.049465] devtmpfs: initialized
[    0.066186] Registered cp15_barrier emulation handler
[    0.066216] Registered setend emulation handler
[    0.066458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066538] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069546] pinctrl core: initialized pinctrl subsystem
[    0.070223] Dsb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.964384] usb usb3: Product: xHCI Host Controller
[    2.964820] usb usb3: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[    2.965389] usb usb3: SerialNumber: xhci-hcd.0.auto
[    2.966403] hub 3-0:1.0: USB hub found
[    2.966784] hub 3-0:1.0: 1 port detected
[    2.967479] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.967976] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    2.968660] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.969313] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.970187] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.970917] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.971554] usb usb4: Product: xHCI Host Controller
[    2.971988] usb usb4: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[    2.972557] usb usb4: SerialNumber: xhci-hcd.0.auto
[    2.973497] hub 4-0:1.0: USB hub found
[    2.973920] hub 4-0:1.0: 1 port detected
[    2.974750] usbcore: registered new interface driver usb-storage
[    2.978030] mousedev: PS/2 mouse device common for all mice
[    2.979975] i2c /dev entries driver
[    2.984412] pca953x 2-0020: using no AI
[    2.995830] rk808 0-001b: chip id: 0x0
[    3.000520] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.001092] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.001643] rk808-regulator rk808-regulator: max buck steps per change: 4
[    3.003427] vdd_center: supplied by vcc5v0_sys
[    3.004477] vdd_cpu_l: supplied by vcc5v0_sys
[    3.005211] vcc_ddr_s3: supplied by vcc5v0_sys
[    3.006267] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    3.007357] vcc1v8_dvp: supplied by vcc5v0_sys
[    3.008238] vcc3v0_touch: supplied by vcc5v0_sys
[    3.010021] vcc1v8_s3: supplied by vcc5v0_sys
[    3.010694] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    3.012414] vcc_sdio_s0: supplied by vcc5v0_sys
[    3.013321] vcca3v0_codec: supplied by vcc5v0_sys
[    3.014947] vcc1v5_s3: supplied by vcc5v0_sys
[    3.015858] vcca1v8_codec: supplied by vcc5v0_sys
[    3.017469] vcc3v0_s3: supplied by vcc5v0_sys
[    3.018030] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    3.018661] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    3.019675] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    3.023794] rk808-rtc rk808-rtc: registered as rtc0
[    3.024791] rk808-rtc rk808-rtc: setting system clock to 2021-03-10T11:15:15 UTC (1615374915)
[    3.028670] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.030739] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    3.031282] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    3.031812] vdd_cpu_b: supplied by vcc5v0_sys
[    3.035324] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.036374] random: fast init done
[    3.037778] vdd_gpu: supplied by vcc5v0_sys
[    3.045981] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    3.048546] sdhci: Secure Digital Host Controller Interface driver
[    3.049095] sdhci: Copyright(c) Pierre Ossman
[    3.049505] Synopsys Designware Multimedia Card Interface Driver
[    3.051430] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.052259] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    3.052922] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    3.053520] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    3.054164] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    3.055135] mmc2: CQHCI version 5.10
[    3.055707] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    3.056975] ledtrig-cpu: registered to indicate activity on CPUs
[    3.058740] hid: raw HID events driver (C) Jiri Kosina
[    3.059345] usbcore: registered new interface d
                                                  [    3.192879] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.228029] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.228684] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    3.229441] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    3.287121] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.287712] pci_bus 0000:00: root bus resource [bus 00-1f]
[    3.288202] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    3.288813] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    3.289701] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    3.290403] pci 0000:00:00.0: supports D1
[    3.290721] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.290771] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.292991] dwmmc_rockchip fe320000.mmc: All phases bad!
[    3.293471] mmc1: tuning execution failed: -5
[    3.298055] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.299002] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    3.299597] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.300222] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    3.300729] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    3.301352] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    3.301876] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    3.302498] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    3.303006] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    3.303628] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    3.304135] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    3.304756] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    3.305263] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    3.305858] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    3.306482] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    3.307450] pci 0000:01:00.0: PME# supported from D3hot
[    3.308152] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    3.309904] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    3.315842] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    3.316451] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    3.317067] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    3.317708] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    3.318336] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    3.318891] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    3.319475] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    3.320030] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    3.320614] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    3.321168] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    3.321721] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.321756] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    3.323127] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    3.323712] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    3.324267] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    3.324854] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.325301] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    3.326147] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.327007] pcieport 0000:00:00.0: PME: Signaling with IRQ 90
[    3.327856] pcieport 0000:00:00.0: AER: enabled with IRQ 90
[    3.328687] ahci 0000:01:00.0: version 3.0
[    3.329074] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    3.330234] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    3.330913] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    3.331638] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    3.335959] scsi host0: ahci
[    3.336910] scsi host1: ahci
[    3.337854] scsi host2: ahci
[    3.338687] scsi host3: ahci
[    3.339573] scsi host4: ahci
[    3.340057] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91
[    3.340714] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92
[    3.341369] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93
[    3.342048] ata4: SATA max UDMA/133
                                       [    3.513601] hub 3-1:1.0: USB hub found
[    3.514190] hub 3-1:1.0: 4 ports detected
[    3.608289] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.726486] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    3.727212] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.727842] usb 4-1: Product: USB3.0 Hub
[    3.728292] usb 4-1: Manufacturer: VIA Labs, Inc.
[    3.753637] hub 4-1:1.0: USB hub found
[    3.754130] hub 4-1:1.0: 4 ports detected
[    4.409939] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.430931] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    4.431670] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.432315] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
[    4.432772] usb 4-1.4: Manufacturer: Realtek
[    4.433154] usb 4-1.4: SerialNumber: 000000001
[   12.033876] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   12.102987] ata1.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   12.103595] ata1.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   12.114459] ata1.00: configured for UDMA/133
[   12.115497] scsi 0:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   12.117577] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   12.118310] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   12.118847] sd 0:0:0:0: [sda] Write Protect is off
[   12.119286] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   12.119852] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.168273]  sda: sda1 sda9
[   12.171544] sd 0:0:0:0: [sda] Attached SCSI disk
[   12.773854] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   12.849243] ata2.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   12.849874] ata2.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   12.860595] ata2.00: configured for UDMA/133
[   12.861606] scsi 1:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   12.863682] sd 1:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   12.864384] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[   12.864915] sd 1:0:0:0: [sdb] Write Protect is off
[   12.865353] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[   12.865953] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   12.910802]  sdb: sdb1 sdb9
[   12.914099] sd 1:0:0:0: [sdb] Attached SCSI disk
[   13.457848] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   13.477268] ata3.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   13.477890] ata3.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   13.488626] ata3.00: configured for UDMA/133
[   13.489590] scsi 2:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   13.491692] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   13.492395] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[   13.492929] sd 2:0:0:0: [sdc] Write Protect is off
[   13.493367] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   13.493973] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.534289]  sdc: sdc1 sdc9
[   13.537433] sd 2:0:0:0: [sdc] Attached SCSI disk
[   14.145848] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   14.197089] ata4.00: ATA-11: WDC  WUH721818ALE6L4, PCGNW120, max UDMA/133
[   14.197691] ata4.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 32), AA
[   14.208376] ata4.00: configured for UDMA/133
[   14.209318] scsi 3:0:0:0: Direct-Access     ATA      WDC  WUH721818AL W120 PQ: 0 ANSI: 5
[   14.211462] sd 3:0:0:0: [sdd] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[   14.212164] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[   14.212698] sd 3:0:0:0: [sdd] Write Protect is off
[   14.213136] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[   14.213701] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   14.264663]  sdd: sdd1 sdd9
[   14.267871] sd 3:0:0:0: [sdd] Attached SCSI disk
[   14.524271] ata5: SATA link down (SStatus 0 SControl 300)
[   14.527943] Freeing unused kernel memory: 4352K
[   14.528527] Run /init as init process
[   14.528863]   with arguments:
[   14.529133]     /init
[   14.529344]     earlyprintk
[   14.529598]   with environment:
[   14.529922]     HOME=/
[   14.530141]     TERM=linux
[   14.530390]     ubootpart=559a8d18-01
[   14.530720]     cgroup_enable=memory
[   14.531043]     cgroup_memory=1
Loading, please wait...
Starting version 241
[   15.185243] input: adc-keys as /devices/platform/adc-keys/input/input1
[   15.294972] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[   15.295582] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[   15.296350] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[   15.297271] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[   15.298121] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[   15.298638] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[   15.299256] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[   15.299944] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[   15.300566] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[   15.306141] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[   15.309331] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[   15.310003] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[   15.310471] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[   15.311133] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[   15.311793] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[   15.312443] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[   15.313070] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[   15.313747] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[   15.314304] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[   15.314824] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   15.446903] libphy: stmmac: probed
[   15.447235] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   15.448337] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Begin: Loading essential drivers ... [   15.727437] async_tx: api initialized (async)
done.
[   16.021782] random: crng init done
done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
done.
[   16.495945] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... /scripts/local-bottom/mdadm: 2: /scripts/local-bottom/mdadm: rm: not found
done.
[   17.460924] systemd[1]: Inserted module 'autofs4'
[   17.528411] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   17.531308] systemd[1]: Detected architecture arm64.
Welcome to Armbian 21.02.3 Buster!
[   17.580730] systemd[1]: Set hostname to <helios64-archive.home>.
[   18.730163] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[   18.749925] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[   18.752922] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[   18.879402] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
[   19.018564] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   19.030525] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[   19.041994] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
         Starting Availability of block devices...
         Starting Load Kernel Modules...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on Device-mapper event daemon FIFOs.
[   19.110178] lm75 2-004c: supply vs not found, using dummy regulator
[   19.111435] lm75 2-004c: hwmon4: sensor 'lm75'
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Reached target Slices.
         Mounting RPC Pipe File System...
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Listening on udev Kernel Socket.
         Starting udev Coldplug all Devices...
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
         Starting Nameserver information manager...
         Starting Create list of re…odes for the current kernel...
[  OK  ] Listening on RPCbind Server Activation Socket.
[   19.296618] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[   19.312410] RPC: Registered named UNIX socket transport module.
[   19.312944] RPC: Registered udp transport module.
[   19.313364] RPC: Registered tcp transport module.
[   19.313782] RPC: Registered tcp NFSv4.1 backchannel transport module.
         Mounting Huge Pages File System...
         Mounting Kernel Debug File System...
[  OK  ] Listening on LVM2 poll daemon socket.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Journal Socket (/dev/log).
         Mounting NFSD configuration filesystem...
         Starting Monitoring of LVM…meventd or progress polling...
         Starting Set the console keyboard layout...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Availability of block devices.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted RPC Pipe File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[   19.533238] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[  OK  ] Started Create list of req… nodes for the current kernel.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted NFSD configuration filesystem.
[  OK  ] Started Nameserver information manager.
         Starting Create System Users...
         Starting Load/Save Random Seed...
         Starting pNFS block layout mapping daemon...
         Starting Apply Kernel Variables...
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
[  OK  ] Started Monitoring of LVM2… dmeventd or progress polling.
[  OK  ] Started Create System Users.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started pNFS block layout mapping daemon.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting Mount /tmp as tmp…e access to the root device...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted Mount /tmp as tmpf…ite access to the root device.
[  OK  ] Started udev Coldplug all Devices.
         Starting udev Wait for Complete Device Initialization...
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Started Helper to synchronize boot up for ifupdown.
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Started Network Service.
[   20.452029] input: beeper as /devices/platform/beeper/input/input2
         Starting Wait for Network to be Configured...
[  OK  ] Found device /dev/ttyS2.
[   20.539827] mc: Linux media interface: v0.10
[   20.604619] videodev: Linux video capture interface: v2.00
[   20.623421] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   20.624357] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   20.625017] sd 2:0:0:0: Attached scsi generic sg2 type 0
[   20.628114] sd 3:0:0:0: Attached scsi generic sg3 type 0
[   20.671410] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   20.708721] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   20.713450] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   20.714185] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 5
[   20.715050] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010
[   20.715899] xhci-hcd xhci-hcd.2.auto: irq 75, io mem 0xfe800000
[   20.716810] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   20.717544] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.717568] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   20.718203] usb usb5: Product: xHCI Host Controller
[   20.719512] usb usb5: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.720080] usb usb5: SerialNumber: xhci-hcd.2.auto
[   20.723500] rkvdec ff660000.video-codec: Adding to iommu group 1
[   20.725331] hub 5-0:1.0: USB hub found
[   20.725734] hub 5-0:1.0: 1 port detected
[   20.726603] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   20.727108] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6
[   20.727796] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   20.728463] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   20.729328] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   20.730090] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.730732] usb usb6: Product: xHCI Host Controller
[   20.731166] usb usb6: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd
[   20.731733] usb usb6: SerialNumber: xhci-hcd.2.auto
[   20.732809] hub 6-0:1.0: USB hub found
[   20.733192] hub 6-0:1.0: 1 port detected
[   20.742097] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   20.743232] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1
[   20.743798] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   20.747277] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   20.748720] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[   20.749003] panfrost ff9a0000.gpu: clock rate = 500000000
[   20.749724] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[   20.774574] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[   20.775924] rockchip-vop ff900000.vop: Adding to iommu group 3
[   20.775959] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   20.777127] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   20.777872] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   20.778905] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   20.783735] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
[   20.783861] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[   20.785373] [drm] unsupported AFBC format[3231564e]
[   20.787885] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[   20.789309] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[   20.790799] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   20.793044] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   20.806687] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   21.011893] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   21.180595] spl: loading out-of-tree module taints kernel.
[   21.180659] spl: loading out-of-tree module taints kernel.
[   21.180700] spl: loading out-of-tree module taints kernel.
[   21.181160] spl: module verification failed: signature and/or required key missing - tainting kernel
[   21.212030] icp: module license 'CDDL' taints kernel.
[   21.212040] icp: module license 'CDDL' taints kernel.
[   21.212048] Disabling lock debugging due to kernel taint
[   21.212052] icp: module license 'CDDL' taints kernel.
[   21.241681] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[   21.258289] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[   21.382398] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   21.398103] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
[   21.398604] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
[   21.398604]          US6,570,884, US6,115,776, and US6,327,625.
[   21.398604]
[   21.400354] usbcore: registered new interface driver r8152
[   21.635228] ZFS: Loaded module v2.0.1-1, ZFS pool version 5000, ZFS filesystem version 5
[  OK  ] Started udev Wait for Complete Device Initialization.
[   21.794104] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
         Starting Install ZFS kernel module...
[  OK  ] Started Install ZFS kernel module.
         Starting Import ZFS pools by cache file...
[   22.155366] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ ***  ] (2 of 2) A start job is running for…ols by cache file (14s / no limit)
[  *** ] (2 of 2) A start job is running for…ols by cache file (33s / no limit)
[  OK  ] Started Import ZFS pools by cache file.
[   53.391364] systemd[1]: Reached target ZFS pool import target.
[  OK  ] Reached target ZFS pool import target.
[   53.408588] systemd[1]: Starting Wait for ZFS Volume (zvol) links in /dev...
[   53.427907] systemd[1]: Starting Mount ZFS filesystems...
[   53.521953] systemd[1]: Started Wait for ZFS Volume (zvol) links in /dev.
[  OK  ] Started Wait for ZFS Volume (zvol) links in /dev.
[   53.540313] systemd[1]: Reached target ZFS volumes are ready.
[  OK  ] Reached target ZFS volumes are ready.
[   53.652099] systemd[1]: Started Mount ZFS filesystems.
[  OK  ] Started Mount ZFS filesystems.
[   53.654143] systemd[1]: Reached target Local File Systems.
[  OK  ] Reached target Local File Systems.
[   53.670421] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
[   53.675998] systemd[1]: Starting Preprocess NFS configuration...
         Starting Raise network interfaces...
         Starting folder2ram systemd service...
         Starting Set console font and keymap...
         Starting Cleanup PHP session files...
         Starting Armbian ZRAM config...
[  OK  ] Started Preprocess NFS configuration.
[  OK  ] Started Set console font and keymap.
[  113.817813] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[  113.818374] rcu:     2-...!: (0 ticks this GP) idle=d12/1/0x4000000000000000 softirq=2636/2636 fqs=1
[  113.819160]  (detected by 0, t=15002 jiffies, g=2893, q=591)
Kernel panic a few minutes after reboot on 21.02.3...
[   30.777027] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: sched_rr_get_interval+0x118/0x118
[   30.777989] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P         C OE     5.10.21-rockchip64 #21.02.3
[   30.778764] Hardware name: Helios64 (DT)
[   30.779112] Call trace:
[   30.779338]  dump_backtrace+0x0/0x200
[   30.779667]  show_stack+0x18/0x68
[   30.779966]  dump_stack+0xcc/0x124
[   30.780270]  panic+0x174/0x374
[   30.780546]  __stack_chk_fail+0x3c/0x40
[   30.780888]  update_rq_clock+0x0/0x108
[   30.781225]  flush_smp_call_function_queue+0x114/0x250
[   30.781681]  generic_smp_call_function_single_interrupt+0x14/0x20
[   30.782221]  ipi_handler+0x7c/0x370
[   30.782535]  handle_percpu_devid_fasteoi_ipi+0x9c/0x1f0
[   30.782996]  generic_handle_irq+0x30/0x48
[   30.783352]  __handle_domain_irq+0x94/0x108
[   30.783727]  gic_handle_irq+0xc0/0x140
[   30.784061]  el1_irq+0xc0/0x180
[   30.784343]  arch_cpu_idle+0x18/0x28
[   30.784662]  default_idle_call+0x44/0x1bc
[   30.785018]  do_idle+0x204/0x278
[   30.785306]  cpu_startup_entry+0x28/0x60
[   30.785655]  secondary_start_kernel+0x170/0x180
[   30.786062] SMP: stopping secondary CPUs
[   30.786418] Kernel Offset: disabled
[   30.786728] CPU features: 0x0240022,6100200c
[   30.787105] Memory Limit: none
[   30.787389] Rebooting in 10 seconds..
Not a panic per-se, but system became unresponsive (unrecoverable) after a few minutes (ondemand governor) on 21.02.3:
[  665.047193] ------------[ cut here ]------------
[  665.047627] NETDEV WATCHDOG: eth0 (rk_gmac-dwmac): transmit queue 0 timed out
[  665.048340] WARNING: CPU: 1 PID: 0 at net/sched/sch_generic.c:443 dev_watchdog+0x398/0x3a0
[  665.049065] Modules linked in: xt_nat xt_tcpudp veth xt_conntrack xt_MASQUERADE nf_conntrack_netlink xfrm_user xfrm_algo nft_counter xt_addrtype nft_compat nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink br_netfilter bridge aufs rfkill governor_performance ledtrig_netdev snd_soc_hdmi_codec hantro_vpu(C) rockchipdrm rockchip_vdec(C) dw_mipi_dsi snd_soc_rockchip_i2s dw_hdmi v4l2_h264 snd_soc_core rockchip_rga videobuf2_dma_contig analogix_dp videobuf2_dma_sg v4l2_mem2mem drm_kms_helper videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 snd_pcm_dmaengine r8152 videobuf2_common snd_pcm cec videodev panfrost gpu_sched rc_core sg snd_timer drm fusb302 snd tcpm mc soundcore
typec leds_pwm drm_panel_orientation_quirks gpio_charger gpio_beeper cpufreq_dt nfsd auth_rpcgss nfs_acl lockd grace sunrpc lm75 ip_tables x_tables autofs4 zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) zcommon(POE) znvpair(POE) zavl(POE) icp(POE) spl(OE) algif_skcipher af_alg dm_crypt dm_mod
[  665.049475]  realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys pwm_fan
[  665.057690] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P         C OE     5.10.21-rockchip64 #21.02.3
[  665.058466] Hardware name: Helios64 (DT)
[  665.058818] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[  665.059350] pc : dev_watchdog+0x398/0x3a0
[  665.059709] lr : dev_watchdog+0x398/0x3a0
[  665.060065] sp : ffff800011bf3d50
[  665.060362] x29: ffff800011bf3d50 x28: ffff0000f5958940
[  665.060839] x27: 0000000000000004 x26: 0000000000000140
[  665.061316] x25: 00000000ffffffff x24: 0000000000000001
[  665.061792] x23: ffff8000118b7000 x22: ffff00004698841c
[  665.062269] x21: ffff000046988000 x20: ffff0000469884c0
[  665.062745] x19: 0000000000000000 x18: 0000000000000010
[  665.063222] x17: 0000000000000000 x16: 0000000000000000
[  665.063698] x15: 00000000000002e9 x14: ffff800011bf3a10
[  665.064175] x13: 00000000ffffffea x12: ffff80001194edf8
[  665.064651] x11: 0000000000000003 x10: ffff800011936db8
[  665.065128] x9 : ffff800011936e10 x8 : 0000000000017fe8
[  665.065604] x7 : c0000000ffffefff x6 : 0000000000000001
[  665.066080] x5 : 0000000000000001 x4 : 0000000000000000
[  665.066557] x3 : 0000000000000103 x2 : 0000000000000102
[  665.067033] x1 : 746b30e3f1235f00 x0 : 0000000000000000
[  665.067510] Call trace:
[  665.067734]  dev_watchdog+0x398/0x3a0
[  665.068067]  call_timer_fn+0x30/0x1f8
[  665.068396]  run_timer_softirq+0x290/0x540
[  665.068765]  efi_header_end+0x160/0x41c
[  665.069111]  irq_exit+0xb8/0xd8
[  665.069397]  __handle_domain_irq+0x98/0x108
[  665.069774]  gic_handle_irq+0xc0/0x140
[  665.070109]  el1_irq+0xc0/0x180
[  665.070395]  arch_cpu_idle+0x18/0x28
[  665.070717]  default_idle_call+0x44/0x1bc
[  665.071077]  do_idle+0x204/0x278
[  665.071367]  cpu_startup_entry+0x28/0x60
[  665.071721]  secondary_start_kernel+0x170/0x180
[  665.072124] ---[ end trace 4f1c5437bbf32498 ]---
[  665.072614] rk_gmac-dwmac fe300000.ethernet eth0: Reset adapter.
[  691.610810] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[  691.611363] rcu:     4-...0: (1 GPs behind) idle=246/0/0x1 softirq=55018/55020 fqs=7313
[  691.612053]  (detected by 5, t=15002 jiffies, g=92545, q=2754)
The relevant part (for my issue) here seems to be "rcu: INFO: rcu_preempt detected stalls on CPUs/tasks". This has happened a lot on every 5.10-kernel, previously I only used performance governors but now it obviously happened on ondemand too. Upon reboot I could not even reach full system boot-up before it stalled, so I'm now back on 5.9.14 which only panics once every ~1-2 weeks but is otherwise stable.
Boot-time panic on 5.10.21-rockchip64 (21.02.3): Unable to handle kernel write to read-only memory at virtual address ffff8000100d3a54
[  OK  ] Started Flush Journal to Persistent Storage.
[  120.234882] Unable to handle kernel write to read-only memory at virtual address ffff8000100d3a54
[  120.235662] Mem abort info:
[  120.235912]   ESR = 0x9600004e
[  120.236186]   EC = 0x25: DABT (current EL), IL = 32 bits
[  120.236654]   SET = 0, FnV = 0
[  120.236926]   EA = 0, S1PTW = 0
[  120.237205] Data abort info:
[  120.237463]   ISV = 0, ISS = 0x0000004e
[  120.237802]   CM = 0, WnR = 1
[  120.238069] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000003669000
[  120.238657] [ffff8000100d3a54] pgd=00000000f7fff003, p4d=00000000f7fff003, pud=00000000f7ffe003, pmd=0040000002200781
[  120.239600] Internal error: Oops: 9600004e [#1] PREEMPT SMP
[  120.240093] Modules linked in: r8152 snd_soc_rockchip_i2s snd_soc_core snd_pcm_dmaengine snd_pcm fusb302 sg tcpm snd_timer typec snd gpio_charger soundcore leds_pwm gpio_beeper cpufreq_dt nfsd auth_rpcgss nfs_acl lockd grace lm75 sunrpc ip_tables x_tables autofs4 zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) zcommon(POE) znvpair(POE) zavl(POE) icp(POE) spl(OE) algif_skcipher af_alg dm_crypt dm_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys pwm_fan
[  120.243782] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P           OE     5.10.21-rockchip64 #21.02.3
[  120.244559] Hardware name: Helios64 (DT)
[  120.244910] pstate: 80000085 (Nzcv daIf -PAN -UAO -TCO BTYPE=--)
[  120.245448] pc : sched_clock+0x1c/0x90
[  120.245784] lr : sched_clock_cpu+0x14/0x30
[  120.246145] sp : ffff800011c13de0
[  120.246440] x29: ffff800011c13eb8 x28: ffff000040311d00
[  120.246914] x27: ffff000040004300 x26: ffff800011cf3de0
[  120.247387] x25: 0000000000000001 x24: 0000000000000000
[  120.247860] x23: 0000000000000000 x22: ffff8000100d42f4
[  120.248333] x21: ffff8000118b9948 x20: ffff0000f77c7d00
[  120.248805] x19: ffff0000f77c7d00 x18: 0000000000000000
[  120.249278] x17: 0000000000000000 x16: 0000000000000000
[  120.249750] x15: 0000000000000000 x14: 00000000000002db
[  120.250222] x13: 0000000000000010 x12: 0000000000000001
[  120.250696] x11: 0000000000000040 x10: ffff80001194ef28
[  120.251168] x9 : ffff80001194ef20 x8 : ffff000040400270
[  120.251640] x7 : 0000000000000000 x6 : 0000000000000000
[  120.252113] x5 : ffff000040400248 x4 : ffff8000e6248000
[  120.252585] x3 : 0000000000000000 x2 : 0000000000000001
[  120.253057] x1 : 0000000000000004 x0 : 0000000000000005
[  120.253530] Call trace:
[  120.253752]  sched_clock+0x1c/0x90
[  120.254060] Code: a9025bf5 d000c056 912302d6 a90363f7 (910022d7)
[  120.254606] ---[ end trace 45509e5a34da5642 ]---
[  120.255014] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[  120.255620] SMP: stopping secondary CPUs
[  120.255974] Kernel Offset: disabled
[  120.256285] CPU features: 0x0240022,6100200c
[  120.256662] Memory Limit: none
[  120.256946] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
