oneo Posted March 1, 2021 Posted March 1, 2021 Hey there, so I was curious is there an easier way to make microSD take precedence in the boot order then having to futz with jumpers? Wanting to try out a new distro on microSD before deciding to make the switch and flash it to eMMC. If I do futz with jumpers I'll still be able to mount and write to the eMMC correct? 1
aprayoga Posted March 2, 2021 Posted March 2, 2021 The bootloader (u-boot) is configured to try loading OS from SD card first, then if it failed, it will try internal eMMC. On 3/1/2021 at 11:05 PM, oneo said: If I do futz with jumpers I'll still be able to mount and write to the eMMC correct? Expand You need to remove the jumper just before Linux initialized, otherwise the eMMC would not be detected. More info on our wiki.
SIGSEGV Posted March 2, 2021 Posted March 2, 2021 On 3/1/2021 at 11:05 PM, oneo said: Hey there, so I was curious is there an easier way to make microSD take precedence in the boot order then having to futz with jumpers? Wanting to try out a new distro on microSD before deciding to make the switch and flash it to eMMC. If I do futz with jumpers I'll still be able to mount and write to the eMMC correct? Expand @oneo - what distro are you trying out?
oneo Posted March 7, 2021 Author Posted March 7, 2021 On 3/2/2021 at 8:25 PM, SIGSEGV said: @oneo - what distro are you trying out? Expand Trying out nixOS, it's what I use for most my home infrastructure.
oneo Posted March 7, 2021 Author Posted March 7, 2021 On 3/2/2021 at 5:05 AM, aprayoga said: The bootloader (u-boot) is configured to try loading OS from SD card first, then if it failed, it will try internal eMMC. You need to remove the jumper just before Linux initialized, otherwise the eMMC would not be detected. More info on our wiki. Expand Hmm, guess it must be failing then. I'll need to check via my serial cable because it skipped right to eMMC.
