Tinkerboard Buster Minimal dpkg-reconfigure : command not found
Go to solution Solved by Werner,
Armbianmonitor:
On a fresh Buster Minimal install, what is required to get armbian-config fully functional?
apt install armbian-config 'works' but some functions don't, for instance it fails setting the locale as dpkg-reconfigure errors as
usr/lib/armbian-config/jobs.sh line 839 dpkg-reconfigure : command not found
EDIT:
In armbian-config I selected 'full firmware package' and rebooted, time zone settings now work.
Was odd that the welcome page said run armbian-config (beta) but it had to be installed manually via apt.
Is the debconf package installed?
If not this should be added to minimal package list.
Or better make armbian-config depend on it.
Probably better, yes. Minimal image should stay as minimal as possible.
fresh download just now of minimal image.
debconf is present.
still no armbian-config until
during install
not found 151.101.6.132
failed to fetch http://deb.debian.org/debian/pool/main/u/unzip/unzip_6.0-23+deb10u1_armhf.deb 404 not found 151.101.6.132
couldn't get a wired or wireless connection to do armbianmonitor -u
second time pretty much the same
downloaded again and burned image
debconf is present
no armbian config
nmtui to set network
armbian-config install fails
sudo apt update
sudo apt upgrade
N: InRelease changed version from 10.7 to 10.8
apt install armbian-config  works
armbianmonitor -u states there is a network problem
armbian-config runs and is able to forget and then activate again wifi
can ping yahoo.com but armbianmonitor -u reports network error
@Wernerplease educate me on how to properly test your fix. I am coming up fast but haven't done that yet... but I do have a build system running.
  • Solution
1 hour ago, Technicavolous said:
debconf is present.
good.
also good. Its minimal so even this is not included by default
Not our issue. Seems like the Debian mirror has issues. Simply retry later.
13 hours ago, Technicavolous said:
Makes sense but I'm spoiled by armbian-config and *assumed* it would be there. Maybe a note on the download page that it really IS minimal lol
Thanks!
