Problems with SATA to USB-Adapters
nicklasfrahm
Hello Armbian Kernel Team,
I own a Cubietruck (CB3) and I wanted to setup a fresh debian server system. So I installed Armbian 5.14 (Debian Jessie) on my SD Card and booted the system up. Everything was working as expected, but I have special needs regarding the usage of my filesystems and storage devices.
My desired configuration is (previously working under Armbian Wheezy):
Cubietruck NAND
-> /dev/nand1 (32 MB) = boot partition
-> /dev/nand2 (max) = some data or maybe swap
60 GB SATA Drive (2,5") via SATA to USB adapter
-> /dev/sdb1 (5 GB) = root filesystem
-> /dev/sdb2 (55 GB) = some data
1 TB SATA Drive (3,5") via native SATA port on cubie with additional 12 V power supply
-> /dev/sda1 (1 TB) = important data
So I started the nand-sata-install script and it ran through perfectly, but when wanted to boot up the system again, I received an error message saying that the init system could not be found and it recommended to use the init bootparam.
But in order to exclude errors of my hardware I used the nand-sata-install script to test certain scenarios.
1) working
BOOT: nand1
ROOT: nand2
2) working
BOOT: nand1
ROOT: 60 GB (via SATA)
3) not working
BOOT: nand1
ROOT: 60 GB (via USB to SATA Adapter)
I started the big googling and came up with this article:
http://www.cubieforums.com/index.php?topic=1552.0
It is basically about the kernel module CONFIG_USB_STORAGE, which seems to be disabled and could cause the problem.
How can I get my desired configuration to work again?
Best regards
Nicklas
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
Here the output:
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/fNYc
Please post the URL in the Armbian forum where you've been asked for.
CONFIG_USB_IRDA=m
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIBFUSB=m
# CONFIG_USB_SWITCH_FSA9480 is not set
# USB Network Adapters
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_QF9700=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
# CONFIG_USB_NET_GL620A is not set
# CONFIG_USB_NET_NET1080 is not set
# CONFIG_USB_NET_PLUSB is not set
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_NET_INT51X1=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_USB_VL600=m
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_AT76C50X_USB=m
CONFIG_USB_ZD1201=m
CONFIG_USB_NET_RNDIS_WLAN=m
CONFIG_ATH6KL_USB=m
CONFIG_BRCMFMAC_USB=y
CONFIG_LIBERTAS_USB=m
CONFIG_P54_USB=m
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
CONFIG_RT2800USB_RT35XX=y
CONFIG_RT2800USB_RT53XX=y
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2X00_LIB_USB=m
CONFIG_WIMAX_I2400M_USB=m
CONFIG_MOUSE_SYNAPTICS_USB=m
CONFIG_TABLET_USB_ACECAD=m
CONFIG_TABLET_USB_AIPTEK=m
CONFIG_TABLET_USB_GTCO=m
CONFIG_TABLET_USB_HANWANG=m
CONFIG_TABLET_USB_KBTAB=m
CONFIG_TABLET_USB_WACOM=m
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_USB_JASTEC=y
CONFIG_TOUCHSCREEN_USB_ELO=y
CONFIG_TOUCHSCREEN_USB_E2I=y
CONFIG_TOUCHSCREEN_USB_ZYTRONIC=y
CONFIG_TOUCHSCREEN_USB_ETT_TC45USB=y
CONFIG_TOUCHSCREEN_USB_NEXIO=y
CONFIG_TOUCHSCREEN_USB_EASYTOUCH=y
# CONFIG_I2C_TINY_USB is not set
# USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_IR_MCEUSB=m
CONFIG_V4L_USB_DRIVERS=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SPCA1528=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_SQ930X=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
CONFIG_USB_GSPCA_XIRLINK_CIT=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_VIDEO_PVRUSB2=m
CONFIG_VIDEO_PVRUSB2_SYSFS=y
CONFIG_VIDEO_PVRUSB2_DVB=y
# CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
CONFIG_VIDEO_USBVISION=m
CONFIG_USB_ET61X251=m
CONFIG_USB_SN9C102=m
CONFIG_USB_PWC=m
# CONFIG_USB_PWC_DEBUG is not set
CONFIG_USB_PWC_INPUT_EVDEV=y
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
CONFIG_USB_SI470X=m
CONFIG_USB_MR800=m
CONFIG_USB_DSBR=m
CONFIG_USB_KEENE=m
# Supported USB Adapters
CONFIG_DVB_USB=m
# CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
CONFIG_DVB_USB_DIBUSB_MB_FAULTY=y
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_DIB0700=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
CONFIG_DVB_USB_M920X=m
CONFIG_DVB_USB_GL861=m
CONFIG_DVB_USB_AU6610=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_TTUSB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_USB_OPERA1=m
CONFIG_DVB_USB_AF9005=m
CONFIG_DVB_USB_AF9005_REMOTE=m
CONFIG_DVB_USB_PCTV452E=m
CONFIG_DVB_USB_DW2102=m
CONFIG_DVB_USB_CINERGY_T2=m
CONFIG_DVB_USB_ANYSEE=m
CONFIG_DVB_USB_DTV5100=m
CONFIG_DVB_USB_AF9015=m
CONFIG_DVB_USB_CE6230=m
CONFIG_DVB_USB_FRIIO=m
CONFIG_DVB_USB_EC168=m
CONFIG_DVB_USB_AZ6007=m
CONFIG_DVB_USB_AZ6027=m
CONFIG_DVB_USB_LME2510=m
CONFIG_DVB_USB_TECHNISAT_USB2=m
CONFIG_DVB_USB_IT913X=m
CONFIG_DVB_USB_MXL111SF=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_USB_RTL2832U=m
CONFIG_DVB_USB_TBS5520=m
CONFIG_SMS_USB_DRV=m
CONFIG_DVB_B2C2_FLEXCOP_USB=m
CONFIG_DRM_USB=m
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_UA101=m
CONFIG_SND_USB_CAIAQ=m
CONFIG_SND_USB_CAIAQ_INPUT=y
CONFIG_SND_USB_6FIRE=m
# USB Input Devices
CONFIG_USB_HID=y
CONFIG_USB_HIDDEV=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
# CONFIG_USB_ARCH_HAS_XHCI is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
# CONFIG_USB_DEVICEFS is not set
CONFIG_USB_DEVICE_CLASS=y
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND=y
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_DWC3 is not set
CONFIG_USB_MON=y
CONFIG_USB_WUSB_CBAF=m
CONFIG_USB_WUSB_CBAF_DEBUG=y
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_HCD_PLATFORM is not set
# CONFIG_USB_EHCI_HCD_PLATFORM is not set
# CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
# CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
# CONFIG_USB_U132_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
CONFIG_USB_SUNXI_EHCI=y
CONFIG_USB_SUNXI_OHCI=y
CONFIG_USB_SUNXI_COMMON=y
CONFIG_USB_SW_SUNXI_HCD0=y
# CONFIG_USB_MUSB_HDRC is not set
# CONFIG_USB_RENESAS_USBHS is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=y
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_USBAT=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
CONFIG_USB_STORAGE_ALAUDA=y
CONFIG_USB_STORAGE_ONETOUCH=y
CONFIG_USB_STORAGE_KARMA=y
CONFIG_USB_STORAGE_CYPRESS_ATACB=y
CONFIG_USB_STORAGE_ENE_UB6250=y
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
CONFIG_USB_MDC800=m
# CONFIG_USB_MICROTEK is not set
# USB port drivers
CONFIG_USB_USS720=m
CONFIG_USB_SERIAL=m
CONFIG_USB_EZUSB=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_FUNSOFT=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_F81232=m
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_METRO=m
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7715_PARPORT=y
CONFIG_USB_SERIAL_MOS7840=m
CONFIG_USB_SERIAL_MOTOROLA=m
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QCAUX=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_HP4X=m
# CONFIG_USB_SERIAL_SAFE is not set
CONFIG_USB_SERIAL_SIEMENS_MPI=m
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_VIVOPAY_SERIAL=m
# CONFIG_USB_SERIAL_ZIO is not set
CONFIG_USB_SERIAL_SSU100=m
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
CONFIG_USB_IDMOUSE=m
CONFIG_USB_FTDI_ELAN=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_SISUSBVGA=m
CONFIG_USB_SISUSBVGA_CON=y
CONFIG_USB_LD=m
CONFIG_USB_TRANCEVIBRATOR=m
CONFIG_USB_IOWARRIOR=m
# CONFIG_USB_TEST is not set
CONFIG_USB_ISIGHTFW=m
# CONFIG_USB_YUREX is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_NET2272 is not set
CONFIG_USB_SW_SUNXI_UDC0_SELECT=m
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_SW_SUNXI_UDC0=y
CONFIG_USB_GADGET_DUALSPEED=y
# CONFIG_USB_ZERO is not set
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_ETH_EEM=y
CONFIG_USB_G_NCM=m
CONFIG_USB_GADGETFS=m
CONFIG_USB_FUNCTIONFS=m
CONFIG_USB_FUNCTIONFS_ETH=y
CONFIG_USB_FUNCTIONFS_RNDIS=y
CONFIG_USB_FUNCTIONFS_GENERIC=y
# CONFIG_USB_FILE_STORAGE is not set
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
CONFIG_USB_G_MULTI_CDC=y
CONFIG_USB_G_HID=m
CONFIG_USB_G_DBGP=m
# CONFIG_USB_G_DBGP_PRINTK is not set
CONFIG_USB_G_DBGP_SERIAL=y
CONFIG_USB_G_WEBCAM=m
CONFIG_USB_OTG_UTILS=y
CONFIG_USB_OTG_WAKELOCK=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ULPI is not set
# CONFIG_NOP_USB_XCEIV is not set
CONFIG_USB_SW_SUNXI_USB=y
CONFIG_USB_SW_SUNXI_USB_MANAGER=y
# CONFIG_USB_SW_SUNXI_USB0_HOST_ONLY is not set
CONFIG_USB_SW_SUNXI_USB0_OTG=y
# CONFIG_USB_SW_SUNXI_USB0_DEVICE_ONLY is not set
# CONFIG_USB_SW_SUNXI_USB0_NULL is not set
CONFIG_USB_SW_SUNXI_USB_DEBUG=y
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_HOST=m
# CONFIG_USBIP_DEBUG is not set
CONFIG_PRISM2_USB=m
CONFIG_LINE6_USB=m
# CONFIG_LINE6_USB_DEBUG is not set
# CONFIG_LINE6_USB_DUMP_CTRL is not set
# CONFIG_LINE6_USB_DUMP_MIDI is not set
# CONFIG_LINE6_USB_DUMP_PCM is not set
# CONFIG_LINE6_USB_RAW is not set
# CONFIG_LINE6_USB_IMPULSE_RESPONSE is not set
CONFIG_USB_SERIAL_QUATECH2=m
CONFIG_USB_SERIAL_QUATECH_USB2=m
CONFIG_USB_ENESTORAGE=m
CONFIG_LIRC_IGORPLUGUSB=m
CONFIG_LIRC_TTUSBIR=m
CONFIG_USB_WPAN_HCD=m
And as bonus the lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
└─sda1 8:1 0 931.5G 0 part
sdb 8:16 0 55.9G 0 disk
├─sdb1 8:17 0 5G 0 part
└─sdb2 8:18 0 50.9G 0 part
nand 93:0 0 14.9G 0 disk
├─nand1 93:1 0 32M 0 part
└─nand2 93:2 0 14.8G 0 part
mmcblk0 179:0 0 7.4G 0 disk
└─mmcblk0p1 179:1 0 7.2G 0 part /
Link to comment
The option is obviously set. In case your USB disk is powered by Cubietruck maybe that's the culprit (check for 'Set USB Power ON' in dmesg output and compare with your older Armbian installation -- I would believe it's related to different kernel config and in case the USB disk can not be powered externally I would drop the USB disk and put the rootfs also on the SATA disk)
Link to comment
In order to set up my system properly, I need the system drive physically divided from my data drive.
Could the rootdelay=n option help?
Where do I get the the demsg information from?
And thank you very much for your help.
Link to comment
Notice: rootdelay=120 did not succeed
lsmod output:
Module                  Size  Used by
cpufreq_userspace       3540  0
ap6210                623704  0
sunxi_ir                4044  0
hidp                   17740  0
rfcomm                 58820  0
hci_uart               25074  0
bluetooth             265449  5 hidp,hci_uart,rfcomm
sg                     23918  0
lsusb output:
Bus 005 Device 002: ID 04f3:0103 Elan Microelectronics Corp. ActiveJet K-2024 Multimedia Keyboard
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 174c:55aa ASMedia Technology Inc. ASMedia 2105 SATA bridge
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg output:
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun7i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #7 SMP PREEMPT Tue Jun 21 15:43:57 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun7i
[    0.000000] Memory Reserved:
[    0.000000] SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
[    0.000000] LCD  : 0x44000000 - 0x44ffffff  (  16 MB)
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected.
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0a89440, node_mem_map d0000000
[    0.000000]   DMA zone: 512 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 65024 pages, LIFO batch:15
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 128016 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2576 pages used for memmap
[    0.000000]   HighMem zone: 327152 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 8 pages/cpu @d100e000 s8256 r8192 d16320 u32768
[    0.000000] pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520192
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 2043044k/2043044k available, 54108k reserved, 1318912K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09dfe98   (10080 kB)
[    0.000000]       .init : 0xc09e0000 - 0xc0a18040   ( 225 kB)
[    0.000000]       .data : 0xc0a1a000 - 0xc0a91d68   ( 480 kB)
[    0.000000]        .bss : 0xc0a91d8c - 0xc0c66f78   (1877 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:192
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] start_kernel(): bug: interrupts were enabled early
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.013309] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928)
[    0.076003] pid_max: default: 32768 minimum: 301
[    0.079663] Mount-cache hash table entries: 512
[    0.083889] Initializing cgroup subsys cpuacct
[    0.087211] Initializing cgroup subsys memory
[    0.090636] Initializing cgroup subsys devices
[    0.094076] Initializing cgroup subsys freezer
[    0.097301] Initializing cgroup subsys blkio
[    0.100975] Initializing cgroup subsys perf_event
[    0.104562] CPU: Testing write buffer coherency: ok
[    0.109772] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.116880] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
[    0.122423] Setting up static identity map for 0x40724a18 - 0x40724a70
[    0.239229] CPU1: Booted secondary processor
[    0.297323] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.299329] Brought up 2 CPUs
[    0.304640] SMP: Total of 2 processors activated (3640.52 BogoMIPS).
[    0.307895] devtmpfs: initialized
[    0.313970] dummy:
[    0.317627] NET: Registered protocol family 16
[    0.324163] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.332108] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.336982] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.340139] [ccu-inf] aw clock manager init
[    0.342410] [ccu-inf] aw_ccu_init
[    0.346395] [ccu-inf] script config pll3 to 297MHz
[    0.350148] [ccu-inf] script config pll4 to 300MHz
[    0.353895] [ccu-inf] script config pll6 to 600MHz
[    0.357660] [ccu-inf] script config pll7 to 297MHz
[    0.361408] [ccu-inf] script config pll8 to 336MHz
[    0.364182] Init eGon pin module V2.0
[    0.373789] bio: create slab <bio-0> at 0
[    0.377403] sunxi_gpio driver init ver 1.3
[    0.383681] sunxi_gpio_probe script_parser_fetch '[gpio_para]' 'gpio_pin_3' err
[    0.389305] gpiochip_add: registered GPIOs 1 to 4 on device: A1X_GPIO
[    0.392467] SCSI subsystem initialized
[    0.395327] libata version 3.00 loaded.
[    0.399973] usbcore: registered new interface driver usbfs
[    0.404356] usbcore: registered new interface driver hub
[    0.408529] usbcore: registered new device driver usb
[    0.411643] Linux media interface: v0.10
[    0.415251] Linux video capture interface: v2.00
[    0.420857] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.426500] Switching to clocksource arch_sys_counter
[    0.428588] FS-Cache: Loaded
[    0.430766] CacheFiles: Loaded
[    0.441908] cfg80211: Calling CRDA to update world regulatory domain
[    0.447198] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[    0.451034] [sw_hcd0]: usb host driver initialize........
[    0.455210] [sw_hcd0]: open_usb_clock
[    0.479483] [sw_hcd0]: host_init_state = 1
[    0.480445] [sw_hcd0]: platform is usb host
[    0.483354] [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
[    0.494542] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
[    0.507082] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
[    0.513796] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
[    0.517214] hub 1-0:1.0: USB hub found
[    0.520152] hub 1-0:1.0: 1 port detected
[    0.524007] wrn: hcd is not enable, need not start hcd
[    0.525365] [sw_hcd0]: sw_usb_host0_disable start
[    0.531408] -------sw_hcd0_soft_disconnect---------
[    0.534390] is_on = 0, hcd0_set_vbus_cnt = 0
[    0.537441] [sw_hcd_host0]: Set USB Power Off
[    0.541186] wrn: hcd is not enable, need not stop hcd
[    0.542237] [sw_hcd0]: close_usb_clock
[    0.544701] [sw_hcd0]: sw_usb_host0_disable end
[    0.547911] [sw_udc]: udc_init: version 20080411
[    0.554262] NET: Registered protocol family 2
[    0.570889] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.577867] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.585449] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.592256] TCP: Hash tables configured (established 131072 bind 65536)
[    0.594442] TCP: reno registered
[    0.599318] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.604669] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.608289] NET: Registered protocol family 1
[    0.613616] RPC: Registered named UNIX socket transport module.
[    0.617279] RPC: Registered udp transport module.
[    0.620966] RPC: Registered tcp transport module.
[    0.626358] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.630990] Trying to unpack rootfs image as initramfs...
[    0.882275] Freeing initrd memory: 3556K
[    0.887892] audit: initializing netlink socket (disabled)
[    0.891683] type=2000 audit(0.870:1): initialized
[    0.896189] highmem bounce pool size: 64 pages
[    0.908265] VFS: Disk quotas dquot_6.5.2
[    0.913884] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.921131] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.926699] NFS: Registering the id_resolver key type
[    0.931334] NTFS driver 2.1.30 [Flags: R/W].
[    0.934633] fuse init (API version 7.18)
[    0.939262] JFS: nTxBlock = 8192, nTxLock = 65536
[    0.958742] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
[    0.963036] Btrfs loaded
[    0.965856] msgmni has been set to 1421
[    0.973503] alg: No test for stdrng (krng)
[    0.980212] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.983146] io scheduler noop registered
[    0.986372] io scheduler deadline registered
[    0.990069] io scheduler cfq registered (default)
[    0.995002] sunxi disp driver loaded (/dev/disp api 1.0)
[    1.000577] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.005335] [uart]: used uart info.: 0x05
[    1.010028] [uart]: serial probe 0 irq 33 mapbase 0x01c28000
[    1.036327] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
[    1.038906] console [ttyS0] enabled
[    1.043819] [uart]: serial probe 2 irq 35 mapbase 0x01c28800
[    1.070026] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A
[    1.072656] G2D: drv_g2d_init
[    1.076012] G2D: Module initialized.major:250
[    1.085254] brd: module loaded
[    1.091259] loop: module loaded
[    1.094613] [NAND] nand driver version: 0x2 0x9
[    1.163504] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411
[    1.169512] Dev Sunxi softw311 nand magic does not match for MBR 2:
[    1.175559] Dev Sunxi softw311 nand magic does not match for MBR 3:
[    1.181561] Dev Sunxi softw311 nand magic does not match for MBR 4:
[    1.189308] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present.
[    1.199057] Dev Sunxi softw411 nand: part 1, start 65536, size 65536
[    1.204769] Dev Sunxi softw411 nand: part 2, start 131072, size 30998528
[    1.206786]  nand: nand1 nand2
[    1.209841] [NAND]nand driver, ok.
[    1.216049] pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10
[    1.222385] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
[    1.226931] ahci: SSS flag set, parallel bus scan disabled
[    1.234370] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.241246] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc
[    1.244739] scsi0 : sw_ahci_platform
[    1.251988] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
[    1.256074] [spi-err] Get spi devices number failed
[    1.260776] [spi-err] register spi devices board info failed
[    1.270275] spi: cannot find any using configuration for                     all 4 spi controllers, return directly!
[    1.276379] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[    1.281271] Fixed MDIO Bus: probed
[    1.285808] emac_init fetch emac using configuration failed
[    1.288253] emac driver is disabled
[    1.291819] gmac: use mac address from chipid
[    1.295916] gmac: device MAC address 02:c4:06:c1:11:cb
[    1.301565] [gmac]: sun6i_gmac platform driver registration completed
[    1.304879] PPP generic driver version 2.4.2
[    1.308827] PPP BSD Compression module registered
[    1.312860] PPP Deflate Compression module registered
[    1.320115] PPP MPPE Compression module registered
[    1.323558] NET: Registered protocol family 24
[    1.329731] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.334974] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.337438] [sw-ehci1]: open clock
[    1.360172] [sw-ehci1]: Set USB Power ON
[    1.366613] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.372894] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
[    1.377283] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
[    1.400922] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
[    1.404325] hub 2-0:1.0: USB hub found
[    1.407219] hub 2-0:1.0: 1 port detected
[    1.409887] [sw-ohci1]: open clock
[    1.436036] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.442274] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
[    1.446604] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
[    1.514013] hub 3-0:1.0: USB hub found
[    1.516915] hub 3-0:1.0: 1 port detected
[    1.519579] [sw-ehci2]: open clock
[    1.542266] [sw-ehci2]: Set USB Power ON
[    1.548704] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.554951] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4
[    1.559327] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000
[    1.580919] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00
[    1.584266] hub 4-0:1.0: USB hub found
[    1.587161] hub 4-0:1.0: 1 port detected
[    1.589810] [sw-ohci2]: open clock
[    1.611721] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.617807] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.624226] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5
[    1.628575] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400
[    1.633789] ata1.00: ATA-9: ST1000DM003-1ER162, CC45, max UDMA/133
[    1.639534] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[    1.643621] ata1.00: configured for UDMA/133
[    1.651214] scsi 0:0:0:0: Direct-Access     ATA      ST1000DM003-1ER1 CC45 PQ: 0 ANSI: 5
[    1.658584] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[    1.662811] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.666837] sd 0:0:0:0: [sda] Write Protect is off
[    1.670872] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.678964] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.694078] hub 5-0:1.0: USB hub found
[    1.696976] hub 5-0:1.0: 1 port detected
[    1.701290] Initializing USB Mass Storage driver...
[    1.706428] usbcore: registered new interface driver usb-storage
[    1.707746]  sda: sda1
[    1.711355] USB Mass Storage support registered.
[    1.714940] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.719903] usbcore: registered new interface driver ums-alauda
[    1.724954] usbcore: registered new interface driver ums-cypress
[    1.729957] usbcore: registered new interface driver ums-datafab
[    1.735175] usbcore: registered new interface driver ums_eneub6250
[    1.740177] usbcore: registered new interface driver ums-freecom
[    1.745111] usbcore: registered new interface driver ums-isd200
[    1.750195] usbcore: registered new interface driver ums-jumpshot
[    1.755035] usbcore: registered new interface driver ums-karma
[    1.760119] usbcore: registered new interface driver ums-onetouch
[    1.765149] usbcore: registered new interface driver ums-realtek
[    1.770061] usbcore: registered new interface driver ums-sddr09
[    1.774989] usbcore: registered new interface driver ums-sddr55
[    1.779828] usbcore: registered new interface driver ums-usbat
[    1.784619] mousedev: PS/2 mouse device common for all mice
[    1.790270] ===========================hv_keypad_init=====================
[    1.793699] ========HV Inital ===================
[    1.796316] ehci_irq: port change detect
[    1.800242] tkey_fetch_sysconfig_para: tkey_unused.
[    1.807524] hv_keypad_init: after fetch_sysconfig_para:  normal_i2c: 0x0. normal_i2c[1]: 0x0
[    1.813297] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
[    1.815814] i2c /dev entries driver
[    1.819394] config i2c gpio with gpio_config api
[    1.825101] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
[    1.830906] axp_mfd 0-0034: AXP internal temperature monitoring enabled
[    1.835643] i2c i2c-0: Invalid probe address 0x00
[    1.838700] I2C: i2c-0: AW16XX I2C adapter
[    1.842783] [cedar dev]: not installed! ve_mem_reserve=0
[    1.846182] [tt]----- avs_dev driver load... ----
[    1.849757] [tt]-----      register iomem      ----
[    1.852567] Cannot reserve region for ccmu
[    1.856263] [tt]--- avs_dev driver load ok!! -----
[    1.858016] [ace_drv] start!!!
[    1.860450] [ace_drv] init end!!!
[    1.862117] [pa_drv] start!!!
[    1.864367] [pa_drv] init end!!!
[    1.866778] axp20_ldo1: 1300 mV
[    1.872017] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
[    1.877297] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
[    1.882689] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
[    1.888072] axp20_buck2: 700 <--> 2275 mV at 1450 mV
[    1.894620] somebody is trying to set dcdc3 range to (1300000, 1300000) uV
[    1.899647] but we keep dcdc3 = 1250000 uV from the bootloader
[    1.903916] axp20_buck3: 700 <--> 3500 mV at 1250 mV
[    1.908783] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
[    1.918369] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0
[    1.936839] axp20_ldo2: Failed to create debugfs directory
[    1.940011] incomplete xfer (0x20)
[    1.942269] incomplete xfer (0x20)
[    1.944520] incomplete xfer (0x20)
[    1.946772] incomplete xfer (0x20)
[    1.949408] ehci_irq: port change detect
[    1.951704] incomplete xfer (0x20)
[    1.953955] incomplete xfer (0x20)
[    1.956205] incomplete xfer (0x20)
[    1.958455] incomplete xfer (0x20)
[    1.960723] incomplete xfer (0x20)
[    1.964729] device-mapper: uevent: version 1.0.3
[    1.972536] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.977495] device-mapper: multipath: version 1.3.2 loaded
[    1.983008] device-mapper: multipath round-robin: version 1.0.0 loaded
[    1.988589] device-mapper: multipath queue-length: version 0.1.0 loaded
[    1.994172] device-mapper: multipath service-time: version 0.2.0 loaded
[    1.997620] cpuidle: using governor ladder
[    2.000537] cpuidle: using governor menu
[    2.002858] [mmc-msg] sw_mci_init
[    2.008618] [mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8
[    2.011235] The port change to OHCI now!
[    2.016600] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    2.024920] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.033101] [mmc-msg] sdc0 Probe: base:0xf0618000 irq:64 sg_cpu:f061a000(4fc00000) ret 0.
[    2.038143] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    2.046347] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.054528] [mmc-msg] sdc3 Probe: base:0xf061c000 irq:67 sg_cpu:f061e000(4fc01000) ret 0.
[    2.059104] [mmc_pm]: failed to fetch sdio card configuration!
[    2.061602] sunxi_leds driver init
[    2.065651] Registered led device: blue:ph21:led1
[    2.069573] Registered led device: orange:ph20:led2
[    2.073453] Registered led device: white:ph11:led3
[    2.077301] Registered led device: green:ph07:led4
[    2.082336] ledtrig-cpu: registered to indicate activity on CPUs
[    2.087569] usbcore: registered new interface driver usbhid
[    2.090382] usbhid: USB HID core driver
[    2.093128] ashmem: initialized
[    2.096757] logger: created 256K log 'log_main'
[    2.100614] logger: created 256K log 'log_events'
[    2.104317] logger: created 256K log 'log_radio'
[    2.108102] logger: created 256K log 'log_system'
[    2.116024] asoc: sndspdif <-> sunxi-spdif.0 mapping ok
[    2.119880] [i2S-0] Entered sunxi_i2s_init
[    2.124071] [i2S-0] sunxi_i2s_init I2S used in master mode
[    2.127547] [i2S-0] Entered sunxi_i2s_dev_probe
[    2.132324] [i2S-0] sndi2s_codec_init I2S used in master mode
[    2.137010] [i2S-0] sndi2s_codec_probe I2S used in master mode
[    2.140134] [i2S-0] Entered sunxi_sndi2s_init
[    2.144577] [i2S-0] sunxi_sndi2s_init I2S used in master mode
[    2.149322] asoc: sndi2s <-> sunxi-i2s.0 mapping ok
[    2.153722] IPv4 over IPv4 tunneling driver
[    2.156505] TCP: bic registered
[    2.158781] TCP: cubic registered
[    2.161369] TCP: westwood registered
[    2.163987] TCP: highspeed registered
[    2.166257] TCP: hybla registered
[    2.168439] TCP: htcp registered
[    2.170742] TCP: vegas registered
[    2.172927] TCP: veno registered
[    2.175456] TCP: scalable registered
[    2.177465] TCP: lp registered
[    2.179687] TCP: yeah registered
[    2.182217] TCP: illinois registered
[    2.185440] Initializing XFRM netlink socket
[    2.189523] NET: Registered protocol family 10
[    2.194200] NET: Registered protocol family 17
[    2.197637] NET: Registered protocol family 15
[    2.202361] [mmc_pm]: No sdio card, please check your config !!
[    2.206033] Registering the dns_resolver key type
[    2.208306] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    2.216884] Registering SWP/SWPB emulation handler
[    2.221519] axp20_buck2: Failed to create debugfs directory
[    2.227681] [cpu_freq] INF:-------------------V-F Table-------------------
[    2.232747] [cpu_freq] INF: voltage = 1450mv frequency = 1008MHz
[    2.237792] [cpu_freq] INF: voltage = 1425mv frequency =  912MHz
[    2.242851] [cpu_freq] INF: voltage = 1350mv frequency =  864MHz
[    2.247896] [cpu_freq] INF: voltage = 1250mv frequency =  720MHz
[    2.252953] [cpu_freq] INF: voltage = 1150mv frequency =  528MHz
[    2.257998] [cpu_freq] INF: voltage = 1100mv frequency =  312MHz
[    2.263054] [cpu_freq] INF: voltage = 1050mv frequency =  144MHz
[    2.268099] [cpu_freq] INF: voltage = 1000mv frequency =    0MHz
[    2.273933] [cpu_freq] INF:-----------------------------------------------
[    2.283669] [cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz
[    2.287642] registered taskstats version 1
[    2.292436] I2C: i2c-1: HDMI I2C adapter
[    2.317795] ParseEDID
[    2.334755] EDID version: 1.3
[    2.341022] PCLK=148500000 X 1920 2008 2052 2200 Y 1080 1084 1089 1125 fr 60 PP
[    2.344876] Using above mode as preferred EDID mode
[    2.351892] usb 5-1: new low-speed USB device number 2 using sw-ohci
[    2.355425] Unimplemented SVD code 2
[    2.358098] Unimplemented SVD code 17
[    2.360751] Unimplemented SVD code 31
[    2.366602] disp_clk: Could not find a matching pll-freq for 53900000 pclk
[    2.372449] disp_clk: Could not find a matching pll-freq for 53900000 pclk
[    2.378363] disp_clk: Could not find a matching pll-freq for 108100000 pclk
[    2.384223] disp_clk: Could not find a matching pll-freq for 74200000 pclk
[    2.390053] disp_clk: Could not find a matching pll-freq for 25150000 pclk
[    2.395980] disp_clk: Could not find a matching pll-freq for 138500000 pclk
[    2.398601] ehci_irq: port change detect
[    2.404542] disp_clk: Could not find a matching pll-freq for 146850000 pclk
[    2.410370] disp_clk: Could not find a matching pll-freq for 83650000 pclk
[    2.416205] disp_clk: Could not find a matching pll-freq for 74600000 pclk
[    2.422035] disp_clk: Could not find a matching pll-freq for 78800000 pclk
[    2.427876] disp_clk: Could not find a matching pll-freq for 53450000 pclk
[    2.433718] disp_clk: Could not find a matching pll-freq for 27100000 pclk
[    2.439546] disp_clk: Could not find a matching pll-freq for 26150000 pclk
[    2.444008] Parse_VideoData_Block: VIC 16 (native) support
[    2.447580] Parse_VideoData_Block: VIC 5 support
[    2.451163] Parse_VideoData_Block: VIC 4 support
[    2.454733] Parse_VideoData_Block: VIC 3 support
[    2.458303] Parse_VideoData_Block: VIC 2 support
[    2.461883] Parse_VideoData_Block: VIC 1 support
[    2.465540] Parse_VideoData_Block: VIC 17 support
[    2.469196] Parse_VideoData_Block: VIC 18 support
[    2.472861] Parse_VideoData_Block: VIC 19 support
[    2.476518] Parse_VideoData_Block: VIC 20 support
[    2.480175] Parse_VideoData_Block: VIC 31 support
[    2.483756] Parse_AudioData_Block: max channel=2
[    2.487673] Parse_AudioData_Block: SampleRate code=7
[    2.491340] Parse_AudioData_Block: WordLen code=7
[    2.494824] Find HDMI Vendor Specific DataBlock
[    2.501088] PCLK=138500000 X 1920 1968 2000 2080 Y 1080 1083 1088 1110 fr 59 PN
[    2.506930] PCLK=85500000 X 1366 1436 1579 1792 Y 768 771 774 798 fr 59 PP
[    2.512772] PCLK=74250000 X 1280 1390 1430 1650 Y 720 725 730 750 fr 60 PP
[    2.518256] PCLK=27000000 X 720 736 798 858 Y 480 489 495 525 fr 59 NN
[    2.524097] PCLK=74250000 X 1920 2008 2052 2200 Y 540 542 547 562 fr 60 PP
[    2.529686] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    2.537161] disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0
[    2.582148] input: HID 04f3:0103 as /devices/platform/sw-ohci.2/usb5/5-1/5-1:1.0/input/input1
[    2.592744] generic-usb 0003:04F3:0103.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 04f3:0103] on usb-sw-ohci-1/input0
[    2.609618] input: HID 04f3:0103 as /devices/platform/sw-ohci.2/usb5/5-1/5-1:1.1/input/input2
[    2.619942] generic-usb 0003:04F3:0103.0002: input,hidraw1: USB HID v1.10 Device [HID 04f3:0103] on usb-sw-ohci-1/input1
[    2.911977] usb 2-1: new high-speed USB device number 2 using sw-ehci
[    3.025481] [mmc-msg] mmc 0 detect change, present 1
[    3.064812] scsi1 : usb-storage 2-1:1.0
[    3.524497] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.526950] [mmc-msg] sdc0 power on
[    3.554915] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.559832] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    3.632224] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.636375] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.644739] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.655499] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.660864] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.664915] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.668965] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.673031] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.682038] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.690403] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.701144] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.737523] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.745981] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.751142] [mmc-msg] sdc0 set round clock 42857143, src 600000000
[    3.814704] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    3.819176] mmc0: new high speed SDHC card at address 0007
[    3.823288] mmcblk0: mmc0:0007 SD08G 7.39 GiB
[    3.827355]  mmcblk0: p1
[    3.839113] Console: switching to colour frame buffer device 240x67
[    3.890500] axp20_buck3: incomplete constraints, leaving on
[    3.895324] axp20_buck2: incomplete constraints, leaving on
[    3.900013] axp20_ldo4: incomplete constraints, leaving on
[    3.904723] axp20_ldo3: incomplete constraints, leaving on
[    3.909416] axp20_ldo2: incomplete constraints, leaving on
[    3.912635] console [netcon0] enabled
[    3.916121] netconsole: network logging started
[    3.920302] otg_wakelock_init: No USB transceiver found
[    3.927404] ALSA device list:
[    3.930492]   #0: sunxi-CODEC  Audio Codec
[    3.932679]   #1: sunxi-sndspdif
[    3.934690]   #2: sunxi-sndi2s
[    3.936788]   #3: sunxi-sndhdmi
[    3.940000] Freeing init memory: 224K
[    4.010186] systemd-udevd[94]: starting version 215
[    4.065082] scsi 1:0:0:0: Direct-Access     ASMT     2105             0    PQ: 0 ANSI: 6
[    4.074984] sd 1:0:0:0: [sdb] 117210240 512-byte logical blocks: (60.0 GB/55.8 GiB)
[    4.080427] sd 1:0:0:0: [sdb] Write Protect is off
[    4.084461] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    4.104793] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.125434] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.134476]  sdb: sdb1 sdb2
[    4.142663] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    4.146246] sd 1:0:0:0: [sdb] Attached SCSI disk
[    5.838296] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.021513] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    7.026094] systemd[1]: Detected architecture 'arm'.
[    7.055146] systemd[1]: Set hostname to <cubietruck>.
[    7.625875] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    7.636659] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    7.643864] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.648681] systemd[1]: Expecting device dev-ttyS0.device...
[    7.654183] systemd[1]: Starting Remote File Systems (Pre).
[    7.659899] systemd[1]: Reached target Remote File Systems (Pre).
[    7.664050] systemd[1]: Starting Encrypted Volumes.
[    7.669048] systemd[1]: Reached target Encrypted Volumes.
[    7.676271] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    7.683607] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.686573] systemd[1]: Starting Paths.
[    7.690537] systemd[1]: Reached target Paths.
[    7.698451] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    7.708278] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.711806] systemd[1]: Starting Root Slice.
[    7.716261] systemd[1]: Created slice Root Slice.
[    7.720711] systemd[1]: Starting User and Session Slice.
[    7.726332] systemd[1]: Created slice User and Session Slice.
[    7.730864] systemd[1]: Starting Delayed Shutdown Socket.
[    7.736482] systemd[1]: Listening on Delayed Shutdown Socket.
[    7.742277] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    7.749080] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.753838] systemd[1]: Starting Journal Socket (/dev/log).
[    7.759578] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.763846] systemd[1]: Starting udev Control Socket.
[    7.768948] systemd[1]: Listening on udev Control Socket.
[    7.773109] systemd[1]: Starting udev Kernel Socket.
[    7.778090] systemd[1]: Listening on udev Kernel Socket.
[    7.781952] systemd[1]: Starting Journal Socket.
[    7.786689] systemd[1]: Listening on Journal Socket.
[    7.790428] systemd[1]: Starting System Slice.
[    7.795173] systemd[1]: Created slice System Slice.
[    7.800504] systemd[1]: Started File System Check on Root Device.
[    7.804646] systemd[1]: Starting system-getty.slice.
[    7.810081] systemd[1]: Created slice system-getty.slice.
[    7.815122] systemd[1]: Starting system-serial\x2dgetty.slice.
[    7.821369] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.826907] systemd[1]: Starting Increase datagram queue length...
[    8.093213] systemd[1]: Starting Restore / save the current clock...
[    8.112250] systemd[1]: Mounting Debug File System...
[    8.132180] systemd[1]: Starting udev Coldplug all Devices...
[    8.153131] systemd[1]: Mounting POSIX Message Queue File System...
[    8.211194] systemd[1]: Started Set Up Additional Binary Formats.
[    8.234202] systemd[1]: Starting Load Kernel Modules...
[    8.277080] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    8.302143] systemd[1]: Mounted Huge Pages File System.
[    8.306297] systemd[1]: Starting LSB: Set keymap...
[    8.331410] Bluetooth: Core ver 2.16
[    8.334392] systemd[1]: Starting Slices.
[    8.337929] NET: Registered protocol family 31
[    8.343294] Bluetooth: HCI device and connection manager initialized
[    8.347131] Bluetooth: HCI socket layer initialized
[    8.351163] Bluetooth: L2CAP socket layer initialized
[    8.355032] Bluetooth: SCO socket layer initialized
[    8.358848] systemd[1]: Reached target Slices.
[    8.367826] systemd[1]: Mounted POSIX Message Queue File System.
[    8.372788] systemd[1]: Mounted Debug File System.
[    8.376192] Bluetooth: HCI UART driver ver 2.2
[    8.379940] Bluetooth: HCI H4 protocol initialized
[    8.383992] Bluetooth: HCI BCSP protocol initialized
[    8.387668] Bluetooth: HCILL protocol initialized
[    8.391644] Bluetooth: HCIATH3K protocol initialized
[    8.402406] systemd[1]: Started Increase datagram queue length.
[    8.409990] Bluetooth: RFCOMM TTY layer initialized
[    8.414136] Bluetooth: RFCOMM socket layer initialized
[    8.416843] Bluetooth: RFCOMM ver 1.11
[    8.422586] systemd[1]: Started Restore / save the current clock.
[    8.434416] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.455514] input: sunxi-ir as /devices/virtual/input/input3
[    8.465951] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    8.468255] IR Initial OK
[    8.491344] systemd[1]: Started LSB: Set keymap.
[    8.499200] systemd[1]: Time has been changed
[    8.507034] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.531767] systemd[1]: Starting Syslog Socket.
[    8.538134] systemd[1]: Listening on Syslog Socket.
[    8.542548] systemd[1]: Starting Journal Service...
[    8.553040] [ap6210] select wifi ap6210
[    8.556460] [ap6210] Initializing ap6210.
[    8.561817] [ap6210] platform device registered successfully.
[    8.565814] [ap6210] Using ap6210 configuration.
[    8.592285] systemd[1]: Started Journal Service.
[    8.690844] [mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    8.699013] [mmc-msg] sdc3 power on
[    8.724957] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    8.729877] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    8.812367] [mmc-err] smc 3 err, cmd 52,  RTO
[    8.816562] [mmc-err] smc 3 err, cmd 52,  RTO
[    8.825004] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    8.829024] systemd-udevd[175]: starting version 215
[    8.846761] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    8.849993] [ap6210] WLAN placed in POWER ON
[    8.861761] [mmc-err] smc 3 err, cmd 8,  RTO
[    8.871148] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    8.899283] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    8.911439] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    8.917594] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    8.931730] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    8.965334] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    8.973840] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    8.979719] [mmc-msg] sdc3 set round clock 42857143, src 600000000
[    9.043421] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    9.058005] mmc1: new high speed SDIO card at address 0001
[    9.062539] [ap6210] Linux Kernel SDIO/MMC Driver
[    9.095433] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[    9.539742] [ap6210] WLAN placed in RESET
[   10.659297] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   10.731687] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[   10.744961] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[   10.799079] [ap6210] Using ap6210 configuration.
[   11.022599] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[   12.356112] systemd-journald[174]: Received request to flush runtime journal from PID 1
[   12.736842] sunxi_gmac: probed
[   12.742457] eth0: PHY ID 001cc900 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   12.747280] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   15.749877] PHY: sunxi_gmac-0:00 - Link is Up - 1000/Full
[   23.209529] eth0: no IPv6 routers present
Link to comment
I had the same problems with usb to sata adapters but in my case i was booting from a partition on the ssd connected to usb to sata adapter.
I suggest that you test an older image that is known to work at least in my case on cubietruck. This is the  Armbian_5.10_Cubietruck_Debian_jessie_4.5.2.image.
PS: use /dev/sdX in the boot cmd, UUID and PARTUUID does not work
Link to comment
I'll keep on trying! :) Thank you for your reply. Is there an archive over ALL armbian versions? I only now the http://mirror.igorpecovnik.com, where some versions are missing.
Only locally on my hard drive, we can't occupy too much off a server space. I am not sure you can find an answer in historical versions.
NAND u-boot is only one version and that one is very old but it's most likely unrelated to this is issue in first place.
Our kernel has enabled:
I made several tests by myself and NAND & SD boot, SATA or USB root works. With USB I always made test on some USB flash key. Never used an USB to SATA adapter. Perhaps this needs some extra kernel feature / parameter or it's simply not compatible. Try with new kernel, but you will need to boot from SD since NAND is not supported.
Link to comment
Got it to work with a dirty hack at 3 o'clock tonight.
I put Armbian 4.5 Wheezy (Legacy) on my first SD card. I booted up and edited the nand-sata-install script as you had hardcoded the sda into the var $DRIVE, and he would not recognize my sdb drive. So I Exchanged all further occurrencys of sda with sdb. Ran the script and it would now allow me to select my sdb1 partition as root partition. Ran the script and it went through perfectly fine. Rebooted and plugged in a second SD card with Armbian 5.14 on it after it had started up. Replaced my Wheezy sources.list with the Jessie one. apt-get update, apt-get dist-upgrade went through perfectly. Rebooted -> Kernel Panic. Put in my first SD Card with 4.5 to install again. System starts Debian 8 with boot mounted in nand1, root on sdb1. Whenever I remove the SD card before startup I receive a kernel panic. It only starts with the first SD but I can remove it if the system is online. Wanna try it with an empty SD Card today to test if he really boots from nand1.
How much space does it take? I would volunteer to host it.
Link to comment
I have made several changes in nand-install-script lately, but you are not using that one since it's not yet part of the build - now we rely on UUID but again this is not working / tested for NAND based u-boot.
Full archive would be 200-300Gb but I does not make much sense - thanks anyway. But we might need to setup more (automatic) mirrors once, that would be interesting.
Link to comment
Interesting, does UUID work now in the boot.cmd for USB to sata connected ssd's ? The last time that I tested I was able to boot with UUID only from the sd card.
Link to comment
With legacy kernel (3.4), booting from usb to sata was always working
Link to comment
