Hello, problem is next: my Orange Pi 3 now can't get IP address from my router. To solve it, I've connected via USB-TTL and on step "login:" it totally  stucks and doesn't response for keyboard.
What variants do I have, except reinstall OS? :)
U-Boot SPL 2020.10-armbian (Feb 04 2021 - 00:24:13 +0100)
DRAM: 2048 MiB
Trying to boot from MMC2
NOTICE:  BL31: v2.2(debug):a04808c-dirty
NOTICE:  BL31: Built : 00:24:06, Feb  4 2021
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Found U-Boot DTB at 0xc07e188, model: OrangePi 3
INFO:    ARM GICv2 driver initialized
NOTICE:  PMIC: Probing AXP805
NOTICE:  PMIC: AXP805 detected
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Feb 04 2021 - 00:24:13 +0100) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi 3
DRAM:  2 GiB
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 1:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
No working controllers found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3173 bytes read in 2 ms (1.5 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
203 bytes read in 1 ms (198.2 KiB/s)
MMC: no card present
35737 bytes read in 6 ms (5.7 MiB/s)
4191 bytes read in 3 ms (1.3 MiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 45000000
10050849 bytes read in 1007 ms (9.5 MiB/s)
21792776 bytes read in 2181 ms (9.5 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=41730000
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    10050785 Bytes = 9.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 4966a000, end 49fffce1 ... OK
   Loading Device Tree to 00000000495f8000, end 0000000049669fff ... OK
Starting kernel ...
Armbian 21.02.3 Buster ttyS0
orangepi3 login:
Board: Not on the list
Make sure Tx line isn't broken.
Try setting verbosity to 7 in your /boot/armbianEnv.txt to get more info about what is going on until stuck.
