maka Posted October 19, 2024 Posted October 19, 2024 Tell me where to buy this box for less than 26€ and i' ll port it to armbian. 😝 1 Quote
SteeMan Posted October 19, 2024 Posted October 19, 2024 On 10/19/2024 at 11:53 AM, MMorales said: Anyway im so happy with my 25€ expense. Expand That 25€ is the problem. That amount of money doesn't cover any software costs. One reason those boxes are so cheap is there is no software support. It ships with some android version and will never get a security or bugfix update. Supported boards probably cost twice as much, but there you get some limited software support. But that added cost to the board manufactuer needs to get paid for in some way (thus the higher cost of a proper SBC). The real problem is that neither cheap boxes that provide zero support nor proper SBC boards that provide limited support truly reflect the huge cost of supporting software and security updates and bug fixes for those boards long term. That is a gap that Armbian fills, but no one really is willing to pay for that huge cost of support. Everyone expects that developers should donate all their time for free to open source projects like Armbian (or any of the upstream components) so that end users can have a perfect supported set of software for free on a 25€ box. 0 Quote
mmie4jbcu Posted October 19, 2024 Posted October 19, 2024 (edited) Quote Expand @MMorales I think your board may still be of the 8GB RAM/64 GB emmc config. Why don't you try installing the armbian image for station m2 from here: https://www.armbian.com/station-m2/ After flashing the image, change the fdtfile=rockchip/rk3566-firefly-roc-pc.dtb line in the boot/armbianEnv.txt file to fdtfile=rockchip/rk3566-box-demo.dtb And also remove or comment out the line overlay_prefix=rk35xx Edited October 19, 2024 by mmie4jbcu reformatting, additional info 1 Quote
Hqnicolas Posted October 20, 2024 Posted October 20, 2024 (edited) On 10/19/2024 at 5:10 PM, mmie4jbcu said: @MMorales I think your board may still be of the 8GB RAM/64 GB emmc config. Why don't you try installing the armbian image for station m2 from here: Expand I would like you to be more empirical in your claims, you need to base your theories on something, basically you are suggesting that my previous post is not empirical enough. I'll be more repetitive so that you hit the same key again. I want to make it clear that TV-Box is not to be considered reliable. You have been scammed, and this is part of the TV Box scheme. look around Edited October 20, 2024 by Hqnicolas 0 Quote
mmie4jbcu Posted October 20, 2024 Posted October 20, 2024 @Hqnicolas Take a chill pill dude. I am not trying to prove/disprove anything. I am simply suggesting that the board may indeed be of 8/64 config. Sometimes, due to screwed up u-boot, not all the RAM is reported correctly. And here, I can see that adding up the memory (3.8) and zram (1.9), it comes to around 6GB. Hence, I suspect the memory is still there, it's just not reported correctly because of the zram/swap thing. Removing the swap/zram completely may indeed show it to be 8GB. On your note of TV boxes being unreliable, I never refuted your claim. I agree about the unreliability. At the same time, I own two of these x88 pro20 boxes (8/128 and 4/32) and looking at the chips and the markings on the board, I have certain confidence that it would be an 8/64 indeed. And, I own a total of 4 tv boxes, and a total of 4 sbcs (2 raspberry pis, one orange pi 5 plus, 1 starfive vision V 2), so I know what to expect and how wild things are out in the tv box world. I am sure you also know better than to claim to be the final authority on declaring all tv boxes as "unreliable" 3 Quote
MMorales Posted October 20, 2024 Posted October 20, 2024 (edited) @maka i found it here Now If you are a word man do your work. Edited October 20, 2024 by MMorales 0 Quote
Energokom Posted October 20, 2024 Posted October 20, 2024 (edited) On 10/19/2024 at 4:11 PM, SteeMan said: The real problem is that neither cheap boxes that provide zero support nor proper SBC boards that provide limited support truly reflect the huge cost of supporting software and security updates and bug fixes for those boards long term. Expand Therefore, if you do not need GPIOs, it is better to buy a mini PC than an SBC. People buy TV boxes for Linux precisely because of the cheapness. Few people need SBCs. Most people need a small device in a box for a minimal price. Why buy a banana pi M5 pro for $ 195, which will stop support in a few years, when you can buy x86 mini PC with this money and not know the problems with support? Can you name the reasons why it is worth buying an SBC instead of a mini PC? Edited October 20, 2024 by Energokom 1 Quote
MMorales Posted October 20, 2024 Posted October 20, 2024 @Energokom Totally agreed. I came from raspberrypi and orangepi world, i have severals arduinos, esp32 etc. but now i only need a cheap tvbox with beautifull box and little display who tells me whats happening without ask. And some people says there is no support? what a better support than a comunity who helps eachother. Thanks @mmie4jbcu for your help. 0 Quote
SteeMan Posted October 20, 2024 Posted October 20, 2024 On 10/20/2024 at 6:45 PM, Energokom said: Can you name the reasons why it is worth buying an SBC instead of a mini PC? Expand Yes, that added cost goes to paying people to provide the software support that users want and need. Instead people demand software support from other people for free and get upset with Armbian and others when things don't work the way they want them too. Nothing comes for free. 2 Quote
Hqnicolas Posted October 21, 2024 Posted October 21, 2024 (edited) On 10/20/2024 at 6:16 PM, MMorales said: @maka i found it here Expand @maka Some clever people in Pescara, Italy, are trying to get rid of an unidentified object from abroad. It's not refuged, but it's attacking locals on port 22 and the oscar goes to: On 10/20/2024 at 6:16 PM, MMorales said: Now If you are a word man do your work. Expand thank god i'm nobody, from a third world country: On 10/20/2024 at 7:55 PM, MMorales said: And some people says there is no support? Expand @maka I believe you are someone, so this was for you.... On 10/20/2024 at 5:09 AM, mmie4jbcu said: I am not trying to prove/disprove anything. Expand My verdict is, learn embedded systems and support this board. everyone here was once outraged by an unsupported sign board my example It will take you some time to learn and support the board, so we will see you around here a lot. Edited October 21, 2024 by Hqnicolas 0 Quote
fragpic Posted March 13 Posted March 13 @mmie4jbcu On 10/19/2024 at 5:10 PM, mmie4jbcu said: After flashing the image, change the fdtfile=rockchip/rk3566-firefly-roc-pc.dtb line in the boot/armbianEnv.txt file to fdtfile=rockchip/rk3566-box-demo.dtb And also remove or comment out the line overlay_prefix=rk35xx Expand I see that you're able to get armbian running fine on your Pro 20. Will following these get everything to work? incl usb and bluetooth? 0 Quote
fragpic Posted March 15 Posted March 15 (edited) I got the station m2 debian minimal image to work with the changes you suggested. Everything worked fine but as soon as I ran armbian-upgrade, wifi, usb etc broke. Does that mean that we cannot run updates? Edited March 15 by fragpic 0 Quote
fragpic Posted March 15 Posted March 15 Final update, issue was with armbian-upgrade restoring the dtb to the original files. Skipping dtb update should be enough. I was also able to install to emmc by using the armbian-install script. Everything seems to be running pretty stable so far. Thanks @mmie4jbcu for your help! 1 Quote
