4 hours ago, MMorales said:
Anyway im so happy with my 25€ expense.
That 25€ is the problem.
That amount of money doesn't cover any software costs.  One reason those boxes are so cheap is there is no software support.  It ships with some android version and will never get a security or bugfix update.
Supported boards probably cost twice as much, but there you get some limited software support.  But that added cost to the board manufactuer needs to get paid for in some way (thus the higher cost of a proper SBC).
The real problem is that neither cheap boxes that provide zero support nor proper SBC boards that provide limited support truly reflect the huge cost of supporting software and security updates and bug fixes for those boards long term.  That is a gap that Armbian fills, but no one really is willing to pay for that huge cost of support.  Everyone expects that developers should donate all their time for free to open source projects like Armbian (or any of the upstream components) so that end users can have a perfect supported set of software for free on a 25€ box.
Posted (edited)
Quote
@MMorales
I think your board may still be of the 8GB RAM/64 GB emmc config. Why don't you try installing the armbian image for station m2 from here:  https://www.armbian.com/station-m2/
After flashing the image, change the fdtfile=rockchip/rk3566-firefly-roc-pc.dtb line in the boot/armbianEnv.txt file to fdtfile=rockchip/rk3566-box-demo.dtb
And also remove or comment out the line overlay_prefix=rk35xx
Edited by mmie4jbcu
reformatting, additional info
Posted (edited)
8 hours ago, mmie4jbcu said:
@MMorales
I would like you to be more empirical in your claims,
you need to base your theories on something,
basically you are suggesting that my previous post is not empirical enough.
I'll be more repetitive so that you hit the same key again.
I want to make it clear that TV-Box is not to be considered reliable.
You have been scammed, and this is part of the TV Box scheme.
look around
Edited by Hqnicolas
@Hqnicolas Take a chill pill dude. I am not trying to prove/disprove anything.
I am simply suggesting that the board may indeed be of 8/64 config. Sometimes, due to screwed up u-boot, not all the RAM is reported correctly. And here, I can see that adding up the memory (3.8) and zram (1.9), it comes to around 6GB. Hence, I suspect the memory is still there, it's just not reported correctly because of the zram/swap thing. Removing the swap/zram completely may indeed show it to be 8GB.
On your note of TV boxes being unreliable, I never refuted your claim. I agree about the unreliability. At the same time, I own two of these x88 pro20 boxes (8/128 and 4/32) and looking at the chips and the markings on the board, I have certain confidence that it would be an 8/64 indeed.
And, I own a total of 4 tv boxes, and a total of 4 sbcs (2 raspberry pis, one orange pi 5 plus, 1 starfive vision V 2), so I know what to expect and how wild things are out in the tv box world.
I am sure you also know better than to claim to be the final authority on declaring all tv boxes as "unreliable"
Posted (edited)
Therefore, if you do not need GPIOs, it is better to buy a mini PC than an SBC. People buy TV boxes for Linux precisely because of the cheapness. Few people need SBCs. Most people need a small device in a box for a minimal price. Why buy a banana pi M5 pro for $ 195, which will stop support in a few years, when you can buy x86 mini PC with this money and not know the problems with support?
Can you name the reasons why it is worth buying an SBC instead of a mini PC?
Edited by Energokom
@Energokom Totally agreed. I came from raspberrypi and orangepi world, i have severals arduinos, esp32 etc. but now i only need a cheap tvbox with beautifull box and little display who tells me whats happening without ask.
And some people says there is no support? what a better support than a comunity who helps eachother.
Thanks @mmie4jbcu for your help.
Yes, that added cost goes to paying people to provide the software support that users want and need.  Instead people demand software support from other people for free and get upset with Armbian and others when things don't work the way they want them too.  Nothing comes for free.
Posted (edited)
17 hours ago, MMorales said:
@maka i found it here
@maka Some clever people in Pescara, Italy, are trying to get rid of an unidentified object from abroad.
It's not refuged, but it's attacking locals on port 22
and the oscar goes to:
Now If you are a word man do your work.
thank god i'm nobody, from a third world country:
@maka I believe you are someone, so this was for you....
My verdict is, learn embedded systems and support this board.
everyone here was once outraged by an unsupported sign board my example
It will take you some time to learn and support the board, so we will see you around here a lot.
Edited by Hqnicolas
@mmie4jbcu
I see that you're able to get armbian running fine on your Pro 20. Will following these get everything to work? incl usb and bluetooth?
Posted (edited)
I got the station m2 debian minimal image to work with the changes you suggested. Everything worked fine but as soon as I ran armbian-upgrade, wifi, usb etc broke. Does that mean that we cannot run updates?
Edited by fragpic
Final update, issue was with armbian-upgrade restoring the dtb to the original files. Skipping dtb update should be enough. I was also able to install to emmc by using the armbian-install script.
Everything seems to be running pretty stable so far. Thanks @mmie4jbcu for your help!
For production, boxes are much more interesting than boards. We just need to deal with a honest manufacturer. The last dtb from @mmie4jbcu worked very well for me in a x88 pro 20.
@MMorales@mmie4jbcu
i have the same x88 pro 20 clone like you guys, on the pcb is written "x88pro-rk3566-4d32-v1.0", which should state for 4gb ddr and 32gb rom i guess?
I installed latest armbian for station m2 with image-included demo-box.dtb, everything is working so far, despite bluetooth (CDtech-208821C=RTL8821CS). installed armbian-firmware-full but bt still doesn't work.
Maybe usefull for just Linux-Users (i don't have a windows pc):
original loader didn't allow me to boot from sd-card, rkdeveloptool (or xrock or rdeveltool-gui) didn't work for me, so i used proprietary upgrade_tool for linux from rockchip:
https://docs.radxa.com/en/zero/zero3/low-level-dev/upgrade-tool
I downloaded this loader from radxa https://dl.radxa.com/rock3/images/loader/rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin and flashed it with:
sudo ./upgrade_tool wl 0x0 rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin
After that i put in the sdcard and it bootet straight (wait for min. 5 seconds) to armbian!
my Rupa 88 Pro 20, wifi/bt chip is cdtech 208821c (rtl8821cs), with real 4g32 had no bluetooth with mmie4jbcu's dtb or the included box-demo.dtb. with a lil help from claude.ai, i mix mmie4jbcu's dtb with x96x6.dtb from another thread here. et voilá bluetooth is working after
apt install armbian-firmware-full
rk3566-box-X88PRO20.dtb
@davem, I have similar  X88 Pro TV box clone which got "X88PRO-RK3566-4D32-V2.1" written on the PCB. I was struggling to boot the system using SD card since the Android image that came with the box was not allowing.
Thanks for sharing about the upgrade tool and modified x96x6.dtb. Without your posts I could not made it to work.  I got "Armbian_community_26.2.0-trunk.792_Rk3566-box-demo_trixie_current_6.18.24_minimal.img.xz" successfully writte and booted. Later I have installed KDE based Desktop as well on 64GB Micro SD card. My USB 3.0 (the blue one) is somehow not working, Since I have a USB hub its not a deal breaker. Following are working properly as of now.
Summary:
Bluetooth - Working
On Board LAN - 1000Mbps - Working.
WiFI - connected to 2.4 Ghz network - Working.
HDMI Display - Working. I have not test HDMI audio though.
Sound - No 3.5mm Analog jack in this model. However the sound is working via Bluetooth head phone and Speaker with USB input/power.
USB 2.0 - Connected Keyboard, mouse and speaker via USB 2.0 Hub - Working.
USB 3.0 - This works fine when we boot in Android - Not working.
Toss Link - Though the box got a port in the back, I don't have any device that can be connected - Not Tested.
Note: I have windows 11 system as my desktop PC. I could not edit the Micro SD card created using BalenaEtcher. I had to use Ubuntu system in order to prepare the SD card and to edit the boot/armbianEnv.txt with fdtfile=rockchip/rk3566-box-X88PRO20.dtb
I am trying to enable the VFD display to show the current time. This board came with AiP1628 chip, will be going the posts to make it working. If you got it already working then kindly share the info. 🙂
