timonoj Posted August 18, 2016 Posted August 18, 2016 Hi guys, I'm getting this error while trying to boot my Banana Pi with an SD card. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2447 bytes read in 211 ms (10.7KiB/s) ##Executing script at 43100000 Wrong image format for "source" command SCRIPT FAILED: Continuing... scanning bus for devices... Found 0 device(s). SCSI device 0: Device 0: not available [...] I'm coming from using Lubuntu with no problems for nearly a year. The SD card works no problem (or at least it worked perfectly fine with Lubuntu). I also tested with a way faster microSD 64GB I usually have in the GoPro, with the same result. What should I do to continue? I reckon this must be a n00b mistake, I must be missing something...
Igor Posted August 18, 2016 Posted August 18, 2016 Please provide a link to the image you are installing.
timonoj Posted August 18, 2016 Author Posted August 18, 2016 I'm very sorry, I just noticed I missed what I was using and was heading already to post it.. http://mirror.igorpecovnik.com/Armbian_5.14_Bananapi_Ubuntu_xenial_4.6.2.7z Xenial server (vanilla) 4.6.2 for Banana Pi.
Igor Posted August 18, 2016 Posted August 18, 2016 It boots fine. How did you write an image? http://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card
timonoj Posted August 18, 2016 Author Posted August 18, 2016 I used dd if=./file of=/dev/sdc Since you mention it, I'll use the buffer size option and try again...
tkaiser Posted August 18, 2016 Posted August 18, 2016 I'm getting this error while trying to boot my Banana Pi with an SD card And does it then continue to boot after showing countless info, warnings or even errors or does booting stop?
timonoj Posted August 18, 2016 Author Posted August 18, 2016 ...aaaand it seems to get much further. But...still not. Stuck at "*Starting SSH Keys regeneration" for over 10 mins. Should I ssh into it? And does it then continue to boot after showing countless info, warnings or even errors or does booting stop? Yeah, it eventually crashed and stopped booting. It gave me an uboot prompt. But now it seems to load the kernel, although it still seems to be doing something...
tkaiser Posted August 18, 2016 Posted August 18, 2016 Getting stuck on u-boot prompt might be related to peripherals connected (I personally had weird USB peripherals causing this as well as a noisy power source leading to noise on RX of uart0 which prevented u-boot from continuing) so it's the best idea to disconnect everything expect serial console. Then we might have introduced a 'bad user experience' problem a few months ago since the board might be ready for login while the user waits for an automated reboot that will never happen with Xenial images. But since you mention 'Starting SSH Keys regeneration' (part of our firstrun script that does a lot in the background) it might also be related to insufficient power supply. Unless you power Banana Pi M1 through the SATA power port it's a known problem that many USB cables drop voltage too much under load due to high resistance. If you can try to exchange PSU and cable if problem persists. In case peripherals or a board powered SATA disk is connected please try without at least for first login. Once you got Armbian up and running you can monitor voltage available through sysfs and check whether that's the culprit or not
timonoj Posted August 18, 2016 Author Posted August 18, 2016 Hum...I was just waiting thinking maybe it was doing something extremely long. I just hit enter, just in case, and gave the login prompt back. So it seems after finishing whatever it was doing with the SSH keys, it didn't throw any further messages. I SSHed into it, and was prompted to change the password. Did a reboot and wasn't shown again any first boot script. Seems to work now!
tkaiser Posted August 18, 2016 Posted August 18, 2016 Hum...I was just waiting thinking maybe it was doing something extremely long. I just hit enter, just in case, and gave the login prompt back. Yeah, 'bad user experience' as already suspected. Since we had a few complaints regarding this we already had a look into it and Zador came up with some ideas that hopefully prevent this sort 'failure experience'...
timonoj Posted August 18, 2016 Author Posted August 18, 2016 Oh ok...not that horrible user experience, huh! So far it's looking good...I'll get into more complicated stuff now, thanks a lot!
zador.blood.stained Posted August 18, 2016 Posted August 18, 2016 Yeah, 'bad user experience' as already suspected. Since we had a few complaints regarding this we already had a look into it and Zador came up with some ideas that hopefully prevent this sort 'failure experience'... The main idea is - remove all extra messages from firstrun script. Since now we use fallocate instead of dd for emergency swap file creation and we don't update packages list on first boot, the script should execure fast enough that we don't need to output its progress. 1
