Hallo,
unfortunately i can't find the current orangepi image (https://www.armbian.com/orangepi/). The links to the images either go nowhere (404 file not found) or point to bananapi images.
What is the correct link for the current Ubuntu image for the Orangepi?
Thank you very much.
38 minutes ago, linda said:
Hallo,
It seems that not every redirect-server got the images at this time :(
So you may retry the link to get another redirect-server with the images or do use the follwoing one, which at this time got the images :)
https://mirrors.ustc.edu.cn/armbian-dl/bananapi/archive/
4 minutes ago, linda said:
Your link points to bananapi-images.
Which OrangePi exactly do you have? There are different models - some images are compatible with Bananas, mainly not.
