LocationUnknown Posted December 2, 2021 Posted December 2, 2021 I haven't tested using ssh yet. And yes at the time it was connected to my TV. But normally it's connected to my monitor which is 1920x1080.
balbes150 Posted December 3, 2021 Author Posted December 3, 2021 13 часов назад, LocationUnknown сказал: I haven't tested using ssh yet. And yes at the time it was connected to my TV. But normally it's connected to my monitor which is 1920x1080. ssh won't work (you don't have an address to connect to), until you have a proper LAN connection, you can't use it (judging by the log, you don't have an IP address assigned to the LAN)
observer1379 Posted December 12, 2021 Posted December 12, 2021 dude, help me please https://bbs.stationpc.com/forum.php?mod=viewthread&tid=209&page=2#pid716
balbes150 Posted December 22, 2021 Author Posted December 22, 2021 Version 20211222-edge with 5.16-rc6 kernel. Added support for HDMI audio. 1
balbes150 Posted December 27, 2021 Author Posted December 27, 2021 Ver 20211227-current kernel 5.16-rc6 for Station P2 (rk3568) and M2 (rk3566) Fixed LAN2. (Station P2 ) Fixed the reboot and shutdown of the Sd card. Added support for the on/off button. Now, after switching off, you do not need to pull the power supply out of the mains, just press the button on the P2 case. Also, the operating system turns off when the button is pressed briefly. 2
balbes150 Posted February 12, 2022 Author Posted February 12, 2022 Ver 20220211-edge kernel 5.17-rc3 20220210-edge kernel 5.16.8 20220209-legacy kernel 4.19.219 The good news is that Station M2 P2 is now included on the download page and after the official release, links to download the official versions will be available.
balbes150 Posted February 14, 2022 Author Posted February 14, 2022 New version 20220214 of images with 5.16 and 5.17 kernel for Station P2. All ports USB2\3, SATA, LED work, SD and eMMC operation speed is improved
redjr Posted February 14, 2022 Posted February 14, 2022 Hello, I'm just finding some time to get back to working with the Stationpc P2 after being away for a couple months. Lots of new updates and a new Bootloader and OS Assistant make getting a new OS up and running more easily now. My question is; If either an M.2 or SSD are installed, will the OS Assistant recognize multiple partitions for installation of 2 OS'es on a single device and allow the selection of installation? And then subsequently, those 2 OS options show up in the Bootloader? I want to give a shout out to @balbes150 for his dedication and effort on getting new builds, with more improvements to Armbian (on several platforms) up and running. It doesn't go unnoticed. I will happily contribute to the cause. Rick
balbes150 Posted February 15, 2022 Author Posted February 15, 2022 16 часов назад, redjr сказал: If either an M.2 PCI M2 is supported so far only with legacy core (4.19), there is no support for PCI M2 in the main core yet, only SATA works 16 часов назад, redjr сказал: will the OS Assistant I have Armbian installed in eMMC, and I do not know how the Assistant OS works
thc013 Posted February 16, 2022 Posted February 16, 2022 Huh i am not a owner of a m2 but i am a rk3566 user pci ? pcie not working ? https://gitlab.com/pine64-org/quartz-bsp/linux-next/-/commit/0e2d1d8ff6cfe4bca99de4906d6eb14a2416b2c6 well my pcie dvbc tv card works from what i understand it is not 100% stable with high loads , more the fine tunning and would be fixed if another thing got posted first in the kernel ow and hdmi in 5.10 does work , only trouble i have is with rga and the npu
redjr Posted February 17, 2022 Posted February 17, 2022 If you're replying to my post, that was not my question. I was curious if the Firefly bootloader and OS Assistant would recognize(and support) unique bootable partitions on either an M.2, or SSD. I've got my M.2 working great with one partition.
thc013 Posted February 17, 2022 Posted February 17, 2022 i didnt it depends how smart or stupid os-assistant program/script is not uboot . and in my opinion you could solve your answer with just a google search got 4 partitions and editing a extlinux.conf is easy .
balbes150 Posted February 18, 2022 Author Posted February 18, 2022 17.02.2022 в 02:24, thc013 сказал: Huh i am not a owner of a m2 but i am a rk3566 user What model are you writing about ? 17.02.2022 в 02:24, thc013 сказал: pcie not working ? I checked the DTB given by the link on M2, it is not working, HDMI LAN USB does not work with it. if compare the official DTS from Firefly, it has completely different parameters. In the latest version, 20220218-edge (5.17-rc4) NVMe runs on Station M2.
thc013 Posted February 19, 2022 Posted February 19, 2022 i got the model you should have by now or is on the way the firefly dts is weird core and then base and then model pcie was a little fixed months ago and lately someone noticed data corruption so they fixed that in the last 5.16, 5.17 last what i read about is that the patches are not included yet but you can find them , i see you included these usb3 and pcie patch. the 4.19 downstream rockchip also adjusted some pcie settings i wouldnt know if that dts works or not , proberly some litte changes it is a dts from the 5.13-14 and yeah comparing a downstream dts with a mainline is not 1 to 1 but you know that , but for mainline it is easy you have a good working dts for the quartz64 to begin a port for a m2 only a shematic a your almost done
balbes150 Posted February 20, 2022 Author Posted February 20, 2022 Added version 20220220-5.16 for Station M2 with NVMe and Wifi support
x893 Posted March 4, 2022 Posted March 4, 2022 Hello, can i use image 20220220-5.16 for Station M2 with Pine64 Quartz64 ? Thanks in advance
tenox Posted March 6, 2022 Posted March 6, 2022 Can someone help with the serial console? Is it RS232 RX/TX, _2 or _3 or 485 and what baud rate? Cycled through all baudrates and just getting garbage.
CryBaby Posted March 6, 2022 Posted March 6, 2022 5 hours ago, tenox2 said: Cycled through all baudrates and just getting garbage. Are you using minicom? Sometimes the baud rate is set to 1000000 or something really high and minicom only goes up to 150000. Try tmux or screen.
tenox Posted March 7, 2022 Posted March 7, 2022 6 hours ago, CryBaby said: Are you using minicom? Sometimes the baud rate is set to 1000000 or something really high and minicom only goes up to 150000. Try tmux or screen. I'm using picocomm, also tried minicom and putty on windows. Most importantly, which port should it be? RS232_2 _3 or RS485 with a RS458 to USB adapter? Thanks!
tenox Posted March 7, 2022 Posted March 7, 2022 Oh sorry, I was trying to use the "Control Port", I was hoping to see serial output there. Looks like I need to connect here https://wiki.t-firefly.com/en/ROC-RK3568-PC/debug.html
CryBaby Posted March 7, 2022 Posted March 7, 2022 That's a bit inconvenient. You might be able to move the console to the external port by changing the kernel boot command. Not sure what to, maybe ttyS3 or ttyS4.
jeanrhum Posted March 7, 2022 Posted March 7, 2022 On 3/4/2022 at 1:47 PM, x893 said: Hello, can i use image 20220220-5.16 for Station M2 with Pine64 Quartz64 ? Thanks in advance Hi, you can try, but take care of changing the dtb to use quartz64. My last try was successful and most basic features were working well.
x893 Posted March 7, 2022 Posted March 7, 2022 On 2/20/2022 at 1:14 PM, balbes150 said: Added version 20220220-5.16 for Station M2 with NVMe and Wifi support Hello, i try find instruction to build Armbian for RK3566 (Station M2 or other) but unsuccessfull. Can you provide link to instructions to build from sources ? Thanks in advance
balbes150 Posted March 8, 2022 Author Posted March 8, 2022 https://en.t-firefly.com/product/industry/itx3588j 1
balbes150 Posted March 8, 2022 Author Posted March 8, 2022 19 часов назад, x893 сказал: i try find instruction to build Armbian for RK3566 (Station M2 or other) but unsuccessfull. Which model do you want to build an image for ?
tenox Posted March 8, 2022 Posted March 8, 2022 How does Multi Boot bootloader affect Armbian in any way? https://wiki.stationpc.com/docs/stationpc/systembootloader
x893 Posted March 8, 2022 Posted March 8, 2022 23 minutes ago, balbes150 said: Which model do you want to build an image for ? I have 3 boards - Pine64 SOQuartz, Quartz64-A and X88 Pro 20. Now i build ubuntu (thanks @choggy13 from pine64 forum and github). But armbian more preffered for me (i use armbian for other boards-RPi, NanoPi, etc.). I found patches for Quartz64-A dts in armbian/build but can't find Quartz64 dts in tree.
tenox Posted March 8, 2022 Posted March 8, 2022 I can install this on to eMMC, boots and works fine: Armbian 22.02 Bullseye XFCE Kernel 4.19.y, Size: 856Mb, Updated: Feb 28, 2022 But this one won't boot after install to eMMC: Armbian 22.02 Jammy Kernel 5.16.y, Size: 366Mb, Updated: Feb 27, 2022 MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! loading... mmc_init: -95, time 9 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... fs_devread read outside partition 3221225368 fs_devread read outside partition 3221225368 fs_devread read outside partition 3221225368 fs_devread read outside partition 3221225368 fs_devread read outside partition 3221225368 fs_devread read outside partition 3221225368 Device 0: unknown device Any ideas?
balbes150 Posted March 9, 2022 Author Posted March 9, 2022 21 час назад, tenox2 сказал: How does Multi Boot bootloader affect Armbian in any way? The current version of Firefly multi-boot (which is installed in SPI) uses an outdated startup scheme that cannot work with new versions of Armbian. I am communicating with the Firefly developers to fix this issue. 21 час назад, x893 сказал: I have 3 boards - Pine64 SOQuartz, Quartz64-A Additional settings are needed to get a working image. In the near future I plan to add CSC settings for quartz64. 21 час назад, x893 сказал: X88 Pro 20 This hardware is not supported and will not work. 19 часов назад, tenox2 сказал: But this one won't boot after install to eMMC: Have you updated u-boot according to the instructions for Armbian? 1
