MrCoolAndroid Posted September 1, 2021 Posted September 1, 2021 Hello there! Before I start I'm gonna give a bit of information about my TV Box MXQ Pro 4K (S905W) 1GB RAM 8GB STORAGE Armbian 20.02 Kernel 5.5 (or that's what I remember) Okey, so I wanna install a Wi-Fi driver on Armbian I think my Wi-Fi chip is RTL8189ES (I'm gonna check tomorrow to be sure) I've looking on the forum and Google and so far I know that i need Linux headers, i installed them from armbian-config but i don't know if they are installed correctly, because I can't find them anywhere Then I need the RTL8189ES driver and run a Makefile Is this right? If so, what are the correct steps (like what exactly i need to do) and where I can find the Wi-Fi driver Any help is appreciated! Thanks
Clonazepunk Posted September 1, 2021 Posted September 1, 2021 Hi! If I remember, your wifi chip is already supported by Armbian. Try installing the package armbian-firmware-full it should do the trick, and save you a lot of time compiling the drivers from source Hope it helps!
MrCoolAndroid Posted September 1, 2021 Author Posted September 1, 2021 On 9/1/2021 at 3:49 PM, Clonazepunk said: Hi! If I remember, your wifi chip is already supported by Armbian. Try installing the package armbian-firmware-full it should do the trick, and save you a lot of time compiling the drivers from source Hope it helps! Expand Alright I will try! After installing i reboot? how can I check if it works?
MrCoolAndroid Posted September 1, 2021 Author Posted September 1, 2021 On 9/1/2021 at 3:49 PM, Clonazepunk said: Hi! If I remember, your wifi chip is already supported by Armbian. Try installing the package armbian-firmware-full it should do the trick, and save you a lot of time compiling the drivers from source Hope it helps! Expand So i installed the package but i don't see any changes or something, do I need to do something else? Like to install the driver that it's on some folder? I was looking up on the internet and I need to download the Linux headers (as I said before) but i can't find any one compatible with my system, using the armbian-config I tried to install it but i can't find the headers anywhere, what I can do?
Clonazepunk Posted September 1, 2021 Posted September 1, 2021 Well, to help you with the headers, I need to know which kernel exactly are you using. Show me the output of the command "uname -a", please Also, installing the package by itself should be enough to make the interface wlan0 to show up. But don't panic. Let's see the headers issue first
MrCoolAndroid Posted September 1, 2021 Author Posted September 1, 2021 On 9/1/2021 at 11:11 PM, Clonazepunk said: Well, to help you with the headers, I need to know which kernel exactly are you using. Show me the output of the command "uname -a", please Also, installing the package by itself should be enough to make the interface wlan0 to show up. But don't panic. Let's see the headers issue first Expand The output is Linux aml 5.5.0-rc6-aml-s9xxx #rc1.037 SMP PREEMPT Wed Feb 5 15:16:17 MSK 2020 aarch64 aarch64 aarch64 GNU/Linux (I don't know how to use a format to show the code better) Also thanks for answering and helping me!
SteeMan Posted September 2, 2021 Posted September 2, 2021 Are you sure your dtb file maps to the correct wifi? The purpose of the dtb is to map the hardware to the kernel. If you don't have the correct dtb you will never get the correct driver to load.
SteeMan Posted September 2, 2021 Posted September 2, 2021 As was stated in the FAQ, don't expect to get working wifi on these TV boxes. I have over 10 different boxes and wifi doesn't work on any of them. If you need/want wifi, the best way is through a usb wifi adapter.
MrCoolAndroid Posted September 2, 2021 Author Posted September 2, 2021 On 9/2/2021 at 12:20 AM, SteeMan said: As was stated in the FAQ, don't expect to get working wifi on these TV boxes. I have over 10 different boxes and wifi doesn't work on any of them. If you need/want wifi, the best way is through a usb wifi adapter. Expand Yes I was thinking on getting a WiFi adapter, and I have the p281 dtb, it's the S905W one
uropb Posted September 2, 2021 Posted September 2, 2021 From forum.manlaro : I got RTL8189ETV (may also works with rtl8189es) working with jwrdegoede/rtl8189ES_linux: (kernel : 5.13.12-1-MANJARO-ARM #1 SMP Wed Aug 18 07:36:58 UTC 2021 aarch64 GNU/Linux) git clone https://github.com/jwrdegoede/rtl8189ES_linux.git sudo pacman -S linux-headers cd /usr/lib/modules/5.13.12-1-MANJARO-ARM/build/arch sudo mv arm armold sudo mv arm64 arm cd ~/rtl8189ES_linux/ make -j4 ARCH=arm KSRC=/usr/lib/modules/5.13.12-1-MANJARO-ARM/build sudo cp 8189es.ko /usr/lib/modules/5.13.12-1-MANJARO-ARM/kernel/drivers/net/wireless/realtek/ sudo depmod -a sudo modprobe 8189es Check with nmtui or ip addr and rename arm&arm64 back. 2
Clonazepunk Posted September 2, 2021 Posted September 2, 2021 On 9/2/2021 at 12:32 AM, MrCoolAndroid said: Yes I was thinking on getting a WiFi adapter, and I have the p281 dtb, it's the S905W one Expand That's good to know Before trying anything else, you should try other dtb files, as stated by @SteeMan. I was lucky. My S905W box works like a charm with a realtek chip as well. you can do it without recompiling the kernel by using @balbes150images. There's a plenty of files to try out make sure you have the p281 board, of doesn't, try other dtb files if you're sure your board is a p281 (which also means it's defective from factory, with different hardware), then you should try to compile the drivers from the git you found ok, that's a lot of info. I'll keep helping you through this post, and sorry for the late replies. I suffer from some conditions that keeps me away from staying too much on the PC Hope It works!
Clonazepunk Posted September 2, 2021 Posted September 2, 2021 On 9/2/2021 at 3:55 PM, uropb said: From forum.manlaro : I got RTL8189ETV (may also works with rtl8189es) working with jwrdegoede/rtl8189ES_linux: (kernel : 5.13.12-1-MANJARO-ARM #1 SMP Wed Aug 18 07:36:58 UTC 2021 aarch64 GNU/Linux) git clone https://github.com/jwrdegoede/rtl8189ES_linux.git sudo pacman -S linux-headers cd /usr/lib/modules/5.13.12-1-MANJARO-ARM/build/arch sudo mv arm armold sudo mv arm64 arm cd ~/rtl8189ES_linux/ make -j4 ARCH=arm KSRC=/usr/lib/modules/5.13.12-1-MANJARO-ARM/build sudo cp 8189es.ko /usr/lib/modules/5.13.12-1-MANJARO-ARM/kernel/drivers/net/wireless/realtek/ sudo depmod -a sudo modprobe 8189es Check with nmtui or ip addr and rename arm&arm64 back. Expand Manjaro is a good choice It works out of the box with my S905W board! Thanks for pointing out. I forgot that
MrCoolAndroid Posted September 2, 2021 Author Posted September 2, 2021 On 9/2/2021 at 6:47 PM, Clonazepunk said: That's good to know Before trying anything else, you should try other dtb files, as stated by @SteeMan. I was lucky. My S905W box works like a charm with a realtek chip as well. you can do it without recompiling the kernel by using @balbes150images. There's a plenty of files to try out make sure you have the p281 board, of doesn't, try other dtb files if you're sure your board is a p281 (which also means it's defective from factory, with different hardware), then you should try to compile the drivers from the git you found ok, that's a lot of info. I'll keep helping you through this post, and sorry for the late replies. I suffer from some conditions that keeps me away from staying too much on the PC Hope It works! Expand I would like to try another DTBs, the problem is that Armbian is installed on the eMMC haha, anyways I think I'm just gonna buy a WiFi adapter or try with what @uropb said, and don't worry it's all good, stay safe!
MrCoolAndroid Posted September 2, 2021 Author Posted September 2, 2021 On 9/2/2021 at 3:55 PM, uropb said: From forum.manlaro : I got RTL8189ETV (may also works with rtl8189es) working with jwrdegoede/rtl8189ES_linux: (kernel : 5.13.12-1-MANJARO-ARM #1 SMP Wed Aug 18 07:36:58 UTC 2021 aarch64 GNU/Linux) git clone https://github.com/jwrdegoede/rtl8189ES_linux.git sudo pacman -S linux-headers cd /usr/lib/modules/5.13.12-1-MANJARO-ARM/build/arch sudo mv arm armold sudo mv arm64 arm cd ~/rtl8189ES_linux/ make -j4 ARCH=arm KSRC=/usr/lib/modules/5.13.12-1-MANJARO-ARM/build sudo cp 8189es.ko /usr/lib/modules/5.13.12-1-MANJARO-ARM/kernel/drivers/net/wireless/realtek/ sudo depmod -a sudo modprobe 8189es Check with nmtui or ip addr and rename arm&arm64 back. Expand I will try this and will let u know how it goes!
Clonazepunk Posted September 2, 2021 Posted September 2, 2021 On 9/2/2021 at 7:19 PM, MrCoolAndroid said: I would like to try another DTBs, the problem is that Armbian is installed on the eMMC haha, anyways I think I'm just gonna buy a WiFi adapter or try with what @uropb said, and don't worry it's all good, stay safe! Expand But that's no problem You still can edit the extlinux.conf file, inside the boot partition Just take care of not setting up any invalid option in it, else you'll break your system (Though it's easy to recover)
MrCoolAndroid Posted September 2, 2021 Author Posted September 2, 2021 On 9/2/2021 at 8:09 PM, Clonazepunk said: But that's no problem You still can edit the extlinux.conf file, inside the boot partition Just take care of not setting up any invalid option in it, else you'll break your system (Though it's easy to recover) Expand Oh alright, now the problem is if the DTB doesn't work, how can I change it? And I'm trying to uropb solution and so far so good, the problem now is trying to download a compatible linux header, i tried with meson64 header and everything ok compiling, but the version magic doesn't match so it can't be installed, the same if I do modprobe -f
MrCoolAndroid Posted September 3, 2021 Author Posted September 3, 2021 On 9/2/2021 at 3:55 PM, uropb said: From forum.manlaro : I got RTL8189ETV (may also works with rtl8189es) working with jwrdegoede/rtl8189ES_linux: (kernel : 5.13.12-1-MANJARO-ARM #1 SMP Wed Aug 18 07:36:58 UTC 2021 aarch64 GNU/Linux) git clone https://github.com/jwrdegoede/rtl8189ES_linux.git sudo pacman -S linux-headers cd /usr/lib/modules/5.13.12-1-MANJARO-ARM/build/arch sudo mv arm armold sudo mv arm64 arm cd ~/rtl8189ES_linux/ make -j4 ARCH=arm KSRC=/usr/lib/modules/5.13.12-1-MANJARO-ARM/build sudo cp 8189es.ko /usr/lib/modules/5.13.12-1-MANJARO-ARM/kernel/drivers/net/wireless/realtek/ sudo depmod -a sudo modprobe 8189es Check with nmtui or ip addr and rename arm&arm64 back. Expand Hey there! Sorry to bother u, do you have any Linux header compatible with my kernel? uname -r 5.5.0-rc6-aml-s9xxx If not, is there a way to change a module's version magic? Because I can compile it correctly but i can't modprobe or insmod
MrCoolAndroid Posted September 5, 2021 Author Posted September 5, 2021 On 9/3/2021 at 11:35 PM, uropb said: Expand Hey there! So after installing the header and compiling i get the error: Building modules, stage 2. MODPOST 1 modules /bin/sh: 1: scripts/mod/modpost: Exec format error scripts/Makefile.modpost:93: recipe for target '__modpost' failed make[2]: *** [__modpost] Error 2 Makefile:1606: recipe for target 'modules' failed make[1]: *** [modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.5.0-rc6-arm-64' Makefile:1640: recipe for target 'modules' failed make: *** [modules] Error 2 And doing file modpost on scripts/mod/modpost it's on _x86-64
MrCoolAndroid Posted September 5, 2021 Author Posted September 5, 2021 Somehow I don't see @uropbpost but i saw it before and answered to it, So i re-posted something recently that i already posted before but i can't see it for some reason
balbes150 Posted September 6, 2021 Posted September 6, 2021 On 9/5/2021 at 3:24 PM, MrCoolAndroid said: Somehow I don't see @uropbpost but i saw it before and answered to it, So i re-posted something recently that i already posted before but i can't see it for some reason Expand The links are deleted.
MrCoolAndroid Posted September 6, 2021 Author Posted September 6, 2021 On 9/6/2021 at 7:04 AM, balbes150 said: The links are deleted. Expand Oh alright... I will not post those again
Igor Posted September 7, 2021 Posted September 7, 2021 Perhaps its related. External module compilation was broken in official experimental kernels, but it was fixed yesterday. So once kernel packages will be rebuild, external modules compilation will work again. https://github.com/armbian/build/issues/3103#issuecomment-913806735
MrCoolAndroid Posted September 7, 2021 Author Posted September 7, 2021 On 9/7/2021 at 5:50 AM, Igor said: Perhaps its related. External module compilation was broken in official experimental kernels, but it was fixed yesterday. So once kernel packages will be rebuild, external modules compilation will work again. https://github.com/armbian/build/issues/3103#issuecomment-913806735 Expand Oh alright, on others headers (like sunxi header) the compilation works of course, but the version magic doesn't match
Bernie.Wieser Posted April 4, 2023 Posted April 4, 2023 I installed headers, ran armbian-config to install sources, and get an error says lib modules build doesn't exist. Lib modules is full of stuff - so what am I missing?
SteeMan Posted April 4, 2023 Posted April 4, 2023 @Bernie.Wieser Please provide more information on what you have and what you are trying to do along with errors reported. First what build are you running and on what hardware? Second what are you trying to do that you have installed headers? Third, what errors are you getting when you do the thing you are trying to do.
