lampra Posted September 9, 2021 Posted September 9, 2021 Armbianmonitor: http://ix.io/3ykc **Is this the correct location, or it should be at the other supported boards? It seems that DT overlays are not working root@orangepizero2:~# cat /boot/armbianEnv.txt verbosity=1 console=serial disp_mode=1080p60 fb0_width=1280 fb0_height=720 rootdev=UUID=b8899b39-b6cb-4718-bdbb-e1b39816db74 rootfstype=ext4 overlays=w1-gpio param_w1_pin=PC9 param_w1_pin_int_pullup=1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Boot log: Spoiler [41]HELLO! BOOT0 is starting May 13 2020 14:10:04! [46]BOOT0 commit : 593cf83 [48]set pll start [51]periph0 has been enabled [54]set pll end [56]unknow PMU [57]PMU: AXP806 [64]vaild para:1 select dram para0 [68]board init ok [69]DRAM BOOT DRIVE INFO: V0.52 [73]the chip id is 0x5000 [75]chip id check OK [77]DRAM_VCC set to 1500 mv [81]read_calibration error [85]read_calibration error [89]read_calibration error [93]read_calibration error [97]read_calibration error [100]read_calibration error [104]read_calibration error [108]read_calibration error [112]read_calibration error [116]read_calibration error [119]retraining final error [123][AUTO DEBUG]32bit,1 ranks training success! [131]DRAM CLK =720 MHZ [133]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [139]Actual DRAM SIZE =512 M [142]DRAM SIZE =512 MBytes, para1 = 30ea, para2 = 2000000, dram_tpr13 = 6041 [155]DRAM simple test OK. [158]rtc standby flag is 0x0, super standby flag is 0x0 [163]dram size =512 [165]*****dram handle ok**** [169]card no is 0 [171]sdcard 0 line count 4 [173][mmc]: mmc driver ver 2019-12-19 10:41 [178][mmc]: sdc0 spd mode error, 2 [181][mmc]: set f_max to 50M, set f_max_ddr to 25M [186][mmc]: mmc 0 bias 0 [194][mmc]: Wrong media type 0x0 [197][mmc]: ***Try SD card 0*** [217][mmc]: HSSDR52/SDR25 4 bit [220][mmc]: 50000000 Hz [222][mmc]: 15193 MB [224][mmc]: ***SD/MMC 0 init OK!!!*** [326]Loading boot-pkg Succeed(index=0). [330]Entry_name = u-boot [339]Entry_name = monitor [343]Entry_name = dtbo [345]Entry_name = dtb [349]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-armbian (Aug 28 2021 - 20:00:15 +0200) Xunlong Software [00.426]CPU: Allwinner H616 [00.429]Model: Orange Pi Zero 2 I2C: ready [00.433]DRAM: 512 MiB Relocation Offset is: 15ec9000 [00.473]secure enable bit: 0 [00.476]PMU: AXP806 [00.480]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.662]sunxi overlay merged okqv [00.666]drv_disp_init [00.695]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.700]drv_disp_init finish [00.703]gic: sec monitor mode [00.708]flash init start [00.710]workmode = 0,storage type = 1 [00.714]MMC: 0 [00.715]get mem for descripter OK ! card_caps:0x3000000a host_caps:0x3000003f [00.752]sunxi flash init ok [00.756]Loading Environment from FAT... [00.759]get mem for descripter OK ! ** Bad device mmc 1 ** Failed (-5) [00.774]usb burn from boot delay time 0 weak:otg_phy_config [00.788]usb prepare ok [01.591]overtime [01.595]do_burn_from_boot usb : no usb exist [01.599]boot_gui_init:start card_caps:0x3000000a host_caps:0x3000003f 250 bytes read in 10 ms (24.4 KiB/s) Set HDMI disp_mode to 1080p60 250 bytes read in 9 ms (26.4 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [01.932]boot_gui_init:finish [01.935]bmp_name=/boot/boot.bmp 230454 bytes read in 20 ms (11 MiB/s) [01.971]update dts Net: [01.974]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 card_caps:0x3000000a host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2612 bytes read in 11 ms (231.4 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 250 bytes read in 9 ms (26.4 KiB/s) 6696232 bytes read in 297 ms (21.5 MiB/s) 24127560 bytes read in 1022 ms (22.5 MiB/s) ## Booting kernel from Legacy Image at 41000000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 24127496 Bytes = 23 MiB Load Address: 41000000 Entry Point: 41000000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 6696168 Bytes = 6.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Ramdisk to 4999d000, end 49fffce8 ... OK reserving fdt memory region: addr=48000000 size=1000000 ## Linux machid: 00000000, FDT addr: 5be89580 Starting kernel ... Loading, please wait... Starting version 247.3-6 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.36.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 157906/1106368 files, 946236/3845120 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Armbian 21.08.2 Bullseye! [ OK ] Created slice system-getty.slice. [ OK ] Created slice system-modprobe.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Created slice User and Session Slice. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ OK ] Reached target Local Encrypted Volumes. [ OK ] Reached target Paths. [ OK ] Reached target Slices. [ OK ] Reached target Swap. [ OK ] Reached target System Time Set. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on Syslog Socket. [ OK ] Listening on fsck to fsckd communication Socket. [ OK ] Listening on initctl Compatibility Named Pipe. [ OK ] Listening on Journal Audit Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket. [ OK ] Listening on udev Control Socket. [ OK ] Listening on udev Kernel Socket. Mounting Huge Pages File System... Mounting POSIX Message Queue File System... Mounting RPC Pipe File System... Mounting Kernel Debug File System... Starting Restore / save the current clock... Starting Set the console keyboard layout... Starting Create list of st…odes for the current kernel... Starting Load Kernel Module configfs... Starting Load Kernel Module drm... Starting Load Kernel Module fuse... [ OK ] Started Nameserver information manager. [ OK ] Reached target Network (Pre). Starting Load Kernel Modules... Starting Remount Root and Kernel File Systems... Starting Coldplug All udev Devices... [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted RPC Pipe File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Finished Restore / save the current clock. [ OK ] Finished Create list of st… nodes for the current kernel. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Set the console keyboard layout. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Load/Save Random Seed... Starting Create System Users... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Create System Users. Starting Create Static Device Nodes in /dev... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... Starting Helper to synchronize boot up for ifupdown... Starting Rule-based Manage…for Device Events and Files... [ OK ] Mounted /tmp. [ OK ] Finished Helper to synchronize boot up for ifupdown. [ OK ] Reached target Local File Systems. Starting Armbian ZRAM config... Starting Set console font and keymap... Starting Preprocess NFS configuration... [ OK ] Finished Set console font and keymap. [ OK ] Finished Preprocess NFS configuration. [ OK ] Finished Load Kernel Modules. [ OK ] Reached target NFS client services. Starting Apply Kernel Variables... [ OK ] Finished Apply Kernel Variables. [ OK ] Started Rule-based Manager for Device Events and Files. Starting Raise network interfaces... [ OK ] Reached target Hardware activated USB gadget. [ OK ] Finished Raise network interfaces. [ OK ] Found device /dev/ttyS0. [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. Starting Load/Save RF Kill Switch Status... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Finished Armbian ZRAM config. Starting Armbian memory supported logging... [ OK ] Finished Armbian memory supported logging. Starting Journal Service... [ OK ] Started Journal Service. Starting Flush Journal to Persistent Storage... [ OK ] Finished Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. [ OK ] Started Entropy Daemon based on the HAVEGE algorithm. Starting RPC bind portmap service... Starting Update UTMP about System Boot/Shutdown... [ OK ] Finished Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. Starting Armbian hardware monitoring... Starting Armbian hardware optimization... [ OK ] Started RPC bind portmap service. [ OK ] Finished Armbian hardware monitoring. [ OK ] Reached target Remote File Systems (Pre). [ OK ] Reached target Remote File Systems. [ OK ] Reached target RPC Port Mapper. [ OK ] Finished Load/Save Random Seed. [ OK ] Finished Armbian hardware optimization. [ OK ] Reached target Basic System. Starting Save/Restore Sound Card State... Starting Bluetooth AW859A... [ OK ] Started Regular background program processing daemon. [ OK ] Started D-Bus System Message Bus. Starting Network Manager... Starting Remove Stale Onli…t4 Metadata Check Snapshots... Starting Init Hdmi Audio... Starting LSB: Load kernel …d to enable cpufreq scaling... Starting Dispatcher daemon for systemd-networkd... Starting System Logging Service... Starting Self Monitoring a…g Technology (SMART) Daemon... Starting Resets System Activity Logs... Starting User Login Management... Starting WPA supplicant... [ OK ] Finished Save/Restore Sound Card State. [ OK ] Started Bluetooth AW859A. [ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots. [ OK ] Started Init Hdmi Audio. [ OK ] Reached target Sound Card. [ OK ] Finished Resets System Activity Logs. Starting Bluetooth service... Starting Load/Save RF Kill Switch Status... [ OK ] Started LSB: Load kernel m…ded to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started LSB: set CPUFreq kernel parameters. [ OK ] Started System Logging Service. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started User Login Management. [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. [ OK ] Started Self Monitoring an…ing Technology (SMART) Daemon. [ OK ] Started WPA supplicant. [ OK ] Started Bluetooth service. [ OK ] Reached target Bluetooth. Starting Hostname Service... [ OK ] Started Hostname Service. [ OK ] Started Network Manager. [ OK ] Reached target Network. [ OK ] Reached target Network is Online. Starting chrony, an NTP client/server... Starting LSB: Advanced IEEE 802.11 management daemon... Starting OpenVPN service... Starting /etc/rc.local Compatibility... Starting OpenBSD Secure Shell server... Starting Permit User Sessions... [ OK ] Started Unattended Upgrades Shutdown. [ OK ] Started vnStat network traffic monitor. [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Finished OpenVPN service. [ OK ] Started /etc/rc.local Compatibility. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ OK ] Reached target Login Prompts. [ OK ] Started chrony, an NTP client/server. [ OK ] Reached target System Time Synchronized. [ OK ] Started Daily apt download activities. [ OK ] Started Daily apt upgrade and clean activities. [ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems. [ OK ] Started Discard unused blocks once a week. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily man-db regeneration. [ OK ] Started Run system activit…ounting tool every 10 minutes. [ OK ] Started Generate summary o…esterday's process accounting. [ OK ] Reached target Timers. [ OK ] Started OpenBSD Secure Shell server. Starting Network Manager Script Dispatcher Service... [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started Dispatcher daemon for systemd-networkd. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Finished Update UTMP about System Runlevel Changes. Armbian 21.08.2 Bullseye ttyS0
Werner Posted September 9, 2021 Posted September 9, 2021 4 hours ago, lampra said: **Is this the correct location, or it should be at the other supported boards? I guess I'll add H616 in this section somewhen so it is fine.
