The LED1 and LED2 on the BanabaPi Pro. How do I get them to show MMC card usage and the watchdog heart beat?
Go to solution Solved by Werner,
Hello all. A possible mission impossible challenge for someone who wishes to accept it and this message will not self-destruct in 10 seconds.  :-)
The LED1 (green) and LED2 (blue) on the BanabaPi Pro. How do I get them to show the watchdog heart beat and the MMC card usage?
An out-of-date Rasbian Distro for the Lemaker BananaPi Pro had this feature this right-out-of-the-box, but at the moment on Armbian I've only got the steady red power LED. Is there a way to enable this functionality within Armbian?
  • Solution
I usually do the noob way finding the trigger files for LEDs :P
du -a /sys | grep led | grep trigger
I don't know what trigger is needed for mmc but heartbeat is self-explaining. echo heartbeat > trigger
Pssst ... If you cat the trigger file, it'll tell you the valid options, and which one is currently selected.
tparys@laptop:~$ cat /sys/class/leds/input4\:\:capslock/trigger
none usb-gadget usb-host rfkill-any rfkill-none kbd-scrolllock kbd-numlock [kbd-capslock]
kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock
kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock ACAD-online BAT0-charging-or-full
BAT0-charging BAT0-full BAT0-charging-blink-full-solid disk-activity disk-read disk-write
ide-disk mtd nand-disk cpu cpu0 cpu1 cpu2 cpu3 cpu4 cpu5 cpu6 cpu7 panic mmc0 rfkill0
phy0rx phy0tx phy0assoc phy0radio rfkill1 audio-mute audio-micmute
I'd wager the correct trigger is "mmc0", unless there's a both a SD card and eMMC slot on that board?
19 hours ago, Myron said:
The LED1 (green) and LED2 (blue) on the BananaPi Pro. How do I get them to show the watchdog heart beat and the MMC card usage?
on my BananaPi M1 I can only control the green LED, but for that usage I do use the following command-line:
echo 'mmc0' > /sys/class/leds/bananapi:green:usr/trigger
only green LED available:
# ls -l  /sys/class/leds/
lrwxrwxrwx 1 root root 0 Sep 11 22:11 bananapi:green:usr ->  ./../devices/platform/leds/leds/bananapi:green:usr
Thank-you.  I have got a lot to learn and at the moment my learning curve is as steep as a Saturn 5 rocket blasting off and going into orbit.  I am self-educating way more than I am asking questions.
echo heartbeat > /sys/devices/platform/leds/leds/bananapro:blue:usr/trigger
echo mmc0 > /sys/devices/platform/leds/leds/bananapro:green:usr/trigger
Erm.....  {sheepish look to my face and batting eyelids . . . .}  How do I get this to persist across reboots, or the file I need to alter to make this the default.  :-)
EDIT: I think I found answer to my question.  https://smallbusiness.chron.com/run-command-startup-linux-27796.html  Is this correct?
Thank-you everyone. I would mark multiple solutions, but the board only allows me to mark one.
I got it working. Used the cron @reboot method on user root.  The LEDs are useful where on the screen it may look like it's got stuck, the LEDs will at least show if there is some activity and if the SOC is still got a heartbeat.  I'm still a noob on the higher technical issues of Linux.  I have one more question to ask and that will be in another thread.    (Yes, I will donate!  I've seen the donate link on the Armbian home page, but as you all know, the budget that keeps the roof over the head, electricity supplied, food on the table, etc... is priority. Shall donate what I can, when I can.)
EDIT: I finally ended up using the /etc/rc.local method.  Thank-you @Werner and @guidol.
Yes. I knew this.  What happened is that I totally forgot about the /sys folder and then I remember that it's quite a large tree. Didn't think about using du and grep that way.
Yep, Working perfectly.  [Now only if I could get xdrp, X and xfce4 play nicely. That's another thread.]
