eClapton Posted October 4, 2021 Posted October 4, 2021 Hello I need to change a drive in the Helios64, and so I bought a new WD 2TB drive. Using a WD My Book 111D USB enclosure, I have partitioned, formatted and copied the data from the old drive. But when I change the drives to put the new one in the Helios64, the drive appears unformatted. See below. I can't understand what's happening, when I plug it back through USB everything is back to normal. Does the partitioning through USB differ somehow??? It appears as if the partition table "stays in the USB enclosure", which doesn't make sense for me. Is there something to try? Do I have to start again the process in the NAS enclosure? I don't want to spend 6+ hours copying everything back... I'm using armbian 5.10.35-rockchip64, and OMV 5. The disk appears in /dev/sda. When connected through SATA: eclapton@helios64:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 1,8T 0 disk sdb 8:16 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sdc 8:32 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sdd 8:48 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sde 8:64 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup mmcblk2 179:0 0 14,6G 0 disk └─mmcblk2p1 179:1 0 14,4G 0 part / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk When connected through USB: eclapton@helios64:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 1,8T 0 disk ├─sda1 8:1 0 1,2T 0 part └─sda2 8:2 0 613G 0 part sdb 8:16 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sdc 8:32 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sdd 8:48 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sde 8:64 0 931,5G 0 disk └─md0 9:0 0 2,7T 0 raid5 /srv/dev-disk-by-label-Backup sr0 11:0 1 30M 0 rom mmcblk2 179:0 0 14,6G 0 disk └─mmcblk2p1 179:1 0 14,4G 0 part / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk
Werner Posted October 4, 2021 Posted October 4, 2021 Maybe encryption is enabled on mybook and that is why removed from the enclosure it cannot be read?
eClapton Posted October 4, 2021 Author Posted October 4, 2021 There’s no option for that, it’s just an enclosure. The drives formatted from the helios64, in ext4. An encription would cause even the partition table to disappear??
Werner Posted October 4, 2021 Posted October 4, 2021 Depends on implementation which can be just guessed on proprietary stuff.
eClapton Posted October 4, 2021 Author Posted October 4, 2021 Gonna write down the partition table again.. lets see... Funny thing is, now fdisk says : Disk /dev/sda: 1,8 TiB, 2000398934016 bytes, 3907029168 sectors Disk model: WDC WD20EFAX-68F Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: dos Disk identifier: 0x899593b4 But before (I have a txt copy) it said: Disk /dev/sdf: 1.8 TiB, 2000365289472 bytes, 3906963456 sectors Disk model: My Book 111D Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: A82DBF47-D710-4648-96E9-74B44F5FCA0F Device Start End Sectors Size Type /dev/sdf1 2048 2441406250 2441404203 1.1T Linux filesystem /dev/sdf2 2441406464 3906963422 1465556959 698.9G Linux filesystem Physical sector size is now different???? Does that make sense to you? Thanks
eClapton Posted October 4, 2021 Author Posted October 4, 2021 Looking up on Google @Werner was right: the WD My book has a chip to encrypt the drive. Wiped it up and started anew. Thanks!!
