Armbianmonitor:
Hello all,
I wanted to start using the camera on my RockPI 4B today, but unfortunately I can't find an entry for it under "armbian-config" and under "boot/config*" I personally can't clearly identify the setting/parameter for it.
Can you please help me with this? That would be very helpful for me, thank you.
Kind regards
Z. Matthias
Moved to Common issues / peer to peer technical support
since it is untested 3rd party hardware
16 hours ago, Zhexue. said:
Armbianmonitor:
Hello all,
Kind regards
Z. Matthias
Hello. You are using a "current" image, for the camera to work you need a "legacy" image. There you have overlays to enable the rpi cameras, version 1 and 2, but I am not sure if the NoIR will work.
You need to use the RK Gstreamer plugin from the RK Multimedia Framework, instructions on this post. Please share your results here, I am very interested to know if it works or not.
Hey JMCC,
thank you so much for your help.
But I can't find this file: media-buster-legacy-rk3399
So, what can I do now? IS there any other subjects or ideas?
best regards from Berlin
Z. Matthias
