/dev/zram.. - Configuration ....
Armbianmonitor:
Hello all,
I have a question today regarding ARMBIAN - Linux and the configuration of the ZRAM ....
Under the ARMBIAN for RockPI 4 I have a ZRAM for the SWAP and a ZRAM for /var/log.
Is it possible that I change this configuration and use the eMMC memory for these two areas?
Because the big problem with /var/log is that it is simply too small and thus constantly runs into "ERROR" -> volume full.
Thank you very much and I am looking forward to constructive contributions to solve my problem.
Kind regards
Hey Werner,
thank you very much for this help. And YES, that was it. In first time, I disable the following 2 Services:
* armbian-ramlog.service
* armbian-zram-config.service
With ONLY disabling the service "armbian-zram-config.service", it was not enough.
But now, it is work and I am happy, because one of my system has still shutdown this night while the volume "/var/log" is going to 100%....
Thank you very much for your help...
Z. Matthias
