Hi whoever can help.
Just bought the Topic device.
Very disappointed because of very poor docs and support.
I cannot boot Armbian.
There are must be something undocumented.
I just burnt image desktop Armbian with dd if=image of=/dev/sdc to SD but it is ext4 on /dev/sdc1 and fsck reports good.
Well I made it is bootable by setting boot flag in partition but the device is not going to boot. None of leds is lighting.
The device is booting well without any SD from it's internal flash into Android. (How to put there Armbian by the way?)
It is also booting into Android from SD which I burnt under Windows(!!!!) with a "special" buggy tool Phoenix (Crazy!!!)
What a trick should be to run Armbian?
Thanks in advance to anybody who can advise about this magic?
PS. The most intelligent advise was on Orange PI site that everybody who is trying to boot up must be patient because the first boot is always long!!! This is awesome!!! How long to be patient!!!
I followed carefully to all 3 your advices but the same result: no lights and no booting for at least 5 minutes.
Can somebody send the CRC of the Armbian image? (I mean sha or md5 sum)
Can somebody write what red and green leds mean?
Is it right that FAT is not requred and system should be able to boot exactly from ext4 without any config files?
Below is my log where I put Armbian image into the same OK-boot flash with Android.
auto@cors40u:/media/auto$ sudo fdisk /dev/sdc
[sudo] password for auto:
Welcome to fdisk (util-linux 2.27.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p
Disk /dev/sdc: 7,4 GiB, 7892631552 bytes, 15415296 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot   Start      End  Sectors  Size Id Type
/dev/sdc1       4923392 15413246 10489855    5G  b W95 FAT32
/dev/sdc2  *      73728   106495    32768   16M  6 FAT16
/dev/sdc3             1  4923392  4923392  2,4G 85 Linux extended
/dev/sdc5        106496   139263    32768   16M 83 Linux
/dev/sdc6        139264   172031    32768   16M 83 Linux
/dev/sdc7        172032  1744895  1572864  768M 83 Linux
/dev/sdc8       1744896  1777663    32768   16M 83 Linux
/dev/sdc9       1777664  1843199    65536   32M 83 Linux
/dev/sdc10      1843200  3416063  1572864  768M 83 Linux
/dev/sdc11      3416064  3448831    32768   16M 83 Linux
/dev/sdc12      3448832  3481599    32768   16M 83 Linux
/dev/sdc13      3481600  3514367    32768   16M 83 Linux
/dev/sdc14      3514368  3579903    65536   32M 83 Linux
/dev/sdc15      3579904  3612671    32768   16M 83 Linux
/dev/sdc16      3612672  4923391  1310720  640M 83 Linux
Partition table entries are not in disk order.
Command (m for help): q
auto@cors40u:/media/auto/DATA/_ISO/ambian4opi$ sudo dd if=Armbian_5.14_Orangepiplus2e_Debian_jessie_3.4.112_desktop.raw of=/dev/sdc bs=4M
667+1 records in
667+1 records out
2799697920 bytes (2,8 GB, 2,6 GiB) copied, 420,613 s, 6,7 MB/s
auto@cors40u:/media/auto/DATA/_ISO/ambian4opi$ sudo fdisk /dev/sdc
Disklabel type: dos
Disk identifier: 0x7143b565
/dev/sdc1        2048 5468159 5466112  2,6G 83 Linux
As Igor said, try reading the documentation: http://docs.armbian.com/User-Guide_Getting-Started/
The fourth topic there will tell you how to check the download.
On linux, after dd has finished, don't forget to do a 'sync'.
Most common problems: faulty SD-card (happens a lot), faulty power supply.
Tip: attach a ttl-usb cable between your orange pi and your pc and watch what happens on boot.
I knew about pgp 20 years ago. Are we going back to the Future? :)
1. I want md5sum /dev/sdc1 This is only the FASTEST TRUE way to check if everything is right with the image burnt already.
2. I need to know if the leds do not flash/lights in 10 seconds does it worth to wait for 5 minutes or MORE? or start to think what is wrong?
How patient should I be? What does this term mean on Orange PI official web-site? "BE PATIENT" = how much time?
3. Still nobody advised if EXT4 is good for direct booting by small PC? Why am I asking?
Because EXT4 is not simple like FAT and needs drivers to be preloaded or at least such trick boot system like grub is.
Is that so difficult to document for novice users like I am?
If I need to dance with debug tools around usb in such a VERY trivial situation I would rather prefer to quit back to OTHER system.
Sorry to say that in the community which I would like to join.
All Armbian images are using a U-Boot that is EXT4 aware, so SD images has only one EXT4 partition.
As Pieter said, checking the debug serial output will help to figure where it is choking.
  Quote
Won't help you if u-boot or SPL are corrupted
The only way to see what is happening is UART console. LEDs are controlled from software, so they can't tell you much.
You can't put whole rootfs on FAT partition (at least without some very strong magic to emulate file permissions and owner information). These "small PCs" are using u-boot which does have ext4 filesystem drivers, well, unless you build your image on Debian Stretch (testing) or sid, which uses ext4 flags not supported by u-boot.
Yes. Compared to Raspberry Pi, these boards are not perfect for novice users, and also most things are already documented (i.e. here)
I wouldn't call this a trivial situation. If you search through this forum, you can see that most of early boot problems are related to either SD card problems (including using wrong/incomplete procedure for writing an image) or power supply problems (or interference from connected USB peripherials), but it may take ages and insane efforts to force users to admit that problem is on theirs side.
These images are designed to work out of the box, you don't need to touch anything related to partition table
Perfect! Thank you guys! I will try harder!
But I would like your last comments go to the FAQ. :)
Clear, Understanding, Perfect! Of course for the novice but what it is you guys must want our circle to grow. :)
Thanks again, no questions anymore this time.
PS. But one remark I would like to make: some flashing leds must be during boot up to give advise to the others that everything is going on the way during some seconds. I believe the image can include such software feature. For example why give someone a hope that something can be fine if it is not going to be. Please look at the others who developed such software. "BE PATIENT" is not the case. Must be some expectations.
UART output:
U-Boot SPL 2016.05-armbian (Jun 01 2016 - 20:28:42)
DRAM: 2048 MiB
Trying to boot from MMC2
(flashing cursor forever)
What could that mean?
PGP Signature OK
Voltage 5.11B Current: 0.20A
PS: Samsung 5V/2A
No any USB attached
MicroSD Transcend Premium 400x 16GB (tested and working very good)
What is VERY strange for me is that without SD card inserted the output of UART is completely different.
I believe that something on start should be the same???
auto@cors40u:~$ head orange.log
HELLO! BOOT0 is starting!
boot0 version : 4.2.0
boot0 commit : c8c201b51b7ea1baa94590a1887313124d9a5879
fel_flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
auto@cors40u:~$
Xenial Server
BUT the green led is ON
After about 10 minutes!: Power OFF/ON (Cycle)
Trying to boot from MMC1 !!!!!!!!!
After that the image loaded restarted,  loaded again from MMC1
Login: root
Change password
Change Display setting
Reboot to take effect
Booted into Android on internal flash
Power cycling
Booted into Ubuntu
All those things followed with some errors. I do not know if they are vital...
After apt-get upgrade and shutdown the luck came to an end. :)
Looks like U-Boot also upgraded.
The Green Led is always ON but:
What is it??? Any Idea??? How to force MMC1?
U-Boot SPL 2016.05-armbian (Jul 05 2016 - 17:49:12)
DRAM: 2048 MiB
DRAM: 2048 MiB
DRAM: 2048 MiB
DRAM: 2048 MiB
DRAM: 2048 MiB
DRAM: 2048 MiB
DRAM: 2048 MiB
  On 9/5/2016 at 6:59 AM, dnm2dnm said:
Xenial Server
This may be u-boot related: https://irclog.whitequark.org/linux-sunxi/2016-09-04#17460244;
In simple words - all boards with eMMC may be affected by random boot problems, but in a week new u-boot version should be released and this issue should be fixed.
Meanwhile maybe we should make a few test images with new u-boot (2016.09-rc2) to confirm that this fixes the problem
Are you asking me about something?
With current u-boot , you clearly can't boot so you need to wait for our update or try to compile recent u-boot version 2016.09-rc2 on yourself.
Is U-boot somewhere between 0 sector and first partition?
Can somebody give .bin of it and tell where it starts?
I will "BE PATIENT" for a week or so... :)
  On 9/5/2016 at 11:31 AM, Igor said:
Try this one:
http://mirror.igorpecovnik.com/test/u-boot-sunxi-with-spl.bin
dd if=u-boot-sunxi-with-spl.bin of=/dev/YOUR_SD_CARD bs=1024 seek=8 status=noxfer
sync
Yes, this is OK.
BUT only after "fresh" dd if=image
When I tried to do this things on the image which was already inserted in Orange PI with old u-boot, i.e. I was already tried to start it then it was not working.
Logs are in the attachment for your review in case of interest.
Thanks a lot for the help!
log1.txtFetching info...
log2.txtFetching info...
I would like to add a remark that my feeling is that hardware developers forgot to put somewhere a resistor which support ground or VCC and some pin is "in the air" because of it sometimes when system warm it can start normally... something like that... I am not sure.
