What do you mean "not working"? Kernel 5.10 from qxhome is a rockchip legacy kernel for rk3588 and qxhome modified it to support rk3568. It's not a rockchip official supported branch for rk356x.
I tried:
Armbian_22.05.1_Rock-3a_bullseye_edge_5.18.0.img.xz
Armbian_22.05.1_Rock-3a_jammy_edge_5.18.0_cinnamon_desktop.img.xz
Armbian_22.05.1_Rock-3a_jammy_edge_5.18.0_xfce_desktop.img.xz
"Not working" means that there are no signal from HDMI.
03.06.2022 в 03:06, Alexei Shcherbakov сказал:
Alexey, did you manage to receive video signal via HDMI on armbian images? I have the same problem.
Алексей, вам удалось получать видеосигнал по HDMI на образах armbian? У меня такая же проблема.
Could you share the dmesg? My img are working, both cli and desktop versions. Have you tried to reflash the img? If possible, share the systemctl status of you desktop manager
Tried:
Armbian_22.05.3_Rock-3a_jammy_edge_5.18.0_cinnamon_desktop.img
and
Armbian_22.08.0-trunk_Rock-3a_jammy_edge_5.18.11_gnome_desktop.img
Both start but do not see or recognize the SPI NOR memory. From  dmesg:
[    6.256659] spi-nor spi4.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    6.256695] spi-nor: probe of spi4.0 failed with error -2
Same issue, all images with 5.18 kernel doesn't output video to my 1366x768 TV. Only image with 4.19 kernel works, but when I try to enable desktop via armbian-config it downloads gnome and after long hours of install the system isn't usable at all.
